Re: [WIKI] Ручная смена инструмента с автоизмерением длины.
Добавлено: 10 фев 2018, 19:29
может в -c gladevcp дело(в обоих вкладках не прописано)
Статьи, обзоры, цены на станки и комплектующие.
https://cnc-club.ru/forum/
Надо подправить в .ini в строках 26-32 такMGG писал(а):Во вложении все хал и ини
GLADEVCP = -u spindle-vfd.py spindle-vfd-panel.glade
EMBED_TAB_NAME=Auto Tool Measurement
EMBED_TAB_COMMAND=gladevcp -u python/auto_tool_measurement.py -x {XID} auto_tool_measurement.glade
EMBED_TAB_NAME=Probe Screen
EMBED_TAB_COMMAND=gladevcp -u python/probe_screen.py -x {XID} probe_icons/probe_screen.glade
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.8
Machine configuration directory is '/home/mgg/linuxcnc/configs/my-conf_1'
Machine configuration file is 'my.ini'
INIFILE=/home/mgg/linuxcnc/configs/my-conf_1/my.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Found file(REL): ./my.hal
Found file(REL): ./custom.hal
Starting TASK program: milltask
Starting DISPLAY program: axis
**** probe_screen GETINIINFO ****
Preference file path: /home/mgg/linuxcnc/configs/my-conf_1/to_pci.pref
Xlib.protocol.request.QueryExtension
**** auto_tool_measurement GETINIINFO ****
gladevcp: trouble looking for handlers in 'auto_tool_measurement': Недопустимый аргумент
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=3792
Killing task milltask, PID=3841
task: 294 cycles, min=0.000019, max=0.021316, avg=0.009485, 0 latency excursions (> 10x expected cycle time of 0.010000s)
spindle-vfd: device='/dev/ttyUSB0', baud=19200, bits=8, parity='none', stopbits=1, slave=1, verbose=0, debug=0
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
/usr/bin/gladevcp:185: GtkWarning: GtkSpinButton: setting an adjustment with non-zero page size is deprecated
builder.add_from_file(xmlname)
HAL: ERROR: duplicate component name 'auto_tool_measurement'
File "/usr/bin/gladevcp", line 122, in load_handlers
objlist = h(halcomp,builder,useropts)
File "python/auto_tool_measurement.py", line 407, in get_handlers
return [HandlerClass(halcomp,builder,useropts)]
File "python/auto_tool_measurement.py", line 345, in __init__
self.halcomp = hal.component("auto_tool_measurement")
error: Недопустимый аргумент
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_tool_number_value_changed'
builder.connect_signals(handlers)
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_manual_change'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_set_z'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_set_y'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_set_x'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_touch_off_z_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_touch_off_y_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_touch_off_x_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_probe_workpiece'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_block_height_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_probe_vel_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_search_vel_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'clicked_btn_probe_tool_setter'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_spbtn_probe_height_value_changed'
/usr/bin/gladevcp:212: RuntimeWarning: missing handler 'on_chk_use_tool_measurement_toggled'
/usr/bin/gladevcp:295: GtkWarning: gtk_widget_size_allocate(): attempt to allocate widget with width -5 and height 15
gtk.main()
custom_postgui.hal:28: Pin 'auto_tool_measurement.toolchange-change' does not exist
File "/usr/bin/gladevcp", line 309, in <module>
main()
File "/usr/bin/gladevcp", line 219, in main
window = xembed.reparent(window, opts.parent)
File "/usr/lib/pymodules/python2.7/gladevcp/xembed.py", line 28, in reparent
w.map()
File "/usr/lib/pymodules/python2.7/Xlib/xobject/drawable.py", line 386, in map
window = self.id)
File "/usr/lib/pymodules/python2.7/Xlib/protocol/rq.py", line 1408, in __init__
/usr/bin/gladevcp:295: GtkWarning: GdkWindow 0x3e00003 unexpectedly destroyed
gtk.main()
display.send_request(self, onerror is not None)
File "/usr/lib/pymodules/python2.7/Xlib/protocol/display.py", line 313, in send_request
**** GLADE VCP ERROR: X Protocol Error: 3
self.request_queue_lock.release()
KeyboardInterrupt
3792
PID TTY STAT TIME COMMAND
3841
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f800 (usable)
[ 0.000000] BIOS-e820: 000000000009f800 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000009fee0000 (usable)
[ 0.000000] BIOS-e820: 000000009fee0000 - 000000009fee3000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000009fee3000 - 000000009fef0000 (ACPI data)
[ 0.000000] BIOS-e820: 000000009fef0000 - 000000009ff00000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[ 0.000000] SMBIOS 2.3 present.
[ 0.000000] DMI: System manufacturer System Product Name/P5VD2-MX, BIOS ASUS P5VD2-MX ACPI BIOS Revision 0401 06/16/2006
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x9fee0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CCFFF write-protect
[ 0.000000] CD000-FFFFF uncachable
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 base 080000000 mask FE0000000 write-back
[ 0.000000] 2 base 0C0000000 mask FF8000000 write-combining
[ 0.000000] 3 base 09FF00000 mask FFFF00000 uncachable
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00f5920] f5920
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36528000 - 3728c000
[ 0.000000] ACPI: RSDP 000f7810 00014 (v00 AWARD )
[ 0.000000] ACPI: RSDT 9fee3040 00030 (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: FACP 9fee30c0 00074 (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: DSDT 9fee3180 07137 (v01 AWARD AWRDACPI 00001000 MSFT 0100000E)
[ 0.000000] ACPI: FACS 9fee0000 00040
[ 0.000000] ACPI: MCFG 9feea400 0003C (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: APIC 9feea300 00090 (v01 AWARD AWRDACPI 42302E31 AWRD 00000000)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] 1670MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0009fee0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0009fee0
[ 0.000000] On node 0 totalpages: 654959
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5128200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 3342 pages used for memmap
[ 0.000000] HighMem zone: 424404 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x408
[ 0.000000] ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x03] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x04] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 4, version 3, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: IOAPIC (id[0x05] address[0xfecc0000] gsi_base[24])
[ 0.000000] IOAPIC[1]: apic_id 5, version 3, address 0xfecc0000, GSI 24-47
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 64
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 9ff00000 (gap: 9ff00000:40100000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77ad000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 649841
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=685f2945-ac33-4dc3-8e1f-e7b1b0a54ffd ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 5240448 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0009fee0)
[ 0.000000] Memory: 2573540k/2620288k available (3495k kernel code, 46296k reserved, 1237k data, 416k init, 1710984k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:1024 16
[ 0.000000] CPU 0 irqstacks, hard=f4806000 soft=f4808000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1861.829 MHz processor.
