Re: Mesa 5i25+7i77-с чего начать?
Добавлено: 18 янв 2016, 11:38
какой конфиг не загружается?
(выложи или покажи ,где выкладывал)
Статьи, обзоры, цены на станки и комплектующие.
https://cnc-club.ru/forum/
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.3
Machine configuration directory is '/home/ulp/linuxcnc/configs'
Machine configuration file is '7i77.ini'
INIFILE=/home/ulp/linuxcnc/configs/7i77.ini
PARAMETER_FILE=7i77.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
emc/iotask/ioControl.cc 768: can't load tool table.
Found file(REL): ./7i77.hal
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=8604
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
HAL: ERROR: function 'hm2_5i25.0.pet_watchdog' not found
./7i77.hal:24: addf failed
8604
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000008d800 (usable)
[ 0.000000] BIOS-e820: 000000000008d800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000020000000 (usable)
[ 0.000000] BIOS-e820: 0000000020000000 - 0000000020100000 (reserved)
[ 0.000000] BIOS-e820: 0000000020100000 - 0000000079730000 (usable)
[ 0.000000] BIOS-e820: 0000000079730000 - 0000000079760000 (reserved)
[ 0.000000] BIOS-e820: 0000000079760000 - 0000000079770000 (ACPI data)
[ 0.000000] BIOS-e820: 0000000079770000 - 00000000798a2000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000798a2000 - 0000000079ba0000 (reserved)
[ 0.000000] BIOS-e820: 0000000079ba0000 - 0000000079ba1000 (usable)
[ 0.000000] BIOS-e820: 0000000079ba1000 - 0000000079be3000 (reserved)
[ 0.000000] BIOS-e820: 0000000079be3000 - 0000000079d53000 (usable)
[ 0.000000] BIOS-e820: 0000000079d53000 - 0000000079ffa000 (reserved)
[ 0.000000] BIOS-e820: 0000000079ffa000 - 000000007a000000 (usable)
[ 0.000000] BIOS-e820: 00000000e00f8000 - 00000000e00f9000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed01000 - 00000000fed02000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.8 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. To be filled by O.E.M./J1800N-D2P, BIOS F2 03/06/2014
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7a000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-E7FFF write-through
[ 0.000000] E8000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 07A000000 mask FFE000000 uncachable
[ 0.000000] 2 base 07C000000 mask FFC000000 uncachable
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00fd6b0] fd6b0
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c0089000] 89000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36416000 - 37203000
[ 0.000000] ACPI: RSDP 000f04a0 00024 (v02 ALASKA)
[ 0.000000] ACPI: XSDT 79763078 00074 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FACP 7976e450 0010C (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: DSDT 79763180 0B2CD (v02 ALASKA A M I 01072009 INTL 20120913)
[ 0.000000] ACPI: FACS 798a1f80 00040
[ 0.000000] ACPI: APIC 7976e560 00068 (v03 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: FPDT 7976e5c8 00044 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.000000] ACPI: MCFG 7976e610 0003C (v01 ALASKA A M I 01072009 MSFT 00000097)
[ 0.000000] ACPI: LPIT 7976e650 00104 (v01 ALASKA A M I 00000003 VLV2 0100000D)
[ 0.000000] ACPI: HPET 7976e758 00038 (v01 ALASKA A M I 01072009 AMI. 00000005)
[ 0.000000] ACPI: SSDT 7976e790 00763 (v01 PmRef CpuPm 00003000 INTL 20061109)
[ 0.000000] ACPI: SSDT 7976eef8 00290 (v01 PmRef Cpu0Tst 00003000 INTL 20061109)
[ 0.000000] ACPI: SSDT 7976f188 0017A (v01 PmRef ApTst 00003000 INTL 20061109)
[ 0.000000] ACPI: UEFI 7976f308 00042 (v01 ALASKA A M I 00000000 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1064MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007a000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000008d
[ 0.000000] 0: 0x00000100 -> 0x00020000
[ 0.000000] 0: 0x00020100 -> 0x00079730
[ 0.000000] 0: 0x00079ba0 -> 0x00079ba1
[ 0.000000] 0: 0x00079be3 -> 0x00079d53
[ 0.000000] 0: 0x00079ffa -> 0x0007a000
[ 0.000000] On node 0 totalpages: 497444
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f54d6200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3933 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221230 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2129 pages used for memmap
[ 0.000000] HighMem zone: 268376 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] dfl res lint[0x68])
[ 0.000000] ACPI: NMI not connected to LINT 1!
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] dfl level lint[0xf1])
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-86
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 2 CPUs, 0 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 103
[ 0.000000] PM: Registered nosave memory: 000000000008d000 - 000000000008e000
[ 0.000000] PM: Registered nosave memory: 000000000008e000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[ 0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020100000
[ 0.000000] Allocating PCI resources starting at 7a000000 (gap: 7a000000:660f8000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:2 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77cf000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 493539
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=3864dc2e-a636-4a78-900c-74e1850e8199 ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 3997568 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007a000)
[ 0.000000] Memory: 1949148k/1998848k available (3495k kernel code, 40628k reserved, 1237k data, 416k init, 1082020k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:512 16
[ 0.000000] CPU 0 irqstacks, hard=f5008000 soft=f500a000
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] spurious 8259A interrupt: IRQ7.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration failed
[ 0.004000] TSC: PIT calibration matches HPET. 1 loops
[ 0.004000] Detected 2416.671 MHz processor.
[ 0.000002] Calibrating delay loop (skipped), value calculated using timer frequency.. 4833.34 BogoMIPS (lpj=9666684)
[ 0.000008] pid_max: default: 32768 minimum: 301
[ 0.000075] Security Framework initialized
[ 0.000081] AppArmor: AppArmor disabled by boot time parameter
[ 0.000108] Mount-cache hash table entries: 512
[ 0.000351] Initializing cgroup subsys cpuacct
[ 0.000355] Initializing cgroup subsys memory
[ 0.000365] Initializing cgroup subsys devices
[ 0.000369] Initializing cgroup subsys freezer
[ 0.000372] Initializing cgroup subsys net_cls
[ 0.000375] Initializing cgroup subsys blkio
[ 0.000384] Initializing cgroup subsys perf_event
[ 0.000417] CPU: Physical Processor ID: 0
[ 0.000420] CPU: Processor Core ID: 0
[ 0.000425] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[ 0.000427] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[ 0.010237] mce: CPU supports 6 MCE banks
[ 0.010246] CPU0: Thermal monitoring enabled (TM1)
[ 0.010324] ACPI: Core revision 20120320
[ 0.025717] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.026437] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=0 pin2=0
[ 0.066060] CPU0: Intel(R) Celeron(R) CPU J1800 @ 2.41GHz stepping 03
[ 0.170784] Performance Events: no PEBS fmt2+, generic architected perfmon, Intel PMU driver.
