[    26.296]
X.Org X Server 1.16.4
Release Date: 2014-12-20
[    26.296] X Protocol Version 11, Revision 0
[    26.296] Build Operating System: Linux 4.9.0-4-armmp-lpae armv7l Debian
[    26.296] Current Operating System: Linux orangepipc 4.14.40-rt30-sunxi #1 SMP PREEMPT RT Tue Oct 16 21:10:54 MSK 2018 armv7l
[    26.296] Kernel command line: root=UUID=03637f9f-9f4c-4e5d-a7f1-54f873a76fb7 rootwait rootfstype=ext4 console=tty1 console=ttyS0,115200 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 loglevel=1 ubootpart=9dc5b082-01 ubootsource=mmc usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u "drm_kms_helper.drm_fbdev_overalloc=300"  sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_fb_mem_reserve=16 cgroup_enable=memory swapaccount=1
[    26.296] Build Date: 16 October 2017  09:26:27AM
[    26.296] xorg-server 2:1.16.4-1+deb8u2 (
http://www.debian.org/support)
[    26.296] Current version of pixman: 0.32.6
[    26.296] 	Before reporting problems, check
http://wiki.x.org
	to make sure that you have the latest version.
[    26.296] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[    26.297] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Oct 17 01:40:51 2018
[    26.357] (==) Using config directory: "/etc/X11/xorg.conf.d"
[    26.357] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[    26.444] (==) No Layout section.  Using the first Screen section.
[    26.444] (**) |-->Screen "DefaultScreen" (0)
[    26.444] (**) |   |-->Monitor "<default monitor>"
[    26.445] (**) |   |-->Device "ARMSOC DRM driver"
[    26.445] (==) No monitor specified for screen "DefaultScreen".
	Using a default monitor configuration.
[    26.445] (**) Option "BlankTime" "0"
[    26.445] (**) Option "StandbyTime" "0"
[    26.445] (**) Option "SuspendTime" "0"
[    26.445] (**) Option "OffTime" "0"
[    26.445] (==) Automatically adding devices
[    26.445] (==) Automatically enabling devices
[    26.445] (==) Automatically adding GPU devices
[    26.541] (WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
[    26.541] 	Entry deleted from font path.
[    26.642] (==) FontPath set to:
	/usr/share/fonts/X11/misc,
	/usr/share/fonts/X11/100dpi/:unscaled,
	/usr/share/fonts/X11/75dpi/:unscaled,
	/usr/share/fonts/X11/Type1,
	/usr/share/fonts/X11/100dpi,
	/usr/share/fonts/X11/75dpi,
	built-ins
[    26.642] (==) ModulePath set to "/usr/lib/xorg/modules"
[    26.642] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[    26.642] (II) Loader magic: 0x647f20
[    26.642] (II) Module ABI versions:
[    26.642] 	X.Org ANSI C Emulation: 0.4
[    26.642] 	X.Org Video Driver: 18.0
[    26.642] 	X.Org XInput driver : 21.0
[    26.642] 	X.Org Server Extension : 8.0
[    26.644] (II) xfree86: Adding drm device (/dev/dri/card0)
[    26.650] (II) no primary bus or device found
[    26.650] 	falling back to /sys/devices/platform/display-engine/drm/card0
[    26.650] (II) LoadModule: "glx"
[    26.697] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[    27.518] (II) Module glx: vendor="X.Org Foundation"
[    27.518] 	compiled for 1.16.4, module version = 1.0.0
[    27.518] 	ABI class: X.Org Server Extension, version 8.0
[    27.518] (==) AIGLX enabled
[    27.518] (II) LoadModule: "armsoc"