[ 0.008003] Calibrating delay loop (skipped), value calculated using timer frequency.. 3723.65 BogoMIPS (lpj=7447316)
[ 0.008008] pid_max: default: 32768 minimum: 301
[ 0.008065] Security Framework initialized
[ 0.008071] AppArmor: AppArmor disabled by boot time parameter
[ 0.008094] Mount-cache hash table entries: 512
[ 0.008365] Initializing cgroup subsys cpuacct
[ 0.008368] Initializing cgroup subsys memory
[ 0.008378] Initializing cgroup subsys devices
[ 0.008381] Initializing cgroup subsys freezer
[ 0.008384] Initializing cgroup subsys net_cls
[ 0.008386] Initializing cgroup subsys blkio
[ 0.008395] Initializing cgroup subsys perf_event
[ 0.008429] CPU: Physical Processor ID: 0
[ 0.008431] CPU: Processor Core ID: 0
[ 0.008434] mce: CPU supports 6 MCE banks
[ 0.008442] CPU0: Thermal monitoring enabled (TM1)
[ 0.008505] ACPI: Core revision 20120320
[ 0.019177] Enabling APIC mode: Flat. Using 2 I/O APICs
[ 0.020711] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.060411] CPU0: Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz stepping 06
[ 0.064003] Performance Events: PEBS fmt0-, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.064003] PEBS disabled due to CPU errata.
[ 0.064003] ... version: 2
[ 0.064003] ... bit width: 40
[ 0.064003] ... generic registers: 2
[ 0.064003] ... value mask: 000000ffffffffff
[ 0.064003] ... max period: 000000007fffffff
[ 0.064003] ... fixed-purpose events: 3
[ 0.064003] ... event mask: 0000000700000003
[ 0.072066] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.084027] CPU 1 irqstacks, hard=f48d4000 soft=f48d6000
[ 0.084030] Booting Node 0, Processors #1
[ 0.012000] Initializing CPU#1
[ 0.096049] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.096105] Brought up 2 CPUs
[ 0.096108] Total of 2 processors activated (7447.31 BogoMIPS).
[ 0.097539] devtmpfs: initialized
[ 0.097539] PM: Registering ACPI NVS region [mem 0x9fee0000-0x9fee2fff] (12288 bytes)
[ 0.097539] dummy:
[ 0.097539] NET: Registered protocol family 16
[ 0.097539] ACPI: bus type pci registered
[ 0.097539] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.097539] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.097539] PCI: Using MMCONFIG for extended config space
[ 0.097539] PCI: Using configuration type 1 for base access
[ 0.097539] mtrr: your CPUs had inconsistent fixed MTRR settings
[ 0.097539] mtrr: probably your BIOS does not setup all CPUs.
[ 0.097539] mtrr: corrected configuration.
[ 0.100424] bio: create slab <bio-0> at 0
[ 0.100424] ACPI: Added _OSI(Module Device)
[ 0.100424] ACPI: Added _OSI(Processor Device)
[ 0.100424] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.100424] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.102796] ACPI: EC: Look up EC in DSDT
[ 0.116544] ACPI: Interpreter enabled
[ 0.116563] ACPI: (supports S0 S1 S3 S4 S5)
[ 0.116606] ACPI: Using IOAPIC for interrupt routing
[ 0.126082] ACPI: No dock devices found.
[ 0.126092] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.126181] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.126310] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.126315] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.126318] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.126322] pci_root PNP0A08:00: host bridge window [mem 0x000c0000-0x000dffff] (ignored)
[ 0.126326] pci_root PNP0A08:00: host bridge window [mem 0x9ff00000-0xfebfffff] (ignored)
[ 0.126330] PCI: root bus 00: using default resources
[ 0.126386] PCI host bridge to bus 0000:00
[ 0.126389] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.126393] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.126415] pci 0000:00:00.0: [1106:0327] type 00 class 0x060000
[ 0.126430] pci 0000:00:00.0: reg 10: [mem 0xc0000000-0xc7ffffff pref]
[ 0.126519] pci 0000:00:00.1: [1106:1327] type 00 class 0x060000
[ 0.126587] pci 0000:00:00.2: [1106:2327] type 00 class 0x060000
[ 0.126654] pci 0000:00:00.3: [1106:3327] type 00 class 0x060000
[ 0.126719] pci 0000:00:00.4: [1106:4327] type 00 class 0x060000
[ 0.126786] pci 0000:00:00.5: [1106:5327] type 00 class 0x080020
[ 0.126882] pci 0000:00:00.6: [1106:6327] type 00 class 0x060000
[ 0.126948] pci 0000:00:00.7: [1106:7327] type 00 class 0x060000
[ 0.127016] pci 0000:00:01.0: [1106:b198] type 01 class 0x060400
[ 0.127092] pci 0000:00:02.0: [1106:a327] type 01 class 0x060400
[ 0.127173] pci 0000:00:02.0: PME# supported from D0 D3hot D3cold
[ 0.127213] pci 0000:00:03.0: [1106:c327] type 01 class 0x060400
[ 0.127306] pci 0000:00:03.0: PME# supported from D0 D3hot D3cold
[ 0.127375] pci 0000:00:0f.0: [1106:0591] type 00 class 0x01018f
[ 0.127398] pci 0000:00:0f.0: reg 10: [io 0xfc00-0xfc07]
[ 0.127412] pci 0000:00:0f.0: reg 14: [io 0xf800-0xf803]
[ 0.127425] pci 0000:00:0f.0: reg 18: [io 0xf400-0xf407]
[ 0.127438] pci 0000:00:0f.0: reg 1c: [io 0xf000-0xf003]
[ 0.127451] pci 0000:00:0f.0: reg 20: [io 0xec00-0xec0f]
[ 0.127465] pci 0000:00:0f.0: reg 24: [io 0xe800-0xe8ff]
[ 0.127520] pci 0000:00:0f.1: [1106:0571] type 00 class 0x01018a
[ 0.127582] pci 0000:00:0f.1: reg 20: [io 0xe400-0xe40f]
[ 0.127657] pci 0000:00:10.0: [1106:3038] type 00 class 0x0c0300
[ 0.127718] pci 0000:00:10.0: reg 20: [io 0xe000-0xe01f]
[ 0.127762] pci 0000:00:10.0: supports D1 D2