[ 0.170795] ... version: 3
[ 0.170798] ... bit width: 40
[ 0.170801] ... generic registers: 2
[ 0.170804] ... value mask: 000000ffffffffff
[ 0.170807] ... max period: 000000007fffffff
[ 0.170810] ... fixed-purpose events: 3
[ 0.170812] ... event mask: 0000000700000003
[ 0.182824] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.194773] CPU 1 irqstacks, hard=f50d2000 soft=f50d4000
[ 0.194777] Booting Node 0, Processors #1 Ok.
[ 0.204787] Initializing CPU#1
[ 0.217188] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.217251] Brought up 2 CPUs
[ 0.217255] Total of 2 processors activated (9666.68 BogoMIPS).
[ 0.217789] devtmpfs: initialized
[ 0.218143] PM: Registering ACPI NVS region [mem 0x79770000-0x798a1fff] (1253376 bytes)
[ 0.218373] dummy:
[ 0.218465] NET: Registered protocol family 16
[ 0.218641] ACPI: bus type pci registered
[ 0.218729] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.218735] PCI: not using MMCONFIG
[ 0.219139] PCI: Using configuration type 1 for base access
[ 0.220137] bio: create slab <bio-0> at 0
[ 0.220292] ACPI: Added _OSI(Module Device)
[ 0.220297] ACPI: Added _OSI(Processor Device)
[ 0.220301] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.220305] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.225259] ACPI: EC: Look up EC in DSDT
[ 0.240957] ACPI: SSDT 79758598 00521 (v01 PmRef Cpu0Ist 00003000 INTL 20061109)
[ 0.242213] ACPI: Dynamic OEM Table Load:
[ 0.242219] ACPI: SSDT (null) 00521 (v01 PmRef Cpu0Ist 00003000 INTL 20061109)
[ 0.242490] ACPI: SSDT 79757918 00433 (v01 PmRef Cpu0Cst 00003001 INTL 20061109)
[ 0.243716] ACPI: Dynamic OEM Table Load:
[ 0.243723] ACPI: SSDT (null) 00433 (v01 PmRef Cpu0Cst 00003001 INTL 20061109)
[ 0.244417] ACPI: SSDT 79759e18 0015F (v01 PmRef ApIst 00003000 INTL 20061109)
[ 0.245719] ACPI: Dynamic OEM Table Load:
[ 0.245726] ACPI: SSDT (null) 0015F (v01 PmRef ApIst 00003000 INTL 20061109)
[ 0.245996] ACPI: SSDT 7975af18 0008D (v01 PmRef ApCst 00003000 INTL 20061109)
[ 0.247248] ACPI: Dynamic OEM Table Load:
[ 0.247255] ACPI: SSDT (null) 0008D (v01 PmRef ApCst 00003000 INTL 20061109)
[ 0.248509] ACPI: Interpreter enabled
[ 0.248527] ACPI: (supports S0 S3 S4 S5)
[ 0.248573] ACPI: Using IOAPIC for interrupt routing
[ 0.248615] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.250619] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in ACPI motherboard resources
[ 0.250623] PCI: Using MMCONFIG for extended config space
[ 0.260153] ACPI: Power Resource [USBC] (on)
[ 0.262223] ACPI: Power Resource [FN00] (off)
[ 0.263396] ACPI: No dock devices found.
[ 0.263406] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.263860] \_SB_.PCI0:_OSC invalid UUID
[ 0.263864] _OSC request data:1 8 0
[ 0.263874] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.264406] pci_root PNP0A08:00: host bridge window [io 0x0000-0x006f]
[ 0.264412] pci_root PNP0A08:00: host bridge window [io 0x0078-0x0cf7]
[ 0.264416] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.264420] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.264424] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff]
[ 0.264428] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000fffff]
[ 0.264433] pci_root PNP0A08:00: host bridge window [mem 0x80000000-0xd0816ffe]
[ 0.264490] PCI host bridge to bus 0000:00
[ 0.264495] pci_bus 0000:00: root bus resource [io 0x0000-0x006f]
[ 0.264500] pci_bus 0000:00: root bus resource [io 0x0078-0x0cf7]
[ 0.264504] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff]
[ 0.264508] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[ 0.264512] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff]
[ 0.264516] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000fffff]
[ 0.264521] pci_bus 0000:00: root bus resource [mem 0x80000000-0xd0816ffe]
[ 0.264536] pci 0000:00:00.0: [8086:0f00] type 00 class 0x060000
[ 0.264589] pci 0000:00:02.0: [8086:0f31] type 00 class 0x030000
[ 0.264607] pci 0000:00:02.0: reg 10: [mem 0xd0000000-0xd03fffff]
[ 0.264621] pci 0000:00:02.0: reg 18: [mem 0xc0000000-0xcfffffff pref]
[ 0.264635] pci 0000:00:02.0: reg 20: [io 0xf080-0xf087]
[ 0.264704] pci 0000:00:13.0: [8086:0f23] type 00 class 0x010601
[ 0.264728] pci 0000:00:13.0: reg 10: [io 0xf070-0xf077]
[ 0.264740] pci 0000:00:13.0: reg 14: [io 0xf060-0xf063]
[ 0.264752] pci 0000:00:13.0: reg 18: [io 0xf050-0xf057]
[ 0.264763] pci 0000:00:13.0: reg 1c: [io 0xf040-0xf043]
[ 0.264775] pci 0000:00:13.0: reg 20: [io 0xf020-0xf03f]
[ 0.264787] pci 0000:00:13.0: reg 24: [mem 0xd0816000-0xd08167ff]
[ 0.264827] pci 0000:00:13.0: PME# supported from D3hot
[ 0.264854] pci 0000:00:14.0: [8086:0f35] type 00 class 0x0c0330
[ 0.264877] pci 0000:00:14.0: reg 10: [mem 0xd0800000-0xd080ffff 64bit]
[ 0.264933] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.264969] pci 0000:00:1a.0: [8086:0f18] type 00 class 0x108000
[ 0.264999] pci 0000:00:1a.0: reg 10: [mem 0xd0500000-0xd05fffff]
[ 0.265015] pci 0000:00:1a.0: reg 14: [mem 0xd0400000-0xd04fffff]
[ 0.265113] pci 0000:00:1a.0: PME# supported from D0 D3hot
[ 0.265144] pci 0000:00:1b.0: [8086:0f04] type 00 class 0x040300
[ 0.265171] pci 0000:00:1b.0: reg 10: [mem 0xd0810000-0xd0813fff 64bit]
[ 0.265238] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[ 0.265263] pci 0000:00:1c.0: [8086:0f48] type 01 class 0x060400
[ 0.265320] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.265347] pci 0000:00:1c.1: [8086:0f4a] type 01 class 0x060400