[    27.544] (II) Loading /usr/lib/xorg/modules/drivers/armsoc_drv.so
[    27.707] (II) Module armsoc: vendor="X.Org Foundation"
[    27.707] 	compiled for 1.16.4, module version = 1.4.1
[    27.707] 	Module class: X.Org Video Driver
[    27.707] 	ABI class: X.Org Video Driver, version 18.0
[    27.707] (II) ARMSOC: Driver for ARM Mali compatible chipsets
[    27.707] (++) using VT number 7
[    27.733] (WW) Falling back to old probe method for armsoc
[    27.733] (II) No BusID or DriverName specified - opening /dev/dri/card0
[    27.733] (II) Got BusID display-engine
[    27.766] (II) Opened DRM
[    27.766] (II)    DeviceName is [/dev/dri/card0]
[    27.766] (II)    bus_id is [display-engine]
[    27.766] (II)    DriverName is [sun4i-drm]
[    27.766] (II)    version is [1.0.0]
[    27.766] (II) Screen:0,  CRTC:-1
[    27.782] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[    27.782] (II) ARMSOC(0): Creating default Display subsection in Screen section
	"DefaultScreen" for depth/fbbpp 24/32
[    27.782] (**) ARMSOC(0): Depth 24, (--) framebuffer bpp 32
[    27.782] (==) ARMSOC(0): RGB weight 888
[    27.782] (==) ARMSOC(0): Using gamma correction (1.0, 1.0, 1.0)
[    27.782] (==) ARMSOC(0): Default visual is TrueColor
[    27.782] (II) No BusID or DriverName specified - opening /dev/dri/card0
[    27.782] (II) Got BusID display-engine
[    27.816] (II) Opened DRM
[    27.816] (II)    DeviceName is [/dev/dri/card0]
[    27.816] (II)    bus_id is [display-engine]
[    27.816] (II)    DriverName is [sun4i-drm]
[    27.816] (II)    version is [1.0.0]
[    27.816] (II) ARMSOC(0): Chipset: Mali
[    27.816] (II) ARMSOC(0): Buffer Flipping is Enabled
[    27.816] (II) ARMSOC(0): umplock is Disabled
[    27.816] (II) ARMSOC(0): Setting the video modes ...
[    27.816] (II) ARMSOC(0): Adding all CRTCs
[    27.816] (II) ARMSOC(0): Got CRTC: 0 (id: 28)
[    27.923] (II) ARMSOC(0): Output HDMI-1 has no monitor section
[    28.038] (II) ARMSOC(0): EDID for output HDMI-1
[    28.038] (II) ARMSOC(0): Manufacturer: SAM  Model: 10d  Serial#: 1296707895
[    28.038] (II) ARMSOC(0): Year: 2004  Week: 50
[    28.038] (II) ARMSOC(0): EDID Version: 1.3
[    28.038] (II) ARMSOC(0): Digital Display Input
[    28.038] (II) ARMSOC(0): Max Image Size [cm]: horiz.: 34  vert.: 27
[    28.038] (II) ARMSOC(0): Gamma: 2.20
[    28.038] (II) ARMSOC(0): DPMS capabilities: Off
[    28.038] (II) ARMSOC(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[    28.038] (II) ARMSOC(0): First detailed timing is preferred mode
[    28.038] (II) ARMSOC(0): redX: 0.650 redY: 0.330   greenX: 0.330 greenY: 0.600
[    28.038] (II) ARMSOC(0): blueX: 0.150 blueY: 0.080   whiteX: 0.313 whiteY: 0.329
[    28.038] (II) ARMSOC(0): Supported established timings:
[    28.038] (II) ARMSOC(0): 720x400@70Hz
[    28.038] (II) ARMSOC(0): 640x480@60Hz
[    28.038] (II) ARMSOC(0): 640x480@67Hz
[    28.038] (II) ARMSOC(0): 640x480@72Hz
[    28.038] (II) ARMSOC(0): 640x480@75Hz
[    28.038] (II) ARMSOC(0): 800x600@56Hz
[    28.038] (II) ARMSOC(0): 800x600@60Hz
[    28.038] (II) ARMSOC(0): 800x600@72Hz
[    28.038] (II) ARMSOC(0): 800x600@75Hz
[    28.039] (II) ARMSOC(0): 832x624@75Hz
[    28.039] (II) ARMSOC(0): 1024x768@60Hz
