Аналогичная шляпа. Установка по методичке на сайте. Система чистая Ubuntu 12.04. Вот что пишет:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/cnc/linuxcnc/configs/sim.gmoccapy'
Machine configuration file is 'gmoccapy_4_axis.ini'
INIFILE=/home/cnc/linuxcnc/configs/sim.gmoccapy/gmoccapy_4_axis.ini
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Found file(REL): ./core_sim4.hal
Found file(REL): ./spindle_sim.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Starting TASK program: milltask
Starting DISPLAY program: gmoccapy
**** GMOCCAPY GETINIINFO ****
Preference file path: /home/cnc/linuxcnc/configs/sim.gmoccapy/gmoccapy_4_axis.pref
No option 'dro_size' in section: 'DEFAULT'
No option 'hide_axis_4' in section: 'DEFAULT'
No DEFAULT_SPINDLE_SPEED entry found in [DISPLAY] of INI file
No option 'spindle_start_rpm' in section: 'DEFAULT'
No option 'hide_turtle_jog_button' in section: 'DEFAULT'
No option 'turtle_jog_factor' in section: 'DEFAULT'
No option 'scale_max_vel' in section: 'DEFAULT'
No option 'scale_jog_vel' in section: 'DEFAULT'
No option 'scale_spindle_override' in section: 'DEFAULT'
No option 'scale_feed_override' in section: 'DEFAULT'
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=2951
Killing task milltask, PID=3028
task: 8961 cycles, min=0.000004, max=0.009147, avg=0.001098, 0 latency excursions (> 10x expected cycle time of 0.001000s)
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
/usr/bin/gmoccapy:237: GtkWarning: Invalid icon size 48
self.widgets.window1.show()
Gen6+ requires Kernel 3.6 or later.
python: ../../../../src/mesa/main/context.c:1549: _mesa_make_current: Проверочное утверждение «newCtx->Version > 0» не выполнено.
/usr/bin/linuxcnc: строка 857: 3031 Аварийный останов (подготовлен дамп ядра) $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
2951
PID TTY STAT TIME COMMAND
3028
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009ec00 (usable)
[ 0.000000] BIOS-e820: 000000000009ec00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000020000000 (usable)
[ 0.000000] BIOS-e820: 0000000020000000 - 0000000020200000 (reserved)
[ 0.000000] BIOS-e820: 0000000020200000 - 0000000040004000 (usable)
[ 0.000000] BIOS-e820: 0000000040004000 - 0000000040005000 (reserved)
[ 0.000000] BIOS-e820: 0000000040005000 - 00000000d987b000 (usable)
[ 0.000000] BIOS-e820: 00000000d987b000 - 00000000d9d27000 (reserved)
[ 0.000000] BIOS-e820: 00000000d9d27000 - 00000000d9d28000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000d9d28000 - 00000000d9e4c000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000d9e4c000 - 00000000da605000 (reserved)
[ 0.000000] BIOS-e820: 00000000da605000 - 00000000da606000 (usable)
[ 0.000000] BIOS-e820: 00000000da606000 - 00000000da649000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000da649000 - 00000000dadb1000 (usable)
[ 0.000000] BIOS-e820: 00000000dadb1000 - 00000000dafdd000 (reserved)
[ 0.000000] BIOS-e820: 00000000dafdd000 - 00000000db000000 (usable)
[ 0.000000] BIOS-e820: 00000000db800000 - 00000000dfa00000 (reserved)
[ 0.000000] BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 000000021e600000 (usable)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.7 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. To be filled by O.E.M./B75M-D3V, BIOS F9 08/23/2012
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0xdb000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CFFFF write-protect
[ 0.000000] D0000-E7FFF uncachable
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask E00000000 write-back
[ 0.000000] 1 base 200000000 mask FE0000000 write-back
[ 0.000000] 2 base 0E0000000 mask FE0000000 uncachable
[ 0.000000] 3 base 0DC000000 mask FFC000000 uncachable
[ 0.000000] 4 base 0DB800000 mask FFF800000 uncachable
[ 0.000000] 5 base 21F000000 mask FFF000000 uncachable
[ 0.000000] 6 base 21E800000 mask FFF800000 uncachable
[ 0.000000] 7 base 21E600000 mask FFFE00000 uncachable
[ 0.000000] 8 disabled
[ 0.000000] 9 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 00000000db800000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] found SMP MP-table at [c00fd710] fd710
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009a000] 9a000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 363f0000 - 371f0000
[ 0.000000] ACPI: RSDP 000f0490 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT d9e2e070 0005C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP d9e37638 000F4 (v04 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT d9e2e160 094D8 (v02 ALASKA A M I 00000012 INTL 20051117)
[ 0.000000] ACPI: FACS d9e4af80 00040
[ 0.000000] ACPI: APIC d9e37730 00072 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG d9e377a8 0003C (v01 01072009 MSFT 00000097)
[ 0.000000] ACPI: HPET d9e377e8 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT d9e37820 00495 (v01 IdeRef IdeTable 00001000 INTL 20091112)
[ 0.000000] ACPI: SSDT d9e37cb8 009AA (v01 PmRef Cpu0Ist 00003000 INTL 20051117)
[ 0.000000] ACPI: SSDT d9e38668 00A92 (v01 PmRef CpuPm 00003000 INTL 20051117)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 2616MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x000db000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x00020000
[ 0.000000] 0: 0x00020200 -> 0x00040004
[ 0.000000] 0: 0x00040005 -> 0x000d987b
[ 0.000000] 0: 0x000da605 -> 0x000da606
[ 0.000000] 0: 0x000da649 -> 0x000dadb1
[ 0.000000] 0: 0x000dafdd -> 0x000db000
[ 0.000000] On node 0 totalpages: 892308
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4890200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3950 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 220974 pages, LIFO batch:31
[ 0.000000] HighMem zone: 5233 pages used for memmap
[ 0.000000] HighMem zone: 660375 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020200000
[ 0.000000] Allocating PCI resources starting at dfa00000 (gap: dfa00000:18600000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 885299
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=e62b049a-ed21-4203-a544-e7dfcff35e64 ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[ 0.000000] allocated 7176064 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:000db000)
[ 0.000000] Memory: 3512844k/3588096k available (3496k kernel code, 56388k reserved, 1237k data, 416k init, 2662432k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc136a04a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc136a04a (3496 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:712 16
[ 0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.004000] Detected 3292.752 MHz processor.