[ 0.265403] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.265430] pci 0000:00:1c.2: [8086:0f4c] type 01 class 0x060400
[ 0.265486] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.265512] pci 0000:00:1c.3: [8086:0f4e] type 01 class 0x060400
[ 0.265567] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.265608] pci 0000:00:1d.0: [8086:0f34] type 00 class 0x0c0320
[ 0.265640] pci 0000:00:1d.0: reg 10: [mem 0xd0815000-0xd08153ff]
[ 0.265747] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[ 0.265778] pci 0000:00:1f.0: [8086:0f1c] type 00 class 0x060100
[ 0.265878] pci 0000:00:1f.3: [8086:0f12] type 00 class 0x0c0500
[ 0.265916] pci 0000:00:1f.3: reg 10: [mem 0xd0814000-0xd081401f]
[ 0.265993] pci 0000:00:1f.3: reg 20: [io 0xf000-0xf01f]
[ 0.266139] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 0.266159] pci 0000:01:00.0: reg 10: [io 0xe000-0xe0ff]
[ 0.266191] pci 0000:01:00.0: reg 18: [mem 0xd0704000-0xd0704fff 64bit]
[ 0.266212] pci 0000:01:00.0: reg 20: [mem 0xd0700000-0xd0703fff 64bit pref]
[ 0.266265] pci 0000:01:00.0: supports D1 D2
[ 0.266269] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.273095] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.273102] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.273108] pci 0000:00:1c.0: bridge window [mem 0xd0700000-0xd07fffff]
[ 0.273153] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 0.273222] pci 0000:03:00.0: [8086:244e] type 01 class 0x060401
[ 0.273335] pci 0000:03:00.0: supports D1 D2
[ 0.273339] pci 0000:03:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.273367] pci 0000:00:1c.2: PCI bridge to [bus 03-04]
[ 0.273375] pci 0000:00:1c.2: bridge window [mem 0xd0600000-0xd06fffff]
[ 0.273454] pci 0000:04:00.0: [2718:5125] type 00 class 0x110000
[ 0.273482] pci 0000:04:00.0: reg 10: [mem 0xd0600000-0xd060ffff]
[ 0.273667] pci 0000:03:00.0: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.273684] pci 0000:03:00.0: bridge window [mem 0xd0600000-0xd06fffff]
[ 0.273697] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.273701] pci 0000:03:00.0: bridge window [mem 0xd0600000-0xd06fffff] (subtractive decode)
[ 0.273706] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.273710] pci 0000:03:00.0: bridge window [??? 0x00000000 flags 0x0] (subtractive decode)
[ 0.273763] pci 0000:00:1c.3: PCI bridge to [bus 05-05]
[ 0.273789] pci_bus 0000:00: on NUMA node 0
[ 0.273795] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.274211] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[ 0.274321] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP02._PRT]
[ 0.274430] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP03._PRT]
[ 0.274539] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP04._PRT]
[ 0.274779] \_SB_.PCI0:_OSC invalid UUID
[ 0.274783] _OSC request data:1 f 0
[ 0.274792] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.287774] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.287903] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.288026] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.288150] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[ 0.288272] ACPI: PCI Interrupt Link [LNKE] (IRQs *3 4 5 6 10 11 12 14 15)
[ 0.288396] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[ 0.288522] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.288645] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[ 0.288789] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.288803] vgaarb: loaded
[ 0.288806] vgaarb: bridge control possible 0000:00:02.0
[ 0.288852] PCI: Using ACPI for IRQ routing
[ 0.295004] PCI: pci_cache_line_size set to 64 bytes
[ 0.295086] reserve RAM buffer: 000000000008d800 - 000000000008ffff
[ 0.295091] reserve RAM buffer: 0000000079730000 - 000000007bffffff
[ 0.295095] reserve RAM buffer: 0000000079ba1000 - 000000007bffffff
[ 0.295099] reserve RAM buffer: 0000000079d53000 - 000000007bffffff
[ 0.295103] reserve RAM buffer: 000000007a000000 - 000000007bffffff
[ 0.295304] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.295314] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.297341] Switching to clocksource hpet
[ 0.297433] pnp: PnP ACPI init
[ 0.297450] ACPI: bus type pnp registered
[ 0.297480] pnp 00:00: [io 0x0070-0x0077]
[ 0.297521] pnp 00:00: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.297581] pnp 00:01: [mem 0xfed00000-0xfed003ff]
[ 0.297587] pnp 00:01: IRQ 8 override to edge, high
[ 0.297599] pnp 00:01: [irq 8]
[ 0.297635] pnp 00:01: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.297921] pnp 00:02: [bus 00-ff]
[ 0.297926] pnp 00:02: [io 0x0070-0x0077]
[ 0.297930] pnp 00:02: [io 0x0cf8-0x0cff]
[ 0.297934] pnp 00:02: [io 0x0000-0x006f window]
[ 0.297938] pnp 00:02: [io 0x0078-0x0cf7 window]
[ 0.297942] pnp 00:02: [io 0x0d00-0xffff window]
[ 0.297946] pnp 00:02: [mem 0x000a0000-0x000bffff window]
[ 0.297951] pnp 00:02: [mem 0x000c0000-0x000dffff window]
[ 0.297955] pnp 00:02: [mem 0x000e0000-0x000fffff window]
[ 0.297959] pnp 00:02: [mem 0x00000000 window]
[ 0.297963] pnp 00:02: [mem 0x00000000-0xffffffff window]
[ 0.297967] pnp 00:02: [mem 0x80000000-0xd0816ffe window]
[ 0.298039] pnp 00:02: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.298170] pnp 00:03: [mem 0xff000000-0xffffffff]
[ 0.298215] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[ 0.298242] pnp 00:04: [io 0x002e-0x002f]
[ 0.298246] pnp 00:04: [io 0x004e-0x004f]
[ 0.298250] pnp 00:04: [io 0x0061]
[ 0.298254] pnp 00:04: [io 0x0063]
[ 0.298257] pnp 00:04: [io 0x0065]