[ 0.127765] pci 0000:00:10.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.127789] pci 0000:00:10.1: [1106:3038] type 00 class 0x0c0300
[ 0.127850] pci 0000:00:10.1: reg 20: [io 0xdc00-0xdc1f]
[ 0.127893] pci 0000:00:10.1: supports D1 D2
[ 0.127896] pci 0000:00:10.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.127921] pci 0000:00:10.2: [1106:3038] type 00 class 0x0c0300
[ 0.127982] pci 0000:00:10.2: reg 20: [io 0xd800-0xd81f]
[ 0.128037] pci 0000:00:10.2: supports D1 D2
[ 0.128040] pci 0000:00:10.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.128064] pci 0000:00:10.3: [1106:3038] type 00 class 0x0c0300
[ 0.128125] pci 0000:00:10.3: reg 20: [io 0xd400-0xd41f]
[ 0.128169] pci 0000:00:10.3: supports D1 D2
[ 0.128172] pci 0000:00:10.3: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.128197] pci 0000:00:10.4: [1106:3104] type 00 class 0x0c0320
[ 0.128219] pci 0000:00:10.4: reg 10: [mem 0xdffff000-0xdffff0ff]
[ 0.128301] pci 0000:00:10.4: supports D1 D2
[ 0.128304] pci 0000:00:10.4: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.128334] pci 0000:00:11.0: [1106:3337] type 00 class 0x060100
[ 0.128466] pci 0000:00:11.7: [1106:287e] type 00 class 0x060000
[ 0.128544] pci 0000:00:12.0: [1106:3065] type 00 class 0x020000
[ 0.128566] pci 0000:00:12.0: reg 10: [io 0xd000-0xd0ff]
[ 0.128579] pci 0000:00:12.0: reg 14: [mem 0xdfffe000-0xdfffe0ff]
[ 0.128653] pci 0000:00:12.0: supports D1 D2
[ 0.128656] pci 0000:00:12.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.128683] pci 0000:00:13.0: [1106:337b] type 01 class 0x060400
[ 0.128776] pci 0000:00:13.1: [1106:337a] type 01 class 0x060401
[ 0.128955] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.129043] pci 0000:02:00.0: [10de:0de1] type 00 class 0x030000
[ 0.129060] pci 0000:02:00.0: reg 10: [mem 0xdd000000-0xddffffff]
[ 0.129078] pci 0000:02:00.0: reg 14: [mem 0xc8000000-0xcfffffff 64bit pref]
[ 0.129096] pci 0000:02:00.0: reg 1c: [mem 0xd6000000-0xd7ffffff 64bit pref]
[ 0.129108] pci 0000:02:00.0: reg 24: [io 0xcc00-0xcc7f]
[ 0.129121] pci 0000:02:00.0: reg 30: [mem 0xdef00000-0xdef7ffff pref]
[ 0.129193] pci 0000:02:00.1: [10de:0bea] type 00 class 0x040300
[ 0.129210] pci 0000:02:00.1: reg 10: [mem 0xdeffc000-0xdeffffff]
[ 0.136031] pci 0000:00:02.0: PCI bridge to [bus 02-02]
[ 0.136037] pci 0000:00:02.0: bridge window [io 0xc000-0xcfff]
[ 0.136043] pci 0000:00:02.0: bridge window [mem 0xdd000000-0xdeffffff]
[ 0.136051] pci 0000:00:02.0: bridge window [mem 0xc8000000-0xd7ffffff 64bit pref]
[ 0.136145] pci 0000:03:00.0: [197b:2363] type 00 class 0x010185
[ 0.136242] pci 0000:03:00.0: reg 24: [mem 0xdfefe000-0xdfefffff]
[ 0.136259] pci 0000:03:00.0: reg 30: [mem 0xdfee0000-0xdfeeffff pref]
[ 0.136295] pci 0000:03:00.0: PME# supported from D3hot
[ 0.136331] pci 0000:03:00.1: [197b:2363] type 00 class 0x010185
[ 0.136358] pci 0000:03:00.1: reg 10: [io 0xbc00-0xbc07]
[ 0.136374] pci 0000:03:00.1: reg 14: [io 0xb800-0xb803]
[ 0.136390] pci 0000:03:00.1: reg 18: [io 0xb400-0xb407]
[ 0.136406] pci 0000:03:00.1: reg 1c: [io 0xb000-0xb003]
[ 0.136422] pci 0000:03:00.1: reg 20: [io 0xac00-0xac0f]
[ 0.136500] pci 0000:03:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.136516] pci 0000:00:03.0: PCI bridge to [bus 03-03]
[ 0.136522] pci 0000:00:03.0: bridge window [io 0xa000-0xbfff]
[ 0.136528] pci 0000:00:03.0: bridge window [mem 0xdfe00000-0xdfefffff]
[ 0.136594] pci 0000:04:01.0: [1106:3288] type 00 class 0x040300
[ 0.136616] pci 0000:04:01.0: reg 10: [mem 0xdfdfc000-0xdfdfffff 64bit]
[ 0.136690] pci 0000:04:01.0: PME# supported from D0 D3hot D3cold
[ 0.136708] pci 0000:04:01.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.136758] pci 0000:00:13.0: PCI bridge to [bus 04-04]
[ 0.136767] pci 0000:00:13.0: bridge window [mem 0xdfd00000-0xdfdfffff]
[ 0.136825] pci 0000:05:04.0: [2105:5555] type 00 class 0x110000
[ 0.136841] pci 0000:05:04.0: reg 10: [mem 0xdfcff000-0xdfcff01f]
[ 0.136953] pci 0000:00:13.1: PCI bridge to [bus 05-05] (subtractive decode)
[ 0.136962] pci 0000:00:13.1: bridge window [mem 0xdfc00000-0xdfcfffff]
[ 0.136970] pci 0000:00:13.1: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.136974] pci 0000:00:13.1: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.137006] pci_bus 0000:00: on NUMA node 0
[ 0.137010] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.137569] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEXG._PRT]
[ 0.137715] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PEX0._PRT]
[ 0.137859] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2PE._PRT]
[ 0.137991] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P2PB._PRT]
[ 0.138152] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[ 0.196225] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 *10 11 12)
[ 0.196377] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 10 11 12) *5
[ 0.196534] ACPI: PCI Interrupt Link [LNKC] (IRQs *3 4 6 7 10 11 12)
[ 0.196688] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 *11 12)
[ 0.196802] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.196912] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.197022] ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 6 7 10 11 12) *0, disabled.