[ 0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 6585.50 BogoMIPS (lpj=13171008)
[ 0.000003] pid_max: default: 32768 minimum: 301
[ 0.000027] Security Framework initialized
[ 0.000031] AppArmor: AppArmor disabled by boot time parameter
[ 0.000040] Mount-cache hash table entries: 512
[ 0.000150] Initializing cgroup subsys cpuacct
[ 0.000152] Initializing cgroup subsys memory
[ 0.000156] Initializing cgroup subsys devices
[ 0.000157] Initializing cgroup subsys freezer
[ 0.000158] Initializing cgroup subsys net_cls
[ 0.000159] Initializing cgroup subsys blkio
[ 0.000163] Initializing cgroup subsys perf_event
[ 0.000180] CPU: Physical Processor ID: 0
[ 0.000181] CPU: Processor Core ID: 0
[ 0.000184] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000185] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.000187] mce: CPU supports 7 MCE banks
[ 0.000195] CPU0: Thermal monitoring enabled (TM1)
[ 0.000261] ACPI: Core revision 20120320
[ 0.006748] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.007130] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.046689] CPU0: Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz stepping 09
[ 0.152519] Performance Events: PEBS fmt1+, generic architected perfmon, Intel PMU driver.
[ 0.152524] ... version: 3
[ 0.152525] ... bit width: 48
[ 0.152526] ... generic registers: 4
[ 0.152527] ... value mask: 0000ffffffffffff
[ 0.152528] ... max period: 000000007fffffff
[ 0.152529] ... fixed-purpose events: 3
[ 0.152531] ... event mask: 000000070000000f
[ 0.164532] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.176459] CPU 1 irqstacks, hard=f3cf6000 soft=f3cf8000
[ 0.176462] Booting Node 0, Processors #1
[ 0.186621] Initializing CPU#1
[ 0.189567] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.196396] CPU 2 irqstacks, hard=f3d08000 soft=f3d0a000
[ 0.196399] #2
[ 0.206566] Initializing CPU#2
[ 0.209504] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.216332] CPU 3 irqstacks, hard=f3d1c000 soft=f3d1e000
[ 0.216335] #3 Ok.
[ 0.226492] Initializing CPU#3
[ 0.229438] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.229461] Brought up 4 CPUs
[ 0.229462] Total of 4 processors activated (26342.01 BogoMIPS).
[ 0.231592] devtmpfs: initialized
[ 0.231735] PM: Registering ACPI NVS region [mem 0xd9d28000-0xd9e4bfff] (1196032 bytes)
[ 0.231758] PM: Registering ACPI NVS region [mem 0xda606000-0xda648fff] (274432 bytes)
[ 0.231828] dummy:
[ 0.231865] NET: Registered protocol family 16
[ 0.231935] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[ 0.231937] ACPI: bus type pci registered
[ 0.231970] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[ 0.231973] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[ 0.231974] PCI: Using MMCONFIG for extended config space
[ 0.231975] PCI: Using configuration type 1 for base access
[ 0.232376] bio: create slab <bio-0> at 0
[ 0.232440] ACPI: Added _OSI(Module Device)
[ 0.232442] ACPI: Added _OSI(Processor Device)
[ 0.232444] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.232445] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.233928] ACPI: EC: Look up EC in DSDT
[ 0.235708] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.238805] ACPI: SSDT d9ccf018 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.239195] ACPI: Dynamic OEM Table Load:
[ 0.239197] ACPI: SSDT (null) 0083B (v01 PmRef Cpu0Cst 00003001 INTL 20051117)
[ 0.239420] ACPI: SSDT d9cd0a98 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.239840] ACPI: Dynamic OEM Table Load:
[ 0.239842] ACPI: SSDT (null) 00303 (v01 PmRef ApIst 00003000 INTL 20051117)
[ 0.239932] ACPI: SSDT d9cced98 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.240315] ACPI: Dynamic OEM Table Load:
[ 0.240317] ACPI: SSDT (null) 00119 (v01 PmRef ApCst 00003000 INTL 20051117)
[ 0.240973] ACPI: Interpreter enabled
[ 0.240984] ACPI: (supports S0 S3 S4 S5)
[ 0.241002] ACPI: Using IOAPIC for interrupt routing
[ 0.246423] ACPI: Power Resource [FN00] (off)
[ 0.246483] ACPI: Power Resource [FN01] (off)
[ 0.246541] ACPI: Power Resource [FN02] (off)
[ 0.246600] ACPI: Power Resource [FN03] (off)
[ 0.246657] ACPI: Power Resource [FN04] (off)
[ 0.247049] ACPI: No dock devices found.