[ 0.298260] pnp 00:04: [io 0x0067]
[ 0.298264] pnp 00:04: [io 0x0070]
[ 0.298268] pnp 00:04: [io 0x0080-0x008f]
[ 0.298271] pnp 00:04: [io 0x0092]
[ 0.298275] pnp 00:04: [io 0x00b2-0x00b3]
[ 0.298278] pnp 00:04: [io 0x0680-0x069f]
[ 0.298282] pnp 00:04: [io 0x0400-0x047f]
[ 0.298286] pnp 00:04: [io 0x0500-0x05fe]
[ 0.298289] pnp 00:04: [io 0x0600-0x061f]
[ 0.298293] pnp 00:04: [io 0x164e-0x164f]
[ 0.298360] system 00:04: [io 0x0680-0x069f] has been reserved
[ 0.298365] system 00:04: [io 0x0400-0x047f] has been reserved
[ 0.298370] system 00:04: [io 0x0500-0x05fe] has been reserved
[ 0.298376] system 00:04: [io 0x0600-0x061f] has been reserved
[ 0.298381] system 00:04: [io 0x164e-0x164f] has been reserved
[ 0.298386] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.298669] pnp 00:05: [io 0x0000-0xffffffff disabled]
[ 0.298674] pnp 00:05: [io 0x0a00-0x0a2f]
[ 0.298678] pnp 00:05: [io 0x0a30-0x0a3f]
[ 0.298681] pnp 00:05: [io 0x0a40-0x0a4f]
[ 0.298745] system 00:05: [io 0x0a00-0x0a2f] has been reserved
[ 0.298750] system 00:05: [io 0x0a30-0x0a3f] has been reserved
[ 0.298755] system 00:05: [io 0x0a40-0x0a4f] has been reserved
[ 0.298761] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.299413] pnp 00:06: [io 0x03f8-0x03ff]
[ 0.299423] pnp 00:06: [irq 4]
[ 0.299427] pnp 00:06: [dma 0 disabled]
[ 0.299529] pnp 00:06: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.299564] pnp 00:07: [io 0x0060]
[ 0.299568] pnp 00:07: [io 0x0064]
[ 0.299577] pnp 00:07: [irq 1]
[ 0.299641] pnp 00:07: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.299707] pnp 00:08: [irq 12]
[ 0.299772] pnp 00:08: Plug and Play ACPI device, IDs PNP0f13 (active)
[ 0.300647] pnp 00:09: [io 0x0378-0x037f]
[ 0.300656] pnp 00:09: [irq 5]
[ 0.300661] pnp 00:09: [dma 0 disabled]
[ 0.300976] pnp 00:09: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.301457] pnp 00:0a: [mem 0xe0000000-0xefffffff]
[ 0.301462] pnp 00:0a: [mem 0xfed01000-0xfed01fff]
[ 0.301466] pnp 00:0a: [mem 0xfed03000-0xfed03fff]
[ 0.301470] pnp 00:0a: [mem 0xfed04000-0xfed04fff]
[ 0.301474] pnp 00:0a: [mem 0xfed0c000-0xfed0ffff]
[ 0.301478] pnp 00:0a: [mem 0xfed08000-0xfed08fff]
[ 0.301482] pnp 00:0a: [mem 0xfed1c000-0xfed1cfff]
[ 0.301485] pnp 00:0a: [mem 0xfee00000-0xfeefffff]
[ 0.301489] pnp 00:0a: [mem 0xfef00000-0xfeffffff]
[ 0.301577] system 00:0a: [mem 0xe0000000-0xefffffff] could not be reserved
[ 0.301583] system 00:0a: [mem 0xfed01000-0xfed01fff] has been reserved
[ 0.301588] system 00:0a: [mem 0xfed03000-0xfed03fff] has been reserved
[ 0.301593] system 00:0a: [mem 0xfed04000-0xfed04fff] has been reserved
[ 0.301598] system 00:0a: [mem 0xfed0c000-0xfed0ffff] has been reserved
[ 0.301603] system 00:0a: [mem 0xfed08000-0xfed08fff] has been reserved
[ 0.301608] system 00:0a: [mem 0xfed1c000-0xfed1cfff] has been reserved
[ 0.301613] system 00:0a: [mem 0xfee00000-0xfeefffff] has been reserved
[ 0.301618] system 00:0a: [mem 0xfef00000-0xfeffffff] has been reserved
[ 0.301624] system 00:0a: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.303684] pnp: PnP ACPI: found 11 devices
[ 0.303688] ACPI: ACPI bus type pnp unregistered
[ 0.303692] PnPBIOS: Disabled by ACPI PNP
[ 0.342151] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 01-01] add_size 200000
[ 0.342163] pci 0000:00:1c.1: bridge window [io 0x1000-0x0fff] to [bus 02-02] add_size 1000
[ 0.342169] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 02-02] add_size 200000
[ 0.342174] pci 0000:00:1c.1: bridge window [mem 0x00100000-0x000fffff] to [bus 02-02] add_size 200000
[ 0.342199] pci 0000:00:1c.2: bridge window [io 0x1000-0x0fff] to [bus 03-04] add_size 1000
[ 0.342204] pci 0000:00:1c.2: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-04] add_size 200000
[ 0.342215] pci 0000:00:1c.3: bridge window [io 0x1000-0x0fff] to [bus 05-05] add_size 1000
[ 0.342220] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 05-05] add_size 200000
[ 0.342226] pci 0000:00:1c.3: bridge window [mem 0x00100000-0x000fffff] to [bus 05-05] add_size 200000
[ 0.342241] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.342246] pci 0000:00:1c.1: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.342251] pci 0000:00:1c.1: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.342256] pci 0000:00:1c.2: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.342261] pci 0000:00:1c.3: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.342266] pci 0000:00:1c.3: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.342270] pci 0000:00:1c.1: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.342275] pci 0000:00:1c.2: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.342279] pci 0000:00:1c.3: res[13]=[io 0x1000-0x0fff] get_res_add_size add_size 1000
[ 0.342288] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80000000-0x801fffff 64bit pref]
[ 0.342293] pci 0000:00:1c.1: BAR 14: assigned [mem 0x80200000-0x803fffff]
[ 0.342299] pci 0000:00:1c.1: BAR 15: assigned [mem 0x80400000-0x805fffff 64bit pref]
[ 0.342305] pci 0000:00:1c.2: BAR 15: assigned [mem 0x80600000-0x807fffff 64bit pref]
[ 0.342310] pci 0000:00:1c.3: BAR 14: assigned [mem 0x80800000-0x809fffff]
[ 0.342316] pci 0000:00:1c.3: BAR 15: assigned [mem 0x80a00000-0x80bfffff 64bit pref]
[ 0.342322] pci 0000:00:1c.1: BAR 13: assigned [io 0x2000-0x2fff]
[ 0.342327] pci 0000:00:1c.2: BAR 13: assigned [io 0x3000-0x3fff]
[ 0.342332] pci 0000:00:1c.3: BAR 13: assigned [io 0x4000-0x4fff]