[ 0.197153] ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 6 7 10 *11 12)
[ 0.197232] vgaarb: device added: PCI:0000:02:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.197232] vgaarb: loaded
[ 0.197232] vgaarb: bridge control possible 0000:02:00.0
[ 0.197232] PCI: Using ACPI for IRQ routing
[ 0.207755] PCI: pci_cache_line_size set to 64 bytes
[ 0.207904] reserve RAM buffer: 000000000009f800 - 000000000009ffff
[ 0.207908] reserve RAM buffer: 000000009fee0000 - 000000009fffffff
[ 0.208207] pnp: PnP ACPI init
[ 0.208225] ACPI: bus type pnp registered
[ 0.208344] pnp 00:00: [bus 00-ff]
[ 0.208348] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.208352] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.208355] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.208359] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.208362] pnp 00:00: [mem 0x000c0000-0x000dffff window]
[ 0.208365] pnp 00:00: [mem 0x9ff00000-0xfebfffff window]
[ 0.208435] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.208468] pnp 00:01: [io 0x0400-0x047f]
[ 0.208471] pnp 00:01: [io 0x0500-0x050f]
[ 0.208538] system 00:01: [io 0x0400-0x047f] has been reserved
[ 0.208542] system 00:01: [io 0x0500-0x050f] has been reserved
[ 0.208547] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.209313] pnp 00:02: [mem 0x10000000-0x10000fff]
[ 0.209402] system 00:02: [mem 0x10000000-0x10000fff] could not be reserved
[ 0.209407] system 00:02: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.209764] pnp 00:03: [io 0x0010-0x001f]
[ 0.209767] pnp 00:03: [io 0x0022-0x003f]
[ 0.209770] pnp 00:03: [io 0x0044-0x005f]
[ 0.209773] pnp 00:03: [io 0x0062-0x0063]
[ 0.209776] pnp 00:03: [io 0x0065-0x006f]
[ 0.209779] pnp 00:03: [io 0x0074-0x007f]
[ 0.209782] pnp 00:03: [io 0x0091-0x0093]
[ 0.209785] pnp 00:03: [io 0x00a2-0x00bf]
[ 0.209787] pnp 00:03: [io 0x00e0-0x00ef]
[ 0.209790] pnp 00:03: [io 0x04d0-0x04d1]
[ 0.209793] pnp 00:03: [io 0x0290-0x029f]
[ 0.209796] pnp 00:03: [io 0x0800-0x0805]
[ 0.209799] pnp 00:03: [io 0x0880-0x088f]
[ 0.209902] system 00:03: [io 0x04d0-0x04d1] has been reserved
[ 0.209906] system 00:03: [io 0x0290-0x029f] has been reserved
[ 0.209910] system 00:03: [io 0x0800-0x0805] has been reserved
[ 0.209914] system 00:03: [io 0x0880-0x088f] has been reserved
[ 0.209919] system 00:03: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.209942] pnp 00:04: [dma 4]
[ 0.209945] pnp 00:04: [io 0x0000-0x000f]
[ 0.209948] pnp 00:04: [io 0x0080-0x0090]
[ 0.209951] pnp 00:04: [io 0x0094-0x009f]
[ 0.209954] pnp 00:04: [io 0x00c0-0x00df]
[ 0.210014] pnp 00:04: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.210033] pnp 00:05: [io 0x0070-0x0073]
[ 0.210045] pnp 00:05: [irq 8]
[ 0.210108] pnp 00:05: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.210123] pnp 00:06: [io 0x0061]
[ 0.210184] pnp 00:06: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.210201] pnp 00:07: [io 0x00f0-0x00ff]
[ 0.210209] pnp 00:07: [irq 13]
[ 0.210271] pnp 00:07: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.210485] pnp 00:08: [io 0x03f0-0x03f5]
[ 0.210488] pnp 00:08: [io 0x03f7]
[ 0.210495] pnp 00:08: [irq 6]
[ 0.210498] pnp 00:08: [dma 2]
[ 0.210579] pnp 00:08: Plug and Play ACPI device, IDs PNP0700 (active)
[ 0.210860] pnp 00:09: [io 0x03f8-0x03ff]
[ 0.210868] pnp 00:09: [irq 4]
[ 0.210968] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[ 0.211607] pnp 00:0a: [io 0x0378-0x037f]
[ 0.211611] pnp 00:0a: [io 0x0778-0x077b]
[ 0.211618] pnp 00:0a: [irq 7]
[ 0.211621] pnp 00:0a: [dma 3]
[ 0.211720] pnp 00:0a: Plug and Play ACPI device, IDs PNP0401 (active)
[ 0.211809] pnp 00:0b: [io 0x0060]
[ 0.211812] pnp 00:0b: [io 0x0064]
[ 0.211819] pnp 00:0b: [irq 12]
[ 0.211893] pnp 00:0b: Plug and Play ACPI device, IDs PNP0f13 (active)
[ 0.211993] pnp 00:0c: [mem 0xe0000000-0xefffffff]
[ 0.212104] system 00:0c: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.212109] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.212322] pnp 00:0d: [mem 0x000d2800-0x000d3fff]
[ 0.212326] pnp 00:0d: [mem 0x000f0000-0x000f7fff]
[ 0.212329] pnp 00:0d: [mem 0x000f8000-0x000fbfff]
[ 0.212332] pnp 00:0d: [mem 0x000fc000-0x000fffff]
[ 0.212336] pnp 00:0d: [mem 0x9fee0000-0x9fefffff]
[ 0.212339] pnp 00:0d: [mem 0xffff0000-0xffffffff]
[ 0.212342] pnp 00:0d: [mem 0x00000000-0x0009ffff]
[ 0.212345] pnp 00:0d: [mem 0x00100000-0x9fedffff]
[ 0.212348] pnp 00:0d: [mem 0xfec00000-0xfec00fff]
[ 0.212353] pnp 00:0d: [mem 0xfee00000-0xfee00fff]
[ 0.212356] pnp 00:0d: [mem 0xfff80000-0xfffeffff]
[ 0.212465] system 00:0d: [mem 0x000d2800-0x000d3fff] has been reserved