[ 0.247054] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.247326] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[ 0.247706] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.247708] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.247710] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.247711] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000d3fff]
[ 0.247713] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[ 0.247714] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[ 0.247716] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[ 0.247717] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[ 0.247719] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[ 0.247720] pci_root PNP0A08:00: host bridge window [mem 0xdfa00000-0xfeafffff]
[ 0.247740] PCI host bridge to bus 0000:00
[ 0.247742] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7]
[ 0.247744] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.247745] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.247747] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
[ 0.247748] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[ 0.247750] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[ 0.247751] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[ 0.247753] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[ 0.247754] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[ 0.247756] pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff]
[ 0.247763] pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
[ 0.247790] pci 0000:00:02.0: [8086:0152] type 00 class 0x030000
[ 0.247800] pci 0000:00:02.0: reg 10: [mem 0xf7800000-0xf7bfffff 64bit]
[ 0.247805] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[ 0.247810] pci 0000:00:02.0: reg 20: [io 0xf000-0xf03f]
[ 0.247852] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
[ 0.247872] pci 0000:00:14.0: reg 10: [mem 0xf7c00000-0xf7c0ffff 64bit]
[ 0.247926] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.247946] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
[ 0.247968] pci 0000:00:16.0: reg 10: [mem 0xf7c19000-0xf7c1900f 64bit]
[ 0.248026] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[ 0.248056] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
[ 0.248076] pci 0000:00:1a.0: reg 10: [mem 0xf7c17000-0xf7c173ff]
[ 0.248144] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[ 0.248167] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
[ 0.248181] pci 0000:00:1b.0: reg 10: [mem 0xf7c10000-0xf7c13fff 64bit]
[ 0.248235] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.248256] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
[ 0.248314] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.248339] pci 0000:00:1c.4: [8086:1e18] type 01 class 0x060400
[ 0.248398] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[ 0.248426] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[ 0.248446] pci 0000:00:1d.0: reg 10: [mem 0xf7c16000-0xf7c163ff]
[ 0.248514] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.248532] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.248583] pci 0000:00:1f.0: [8086:1e49] type 00 class 0x060100
[ 0.248686] pci 0000:00:1f.2: [8086:1e00] type 00 class 0x01018f
[ 0.248699] pci 0000:00:1f.2: reg 10: [io 0xf110-0xf117]
[ 0.248706] pci 0000:00:1f.2: reg 14: [io 0xf100-0xf103]
[ 0.248713] pci 0000:00:1f.2: reg 18: [io 0xf0f0-0xf0f7]
[ 0.248720] pci 0000:00:1f.2: reg 1c: [io 0xf0e0-0xf0e3]
[ 0.248727] pci 0000:00:1f.2: reg 20: [io 0xf0d0-0xf0df]
[ 0.248734] pci 0000:00:1f.2: reg 24: [io 0xf0c0-0xf0cf]
[ 0.248765] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
[ 0.248779] pci 0000:00:1f.3: reg 10: [mem 0xf7c15000-0xf7c150ff 64bit]
[ 0.248798] pci 0000:00:1f.3: reg 20: [io 0xf040-0xf05f]
[ 0.248826] pci 0000:00:1f.5: [8086:1e08] type 00 class 0x010185
[ 0.248839] pci 0000:00:1f.5: reg 10: [io 0xf0b0-0xf0b7]
[ 0.248846] pci 0000:00:1f.5: reg 14: [io 0xf0a0-0xf0a3]
[ 0.248853] pci 0000:00:1f.5: reg 18: [io 0xf090-0xf097]
[ 0.248860] pci 0000:00:1f.5: reg 1c: [io 0xf080-0xf083]
[ 0.248867] pci 0000:00:1f.5: reg 20: [io 0xf070-0xf07f]
[ 0.248873] pci 0000:00:1f.5: reg 24: [io 0xf060-0xf06f]
[ 0.248941] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.249011] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[ 0.249030] pci 0000:02:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.249063] pci 0000:02:00.0: reg 18: [mem 0xf0004000-0xf0004fff 64bit pref]
[ 0.249084] pci 0000:02:00.0: reg 20: [mem 0xf0000000-0xf0003fff 64bit pref]
[ 0.249141] pci 0000:02:00.0: supports D1 D2
[ 0.249143] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.256199] pci 0000:00:1c.4: PCI bridge to [bus 02-02]
[ 0.256205] pci 0000:00:1c.4: bridge window [io 0xe000-0xefff]
[ 0.256215] pci 0000:00:1c.4: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.256295] pci 0000:00:1e.0: PCI bridge to [bus 03-03] (subtractive decode)
[ 0.256303] pci 0000:00:1e.0: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.256305] pci 0000:00:1e.0: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.256307] pci 0000:00:1e.0: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.256308] pci 0000:00:1e.0: bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[ 0.256310] pci 0000:00:1e.0: bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[ 0.256312] pci 0000:00:1e.0: bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[ 0.256313] pci 0000:00:1e.0: bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[ 0.256315] pci 0000:00:1e.0: bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[ 0.256316] pci 0000:00:1e.0: bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[ 0.256318] pci 0000:00:1e.0: bridge window [mem 0xdfa00000-0xfeafffff] (subtractive decode)