[    28.039] (II) ARMSOC(0): 1024x768@70Hz
[    28.039] (II) ARMSOC(0): 1024x768@75Hz
[    28.039] (II) ARMSOC(0): 1280x1024@75Hz
[    28.039] (II) ARMSOC(0): 1152x864@75Hz
[    28.039] (II) ARMSOC(0): Manufacturer's mask: 0
[    28.039] (II) ARMSOC(0): Supported standard timings:
[    28.039] (II) ARMSOC(0): #0: hsize: 1280  vsize 1024  refresh: 60  vid: 32897
[    28.039] (II) ARMSOC(0): #1: hsize: 1152  vsize 864  refresh: 75  vid: 20337
[    28.039] (II) ARMSOC(0): Supported detailed timing:
[    28.039] (II) ARMSOC(0): clock: 108.0 MHz   Image Size:  338 x 270 mm
[    28.039] (II) ARMSOC(0): h_active: 1280  h_sync: 1328  h_sync_end 1440 h_blank_end 1688 h_border: 0
[    28.039] (II) ARMSOC(0): v_active: 1024  v_sync: 1025  v_sync_end 1028 v_blanking: 1066 v_border: 0
[    28.039] (II) ARMSOC(0): Ranges: V min: 56 V max: 75 Hz, H min: 30 H max: 81 kHz, PixClock max 145 MHz
[    28.039] (II) ARMSOC(0): Monitor name: SyncMaster
[    28.039] (II) ARMSOC(0): Serial No: HSGXC10515
[    28.039] (II) ARMSOC(0): EDID (in hex):
[    28.039] (II) ARMSOC(0): 	00ffffffffffff004c2d0d0137314a4d
[    28.039] (II) ARMSOC(0): 	320e010380221b782aaaa5a654549926
[    28.039] (II) ARMSOC(0): 	145054bfef808180714f010101010101
[    28.039] (II) ARMSOC(0): 	010101010101302a009851002a403070
[    28.039] (II) ARMSOC(0): 	1300520e1100001e000000fd00384b1e
[    28.039] (II) ARMSOC(0): 	510e000a202020202020000000fc0053
[    28.039] (II) ARMSOC(0): 	796e634d61737465720a2020000000ff
[    28.040] (II) ARMSOC(0): 	00485347584331303531350a20200007
[    28.040] (II) ARMSOC(0): EDID vendor "SAM", prod id 269
[    28.040] (II) ARMSOC(0): Using EDID range info for horizontal sync
[    28.040] (II) ARMSOC(0): Using EDID range info for vertical refresh
[    28.040] (II) ARMSOC(0): Printing DDC gathered Modelines:
[    28.040] (II) ARMSOC(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[    28.040] (II) ARMSOC(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    28.040] (II) ARMSOC(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    28.040] (II) ARMSOC(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    28.040] (II) ARMSOC(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    28.040] (II) ARMSOC(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    28.040] (II) ARMSOC(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    28.040] (II) ARMSOC(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    28.040] (II) ARMSOC(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    28.040] (II) ARMSOC(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    28.041] (II) ARMSOC(0): Printing probed modes for output HDMI-1
[    28.041] (II) ARMSOC(0): Modeline "1280x1024"x60.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[    28.041] (II) ARMSOC(0): Modeline "1280x1024"x75.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "1152x864"x75.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "1024x768"x75.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "1024x768"x70.1   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "1024x768"x60.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "832x624"x74.6   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "800x600"x72.2   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "800x600"x75.