спасибо - это помогло вроде поставить все нужные пакеты...
но сама программа не устанавливается ,хотя откровенно и не "ругается" ...
раньше думал , что make если выдает error , то что то не так,а если warning - то "пройдет"...
но тут вроде не проходит...
nkp@nkp-desktop:~/pcb2gcode-1.1.4$ make
make all-recursive
make[1]: Вход в каталог `/home/nkp/pcb2gcode-1.1.4'
Making all in man
make[2]: Вход в каталог `/home/nkp/pcb2gcode-1.1.4/man'
make[2]: Цель `all' не требует выполнения команд.
make[2]: Выход из каталога `/home/nkp/pcb2gcode-1.1.4/man'
make[2]: Вход в каталог `/home/nkp/pcb2gcode-1.1.4'
g++ -DHAVE_CONFIG_H -I. -I/usr/include -pthread -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -pthread -D_REENTRANT -I/usr/include/gdkmm-2.4 -I/usr/lib/gdkmm-2.4/include -I/usr/include/giomm-2.4 -I/usr/lib/giomm-2.4/include -I/usr/include/pangomm-1.4 -I/usr/lib/pangomm-1.4/include -I/usr/include/gtk-2.0 -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/cairomm-1.0 -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/gio-unix-2.0/ -pthread -D_REENTRANT -I/usr/include/gerbv-2.4.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -g -O2 -MT svg_exporter.o -MD -MP -MF .deps/svg_exporter.Tpo -c -o svg_exporter.o svg_exporter.cpp
In file included from /usr/include/cairomm-1.0/cairomm/cairomm.h:34,
from importer.hpp:28,
from gerberimporter.hpp:27,
from surface.hpp:39,
from board.hpp:46,
from exporter.hpp:38,
from svg_exporter.hpp:46,
from svg_exporter.cpp:26:
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:69:1: warning: "PACKAGE" redefined
In file included from /usr/include/gerbv-2.4.0/gerbv.h:66,
from svg_exporter.hpp:36,
./config.h:60:1: warning: this is the location of the previous definition
from board.hpp:46,
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:72:1: warning: "PACKAGE_BUGREPORT" redefined
./config.h:63:1: warning: this is the location of the previous definition
from board.hpp:46,
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:75:1: warning: "PACKAGE_NAME" redefined
./config.h:66:1: warning: this is the location of the previous definition
from board.hpp:46,
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:78:1: warning: "PACKAGE_STRING" redefined
./config.h:69:1: warning: this is the location of the previous definition
from board.hpp:46,
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:81:1: warning: "PACKAGE_TARNAME" redefined
./config.h:72:1: warning: this is the location of the previous definition
from board.hpp:46,
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:84:1: warning: "PACKAGE_VERSION" redefined
./config.h:78:1: warning: this is the location of the previous definition
from board.hpp:46,
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:90:1: warning: "VERSION" redefined
./config.h:84:1: warning: this is the location of the previous definition
mv -f .deps/svg_exporter.Tpo .deps/svg_exporter.Po
g++ -DHAVE_CONFIG_H -I. -I/usr/include -pthread -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -pthread -D_REENTRANT -I/usr/include/gdkmm-2.4 -I/usr/lib/gdkmm-2.4/include -I/usr/include/giomm-2.4 -I/usr/lib/giomm-2.4/include -I/usr/include/pangomm-1.4 -I/usr/lib/pangomm-1.4/include -I/usr/include/gtk-2.0 -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/cairomm-1.0 -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/gio-unix-2.0/ -pthread -D_REENTRANT -I/usr/include/gerbv-2.4.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -g -O2 -MT board.o -MD -MP -MF .deps/board.Tpo -c -o board.o board.cpp
from gerberimporter.hpp:31,
from board.hpp:46,
from board.cpp:21:
./config.h:60:1: warning: "PACKAGE" redefined
from board.hpp:46,
from board.cpp:21:
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:69:1: warning: this is the location of the previous definition
from board.hpp:46,
from board.cpp:21:
./config.h:63:1: warning: "PACKAGE_BUGREPORT" redefined
from board.hpp:46,
from board.cpp:21:
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:72:1: warning: this is the location of the previous definition
from board.hpp:46,
from board.cpp:21:
./config.h:66:1: warning: "PACKAGE_NAME" redefined
from board.hpp:46,
from board.cpp:21:
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:75:1: warning: this is the location of the previous definition
from board.hpp:46,
from board.cpp:21:
./config.h:69:1: warning: "PACKAGE_STRING" redefined
from board.hpp:46,