[ 0.256332] pci_bus 0000:00: on NUMA node 0
[ 0.256334] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.256514] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.256557] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.256597] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05._PRT]
[ 0.256724] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.260887] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.260927] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.260966] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.261003] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.261041] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.261079] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.261117] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 10 11 12 14 15)
[ 0.261155] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.261205] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.261210] vgaarb: loaded
[ 0.261211] vgaarb: bridge control possible 0000:00:02.0
[ 0.261226] PCI: Using ACPI for IRQ routing
[ 0.262688] PCI: pci_cache_line_size set to 64 bytes
[ 0.262732] reserve RAM buffer: 000000000009ec00 - 000000000009ffff
[ 0.262734] reserve RAM buffer: 0000000040004000 - 0000000043ffffff
[ 0.262735] reserve RAM buffer: 00000000d987b000 - 00000000dbffffff
[ 0.262737] reserve RAM buffer: 00000000da606000 - 00000000dbffffff
[ 0.262739] reserve RAM buffer: 00000000dadb1000 - 00000000dbffffff
[ 0.262741] reserve RAM buffer: 00000000db000000 - 00000000dbffffff
[ 0.262817] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[ 0.262823] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[ 0.264831] Switching to clocksource hpet
[ 0.264869] pnp: PnP ACPI init
[ 0.264875] ACPI: bus type pnp registered
[ 0.265084] pnp 00:00: [bus 00-3e]
[ 0.265086] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.265088] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.265089] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.265091] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.265092] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[ 0.265093] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[ 0.265095] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[ 0.265096] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[ 0.265098] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[ 0.265099] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[ 0.265100] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[ 0.265102] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[ 0.265103] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[ 0.265105] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[ 0.265106] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[ 0.265107] pnp 00:00: [mem 0x000ec000-0x000effff window]
[ 0.265109] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[ 0.265110] pnp 00:00: [mem 0xdfa00000-0xfeafffff window]
[ 0.265112] pnp 00:00: [mem 0x00010000-0x0001ffff window]
[ 0.265147] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.265164] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[ 0.265186] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[ 0.265188] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.265195] pnp 00:02: [io 0x0000-0x001f]
[ 0.265197] pnp 00:02: [io 0x0081-0x0091]
[ 0.265198] pnp 00:02: [io 0x0093-0x009f]
[ 0.265199] pnp 00:02: [io 0x00c0-0x00df]
[ 0.265201] pnp 00:02: [dma 4]
[ 0.265213] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.265218] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.265231] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.265280] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[ 0.265294] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.265304] pnp 00:05: [io 0x002e-0x002f]
[ 0.265306] pnp 00:05: [io 0x004e-0x004f]
[ 0.265308] pnp 00:05: [io 0x0061]
[ 0.265309] pnp 00:05: [io 0x0063]
[ 0.265311] pnp 00:05: [io 0x0065]
[ 0.265313] pnp 00:05: [io 0x0067]
[ 0.265315] pnp 00:05: [io 0x0070]
[ 0.265316] pnp 00:05: [io 0x0080]
[ 0.265318] pnp 00:05: [io 0x0092]
[ 0.265319] pnp 00:05: [io 0x00b2-0x00b3]
[ 0.265320] pnp 00:05: [io 0x0680-0x069f]
[ 0.265321] pnp 00:05: [io 0x0200-0x020f]
[ 0.265323] pnp 00:05: [io 0xffff]
[ 0.265324] pnp 00:05: [io 0xffff]
[ 0.265325] pnp 00:05: [io 0x0400-0x0453]
[ 0.265326] pnp 00:05: [io 0x0458-0x047f]
[ 0.265327] pnp 00:05: [io 0x0500-0x057f]
[ 0.265352] system 00:05: [io 0x0680-0x069f] has been reserved
[ 0.265354] system 00:05: [io 0x0200-0x020f] has been reserved
[ 0.265356] system 00:05: [io 0xffff] has been reserved
[ 0.265357] system 00:05: [io 0xffff] has been reserved
[ 0.265359] system 00:05: [io 0x0400-0x0453] has been reserved
[ 0.265361] system 00:05: [io 0x0458-0x047f] has been reserved
[ 0.265362] system 00:05: [io 0x0500-0x057f] has been reserved
[ 0.265364] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.265370] pnp 00:06: [io 0x0070-0x0077]
[ 0.265375] pnp 00:06: [irq 8]
[ 0.265389] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.265408] pnp 00:07: [io 0x0454-0x0457]
[ 0.265429] system 00:07: [io 0x0454-0x0457] has been reserved
[ 0.265431] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[ 0.265511] pnp 00:08: [io 0x0000-0xffffffff disabled]
[ 0.265512] pnp 00:08: [io 0x0a00-0x0a0f]
[ 0.265514] pnp 00:08: [io 0x0a30-0x0a3f]
[ 0.265515] pnp 00:08: [io 0x0a20-0x0a2f]
[ 0.265537] system 00:08: [io 0x0a00-0x0a0f] has been reserved
[ 0.265539] system 00:08: [io 0x0a30-0x0a3f] has been reserved
