Nick писал(а):Что конкретно говорит? скопируй сюда в тэг code.
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.3
Machine configuration directory is '/home/gena/emc2/configs/мой-станок'
Machine configuration file is 'мой-станок.ini'
INIFILE=/home/gena/emc2/configs/мой-станок/мой-станок.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=mini
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=6660
Cleanup done
Debug file information:
HAL: ERROR: thread 'servothread' not found
мой-станок.hal:117: addf failed
6660
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 9416.280931] I-pipe: Domain RTAI registered.
[ 9416.280940] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[ 9416.280943] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[ 9416.280988] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 9416.280992] PIPELINE layers:
[ 9416.280996] fcf35e20 9ac15d93 RTAI 200
[ 9416.280999] c085cb20 0 Linux 100
[ 9416.305935] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 9416.306095] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[ 9416.306104] RTAI[sched]: hard timer type/freq = APIC/12499938(Hz); default timing: periodic; linear timed lists.
[ 9416.306109] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1599981000 hz.
[ 9416.306112] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 9416.306206] RTAI[usi]: enabled.
[ 9416.376299] RTAI[math]: loaded.
[ 9416.447976] config string '0x378 out '
[ 9417.056055] RTAI[math]: unloaded.
[ 9417.100859] SCHED releases registered named ALIEN RTGLBH
[ 9417.136391] RTAI[malloc]: unloaded.
[ 9417.232151] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 9417.236432] I-pipe: Domain RTAI unregistered.
[ 9417.236480] RTAI[hal]: unmounted.
