Страница 4 из 4
Gcode tools - lathe extension develop
Добавлено: 08 апр 2010, 09:25
Questions to discus
- Cutting tool parameters
- Additional lathe parameters
- Lathe's Gcode features
- Special places
Desired features list
- Special mode for 4axis mills
- Automatic flip along axis
Awaiting of realization
Done
- Path calculation
- Export path to gcode
- Defailt X and Z axis remap
Re: Gcode tools - lathe extension develop
Добавлено: 06 авг 2010, 22:27
Hmmm something wrong with offset's direction... I'll check it right now.
Добавлено: 06 авг 2010, 22:44
Revision 146
I've forgot to add "csp_join_subpaths(offsetted_subpath)[0]" to the fine cut calculation. Now should work fine...
Thanks again for the bug report
and sorry for the bugs
When I will start to write the code correct from the beginning
Добавлено: 07 авг 2010, 08:34
Revision 147
New function in Post-processor: flip or flip axis. It does what you wanted.
Post-processor is in the "Preferences" tab. You can chose from predefined post-processors or add your own to "Additional post-processor".
Example:
flip(x); flips x axis
flip(xy); flips x and y axis
flip(y,x); flips x,y axis
flip(x,y); flips x,y axis
Добавлено: 07 авг 2010, 10:46
alfcnc
Ok ! I'll test... I've think that was a miss...because that was strange problem about the previous ...
Hope that's all is good now... because you can refresh your head...
Post processor come to be working ... very nice. I think that's this give more powerfull to gcodetools...
Добавлено: 03 янв 2011, 02:12
Vlad
Guys good work!
I have a question, its not clear to me how to reverse the cutting? I dont see the option for that... I want to cut from right to left. Thanks.
Добавлено: 03 янв 2011, 03:40
Use Path -> Reverse path from Inkscape's menu.
Also you can add a marker to the path to check it's direction. To do that open stroke style dialog at the Fill and Stroke panel (Ctrl+Shift+F and choose the third tab). And set middle marker which will have "_Smf_End" like name.
Добавлено: 03 янв 2011, 04:28
Vlad
root писал(а):Use Path -> Reverse path from Inkscape's menu.
Thanks for a quick reply! Will try that.
I'll submit a few pictures if I get something interesting done.
Also, what is the latest version now? I downloaded one off the first post in this thread and after installing it said new version is available...
I'm using v 1.6.01
Добавлено: 03 янв 2011, 12:00
Hmmm latest version should be 1.6.04 and there\s nothing new there except some bugfixes.
1.6.04 should be in the first post of this thread.
http://www.cnc-club.ru/forum/viewtopic. ... st_version
Добавлено: 16 мар 2011, 18:23
Vlad
I haven't used the lathe function in a while since the last lathe broke, finally got another one converted and ready to test but it seems like adding G18 does nothing, it still says "bad character y used"...
I have a normal XZ lathe.
Attaching my output file, maybe you can help.
Добавлено: 16 мар 2011, 19:27
Vlad
Vlad писал(а):I haven't used the lathe function in a while since the last lathe broke, finally got another one converted and ready to test but it seems like adding G18 does nothing, it still says "bad character y used"...
Never mind, I figured it out, I was generating "path to Gcode" after Lathe when I did not need to...
Добавлено: 16 мар 2011, 20:04
Glad to hear that you've managed it out
PS Have you seen path preparation function?
Добавлено: 21 мар 2011, 23:56
Vlad
root писал(а):Glad to hear that you've managed it out
No, where can I find it and what does it do?
Добавлено: 22 мар 2011, 00:09
Добавлено: 22 мар 2011, 01:45
Vlad
Thanks, are there plans to include it in the non dev version?
Добавлено: 22 мар 2011, 07:32
Sure, in a month or so it will be the stable version.