[ 0.265540] system 00:08: [io 0x0a20-0x0a2f] has been reserved
[ 0.265542] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.265776] pnp 00:09: [io 0x03f8-0x03ff]
[ 0.265780] pnp 00:09: [irq 4]
[ 0.265781] pnp 00:09: [dma 0 disabled]
[ 0.265817] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.266102] pnp 00:0a: [io 0x0378-0x037f]
[ 0.266106] pnp 00:0a: [irq 7]
[ 0.266107] pnp 00:0a: [dma 0 disabled]
[ 0.266214] pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.266230] pnp 00:0b: [io 0x0010-0x001f]
[ 0.266231] pnp 00:0b: [io 0x0022-0x003f]
[ 0.266232] pnp 00:0b: [io 0x0044-0x005f]
[ 0.266233] pnp 00:0b: [io 0x0062-0x0063]
[ 0.266235] pnp 00:0b: [io 0x0065-0x006f]
[ 0.266236] pnp 00:0b: [io 0x0072-0x007f]
[ 0.266237] pnp 00:0b: [io 0x0080]
[ 0.266238] pnp 00:0b: [io 0x0084-0x0086]
[ 0.266239] pnp 00:0b: [io 0x0088]
[ 0.266241] pnp 00:0b: [io 0x008c-0x008e]
[ 0.266242] pnp 00:0b: [io 0x0090-0x009f]
[ 0.266243] pnp 00:0b: [io 0x00a2-0x00bf]
[ 0.266244] pnp 00:0b: [io 0x00e0-0x00ef]
[ 0.266245] pnp 00:0b: [io 0x04d0-0x04d1]
[ 0.266270] system 00:0b: [io 0x04d0-0x04d1] has been reserved
[ 0.266272] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.266278] pnp 00:0c: [io 0x00f0-0x00ff]
[ 0.266282] pnp 00:0c: [irq 13]
[ 0.266297] pnp 00:0c: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.266480] pnp 00:0d: [mem 0xfed1c000-0xfed1ffff]
[ 0.266481] pnp 00:0d: [mem 0xfed10000-0xfed17fff]
[ 0.266483] pnp 00:0d: [mem 0xfed18000-0xfed18fff]
[ 0.266484] pnp 00:0d: [mem 0xfed19000-0xfed19fff]
[ 0.266485] pnp 00:0d: [mem 0xf8000000-0xfbffffff]
[ 0.266487] pnp 00:0d: [mem 0xfed20000-0xfed3ffff]
[ 0.266488] pnp 00:0d: [mem 0xfed90000-0xfed93fff]
[ 0.266489] pnp 00:0d: [mem 0xfed45000-0xfed8ffff]
[ 0.266491] pnp 00:0d: [mem 0xff000000-0xffffffff]
[ 0.266492] pnp 00:0d: [mem 0xfee00000-0xfeefffff]
[ 0.266493] pnp 00:0d: [mem 0xdfa00000-0xdfa00fff]
[ 0.266531] system 00:0d: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.266533] system 00:0d: [mem 0xfed10000-0xfed17fff] has been reserved
[ 0.266535] system 00:0d: [mem 0xfed18000-0xfed18fff] has been reserved
[ 0.266536] system 00:0d: [mem 0xfed19000-0xfed19fff] has been reserved
[ 0.266538] system 00:0d: [mem 0xf8000000-0xfbffffff] has been reserved
[ 0.266540] system 00:0d: [mem 0xfed20000-0xfed3ffff] has been reserved
[ 0.266542] system 00:0d: [mem 0xfed90000-0xfed93fff] has been reserved
[ 0.266543] system 00:0d: [mem 0xfed45000-0xfed8ffff] has been reserved
[ 0.266545] system 00:0d: [mem 0xff000000-0xffffffff] has been reserved
[ 0.266547] system 00:0d: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.266549] system 00:0d: [mem 0xdfa00000-0xdfa00fff] has been reserved
[ 0.266551] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.266661] pnp 00:0e: [mem 0x20000000-0x201fffff]
[ 0.266662] pnp 00:0e: [mem 0x40004000-0x40004fff]
[ 0.266700] system 00:0e: [mem 0x20000000-0x201fffff] has been reserved
[ 0.266702] system 00:0e: [mem 0x40004000-0x40004fff] has been reserved
[ 0.266704] system 00:0e: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.266720] pnp: PnP ACPI: found 15 devices
[ 0.266721] ACPI: ACPI bus type pnp unregistered
[ 0.266723] PnPBIOS: Disabled by ACPI PNP
[ 0.302444] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.302455] pci 0000:00:1c.4: PCI bridge to [bus 02-02]
[ 0.302458] pci 0000:00:1c.4: bridge window [io 0xe000-0xefff]
[ 0.302464] pci 0000:00:1c.4: bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.302470] pci 0000:00:1e.0: PCI bridge to [bus 03-03]
[ 0.302498] pci 0000:00:1e.0: setting latency timer to 64
[ 0.302501] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.302502] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.302504] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.302505] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.302507] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.302508] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.302510] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.302511] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.302513] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.302514] pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff]
[ 0.302516] pci_bus 0000:02: resource 0 [io 0xe000-0xefff]
[ 0.302517] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[ 0.302519] pci_bus 0000:03: resource 4 [io 0x0000-0x0cf7]
[ 0.302520] pci_bus 0000:03: resource 5 [io 0x0d00-0xffff]
[ 0.302522] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.302523] pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000d3fff]
[ 0.302525] pci_bus 0000:03: resource 8 [mem 0x000d4000-0x000d7fff]
[ 0.302526] pci_bus 0000:03: resource 9 [mem 0x000d8000-0x000dbfff]
[ 0.302528] pci_bus 0000:03: resource 10 [mem 0x000dc000-0x000dffff]
[ 0.302529] pci_bus 0000:03: resource 11 [mem 0x000e0000-0x000e3fff]
[ 0.302531] pci_bus 0000:03: resource 12 [mem 0x000e4000-0x000e7fff]
[ 0.302532] pci_bus 0000:03: resource 13 [mem 0xdfa00000-0xfeafffff]
[ 0.302590] NET: Registered protocol family 2
[ 0.302626] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.302732] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.302865] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.302925] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.302927] TCP: reno registered
[ 0.302929] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.302932] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.302987] NET: Registered protocol family 1
[ 0.302994] pci 0000:00:02.0: Boot video device
[ 0.340620] PCI: CLS 64 bytes, default 64
[ 0.340680] Unpacking initramfs...