[ 0.212471] system 00:0d: [mem 0x000f0000-0x000f7fff] could not be reserved
[ 0.212475] system 00:0d: [mem 0x000f8000-0x000fbfff] could not be reserved
[ 0.212479] system 00:0d: [mem 0x000fc000-0x000fffff] could not be reserved
[ 0.212484] system 00:0d: [mem 0x9fee0000-0x9fefffff] could not be reserved
[ 0.212488] system 00:0d: [mem 0xffff0000-0xffffffff] has been reserved
[ 0.212492] system 00:0d: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.212496] system 00:0d: [mem 0x00100000-0x9fedffff] could not be reserved
[ 0.212500] system 00:0d: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.212504] system 00:0d: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.212508] system 00:0d: [mem 0xfff80000-0xfffeffff] has been reserved
[ 0.212513] system 00:0d: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.212527] pnp: PnP ACPI: found 14 devices
[ 0.212530] ACPI: ACPI bus type pnp unregistered
[ 0.212534] PnPBIOS: Disabled by ACPI PNP
[ 0.249617] Switching to clocksource acpi_pm
[ 0.249685] pci 0000:00:03.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 0.249710] pci 0000:00:03.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.249717] pci 0000:00:03.0: BAR 15: assigned [mem 0xa0000000-0xa01fffff 64bit pref]
[ 0.249721] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.249736] pci 0000:00:02.0: PCI bridge to [bus 02-02]
[ 0.249741] pci 0000:00:02.0: bridge window [io 0xc000-0xcfff]
[ 0.249748] pci 0000:00:02.0: bridge window [mem 0xdd000000-0xdeffffff]
[ 0.249754] pci 0000:00:02.0: bridge window [mem 0xc8000000-0xd7ffffff 64bit pref]
[ 0.249762] pci 0000:00:03.0: PCI bridge to [bus 03-03]
[ 0.249767] pci 0000:00:03.0: bridge window [io 0xa000-0xbfff]
[ 0.249774] pci 0000:00:03.0: bridge window [mem 0xdfe00000-0xdfefffff]
[ 0.249781] pci 0000:00:03.0: bridge window [mem 0xa0000000-0xa01fffff 64bit pref]
[ 0.249790] pci 0000:00:13.0: PCI bridge to [bus 04-04]
[ 0.249797] pci 0000:00:13.0: bridge window [mem 0xdfd00000-0xdfdfffff]
[ 0.249808] pci 0000:00:13.1: PCI bridge to [bus 05-05]
[ 0.249814] pci 0000:00:13.1: bridge window [mem 0xdfc00000-0xdfcfffff]
[ 0.249835] pci 0000:00:01.0: setting latency timer to 64
[ 0.249874] pci 0000:00:13.0: setting latency timer to 64
[ 0.249885] pci 0000:00:13.1: setting latency timer to 64
[ 0.249890] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.249893] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.249897] pci_bus 0000:02: resource 0 [io 0xc000-0xcfff]
[ 0.249900] pci_bus 0000:02: resource 1 [mem 0xdd000000-0xdeffffff]
[ 0.249903] pci_bus 0000:02: resource 2 [mem 0xc8000000-0xd7ffffff 64bit pref]
[ 0.249907] pci_bus 0000:03: resource 0 [io 0xa000-0xbfff]
[ 0.249910] pci_bus 0000:03: resource 1 [mem 0xdfe00000-0xdfefffff]
[ 0.249914] pci_bus 0000:03: resource 2 [mem 0xa0000000-0xa01fffff 64bit pref]
[ 0.249917] pci_bus 0000:04: resource 1 [mem 0xdfd00000-0xdfdfffff]
[ 0.249921] pci_bus 0000:05: resource 1 [mem 0xdfc00000-0xdfcfffff]
[ 0.249924] pci_bus 0000:05: resource 4 [io 0x0000-0xffff]
[ 0.249927] pci_bus 0000:05: resource 5 [mem 0x00000000-0xffffffff]
[ 0.250027] NET: Registered protocol family 2
[ 0.250111] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.250339] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.250851] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.251176] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.251179] TCP: reno registered
[ 0.251183] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.251193] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.251311] NET: Registered protocol family 1
[ 0.251357] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.251595] pci 0000:02:00.0: Boot video device
[ 0.251616] PCI: CLS 32 bytes, default 64
[ 0.251691] Unpacking initramfs...
[ 0.609638] Freeing initrd memory: 13712k freed
[ 0.617844] audit: initializing netlink socket (disabled)
[ 0.617879] type=2000 audit(1518338099.616:1): initialized
[ 0.632532] highmem bounce pool size: 64 pages
[ 0.632539] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.632801] VFS: Disk quotas dquot_6.5.2
[ 0.632838] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.632942] msgmni has been set to 1711
[ 0.633180] alg: No test for stdrng (krng)
[ 0.633217] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.633222] io scheduler noop registered
[ 0.633225] io scheduler deadline registered
[ 0.633249] io scheduler cfq registered (default)
[ 0.633596] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.633621] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.633624] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.634737] GHES: HEST is not enabled!
