Вопрос по проекторам
VictorTom
Настоящее имя: Tom Victor
Сообщение VictorTom »
Front Flips Learn A New Trampoline Trick
Are you tired of watching friends playing basketball or karate in the front yard while you sit around completely bored and frustrated? Do you feel a little uncomfortable in your skin when playing sports, and wish you only an interesting physical activity that you already knew how to do? Well, if you can walk around and see not afraid of altitude, you should know that learning how to bounce and fly up on the trampoline can be just as active that you can excel. With just a few days of training, you will become a toaster in the neighborhood while others follow you proving this newly found talent. At TrampolineFlight you can find out the best trampolines.
Of course, before you can learn how to flip the trampoline forward, you will have to find a trampoline that fits the size of your suit and yard. If you are a kid, this is the time to put mom and dad through the computer to help you browse through some websites specializing in buying new and used trampolines. If you are a parent looking for a way to have fun for your bored son or daughter, then this is when you should take out a cushion and pen so you can make notes about the best trampoline accessories for safety and fun Looks.
Many parents are worried that they will end up with a lawsuit on their hands if they allow children to play on the Olympic-sized trampoline in their backyard. Although the truth is that trampolines are considered children's toys, they can be dangerous if they are not equipped with proper preventive instruments. Two important things to add if young children will use your structure is a trampoline and a trampoline. For more information about trampolines, check out our fanpage: https://www.facebook.com/Best-Trampoline-361835461191615/.
Once you've all set up with a trampoline accessory, it's time to start doing one of the simplest, first-flip trampoline tips. Like all trampoline tricks, you should start by practice as much tips as possible in a standing or slow state. For a front flip, you should start to try jumping, which simply means jumping at a moderate altitude, and kneeling out of the knee to the chest. Get acquainted with the feeling of sprouting, foot and then bringing them back in time to a landing down your feet. Once you're comfortable with the jump, you can also start practicing the kneading part from the deadlock.
Read more at: https://twitter.com/_BestTrampoline.
Последний раз редактировалось VictorTom 14 окт 2019, 17:39, всего редактировалось 1 раз.
Re: Вопрос по проекторам
У простого проектора четкость на столе будет не ахти, это все таки не лазер. На большой стол картинку не растянете, высоты потолка не хватит. Руками и головой будете затенять материал при раскрое. Идея, если честно, так себе...
Cvazist
Сообщение Cvazist »
Есть короткофокусные модели. Чёткость отличная, они для того и сделаны чтобы показывать качественную картинку. Цены разные, есть самосборные. В прокат можно взять для пробы.
все выше предложенное не вяжется с этим
VictorTom писал(а):Хотелось бы для пробы потратить минимум денег на проектор
а в свою очередь без лазера качества не получить...
...палка о двух концах...однако
Последний раз редактировалось xvovanx 25 авг 2019, 19:48, всего редактировалось 1 раз.
Cvazist
Сообщение Cvazist »
Минимум у всех разный
VictorTom писал(а):Кто может подсказать по проекторам.
Хочу сделать раскройную чпу чтоб раскладка деталей проецировалась проектором на материал на столе.
Хотелось бы для пробы потратить минимум денег на проектор(никогда дел с ними не имел)
В любом случае дешево не получится, т.к. готовые решения стоят дорого.
Если есть знания в программировании, электронике, то можно конечно сделать своё, например как-то делал прототип на недорогих китайских гальвосканерах:
https://www.youtube.com/watch?v=Fanln7UDFWo
будет дешевле, но времени на разработку уйдет не мало, если делать самостоятельно.
А если найти программистов, которые за тебя всё сделают, то получиться ещё дороже чем купить готовое решение.