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "800x600"x60.3   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    28.041] (II) ARMSOC(0): Modeline "800x600"x56.2   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    28.042] (II) ARMSOC(0): Modeline "640x480"x75.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    28.042] (II) ARMSOC(0): Modeline "640x480"x72.8   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    28.042] (II) ARMSOC(0): Modeline "640x480"x66.7   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    28.042] (II) ARMSOC(0): Modeline "640x480"x59.9   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    28.042] (II) ARMSOC(0): Modeline "720x400"x70.1   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    28.042] (II) ARMSOC(0): Output HDMI-1 connected
[    28.042] (II) ARMSOC(0): Using exact sizes for initial modes
[    28.042] (II) ARMSOC(0): Output HDMI-1 using initial mode 1280x1024
[    28.042] (II) ARMSOC(0): Got KMS resources
[    28.042] (**) ARMSOC(0): Display dimensions: (340, 270) mm
[    28.042] (**) ARMSOC(0): DPI set to (95, 96)
[    28.042] (II) Loading sub module "dri2"
[    28.042] (II) LoadModule: "dri2"
[    28.042] (II) Module "dri2" already built-in
[    28.042] (II) Loading sub module "exa"
[    28.042] (II) LoadModule: "exa"
[    28.043] (II) Loading /usr/lib/xorg/modules/libexa.so
[    28.063] (II) Module exa: vendor="X.Org Foundation"
[    28.063] 	compiled for 1.16.4, module version = 2.6.0
[    28.063] 	ABI class: X.Org Video Driver, version 18.0
[    28.063] (II) Loading sub module "fb"
[    28.063] (II) LoadModule: "fb"
[    28.063] (II) Loading /usr/lib/xorg/modules/libfb.so
[    28.108] (II) Module fb: vendor="X.Org Foundation"
[    28.108] 	compiled for 1.16.4, module version = 1.0.0
[    28.109] 	ABI class: X.Org ANSI C Emulation, version 0.4
[    28.109] (--) Depth 24 pixmap format is 32 bpp
[    28.150] (II) ARMSOC(0): Soft EXA mode
[    28.151] (II) EXA(0): Driver allocated offscreen pixmaps
[    28.151] (II) EXA(0): Driver registered support for the following operations:
[    28.151] (II)         Solid
[    28.151] (II)         Copy
[    28.151] (II)         Composite (RENDER acceleration)
[    28.151] (II) ARMSOC(0): Setting swap chain size: 2
[    28.151] (II) ARMSOC(0): [DRI2] Setup complete
[    28.151] (II) ARMSOC(0): [DRI2]   DRI driver: armsoc
[    28.151] (==) ARMSOC(0): Backing store enabled
[    28.151] (==) ARMSOC(0): Silken mouse enabled
[    28.162] (II) ARMSOC(0): HW cursor init()
[    28.182] (II) ARMSOC(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[    28.183] (==) ARMSOC(0): DPMS enabled
[    28.183] (--) RandR disabled
[    28.212] (II) SELinux: Disabled on system
[    28.221] (EE) AIGLX error: dlopen of /usr/lib/arm-linux-gnueabihf/dri/armsoc_dri.so failed (/usr/lib/arm-linux-gnueabihf/dri/armsoc_dri.so: cannot open shared object file: No such file or directory)
[    28.221] (EE) AIGLX: reverting to software rendering
[    28.295] (EE) AIGLX error: dlopen of /usr/lib/arm-linux-gnueabihf/dri/swrast_dri.so failed (/usr/lib/arm-linux-gnueabihf/dri/swrast_dri.so: undefined symbol: _glapi_tls_Dispatch)