[ 0.634754] isapnp: Scanning for PnP cards...
[ 0.988898] isapnp: No Plug & Play device found
[ 0.988967] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 1.009329] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.030115] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.030347] Linux agpgart interface v0.103
[ 1.030507] agpgart: Detected VIA P4M890 chipset
[ 1.036111] agpgart-via 0000:00:00.0: AGP aperture is 128M @ 0xc0000000
[ 1.036248] i8042: PNP: PS/2 Controller [PNP0f13:PS2M] at 0x60,0x64 irq 12
[ 1.036251] i8042: PNP: PS/2 controller doesn't have KBD irq; using default 1
[ 1.036732] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.036750] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.036918] mousedev: PS/2 mouse device common for all mice
[ 1.036968] rtc_cmos 00:05: RTC can wake from S4
[ 1.037173] rtc_cmos 00:05: rtc core: registered rtc_cmos as rtc0
[ 1.037228] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 1.037404] TCP: cubic registered
[ 1.037478] NET: Registered protocol family 10
[ 1.037774] Mobile IPv6
[ 1.037778] NET: Registered protocol family 17
[ 1.037784] Registering the dns_resolver key type
[ 1.037863] Using IPI No-Shortcut mode
[ 1.038010] PM: Hibernation image not present or could not be loaded.
[ 1.038025] registered taskstats version 1
[ 1.038633] rtc_cmos 00:05: setting system clock to 2018-02-11 08:35:00 UTC (1518338100)
[ 1.038742] Freeing unused kernel memory: 416k freed
[ 1.038947] Write protecting the kernel text: 3496k
[ 1.038978] Write protecting the kernel read-only data: 984k
[ 1.053469] udevd[49]: starting version 175
[ 1.081819] usbcore: registered new interface driver usbfs
[ 1.081854] usbcore: registered new interface driver hub
[ 1.093663] usbcore: registered new device driver usb
[ 1.094161] SCSI subsystem initialized
[ 1.094241] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.094344] ehci_hcd 0000:00:10.4: EHCI Host Controller
[ 1.094383] ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 1
[ 1.094466] ehci_hcd 0000:00:10.4: irq 21, io mem 0xdffff000
[ 1.102593] via_rhine: v1.10-LK1.5.0 2010-10-09 Written by Donald Becker
[ 1.104066] ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00
[ 1.104149] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.104153] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.104157] usb usb1: Product: EHCI Host Controller
[ 1.104160] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 1.104163] usb usb1: SerialNumber: 0000:00:10.4
[ 1.105662] hub 1-0:1.0: USB hub found
[ 1.105672] hub 1-0:1.0: 8 ports detected
[ 1.106244] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.106328] uhci_hcd 0000:00:10.0: UHCI Host Controller
[ 1.106345] uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 2
[ 1.106407] uhci_hcd 0000:00:10.0: irq 20, io base 0x0000e000
[ 1.106458] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.106462] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.106465] usb usb2: Product: UHCI Host Controller
[ 1.106468] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.106471] usb usb2: SerialNumber: 0000:00:10.0
[ 1.107829] hub 2-0:1.0: USB hub found
[ 1.107838] hub 2-0:1.0: 2 ports detected
[ 1.107987] uhci_hcd 0000:00:10.1: UHCI Host Controller
[ 1.108065] uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 3
[ 1.108119] uhci_hcd 0000:00:10.1: irq 22, io base 0x0000dc00
[ 1.108163] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.108167] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.108170] usb usb3: Product: UHCI Host Controller
[ 1.108173] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.108176] usb usb3: SerialNumber: 0000:00:10.1
[ 1.109726] hub 3-0:1.0: USB hub found
[ 1.109736] hub 3-0:1.0: 2 ports detected
[ 1.109908] uhci_hcd 0000:00:10.2: UHCI Host Controller
[ 1.109922] uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 4
[ 1.109957] uhci_hcd 0000:00:10.2: irq 21, io base 0x0000d800
[ 1.110012] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.110016] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.110019] usb usb4: Product: UHCI Host Controller
[ 1.110022] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.110025] usb usb4: SerialNumber: 0000:00:10.2
[ 1.111544] hub 4-0:1.0: USB hub found
[ 1.111552] hub 4-0:1.0: 2 ports detected
[ 1.111696] uhci_hcd 0000:00:10.3: UHCI Host Controller
[ 1.111707] uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 5
[ 1.111769] uhci_hcd 0000:00:10.3: irq 23, io base 0x0000d400
[ 1.111814] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 1.111818] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.111821] usb usb5: Product: UHCI Host Controller
[ 1.111824] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 1.111827] usb usb5: SerialNumber: 0000:00:10.3
[ 1.113368] hub 5-0:1.0: USB hub found
[ 1.113376] hub 5-0:1.0: 2 ports detected
[ 1.119351] via-rhine 0000:00:12.0: eth0: VIA Rhine II at 0x1d000, 00:00:00:00:00:10, IRQ 23
[ 1.120774] via-rhine 0000:00:12.0: eth0: MII PHY found at address 1, status 0x7849 advertising 01e1 Link 0000
[ 1.123790] libata version 3.00 loaded.