[ 0.342341] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[ 0.342346] pci 0000:00:1c.0: bridge window [io 0xe000-0xefff]
[ 0.342353] pci 0000:00:1c.0: bridge window [mem 0xd0700000-0xd07fffff]
[ 0.342360] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff 64bit pref]
[ 0.342367] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 0.342372] pci 0000:00:1c.1: bridge window [io 0x2000-0x2fff]
[ 0.342379] pci 0000:00:1c.1: bridge window [mem 0x80200000-0x803fffff]
[ 0.342385] pci 0000:00:1c.1: bridge window [mem 0x80400000-0x805fffff 64bit pref]
[ 0.342393] pci 0000:03:00.0: PCI bridge to [bus 04-04]
[ 0.342403] pci 0000:03:00.0: bridge window [mem 0xd0600000-0xd06fffff]
[ 0.342420] pci 0000:00:1c.2: PCI bridge to [bus 03-04]
[ 0.342424] pci 0000:00:1c.2: bridge window [io 0x3000-0x3fff]
[ 0.342431] pci 0000:00:1c.2: bridge window [mem 0xd0600000-0xd06fffff]
[ 0.342437] pci 0000:00:1c.2: bridge window [mem 0x80600000-0x807fffff 64bit pref]
[ 0.342444] pci 0000:00:1c.3: PCI bridge to [bus 05-05]
[ 0.342449] pci 0000:00:1c.3: bridge window [io 0x4000-0x4fff]
[ 0.342456] pci 0000:00:1c.3: bridge window [mem 0x80800000-0x809fffff]
[ 0.342462] pci 0000:00:1c.3: bridge window [mem 0x80a00000-0x80bfffff 64bit pref]
[ 0.342525] pci 0000:03:00.0: setting latency timer to 64
[ 0.342543] pci_bus 0000:00: resource 4 [io 0x0000-0x006f]
[ 0.342547] pci_bus 0000:00: resource 5 [io 0x0078-0x0cf7]
[ 0.342551] pci_bus 0000:00: resource 6 [io 0x0d00-0xffff]
[ 0.342555] pci_bus 0000:00: resource 7 [mem 0x000a0000-0x000bffff]
[ 0.342560] pci_bus 0000:00: resource 8 [mem 0x000c0000-0x000dffff]
[ 0.342564] pci_bus 0000:00: resource 9 [mem 0x000e0000-0x000fffff]
[ 0.342568] pci_bus 0000:00: resource 10 [mem 0x80000000-0xd0816ffe]
[ 0.342572] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.342576] pci_bus 0000:01: resource 1 [mem 0xd0700000-0xd07fffff]
[ 0.342580] pci_bus 0000:01: resource 2 [mem 0x80000000-0x801fffff 64bit pref]
[ 0.342585] pci_bus 0000:02: resource 0 [io 0x2000-0x2fff]
[ 0.342589] pci_bus 0000:02: resource 1 [mem 0x80200000-0x803fffff]
[ 0.342593] pci_bus 0000:02: resource 2 [mem 0x80400000-0x805fffff 64bit pref]
[ 0.342597] pci_bus 0000:03: resource 0 [io 0x3000-0x3fff]
[ 0.342601] pci_bus 0000:03: resource 1 [mem 0xd0600000-0xd06fffff]
[ 0.342605] pci_bus 0000:03: resource 2 [mem 0x80600000-0x807fffff 64bit pref]
[ 0.342610] pci_bus 0000:04: resource 1 [mem 0xd0600000-0xd06fffff]
[ 0.342614] pci_bus 0000:04: resource 4 [io 0x3000-0x3fff]
[ 0.342618] pci_bus 0000:04: resource 5 [mem 0xd0600000-0xd06fffff]
[ 0.342622] pci_bus 0000:04: resource 6 [mem 0x80600000-0x807fffff 64bit pref]
[ 0.342626] pci_bus 0000:05: resource 0 [io 0x4000-0x4fff]
[ 0.342630] pci_bus 0000:05: resource 1 [mem 0x80800000-0x809fffff]
[ 0.342635] pci_bus 0000:05: resource 2 [mem 0x80a00000-0x80bfffff 64bit pref]
[ 0.342741] NET: Registered protocol family 2
[ 0.342832] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.343067] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.343576] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.343831] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.343835] TCP: reno registered
[ 0.343841] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.343851] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.343995] NET: Registered protocol family 1
[ 0.344022] pci 0000:00:02.0: Boot video device
[ 1.938557] pci 0000:00:1d.0: EHCI: BIOS handoff failed (BIOS bug?) 01010001
[ 1.938597] PCI: CLS 64 bytes, default 64
[ 1.938675] Unpacking initramfs...
[ 2.295958] Freeing initrd memory: 14260k freed
[ 2.302361] audit: initializing netlink socket (disabled)
[ 2.302384] type=2000 audit(1453099674.196:1): initialized
[ 2.315373] highmem bounce pool size: 64 pages
[ 2.315381] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 2.315678] VFS: Disk quotas dquot_6.5.2
[ 2.315717] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.315820] msgmni has been set to 1721
[ 2.316065] alg: No test for stdrng (krng)
[ 2.316110] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 2.316115] io scheduler noop registered
[ 2.316119] io scheduler deadline registered
[ 2.316148] io scheduler cfq registered (default)
[ 2.316417] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 2.316446] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 2.316449] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 2.317409] GHES: HEST is not enabled!
[ 2.317427] isapnp: Scanning for PnP cards...
[ 2.671661] isapnp: No Plug & Play device found
[ 2.671739] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.692262] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.713220] 00:06: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 2.713666] Linux agpgart interface v0.103
[ 2.713905] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 2.714372] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 2.714419] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 2.714574] mousedev: PS/2 mouse device common for all mice
[ 2.714673] rtc_cmos 00:00: RTC can wake from S4
[ 2.714825] rtc_cmos 00:00: rtc core: registered rtc_cmos as rtc0
[ 2.714856] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[ 2.715037] TCP: cubic registered
[ 2.715118] NET: Registered protocol family 10
[ 2.715413] Mobile IPv6
[ 2.715418] NET: Registered protocol family 17
[ 2.715425] Registering the dns_resolver key type
[ 2.715490] Using IPI No-Shortcut mode
[ 2.715657] PM: Hibernation image not present or could not be loaded.