[    28.295] (EE) GLX: could not load software renderer
[    28.295] (II) GLX: no usable GL providers found for screen 0
[    28.295] (II) ARMSOC(0): Setting screen physical size to 338 x 270
[    28.893] (II) config/udev: Adding input device USB USB Keykoard (/dev/input/event0)
[    28.893] (**) USB USB Keykoard: Applying InputClass "evdev keyboard catchall"
[    28.893] (II) LoadModule: "evdev"
[    28.894] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[    28.943] (II) Module evdev: vendor="X.Org Foundation"
[    28.943] 	compiled for 1.16.0, module version = 2.9.0
[    28.943] 	Module class: X.Org XInput Driver
[    28.944] 	ABI class: X.Org XInput driver, version 21.0
[    28.944] (II) Using input driver 'evdev' for 'USB USB Keykoard'
[    28.944] (**) USB USB Keykoard: always reports core events
[    28.944] (**) evdev: USB USB Keykoard: Device: "/dev/input/event0"
[    28.944] (--) evdev: USB USB Keykoard: Vendor 0x1c4f Product 0x2
[    28.944] (--) evdev: USB USB Keykoard: Found keys
[    28.944] (II) evdev: USB USB Keykoard: Configuring as keyboard
[    28.944] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.0/0003:1C4F:0002.0001/input/input0/event0"
[    28.944] (II) XINPUT: Adding extended input device "USB USB Keykoard" (type: KEYBOARD, id 6)
[    28.944] (**) Option "xkb_rules" "evdev"
[    28.944] (**) Option "xkb_model" "pc105"
[    28.944] (**) Option "xkb_layout" "us"
[    28.948] (II) config/udev: Adding input device USB USB Keykoard (/dev/input/event1)
[    28.948] (**) USB USB Keykoard: Applying InputClass "evdev keyboard catchall"
[    28.948] (II) Using input driver 'evdev' for 'USB USB Keykoard'
[    28.948] (**) USB USB Keykoard: always reports core events
[    28.948] (**) evdev: USB USB Keykoard: Device: "/dev/input/event1"
[    28.948] (--) evdev: USB USB Keykoard: Vendor 0x1c4f Product 0x2
[    28.949] (--) evdev: USB USB Keykoard: Found 1 mouse buttons
[    28.949] (--) evdev: USB USB Keykoard: Found scroll wheel(s)
[    28.949] (--) evdev: USB USB Keykoard: Found relative axes
[    28.949] (II) evdev: USB USB Keykoard: Forcing relative x/y axes to exist.
[    28.949] (--) evdev: USB USB Keykoard: Found absolute axes
[    28.949] (II) evdev: USB USB Keykoard: Forcing absolute x/y axes to exist.
[    28.949] (--) evdev: USB USB Keykoard: Found keys
[    28.949] (II) evdev: USB USB Keykoard: Configuring as mouse
[    28.949] (II) evdev: USB USB Keykoard: Configuring as keyboard
[    28.949] (II) evdev: USB USB Keykoard: Adding scrollwheel support
[    28.949] (**) evdev: USB USB Keykoard: YAxisMapping: buttons 4 and 5
[    28.949] (**) evdev: USB USB Keykoard: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    28.949] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1b400.usb/usb6/6-1/6-1:1.1/0003:1C4F:0002.0002/input/input1/event1"
[    28.949] (II) XINPUT: Adding extended input device "USB USB Keykoard" (type: KEYBOARD, id 7)
[    28.949] (**) Option "xkb_rules" "evdev"
[    28.949] (**) Option "xkb_model" "pc105"
[    28.949] (**) Option "xkb_layout" "us"
[    28.950] (II) evdev: USB USB Keykoard: initialized for relative axes.
[    28.950] (WW) evdev: USB USB Keykoard: ignoring absolute axes.