[ 1.124146] pata_via 0000:00:0f.1: version 0.3.4
[ 1.125875] scsi0 : pata_via
[ 1.127655] microcode: CPU0 sig=0x6f6, pf=0x1, revision=0x0
[ 1.127754] ACPI: Fan [FAN] (on)
[ 1.127782] scsi1 : pata_via
[ 1.130279] ata1: PATA max UDMA/133 cmd 0x1f0 ctl 0x3f6 bmdma 0xe400 irq 14
[ 1.130284] ata2: PATA max UDMA/133 cmd 0x170 ctl 0x376 bmdma 0xe408 irq 15
[ 1.130994] sata_via 0000:00:0f.0: version 2.6
[ 1.131055] sata_via 0000:00:0f.0: routed to hard irq line 11
[ 1.135006] scsi2 : sata_via
[ 1.136441] scsi3 : sata_via
[ 1.139687] ata3: SATA max UDMA/133 cmd 0xfc00 ctl 0xf800 bmdma 0xec00 irq 21
[ 1.139695] ata4: SATA max UDMA/133 cmd 0xf400 ctl 0xf000 bmdma 0xec08 irq 21
[ 1.140364] pata_jmicron 0000:03:00.1: enabling device (0000 -> 0001)
[ 1.140467] pata_jmicron 0000:03:00.1: setting latency timer to 64
[ 1.141126] scsi4 : pata_jmicron
[ 1.142619] scsi5 : pata_jmicron
[ 1.142710] ata5: PATA max UDMA/100 cmd 0xbc00 ctl 0xb800 bmdma 0xac00 irq 29
[ 1.142714] ata6: PATA max UDMA/100 cmd 0xb400 ctl 0xb000 bmdma 0xac08 irq 29
[ 1.144724] Floppy drive(s): fd0 is 1.44M
[ 1.164062] FDC 0 is a post-1991 82077
[ 1.203744] microcode: CPU0 updated to revision 0xd0, date = 2010-09-30
[ 1.203769] microcode: CPU1 sig=0x6f6, pf=0x1, revision=0x0
[ 1.207074] microcode: CPU1 updated to revision 0xd0, date = 2010-09-30
[ 1.207138] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.340025] ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.523877] ata3.00: ATA-7: WDC WD1600AAJS-00PSA0, 05.06H05, max UDMA/133
[ 1.523882] ata3.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.536437] ata3.00: configured for UDMA/133
[ 1.536604] scsi 2:0:0:0: Direct-Access ATA WDC WD1600AAJS-0 05.0 PQ: 0 ANSI: 5
[ 1.616024] Refined TSC clocksource calibration: 1862.000 MHz.
[ 1.616031] Switching to clocksource tsc
[ 1.740014] ata4: SATA link down 1.5 Gbps (SStatus 0 SControl 300)
[ 1.768016] usb 3-1: new full-speed USB device number 2 using uhci_hcd
[ 1.916423] ahci 0000:03:00.0: version 3.0
[ 1.916518] ahci 0000:03:00.0: PCI: Disallowing DAC for device
[ 1.923057] sd 2:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 1.923138] sd 2:0:0:0: [sda] Write Protect is off
[ 1.923143] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.923176] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.932037] ahci 0000:03:00.0: AHCI 0001.0000 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
[ 1.932042] ahci 0000:03:00.0: flags: 64bit ncq pm led clo pmp pio slum part
[ 1.932623] scsi6 : ahci
[ 1.932749] scsi7 : ahci
[ 1.932840] ata7: SATA max UDMA/133 abar m8192@0xdfefe000 port 0xdfefe100 irq 28
[ 1.932845] ata8: SATA max UDMA/133 abar m8192@0xdfefe000 port 0xdfefe180 irq 28
[ 1.941199] usb 3-1: New USB device found, idVendor=046d, idProduct=c52b
[ 1.941203] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 1.941207] usb 3-1: Product: USB Receiver
[ 1.941210] usb 3-1: Manufacturer: Logitech
[ 1.951692] usbcore: registered new interface driver usbhid
[ 1.951696] usbhid: USB HID core driver
[ 1.956903] sda: sda1 sda2 < sda5 >
[ 1.957385] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.962334] logitech-djreceiver 0003:046D:C52B.0003: hiddev0,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:00:10.1-1/input2
[ 1.967283] input: Logitech Unifying Device. Wireless PID:400d as /devices/pci0000:00/0000:00:10.1/usb3/3-1/3-1:1.2/0003:046D:C52B.0003/input/input0
[ 1.967358] logitech-djdevice 0003:046D:C52B.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Unifying Device. Wireless PID:400d] on usb-0000:00:10.1-1:2
[ 2.184014] usb 3-2: new full-speed USB device number 3 using uhci_hcd
[ 2.252031] ata7: SATA link down (SStatus 0 SControl 300)
[ 2.252065] ata8: SATA link down (SStatus 0 SControl 300)
[ 2.256972] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 2.371215] usb 3-2: New USB device found, idVendor=0403, idProduct=6001
[ 2.371221] usb 3-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.371224] usb 3-2: Product: FT232R USB UART
[ 2.371227] usb 3-2: Manufacturer: FTDI
[ 2.371230] usb 3-2: SerialNumber: A9J8TN73
[ 7.623600] PM: Starting manual resume from disk
[ 7.623605] PM: Hibernation image partition 8:5 present
[ 7.623608] PM: Looking for hibernation image.
[ 7.623877] PM: Image not found (code -22)
[ 7.623881] PM: Hibernation image not present or could not be loaded.
[ 7.666652] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.446756] udevd[376]: starting version 175
[ 9.818215] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 9.818225] ACPI: Power Button [PWRB]
[ 9.818303] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input2
[ 9.818309] ACPI: Sleep Button [SLPB]
[ 9.818550] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[ 9.818555] ACPI: Power Button [PWRF]
[ 9.932031] coretemp coretemp.0: Using relative temperature scale!
[ 9.932045] coretemp coretemp.0: Using relative temperature scale!