[ 2.715678] registered taskstats version 1
[ 2.716212] rtc_cmos 00:00: setting system clock to 2016-01-18 06:47:55 UTC (1453099675)
[ 2.716395] Freeing unused kernel memory: 416k freed
[ 2.716605] Write protecting the kernel text: 3496k
[ 2.716634] Write protecting the kernel read-only data: 984k
[ 2.732420] udevd[49]: starting version 175
[ 2.733827] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 2.755578] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[ 2.755928] r8169 0000:01:00.0: eth0: RTL8168evl/8111evl at 0xf8014000, 74:d4:35:e4:d8:03, XID 0c900800 IRQ 16
[ 2.755934] r8169 0000:01:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[ 2.760206] usbcore: registered new interface driver usbfs
[ 2.760241] usbcore: registered new interface driver hub
[ 2.775195] usbcore: registered new device driver usb
[ 2.775914] SCSI subsystem initialized
[ 2.792214] xhci_hcd 0000:00:14.0: setting latency timer to 64
[ 2.792221] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.792255] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[ 2.792652] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[ 2.792720] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.792724] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.792729] usb usb1: Product: xHCI Host Controller
[ 2.792732] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 2.792736] usb usb1: SerialNumber: 0000:00:14.0
[ 2.793039] xHCI xhci_add_endpoint called for root hub
[ 2.793044] xHCI xhci_check_bandwidth called for root hub
[ 2.793195] hub 1-0:1.0: USB hub found
[ 2.793207] hub 1-0:1.0: 6 ports detected
[ 2.793328] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 2.793340] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[ 2.793374] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 2.793378] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.793382] usb usb2: Product: xHCI Host Controller
[ 2.793386] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[ 2.793390] usb usb2: SerialNumber: 0000:00:14.0
[ 2.793508] xHCI xhci_add_endpoint called for root hub
[ 2.793513] xHCI xhci_check_bandwidth called for root hub
[ 2.793563] hub 2-0:1.0: USB hub found
[ 2.793572] hub 2-0:1.0: 1 port detected
[ 2.794973] microcode: CPU0 sig=0x30673, pf=0x4, revision=0x31e
[ 2.796729] libata version 3.00 loaded.
[ 2.798098] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.825502] ahci 0000:00:13.0: version 3.0
[ 2.829363] ACPI: Fan [FAN0] (off)
[ 2.841089] ahci 0000:00:13.0: AHCI 0001.0300 32 slots 2 ports 3 Gbps 0x2 impl SATA mode
[ 2.841097] ahci 0000:00:13.0: flags: 64bit ncq pm led clo pio slum part
[ 2.841104] ahci 0000:00:13.0: setting latency timer to 64
[ 2.844974] scsi0 : ahci
[ 2.849289] scsi1 : ahci
[ 2.849387] ata1: DUMMY
[ 2.849393] ata2: SATA max UDMA/133 abar m2048@0xd0816000 port 0xd0816180 irq 19
[ 2.849499] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[ 2.849506] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[ 2.849524] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 3
[ 2.849563] ehci_hcd 0000:00:1d.0: debug port 2
[ 2.853461] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[ 2.853492] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xd0815000
[ 2.859730] microcode: CPU1 sig=0x30673, pf=0x4, revision=0x31e
[ 2.862745] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 2.865031] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[ 2.865075] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.865080] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.865085] usb usb3: Product: EHCI Host Controller
[ 2.865088] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 2.865092] usb usb3: SerialNumber: 0000:00:1d.0
[ 2.865279] hub 3-0:1.0: USB hub found
[ 2.865289] hub 3-0:1.0: 8 ports detected
[ 3.176446] usb 3-1: new high-speed USB device number 2 using ehci_hcd
[ 3.176454] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.193074] ata2.00: ATA-8: KINGSTON SV300S37A120G, 603ABBF0, max UDMA/133
[ 3.193080] ata2.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[ 3.198513] ata2.00: configured for UDMA/133
[ 3.198692] scsi 1:0:0:0: Direct-Access ATA KINGSTON SV300S3 603A PQ: 0 ANSI: 5
[ 3.203705] sd 1:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/111 GiB)
[ 3.203865] sd 1:0:0:0: [sda] Write Protect is off
[ 3.203871] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.203921] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 3.204678] sda: sda1 sda2 < sda5 >
[ 3.205285] sd 1:0:0:0: [sda] Attached SCSI disk
[ 3.207785] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 3.296230] Refined TSC clocksource calibration: 2416.666 MHz.
[ 3.296239] Switching to clocksource tsc
[ 3.308525] usb 3-1: New USB device found, idVendor=8087, idProduct=07e6
[ 3.308530] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.308820] hub 3-1:1.0: USB hub found
[ 3.308894] hub 3-1:1.0: 4 ports detected
[ 3.579817] usb 3-1.1: new low-speed USB device number 3 using ehci_hcd
[ 3.676023] usb 3-1.1: New USB device found, idVendor=15d9, idProduct=0a4c
[ 3.676028] usb 3-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 3.676032] usb 3-1.1: Product: USB OPTICAL MOUSE
[ 3.682076] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.1/3-1.1:1.0/input/input1
[ 3.682214] generic-usb 0003:15D9:0A4C.0001: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.0-1.1/input0
[ 3.682249] usbcore: registered new interface driver usbhid
[ 3.682253] usbhid: USB HID core driver
[ 8.365327] PM: Starting manual resume from disk
[ 8.365334] PM: Hibernation image partition 8:5 present
[ 8.365337] PM: Looking for hibernation image.
[ 8.365574] PM: Image not found (code -22)
[ 8.365579] PM: Hibernation image not present or could not be loaded.
[ 8.387207] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.615578] udevd[345]: starting version 175
[ 8.708822] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[ 8.708833] ACPI: Power Button [PWRB]
[ 8.708911] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input3
[ 8.708917] ACPI: Sleep Button [SLPB]
[ 8.708993] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[ 8.708999] ACPI: Power Button [PWRF]
[ 8.761252] parport_pc 00:09: reported by Plug and Play ACPI
[ 8.761314] parport0: PC-style at 0x378, irq 5 [PCSPP,TRISTATE]
[ 8.822492] snd_hda_intel 0000:00:1b.0: setting latency timer to 64
[ 8.900218] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input5
[ 8.937456] input: HDA Intel Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input6
[ 8.937665] input: HDA Intel Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[ 8.937855] input: HDA Intel Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[ 8.938050] input: HDA Intel Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[ 8.938245] input: HDA Intel Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[ 9.296833] Adding 3977212k swap on /dev/sda5. Priority:-1 extents:1 across:3977212k SS
[ 9.315845] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 9.358470] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 9.395047] loop: module loaded
[ 10.269119] RPC: Registered named UNIX socket transport module.
[ 10.269124] RPC: Registered udp transport module.
[ 10.269128] RPC: Registered tcp transport module.
[ 10.269131] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 10.274922] FS-Cache: Loaded
[ 10.281778] NFS: Registering the id_resolver key type
[ 10.281813] FS-Cache: Netfs 'nfs' registered for caching
[ 10.287443] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 11.133471] Bluetooth: Core ver 2.16
[ 11.133498] NET: Registered protocol family 31
[ 11.133502] Bluetooth: HCI device and connection manager initialized
[ 11.133506] Bluetooth: HCI socket layer initialized
[ 11.133510] Bluetooth: L2CAP socket layer initialized
[ 11.133519] Bluetooth: SCO socket layer initialized
[ 11.150269] Bluetooth: RFCOMM TTY layer initialized
[ 11.150279] Bluetooth: RFCOMM socket layer initialized
[ 11.150283] Bluetooth: RFCOMM ver 1.11
[ 11.151275] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 11.151280] Bluetooth: BNEP filters: protocol multicast
[ 11.435905] lp0: using parport0 (interrupt-driven).