[    28.951] (**) USB USB Keykoard: (accel) keeping acceleration scheme 1
[    28.951] (**) USB USB Keykoard: (accel) acceleration profile 0
[    28.951] (**) USB USB Keykoard: (accel) acceleration factor: 2.000
[    28.951] (**) USB USB Keykoard: (accel) acceleration threshold: 4
[    28.953] (II) config/udev: Adding input device PIXART USB OPTICAL MOUSE (/dev/input/event2)
[    28.953] (**) PIXART USB OPTICAL MOUSE: Applying InputClass "evdev pointer catchall"
[    28.953] (II) Using input driver 'evdev' for 'PIXART USB OPTICAL MOUSE'
[    28.953] (**) PIXART USB OPTICAL MOUSE: always reports core events
[    28.953] (**) evdev: PIXART USB OPTICAL MOUSE: Device: "/dev/input/event2"
[    28.954] (--) evdev: PIXART USB OPTICAL MOUSE: Vendor 0x93a Product 0x2510
[    28.954] (--) evdev: PIXART USB OPTICAL MOUSE: Found 3 mouse buttons
[    28.954] (--) evdev: PIXART USB OPTICAL MOUSE: Found scroll wheel(s)
[    28.954] (--) evdev: PIXART USB OPTICAL MOUSE: Found relative axes
[    28.954] (--) evdev: PIXART USB OPTICAL MOUSE: Found x and y relative axes
[    28.954] (II) evdev: PIXART USB OPTICAL MOUSE: Configuring as mouse
[    28.954] (II) evdev: PIXART USB OPTICAL MOUSE: Adding scrollwheel support
[    28.954] (**) evdev: PIXART USB OPTICAL MOUSE: YAxisMapping: buttons 4 and 5
[    28.954] (**) evdev: PIXART USB OPTICAL MOUSE: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[    28.954] (**) Option "config_info" "udev:/sys/devices/platform/soc/1c1d400.usb/usb8/8-1/8-1:1.0/0003:093A:2510.0003/input/input2/event2"
[    28.954] (II) XINPUT: Adding extended input device "PIXART USB OPTICAL MOUSE" (type: MOUSE, id 8)
[    28.954] (II) evdev: PIXART USB OPTICAL MOUSE: initialized for relative axes.
[    28.954] (**) PIXART USB OPTICAL MOUSE: (accel) keeping acceleration scheme 1
[    28.955] (**) PIXART USB OPTICAL MOUSE: (accel) acceleration profile 0
[    28.955] (**) PIXART USB OPTICAL MOUSE: (accel) acceleration factor: 2.000
[    28.955] (**) PIXART USB OPTICAL MOUSE: (accel) acceleration threshold: 4
[    28.957] (II) config/udev: Adding input device PIXART USB OPTICAL MOUSE (/dev/input/mouse0)
[    28.957] (II) No input driver specified, ignoring this device.
[    28.957] (II) This device may have been added with another device file.
[    28.959] (II) config/udev: Adding input device RC for dw_hdmi (/dev/input/event4)
[    28.959] (**) RC for dw_hdmi: Applying InputClass "evdev keyboard catchall"
[    28.959] (II) Using input driver 'evdev' for 'RC for dw_hdmi'
[    28.959] (**) RC for dw_hdmi: always reports core events
[    28.959] (**) evdev: RC for dw_hdmi: Device: "/dev/input/event4"
[    28.959] (--) evdev: RC for dw_hdmi: Vendor 0 Product 0
[    28.959] (--) evdev: RC for dw_hdmi: Found keys
[    28.959] (II) evdev: RC for dw_hdmi: Configuring as keyboard
[    28.959] (**) Option "config_info" "udev:/sys/devices/platform/soc/1ee0000.hdmi/rc/rc1/input4/event4"
[    28.959] (II) XINPUT: Adding extended input device "RC for dw_hdmi" (type: KEYBOARD, id 9)
[    28.959] (**) Option "xkb_rules" "evdev"
[    28.959] (**) Option "xkb_model" "pc105"
[    28.959] (**) Option "xkb_layout" "us"
[    28.962] (II) config/udev: Adding input device sunxi-ir (/dev/input/event3)
[    28.962] (**) sunxi-ir: Applying InputClass "evdev keyboard catchall"
[    28.962] (II) Using input driver 'evdev' for 'sunxi-ir'
[    28.962] (**) sunxi-ir: always reports core events
[    28.962] (**) evdev: sunxi-ir: Device: "/dev/input/event3"
[    28.962] (--) evdev: sunxi-ir: Vendor 0x1 Product 0x1
[    28.962] (--) evdev: sunxi-ir: Found keys
[    28.962] (II) evdev: sunxi-ir: Configuring as keyboard
[    28.962] (**) Option "config_info" "udev:/sys/devices/platform/soc/1f02000.ir/rc/rc0/input3/event3"
