Все кажется нашел в документации:
• M62 P- - turn on digital output synchronized with motion. The P- word specifies the digital output number.
• M63 P- - turn off digital output synchronized with motion. The P- word specifies the digital output number.
• M64 P- - turn on digital output immediately. The P- word specifies the digital output number.
• M65 P- - turn off digital output immediately. The P- word specifies the digital output number.
The P-word ranges from 0 to a default value of 3. If needed the the number of I/O can be increased by using the num_dio
parameter when loading the motion controller. See the Motion Section for more information.
The M62 & M63 commands will be queued. Subsequent commands referring to the same output number will overwrite the older
settings. More than one output change can be specified by issuing more than one M62/M63 command.
The actual change of the specified outputs will happen at the beginning of the next motion command. If there is no subsequent
motion command, the queued output changes won’t happen. It’s best to always program a motion G code (G0, G1, etc) right
after the M62/63.
M64 & M65 happen immediately as they are received by the motion controller. They are not synchronized with movement, and
they will break blending.
Note
M62-65 will not function unless the appropriate motion.digital-out-nn pins are connected in your hal file to outputs.
На недели буду пробовать, как только с приводами разберусь