[ 11.445167] ppdev: user-space parallel port driver
[ 11.818996] r8169 0000:01:00.0: eth0: link down
[ 11.819242] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.819565] r8169 0000:01:00.0: eth0: link down
[ 11.820320] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input11
[ 13.444422] r8169 0000:01:00.0: eth0: link up
[ 13.444573] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 23.793137] eth0: no IPv6 routers present
[ 34.732695] I-pipe: head domain RTAI registered.
[ 34.732957] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 34.733009] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 34.733014] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 2416671000, CPU_FREQ 2416671000
[ 34.733018] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 34.733024] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 5038000
[ 34.748647] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 34.748694] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 34.748701] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists.
[ 34.748706] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416671000 hz.
[ 34.748710] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 34.761149] RTAI[math]: loaded.
[ 34.946075] hm2: loading Mesa HostMot2 driver version 0.15
[ 34.949968] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 34.950014] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 34.950760] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 35.007799] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 35.010856] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 35.013381] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 35.017898] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 35.023519] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 35.124154] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 35.126806] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 35.227977] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 35.227984] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 35.227988] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 35.227991] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 35.227996] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 35.228001] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 35.228006] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 35.228011] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 35.228016] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 35.228020] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 35.228025] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 35.228029] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 35.228034] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 35.228038] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 35.228043] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 35.228047] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 35.228051] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 35.228054] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 35.228058] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 35.228062] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 35.228065] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 35.228069] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 35.228073] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 35.228076] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 35.228080] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 35.228084] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 35.228087] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 35.228091] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 35.228095] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 35.228098] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 35.228102] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 35.228106] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 35.228109] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 35.228113] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 35.228117] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 35.228280] hm2/hm2_5i25.0: registered
[ 35.228285] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 35.615728] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 35.615736] hm2/hm2_5i25.0: unregistered
[ 35.615815] hm2_pci: driver unloaded
[ 35.618357] hm2: unloading
[ 37.760889] RTAI[math]: unloaded.
[ 37.763445] SCHED releases registered named ALIEN PEDV$D
[ 37.770637] RTAI[malloc]: unloaded.
[ 37.869044] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 37.871348] I-pipe: head domain RTAI unregistered.
[ 37.871404] RTAI[hal]: unmounted.
[ 726.352239] hub 3-1:1.0: port 1 disabled by hub (EMI?), re-enabling...
[ 726.352248] usb 3-1.1: USB disconnect, device number 3
[ 726.577987] usb 3-1.1: new low-speed USB device number 4 using ehci_hcd
[ 726.674065] usb 3-1.1: New USB device found, idVendor=15d9, idProduct=0a4c
[ 726.674071] usb 3-1.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 726.674075] usb 3-1.1: Product: USB OPTICAL MOUSE
[ 726.676524] input: USB OPTICAL MOUSE as /devices/pci0000:00/0000:00:1d.0/usb3/3-1/3-1.1/3-1.1:1.0/input/input12
[ 726.676738] generic-usb 0003:15D9:0A4C.0002: input,hidraw0: USB HID v1.11 Mouse [ USB OPTICAL MOUSE] on usb-0000:00:1d.0-1.1/input0
[ 3238.341561] I-pipe: head domain RTAI registered.
[ 3238.341571] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 3238.341615] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 3238.341620] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 2416671000, CPU_FREQ 2416671000
[ 3238.341625] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 3238.341629] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 5189250
[ 3238.350185] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 3238.350234] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 3238.350241] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists.
[ 3238.350247] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416671000 hz.
[ 3238.350250] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 3238.363862] RTAI[math]: loaded.
[ 3238.514634] hm2: loading Mesa HostMot2 driver version 0.15
[ 3238.517086] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 3238.517132] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 3238.517853] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 3238.575055] Board hm2_5i25.0.7i77.0.0 Hardware Mode 0 = standard
[ 3238.578001] Board hm2_5i25.0.7i77.0.0 Software Mode 0 = input_output
[ 3238.580577] Board hm2_5i25.0.7i77.0.0 Software Mode 1 = io_analog
[ 3238.585042] Board hm2_5i25.0.7i77.0.0 Software Mode 2 = io_analog_fieldvoltage
[ 3238.590664] Board hm2_5i25.0.7i77.0.0 Software Mode 3 = io_encoder_analog_fieldvoltage
[ 3238.691166] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 3238.693811] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 3238.794665] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 3238.794671] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 3238.794675] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 3238.794678] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 3238.794683] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 3238.794688] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 3238.794693] hm2/hm2_5i25.0: IO Pin 005 (P3-16): Smart Serial Interface #0, pin TxData0 (Output)
[ 3238.794698] hm2/hm2_5i25.0: IO Pin 006 (P3-04): Smart Serial Interface #0, pin RxData0 (Input)
[ 3238.794703] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 3238.794707] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 3238.794712] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 3238.794716] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 3238.794721] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 3238.794725] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 3238.794729] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 3238.794734] hm2/hm2_5i25.0: IO Pin 014 (P3-11): IOPort
[ 3238.794737] hm2/hm2_5i25.0: IO Pin 015 (P3-12): IOPort
[ 3238.794741] hm2/hm2_5i25.0: IO Pin 016 (P3-13): IOPort
[ 3238.794745] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 3238.794748] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 3238.794752] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 3238.794755] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 3238.794759] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 3238.794763] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 3238.794766] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 3238.794770] hm2/hm2_5i25.0: IO Pin 024 (P2-17): IOPort
[ 3238.794774] hm2/hm2_5i25.0: IO Pin 025 (P2-05): IOPort
[ 3238.794777] hm2/hm2_5i25.0: IO Pin 026 (P2-06): IOPort
[ 3238.794781] hm2/hm2_5i25.0: IO Pin 027 (P2-07): IOPort
[ 3238.794785] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 3238.794788] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 3238.794792] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 3238.794795] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 3238.794799] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 3238.794803] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 3238.794952] hm2/hm2_5i25.0: registered
[ 3238.794956] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 3239.148372] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 3239.148380] hm2/hm2_5i25.0: unregistered
[ 3239.148457] hm2_pci: driver unloaded
[ 3239.150827] hm2: unloading
[ 3241.283350] RTAI[math]: unloaded.
[ 3241.285919] SCHED releases registered named ALIEN PEDV$D
[ 3241.293202] RTAI[malloc]: unloaded.
[ 3241.392094] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 3241.394422] I-pipe: head domain RTAI unregistered.
[ 3241.394477] RTAI[hal]: unmounted.