from board.cpp:21:
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:78:1: warning: this is the location of the previous definition
from board.hpp:46,
from board.cpp:21:
./config.h:72:1: warning: "PACKAGE_TARNAME" redefined
from board.hpp:46,
from board.cpp:21:
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:81:1: warning: this is the location of the previous definition
from board.hpp:46,
from board.cpp:21:
./config.h:78:1: warning: "PACKAGE_VERSION" redefined
from board.hpp:46,
from board.cpp:21:
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:84:1: warning: this is the location of the previous definition
from board.hpp:46,
from board.cpp:21:
./config.h:84:1: warning: "VERSION" redefined
from board.hpp:46,
from board.cpp:21:
/usr/include/cairomm-1.0/cairomm/cairommconfig.h:90:1: warning: this is the location of the previous definition
mv -f .deps/board.Tpo .deps/board.Po
g++ -DHAVE_CONFIG_H -I. -I/usr/include -pthread -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -pthread -D_REENTRANT -I/usr/include/gdkmm-2.4 -I/usr/lib/gdkmm-2.4/include -I/usr/include/giomm-2.4 -I/usr/lib/giomm-2.4/include -I/usr/include/pangomm-1.4 -I/usr/lib/pangomm-1.4/include -I/usr/include/gtk-2.0 -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/cairomm-1.0 -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/gio-unix-2.0/ -pthread -D_REENTRANT -I/usr/include/gerbv-2.4.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -g -O2 -MT drill.o -MD -MP -MF .deps/drill.Tpo -c -o drill.o drill.cpp
from board.hpp:46,
from drill.hpp:48,
from drill.cpp:29:
from drill.hpp:39,
from drill.cpp:29:
from board.hpp:46,
from drill.hpp:48,
from drill.cpp:29:
from drill.hpp:39,
from drill.cpp:29:
from board.hpp:46,
from drill.hpp:48,
from drill.cpp:29:
from drill.hpp:39,
from drill.cpp:29:
from board.hpp:46,
from drill.hpp:48,
from drill.cpp:29:
from drill.hpp:39,
from drill.cpp:29:
from board.hpp:46,
from drill.hpp:48,
from drill.cpp:29:
from drill.hpp:39,
from drill.cpp:29:
from board.hpp:46,
from drill.hpp:48,
from drill.cpp:29:
from drill.hpp:39,
from drill.cpp:29:
from board.hpp:46,
from drill.hpp:48,
from drill.cpp:29:
from drill.hpp:39,
from drill.cpp:29:
mv -f .deps/drill.Tpo .deps/drill.Po
g++ -DHAVE_CONFIG_H -I. -I/usr/include -pthread -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -pthread -D_REENTRANT -I/usr/include/gdkmm-2.4 -I/usr/lib/gdkmm-2.4/include -I/usr/include/giomm-2.4 -I/usr/lib/giomm-2.4/include -I/usr/include/pangomm-1.4 -I/usr/lib/pangomm-1.4/include -I/usr/include/gtk-2.0 -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/cairomm-1.0 -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/gio-unix-2.0/ -pthread -D_REENTRANT -I/usr/include/gerbv-2.4.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -g -O2 -MT gerberimporter.o -MD -MP -MF .deps/gerberimporter.Tpo -c -o gerberimporter.o gerberimporter.cpp
from gerberimporter.cpp:21:
mv -f .deps/gerberimporter.Tpo .deps/gerberimporter.Po
g++ -DHAVE_CONFIG_H -I. -I/usr/include -pthread -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -pthread -D_REENTRANT -I/usr/include/gdkmm-2.4 -I/usr/lib/gdkmm-2.4/include -I/usr/include/giomm-2.4 -I/usr/lib/giomm-2.4/include -I/usr/include/pangomm-1.4 -I/usr/lib/pangomm-1.4/include -I/usr/include/gtk-2.0 -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/cairomm-1.0 -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/gio-unix-2.0/ -pthread -D_REENTRANT -I/usr/include/gerbv-2.4.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -g -O2 -MT layer.o -MD -MP -MF .deps/layer.Tpo -c -o layer.o layer.cpp
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
from layer.hpp:13,
from layer.cpp:2:
mv -f .deps/layer.Tpo .deps/layer.Po
g++ -DHAVE_CONFIG_H -I. -I/usr/include -pthread -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -pthread -D_REENTRANT -I/usr/include/gdkmm-2.4 -I/usr/lib/gdkmm-2.4/include -I/usr/include/giomm-2.4 -I/usr/lib/giomm-2.4/include -I/usr/include/pangomm-1.4 -I/usr/lib/pangomm-1.4/include -I/usr/include/gtk-2.0 -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/cairomm-1.0 -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/gio-unix-2.0/ -pthread -D_REENTRANT -I/usr/include/gerbv-2.4.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -g -O2 -MT mill.o -MD -MP -MF .deps/mill.Tpo -c -o mill.o mill.cpp
mv -f .deps/mill.Tpo .deps/mill.Po