[ 0.531187] Freeing initrd memory: 14336k freed
[ 0.532808] audit: initializing netlink socket (disabled)
[ 0.532819] type=2000 audit(1495477038.428:1): initialized
[ 0.541376] highmem bounce pool size: 64 pages
[ 0.541379] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.541535] VFS: Disk quotas dquot_6.5.2
[ 0.541553] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.541599] msgmni has been set to 1688
[ 0.541703] alg: No test for stdrng (krng)
[ 0.541723] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.541726] io scheduler noop registered
[ 0.541727] io scheduler deadline registered
[ 0.541743] io scheduler cfq registered (default)
[ 0.541868] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.541879] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.541880] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.542160] vesafb: mode is 1024x768x32, linelength=4096, pages=0
[ 0.542162] vesafb: scrolling: redraw
[ 0.542164] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 0.542420] vesafb: framebuffer at 0xe0000000, mapped to 0xf8080000, using 3072k, total 3072k
[ 0.581441] Console: switching to colour frame buffer device 128x48
[ 0.620385] fb0: VESA VGA frame buffer device
[ 0.620423] GHES: HEST is not enabled!
[ 0.620431] isapnp: Scanning for PnP cards...
[ 0.929077] isapnp: No Plug & Play device found
[ 0.929109] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.949424] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.969925] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.970094] Linux agpgart interface v0.103
[ 0.970161] agpgart-intel 0000:00:00.0: Intel Ivybridge Chipset
[ 0.970210] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[ 0.970875] agpgart-intel 0000:00:00.0: detected 65536K stolen memory
[ 0.970957] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[ 0.971044] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 0.971466] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.971475] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.971545] mousedev: PS/2 mouse device common for all mice
[ 0.971589] rtc_cmos 00:06: RTC can wake from S4
[ 0.971696] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[ 0.971720] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 0.971803] TCP: cubic registered
[ 0.971851] NET: Registered protocol family 10
[ 0.971984] Mobile IPv6
[ 0.971986] NET: Registered protocol family 17
[ 0.971989] Registering the dns_resolver key type
[ 0.972022] Using IPI No-Shortcut mode
[ 0.972092] PM: Hibernation image not present or could not be loaded.
[ 0.972100] registered taskstats version 1
[ 0.972361] rtc_cmos 00:06: setting system clock to 2017-05-22 18:17:19 UTC (1495477039)
[ 0.972435] Freeing unused kernel memory: 416k freed
[ 0.972519] Write protecting the kernel text: 3500k
[ 0.972534] Write protecting the kernel read-only data: 980k
[ 0.982351] udevd[64]: starting version 175
[ 0.994630] usbcore: registered new interface driver usbfs
[ 0.994651] usbcore: registered new interface driver hub
[ 0.996492] SCSI subsystem initialized
[ 0.999134] usbcore: registered new device driver usb
[ 0.999438] ACPI: Fan [FAN0] (off)
[ 0.999482] ACPI: Fan [FAN1] (off)
[ 0.999502] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 0.999506] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.999516] ACPI: Fan [FAN2] (off)
[ 0.999525] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 0.999546] ACPI: Fan [FAN3] (off)
[ 0.999580] ACPI: Fan [FAN4] (off)
[ 0.999610] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 0.999656] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.999658] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.999660] usb usb1: Product: xHCI Host Controller
[ 0.999662] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 0.999664] usb usb1: SerialNumber: 0000:00:14.0
[ 0.999820] xHCI xhci_add_endpoint called for root hub
[ 0.999822] xHCI xhci_check_bandwidth called for root hub
[ 0.999850] hub 1-0:1.0: USB hub found
[ 0.999857] hub 1-0:1.0: 4 ports detected
[ 0.999921] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.999926] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 0.999944] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 0.999946] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.999948] usb usb2: Product: xHCI Host Controller
[ 0.999950] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 0.999952] usb usb2: SerialNumber: 0000:00:14.0
[ 1.000251] xHCI xhci_add_endpoint called for root hub
[ 1.000253] xHCI xhci_check_bandwidth called for root hub
[ 1.000278] hub 2-0:1.0: USB hub found
[ 1.000285] hub 2-0:1.0: 4 ports detected
[ 1.003062] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.010190] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 1.010449] r8169 0000:02:00.0: eth0: RTL8168evl/8111evl at 0xf8016000, 90:2b:34:d3:01:03, XID 0c900800 IRQ 16
[ 1.010452] r8169 0000:02:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 1.011310] libata version 3.00 loaded.