[ 7246.585314] I-pipe: head domain RTAI registered.
[ 7246.585322] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 7246.585367] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 7246.585372] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 5207894, CLK_FREQ 2416671000, CPU_FREQ 2416671000
[ 7246.585377] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 7246.585381] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 5207894, 5207894, 4705000
[ 7246.593927] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 7246.593975] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 7246.593982] RTAI[sched]: hard timer type/freq = APIC/5207894(Hz); default timing: oneshot; linear timed lists.
[ 7246.593988] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2416671000 hz.
[ 7246.593991] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 7246.600615] RTAI[math]: loaded.
[ 7246.751571] hm2: loading Mesa HostMot2 driver version 0.15
[ 7246.753949] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[ 7246.753996] hm2_pci: discovered 5i25 at 0000:04:00.0
[ 7246.755391] hm2/hm2_5i25.0: Smart Serial Firmware Version 43
[ 7246.811852] Board hm2_5i25.0.7i77.0.1 Hardware Mode 0 = standard
[ 7246.814498] Board hm2_5i25.0.7i77.0.1 Software Mode 0 = analogout_enables
[ 7246.915009] hm2/hm2_5i25.0: 34 I/O Pins used:
[ 7246.915015] hm2/hm2_5i25.0: IO Pin 000 (P3-01): IOPort
[ 7246.915019] hm2/hm2_5i25.0: IO Pin 001 (P3-14): IOPort
[ 7246.915023] hm2/hm2_5i25.0: IO Pin 002 (P3-02): IOPort
[ 7246.915028] hm2/hm2_5i25.0: IO Pin 003 (P3-15): Smart Serial Interface #0, pin TxData1 (Output)
[ 7246.915033] hm2/hm2_5i25.0: IO Pin 004 (P3-03): Smart Serial Interface #0, pin RxData1 (Input)
[ 7246.915037] hm2/hm2_5i25.0: IO Pin 005 (P3-16): IOPort
[ 7246.915041] hm2/hm2_5i25.0: IO Pin 006 (P3-04): IOPort
[ 7246.915045] hm2/hm2_5i25.0: IO Pin 007 (P3-17): Muxed Encoder Select #0, pin Mux Select 0 (Output)
[ 7246.915050] hm2/hm2_5i25.0: IO Pin 008 (P3-05): Muxed Encoder #0, pin Muxed A (Input)
[ 7246.915054] hm2/hm2_5i25.0: IO Pin 009 (P3-06): Muxed Encoder #0, pin Muxed B (Input)
[ 7246.915059] hm2/hm2_5i25.0: IO Pin 010 (P3-07): Muxed Encoder #0, pin Muxed Index (Input)
[ 7246.915063] hm2/hm2_5i25.0: IO Pin 011 (P3-08): Muxed Encoder #1, pin Muxed A (Input)
[ 7246.915068] hm2/hm2_5i25.0: IO Pin 012 (P3-09): Muxed Encoder #1, pin Muxed B (Input)
[ 7246.915072] hm2/hm2_5i25.0: IO Pin 013 (P3-10): Muxed Encoder #1, pin Muxed Index (Input)
[ 7246.915077] hm2/hm2_5i25.0: IO Pin 014 (P3-11): Muxed Encoder #2, pin Muxed A (Input)
[ 7246.915081] hm2/hm2_5i25.0: IO Pin 015 (P3-12): Muxed Encoder #2, pin Muxed B (Input)
[ 7246.915086] hm2/hm2_5i25.0: IO Pin 016 (P3-13): Muxed Encoder #2, pin Muxed Index (Input)
[ 7246.915090] hm2/hm2_5i25.0: IO Pin 017 (P2-01): IOPort
[ 7246.915094] hm2/hm2_5i25.0: IO Pin 018 (P2-14): IOPort
[ 7246.915097] hm2/hm2_5i25.0: IO Pin 019 (P2-02): IOPort
[ 7246.915101] hm2/hm2_5i25.0: IO Pin 020 (P2-15): IOPort
[ 7246.915105] hm2/hm2_5i25.0: IO Pin 021 (P2-03): IOPort
[ 7246.915108] hm2/hm2_5i25.0: IO Pin 022 (P2-16): IOPort
[ 7246.915112] hm2/hm2_5i25.0: IO Pin 023 (P2-04): IOPort
[ 7246.915116] hm2/hm2_5i25.0: IO Pin 024 (P2-17): Muxed Encoder Select #6, pin Mux Select 0 (Output)
[ 7246.915121] hm2/hm2_5i25.0: IO Pin 025 (P2-05): Muxed Encoder #3, pin Muxed A (Input)
[ 7246.915125] hm2/hm2_5i25.0: IO Pin 026 (P2-06): Muxed Encoder #3, pin Muxed B (Input)
[ 7246.915130] hm2/hm2_5i25.0: IO Pin 027 (P2-07): Muxed Encoder #3, pin Muxed Index (Input)
[ 7246.915134] hm2/hm2_5i25.0: IO Pin 028 (P2-08): IOPort
[ 7246.915137] hm2/hm2_5i25.0: IO Pin 029 (P2-09): IOPort
[ 7246.915141] hm2/hm2_5i25.0: IO Pin 030 (P2-10): IOPort
[ 7246.915146] hm2/hm2_5i25.0: IO Pin 031 (P2-11): IOPort
[ 7246.915150] hm2/hm2_5i25.0: IO Pin 032 (P2-12): IOPort
[ 7246.915153] hm2/hm2_5i25.0: IO Pin 033 (P2-13): IOPort
[ 7246.915300] hm2/hm2_5i25.0: registered
[ 7246.915304] hm2_5i25.0: initialized AnyIO board at 0000:04:00.0
[ 7247.264107] hm2_5i25.0: dropping AnyIO board at 0000:04:00.0
[ 7247.264116] hm2/hm2_5i25.0: unregistered
[ 7247.264193] hm2_pci: driver unloaded
[ 7247.266783] hm2: unloading
[ 7249.398720] RTAI[math]: unloaded.
[ 7249.401018] SCHED releases registered named ALIEN PEDV$D
[ 7249.409137] RTAI[malloc]: unloaded.
[ 7249.505578] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 7249.507937] I-pipe: head domain RTAI unregistered.
[ 7249.507992] RTAI[hal]: unmounted.
но вот так то всё работает:vovafed писал(а):сейчас проверил без включеной 7i77 ошибка таже
возможно еще не в тот разьем 5i25 втыкаюсь
в p2 нет пока возможности воткнутся надо паять
В новых версиях функция hm2_5i25.0.pet_watchdog выполняется во время hm2_5i25.0.write или read.vovafed писал(а):HAL: ERROR: function 'hm2_5i25.0.pet_watchdog' not found
./hm2-servo7i77.hal:64: addf failed