g++ -DHAVE_CONFIG_H -I. -I/usr/include -pthread -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -pthread -D_REENTRANT -I/usr/include/gdkmm-2.4 -I/usr/lib/gdkmm-2.4/include -I/usr/include/giomm-2.4 -I/usr/lib/giomm-2.4/include -I/usr/include/pangomm-1.4 -I/usr/lib/pangomm-1.4/include -I/usr/include/gtk-2.0 -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/cairomm-1.0 -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/gio-unix-2.0/ -pthread -D_REENTRANT -I/usr/include/gerbv-2.4.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -g -O2 -MT ngc_exporter.o -MD -MP -MF .deps/ngc_exporter.Tpo -c -o ngc_exporter.o ngc_exporter.cpp
from board.hpp:46,
from ngc_exporter.hpp:41,
from ngc_exporter.cpp:20:
from board.hpp:46,
from board.hpp:46,
from board.hpp:46,
from board.hpp:46,
from board.hpp:46,
from board.hpp:46,
from board.hpp:46,
from board.hpp:46,
from board.hpp:46,
from board.hpp:46,
from board.hpp:46,
from board.hpp:46,
from board.hpp:46,
mv -f .deps/ngc_exporter.Tpo .deps/ngc_exporter.Po
g++ -DHAVE_CONFIG_H -I. -I/usr/include -pthread -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -pthread -D_REENTRANT -I/usr/include/gdkmm-2.4 -I/usr/lib/gdkmm-2.4/include -I/usr/include/giomm-2.4 -I/usr/lib/giomm-2.4/include -I/usr/include/pangomm-1.4 -I/usr/lib/pangomm-1.4/include -I/usr/include/gtk-2.0 -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/cairomm-1.0 -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/gio-unix-2.0/ -pthread -D_REENTRANT -I/usr/include/gerbv-2.4.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -g -O2 -MT surface.o -MD -MP -MF .deps/surface.Tpo -c -o surface.o surface.cpp
from surface.cpp:20:
mv -f .deps/surface.Tpo .deps/surface.Po
g++ -DHAVE_CONFIG_H -I. -I/usr/include -pthread -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -pthread -D_REENTRANT -I/usr/include/gdkmm-2.4 -I/usr/lib/gdkmm-2.4/include -I/usr/include/giomm-2.4 -I/usr/lib/giomm-2.4/include -I/usr/include/pangomm-1.4 -I/usr/lib/pangomm-1.4/include -I/usr/include/gtk-2.0 -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/cairomm-1.0 -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/gio-unix-2.0/ -pthread -D_REENTRANT -I/usr/include/gerbv-2.4.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -g -O2 -MT options.o -MD -MP -MF .deps/options.Tpo -c -o options.o options.cpp
mv -f .deps/options.Tpo .deps/options.Po
g++ -DHAVE_CONFIG_H -I. -I/usr/include -pthread -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -pthread -D_REENTRANT -I/usr/include/gdkmm-2.4 -I/usr/lib/gdkmm-2.4/include -I/usr/include/giomm-2.4 -I/usr/lib/giomm-2.4/include -I/usr/include/pangomm-1.4 -I/usr/lib/pangomm-1.4/include -I/usr/include/gtk-2.0 -I/usr/include/glibmm-2.4 -I/usr/lib/glibmm-2.4/include -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/sigc++-2.0 -I/usr/lib/sigc++-2.0/include -I/usr/include/cairomm-1.0 -I/usr/include/pango-1.0 -I/usr/include/cairo -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/gio-unix-2.0/ -pthread -D_REENTRANT -I/usr/include/gerbv-2.4.0 -I/usr/include/glib-2.0 -I/usr/lib/glib-2.0/include -I/usr/include/gtk-2.0 -I/usr/lib/gtk-2.0/include -I/usr/include/atk-1.0 -I/usr/include/cairo -I/usr/include/pango-1.0 -I/usr/include/gio-unix-2.0/ -I/usr/include/pixman-1 -I/usr/include/freetype2 -I/usr/include/directfb -I/usr/include/libpng12 -g -O2 -MT main.o -MD -MP -MF .deps/main.Tpo -c -o main.o main.cpp
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
from main.cpp:35:
mv -f .deps/main.Tpo .deps/main.Po
/bin/bash ./libtool --tag=CXX --mode=link g++ -g -O2 -L/usr/lib -R/usr/lib -o pcb2gcode svg_exporter.o board.o drill.o gerberimporter.o layer.o mill.o ngc_exporter.o surface.o options.o main.o -pthread -lglibmm-2.4 -lgobject-2.0 -lsigc-2.0 -lgthread-2.0 -lrt -lglib-2.0 -pthread -lgdkmm-2.4 -lgiomm-2.4 -lpangomm-1.4 -lgtk-x11-2.0 -lglibmm-2.4 -lcairomm-1.0 -lsigc-2.0 -lgdk-x11-2.0 -latk-1.0 -lgio-2.0 -lpangoft2-1.0 -lgdk_pixbuf-2.0 -lm -lpangocairo-1.0 -lcairo -lpango-1.0 -lfreetype -lfontconfig -lgobject-2.0 -lgmodule-2.0 -lgthread-2.0 -lrt -lglib-2.0 -pthread -lgerbv -lgtk-x11-2.0 -lgdk-x11-2.0 -latk-1.0 -lgio-2.0 -lpangoft2-1.0 -lgdk_pixbuf-2.0 -lm -lpangocairo-1.0 -lcairo -lpango-1.0 -lfreetype -lfontconfig -lgobject-2.0 -lgmodule-2.0 -lgthread-2.0 -lrt -lglib-2.0 -lboost_program_options-mt
make[2]: Выход из каталога `/home/nkp/pcb2gcode-1.1.4'
make[1]: Выход из каталога `/home/nkp/pcb2gcode-1.1.4'