[ 1.018715] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[ 1.018719] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[ 1.018730] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[ 1.018754] ehci_hcd 0000:00:1a.0: debug port 2
[ 1.022615] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[ 1.022625] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7c17000
[ 1.034353] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[ 1.034392] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.034395] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.034397] usb usb3: Product: EHCI Host Controller
[ 1.034399] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.034400] usb usb3: SerialNumber: 0000:00:1a.0
[ 1.034498] hub 3-0:1.0: USB hub found
[ 1.034503] hub 3-0:1.0: 2 ports detected
[ 1.034600] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 1.034604] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 1.034612] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[ 1.034636] ehci_hcd 0000:00:1d.0: debug port 2
[ 1.038522] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 1.038539] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7c16000
[ 1.050292] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 1.050319] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.050323] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.050326] usb usb4: Product: EHCI Host Controller
[ 1.050328] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.050331] usb usb4: SerialNumber: 0000:00:1d.0
[ 1.050438] hub 4-0:1.0: USB hub found
[ 1.050442] hub 4-0:1.0: 2 ports detected
[ 1.050508] ata_piix 0000:00:1f.2: version 2.13
[ 1.050534] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 1.205793] ata_piix 0000:00:1f.2: SCR access via SIDPR is available but doesn't work
[ 1.205811] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 1.206081] scsi0 : ata_piix
[ 1.206167] scsi1 : ata_piix
[ 1.206318] ata1: SATA max UDMA/133 cmd 0xf110 ctl 0xf100 bmdma 0xf0d0 irq 19
[ 1.206320] ata2: SATA max UDMA/133 cmd 0xf0f0 ctl 0xf0e0 bmdma 0xf0d8 irq 19
[ 1.206338] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[ 1.345335] usb 3-1: new high-speed USB device number 2 using ehci_hcd
[ 1.361293] ata_piix 0000:00:1f.5: SCR access via SIDPR is available but doesn't work
[ 1.361312] ata_piix 0000:00:1f.5: setting latency timer to 64
[ 1.361535] scsi2 : ata_piix
[ 1.361586] scsi3 : ata_piix
[ 1.361688] ata3: SATA max UDMA/133 cmd 0xf0b0 ctl 0xf0a0 bmdma 0xf070 irq 19
[ 1.361689] ata4: SATA max UDMA/133 cmd 0xf090 ctl 0xf080 bmdma 0xf078 irq 19
[ 1.382929] ata1.01: ATA-8: Hitachi HDP725050GLA360, GM4OA52A, max UDMA/133
[ 1.382934] ata1.01: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.397573] ata1.01: configured for UDMA/133
[ 1.397686] scsi 0:0:1:0: Direct-Access ATA Hitachi HDP72505 GM4O PQ: 0 ANSI: 5
[ 1.477320] usb 3-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.477325] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.477587] hub 3-1:1.0: USB hub found
[ 1.477688] hub 3-1:1.0: 6 ports detected
[ 1.532719] Refined TSC clocksource calibration: 3292.519 MHz.
[ 1.532723] Switching to clocksource tsc
[ 1.540319] sd 0:0:1:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[ 1.540380] sd 0:0:1:0: [sda] Write Protect is off
[ 1.540383] sd 0:0:1:0: [sda] Mode Sense: 00 3a 00 00
[ 1.540403] sd 0:0:1:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.580370] sda: sda1 sda2 < sda5 >
[ 1.580631] sd 0:0:1:0: [sda] Attached SCSI disk
[ 1.592530] usb 4-1: new high-speed USB device number 2 using ehci_hcd
[ 1.724514] usb 4-1: New USB device found, idVendor=8087, idProduct=0024
[ 1.724519] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.724783] hub 4-1:1.0: USB hub found
[ 1.724881] hub 4-1:1.0: 6 ports detected
[ 1.796031] usb 3-1.1: new low-speed USB device number 3 using ehci_hcd
[ 1.891972] usb 3-1.1: New USB device found, idVendor=093a, idProduct=2510
[ 1.891977] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.891981] usb 3-1.1: Product: USB Optical Mouse
[ 1.891983] usb 3-1.1: Manufacturer: PixArt
[ 1.895586] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.1/3-1.1:1.0/input/input0
[ 1.895666] generic-usb 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1a.0-1.1/input0
[ 1.895683] usbcore: registered new interface driver usbhid
[ 1.895685] usbhid: USB HID core driver
[ 1.946286] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 1.963497] usb 3-1.4: new high-speed USB device number 4 using ehci_hcd
[ 2.055685] usb 3-1.4: New USB device found, idVendor=1a40, idProduct=0101
[ 2.055690] usb 3-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.055694] usb 3-1.4: Product: USB 2.0 Hub
[ 2.055966] hub 3-1.4:1.0: USB hub found
[ 2.056056] hub 3-1.4:1.0: 4 ports detected
[ 2.127085] usb 3-1.5: new low-speed USB device number 5 using ehci_hcd
[ 2.224633] usb 3-1.5: New USB device found, idVendor=046d, idProduct=c312
[ 2.224638] usb 3-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.224642] usb 3-1.5: Product: USB Multimedia Keyboard
[ 2.224644] usb 3-1.5: Manufacturer: BTC
[ 2.227637] input: BTC USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.5/3-1.5:1.0/input/input1
[ 2.227673] generic-usb 0003:046D:C312.0002: input,hidraw1: USB HID v1.10 Keyboard [BTC USB Multimedia Keyboard] on usb-0000:00:1a.0-1.5/input0
[ 2.234281] input: BTC USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.5/3-1.5:1.1/input/input2
[ 2.234356] generic-usb 0003:046D:C312.0003: input,hiddev0,hidraw2: USB HID v1.10 Device [BTC USB Multimedia Keyboard] on usb-0000:00:1a.0-1.5/input1
[ 2.326306] usb 3-1.4.1: new full-speed USB device number 6 using ehci_hcd
[ 2.419000] usb 3-1.4.1: New USB device found, idVendor=c1a5, idProduct=0501