[    28.963] (II) XINPUT: Adding extended input device "sunxi-ir" (type: KEYBOARD, id 10)
[    28.963] (**) Option "xkb_rules" "evdev"
[    28.963] (**) Option "xkb_model" "pc105"
[    28.963] (**) Option "xkb_layout" "us"
[    36.510] (II) ARMSOC(0): EDID vendor "SAM", prod id 269
[    36.510] (II) ARMSOC(0): Using hsync ranges from config file
[    36.510] (II) ARMSOC(0): Using vrefresh ranges from config file
[    36.510] (II) ARMSOC(0): Printing DDC gathered Modelines:
[    36.510] (II) ARMSOC(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[    36.510] (II) ARMSOC(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    36.510] (II) ARMSOC(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    36.510] (II) ARMSOC(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    36.510] (II) ARMSOC(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    36.510] (II) ARMSOC(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    36.510] (II) ARMSOC(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    36.510] (II) ARMSOC(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    36.510] (II) ARMSOC(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    36.510] (II) ARMSOC(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    36.510] (II) ARMSOC(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    36.510] (II) ARMSOC(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "832x624"x0.0   57.28  832 864 928 1152  624 625 628 667 -hsync -vsync (49.7 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "800x600"x0.0   49.50  800 816 896 1056  600 601 604 625 +hsync +vsync (46.9 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "800x600"x0.0   50.00  800 856 976 1040  600 637 643 666 +hsync +vsync (48.1 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "1152x864"x0.0  108.00  1152 1216 1344 1600  864 865 868 900 +hsync +vsync (67.5 kHz e)
[    36.511] (II) ARMSOC(0): EDID vendor "SAM", prod id 269
[    36.511] (II) ARMSOC(0): Using hsync ranges from config file
[    36.511] (II) ARMSOC(0): Using vrefresh ranges from config file
[    36.511] (II) ARMSOC(0): Printing DDC gathered Modelines:
[    36.511] (II) ARMSOC(0): Modeline "1280x1024"x0.0  108.00  1280 1328 1440 1688  1024 1025 1028 1066 +hsync +vsync (64.0 kHz eP)
[    36.511] (II) ARMSOC(0): Modeline "800x600"x0.0   40.00  800 840 968 1056  600 601 605 628 +hsync +vsync (37.9 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "800x600"x0.0   36.00  800 824 896 1024  600 601 603 625 +hsync +vsync (35.2 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "640x480"x0.0   31.50  640 656 720 840  480 481 484 500 -hsync -vsync (37.5 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "640x480"x0.0   31.50  640 664 704 832  480 489 492 520 -hsync -vsync (37.9 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "640x480"x0.0   30.24  640 704 768 864  480 483 486 525 -hsync -vsync (35.0 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "640x480"x0.0   25.18  640 656 752 800  480 490 492 525 -hsync -vsync (31.5 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "720x400"x0.0   28.32  720 738 846 900  400 412 414 449 -hsync +vsync (31.5 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "1280x1024"x0.0  135.00  1280 1296 1440 1688  1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "1024x768"x0.0   78.75  1024 1040 1136 1312  768 769 772 800 +hsync +vsync (60.0 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "1024x768"x0.0   75.00  1024 1048 1184 1328  768 771 777 806 -hsync -vsync (56.5 kHz e)
[    36.511] (II) ARMSOC(0): Modeline "1024x768"x0.0   65.00  1024 1048 1184 1344  768 771 777 806 -hsync -vsync (48.4 kHz e)