[ 2.419005] usb 3-1.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.419008] usb 3-1.4.1: Product: AvPass
[ 2.419011] usb 3-1.4.1: Manufacturer: AVEST
[ 2.419013] usb 3-1.4.1: SerialNumber: AVP3060099435
[ 2.420581] generic-usb 0003:C1A5:0501.0004: hiddev0,hidraw3: USB HID v1.10 Device [AVEST AvPass] on usb-0000:00:1a.0-1.4.1/input0
[ 2.489778] usb 3-1.4.3: new low-speed USB device number 7 using ehci_hcd
[ 2.586086] usb 3-1.4.3: New USB device found, idVendor=04b9, idProduct=1000
[ 2.586091] usb 3-1.4.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[ 2.586094] usb 3-1.4.3: Product: iKey 1000
[ 2.586097] usb 3-1.4.3: Manufacturer: Rainbow Technologies
[ 3.327129] init: ureadahead main process (290) terminated with status 5
[ 4.174269] Adding 8259580k swap on /dev/sda5. Priority:-1 extents:1 across:8259580k
[ 5.067551] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 6.122146] udevd[483]: starting version 175
[ 8.805555] lp: driver loaded but no devices found
[ 9.771895] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[ 9.771901] ACPI: Power Button [PWRB]
[ 9.771946] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 9.771950] ACPI: Power Button [PWRF]
[ 9.844836] parport_pc 00:0a: reported by Plug and Play ACPI
[ 9.844886] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[ 9.852162] ppdev: user-space parallel port driver
[ 9.868333] microcode: CPU0 sig=0x306a9, pf=0x2, revision=0x12
[ 9.941501] lp0: using parport0 (interrupt-driven).
[ 10.137738] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 11.060923] microcode: CPU1 sig=0x306a9, pf=0x2, revision=0x12
[ 11.062047] microcode: CPU2 sig=0x306a9, pf=0x2, revision=0x12
[ 11.062993] microcode: CPU3 sig=0x306a9, pf=0x2, revision=0x12
[ 11.064158] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 13.158221] [drm] Initialized drm 1.1.0 20060810
[ 13.536524] Bluetooth: Core ver 2.16
[ 13.536541] NET: Registered protocol family 31
[ 13.536543] Bluetooth: HCI device and connection manager initialized
[ 13.536546] Bluetooth: HCI socket layer initialized
[ 13.536548] Bluetooth: L2CAP socket layer initialized
[ 13.536554] Bluetooth: SCO socket layer initialized
[ 13.543992] i915 0000:00:02.0: setting latency timer to 64
[ 13.555072] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[ 13.555074] [drm] MTRR allocation failed. Graphics performance may suffer.
[ 13.555232] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 13.555235] [drm] Driver supports precise vblank timestamp query.
[ 13.555762] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 13.590193] Bluetooth: RFCOMM TTY layer initialized
[ 13.590198] Bluetooth: RFCOMM socket layer initialized
[ 13.590200] Bluetooth: RFCOMM ver 1.11
[ 13.718944] [drm] Enabling RC6 states: RC6 on, RC6p on, RC6pp off
[ 13.765447] NET: Registered protocol family 4
[ 13.841839] NET: Registered protocol family 5
[ 14.016740] checking generic (e0000000 300000) vs hw (e0000000 10000000)
[ 14.016743] fb: conflicting fb hw usage inteldrmfb vs VESA VGA - removing generic driver
[ 14.016763] Console: switching to colour dummy device 80x25
[ 14.016888] fbcon: inteldrmfb (fb0) is primary device
[ 14.354205] Console: switching to colour frame buffer device 128x48
[ 14.393290] fb0: inteldrmfb frame buffer device
[ 14.393292] drm: registered panic notifier
[ 14.399224] acpi device:4d: registered as cooling_device5
[ 14.399427] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[ 14.399464] ACPI: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 14.399482] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[ 14.435894] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 14.435897] Bluetooth: BNEP filters: protocol multicast
[ 14.575741] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input6
[ 14.581102] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 14.581155] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 14.581204] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 14.581246] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 14.581291] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[ 16.642292] init: failsafe main process (848) killed by TERM signal
[ 24.538865] r8169 0000:02:00.0: eth0: link down
[ 24.538911] r8169 0000:02:00.0: eth0: link down
[ 24.538949] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 26.072947] init: plymouth-stop pre-start process (1309) terminated with status 1
[ 26.100399] r8169 0000:02:00.0: eth0: link up
[ 26.100451] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 32.611451] fuse init (API version 7.18)
[ 36.590711] eth0: no IPv6 routers present
[ 766.617469] I-pipe: head domain RTAI registered.
[ 766.617474] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[ 766.617516] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 766.617518] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3292752000, CPU_FREQ 3292752000
[ 766.617520] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 766.617522] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 3319250
[ 766.648809] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 766.648833] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 766.648837] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[ 766.648840] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3292752000 hz.
[ 766.648842] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 766.662646] RTAI[math]: loaded.
[ 779.329308] RTAI[math]: unloaded.
[ 779.330484] SCHED releases registered named ALIEN PEDV$D
[ 779.339478] RTAI[malloc]: unloaded.
[ 779.437276] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 779.438814] I-pipe: head domain RTAI unregistered.
[ 779.438865] RTAI[hal]: unmounted.
Более того, после установки так и не нашел установленные wizard'ы...