[ 10.163334] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 10.212216] udevd[436]: renamed network interface eth0 to eth1
[ 10.253031] [drm] Initialized drm 1.1.0 20060810
[ 10.284124] wmi: Mapper loaded
[ 10.329307] parport_pc 00:0a: reported by Plug and Play ACPI
[ 10.329379] parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE]
[ 10.355585] hda_intel: Disabling MSI
[ 10.355639] snd_hda_intel 0000:02:00.1: PCI: Disallowing DAC for device
[ 10.715706] usbcore: registered new interface driver usbserial
[ 10.715732] usbcore: registered new interface driver usbserial_generic
[ 10.715749] USB Serial support registered for generic
[ 10.715769] usbserial: USB Serial Driver core
[ 10.720083] usbcore: registered new interface driver ftdi_sio
[ 10.720114] USB Serial support registered for FTDI USB Serial Device
[ 10.720183] ftdi_sio 3-2:1.0: FTDI USB Serial Device converter detected
[ 10.720220] usb 3-2: Detected FT232RL
[ 10.720223] usb 3-2: Number of endpoints 2
[ 10.720226] usb 3-2: Endpoint 1 MaxPacketSize 64
[ 10.720229] usb 3-2: Endpoint 2 MaxPacketSize 64
[ 10.720232] usb 3-2: Setting MaxPacketSize 64
[ 10.722550] usb 3-2: FTDI USB Serial Device converter now attached to ttyUSB0
[ 10.722569] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[ 10.815665] input: ImPS/2 Generic Wheel Mouse as /devices/platform/i8042/serio1/input/input4
[ 11.316120] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:02.0/0000:02:00.1/sound/card0/input5
[ 11.316234] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:02.0/0000:02:00.1/sound/card0/input6
[ 11.316333] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:02.0/0000:02:00.1/sound/card0/input7
[ 11.316430] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:02.0/0000:02:00.1/sound/card0/input8
[ 11.316995] hda_intel: position_fix set to 1 for device 1043:81b3
[ 11.317076] snd_hda_intel 0000:04:01.0: PCI: Disallowing DAC for device
[ 11.317465] [drm] nouveau 0000:02:00.0: Detected an NVc0 generation card (0x0c1080a1)
[ 11.322683] [drm] nouveau 0000:02:00.0: Checking PRAMIN for VBIOS
[ 11.379511] [drm] nouveau 0000:02:00.0: ... appears to be valid
[ 11.379515] [drm] nouveau 0000:02:00.0: Using VBIOS from PRAMIN
[ 11.379518] [drm] nouveau 0000:02:00.0: BIT BIOS found
[ 11.379522] [drm] nouveau 0000:02:00.0: Bios version 70.08.29.00
[ 11.379527] [drm] nouveau 0000:02:00.0: TMDS table version 2.0
[ 11.379908] [drm] nouveau 0000:02:00.0: MXM: no VBIOS data, nothing to do
[ 11.379912] [drm] nouveau 0000:02:00.0: DCB version 4.0
[ 11.379916] [drm] nouveau 0000:02:00.0: DCB outp 00: 01000302 00020030
[ 11.379920] [drm] nouveau 0000:02:00.0: DCB outp 01: 02000300 00000000
[ 11.379923] [drm] nouveau 0000:02:00.0: DCB outp 02: 08011392 00020020
[ 11.379926] [drm] nouveau 0000:02:00.0: DCB outp 03: 04022310 00000000
[ 11.379929] [drm] nouveau 0000:02:00.0: DCB conn 00: 00001030
[ 11.379934] [drm] nouveau 0000:02:00.0: DCB conn 01: 00002161
[ 11.379937] [drm] nouveau 0000:02:00.0: DCB conn 02: 00000200
[ 11.379943] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 0 at offset 0x6BB6
[ 11.399931] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 1 at offset 0x71FC
[ 11.406933] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 2 at offset 0x8391
[ 11.406937] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 3 at offset 0x8395
[ 11.406982] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table 4 at offset 0x847D
[ 11.406985] [drm] nouveau 0000:02:00.0: Parsing VBIOS init table at offset 0x84E2
[ 11.426832] [drm] nouveau 0000:02:00.0: 0x6B29: Condition still not met after 20ms, skipping following opcodes
[ 11.431647] nouveau 0000:02:00.0: PCI: Disallowing DAC for device
[ 11.431716] [TTM] Zone kernel: Available graphics memory: 438342 kiB
[ 11.431720] [TTM] Zone highmem: Available graphics memory: 1293834 kiB
[ 11.431723] [TTM] Initializing pool allocator
[ 11.431737] [drm] nouveau 0000:02:00.0: Detected 512MiB VRAM (DDR3)
[ 11.433003] [drm] nouveau 0000:02:00.0: 512 MiB GART (aperture)
[ 11.436735] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 11.436739] [drm] No driver support for vblank timestamp query.
[ 11.700490] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:13.0/0000:04:01.0/input/input9
[ 11.760211] [drm] nouveau 0000:02:00.0: 3 available performance level(s)
[ 11.760219] [drm] nouveau 0000:02:00.0: 0: core 50MHz shader 101MHz memory 135MHz voltage 880mV
[ 11.760224] [drm] nouveau 0000:02:00.0: 1: core 405MHz shader 810MHz memory 324MHz voltage 900mV
[ 11.760229] [drm] nouveau 0000:02:00.0: 3: core 700MHz shader 1400MHz memory 700MHz voltage 990mV
[ 11.760234] [drm] nouveau 0000:02:00.0: c: core 405MHz shader 810MHz memory 324MHz voltage 900mV fanspeed 35%
[ 11.900629] [drm] nouveau 0000:02:00.0: allocated 1680x1050 fb: 0x1a0000, bo f6cfec00
[ 11.900740] fbcon: nouveaufb (fb0) is primary device
[ 11.922776] Console: switching to colour frame buffer device 210x65
[ 11.924956] fb0: nouveaufb frame buffer device
[ 11.924958] drm: registered panic notifier
[ 11.924966] [drm] Initialized nouveau 1.0.0 20120316 for 0000:02:00.0 on minor 0
[ 12.851478] Adding 6369276k swap on /dev/sda5. Priority:-1 extents:1 across:6369276k
[ 12.869003] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 13.058902] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 13.165671] loop: module loaded
[ 14.555942] RPC: Registered named UNIX socket transport module.
[ 14.555947] RPC: Registered udp transport module.
[ 14.555950] RPC: Registered tcp transport module.
[ 14.555952] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 14.606068] FS-Cache: Loaded
[ 14.638673] NFS: Registering the id_resolver key type
[ 14.638702] FS-Cache: Netfs 'nfs' registered for caching
[ 14.647727] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 16.624723] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input10
[ 17.792145] Bluetooth: Core ver 2.16
[ 17.792170] NET: Registered protocol family 31
[ 17.792173] Bluetooth: HCI device and connection manager initialized
[ 17.792177] Bluetooth: HCI socket layer initialized
[ 17.792179] Bluetooth: L2CAP socket layer initialized
[ 17.792186] Bluetooth: SCO socket layer initialized
[ 18.192968] Bluetooth: RFCOMM TTY layer initialized
[ 18.192976] Bluetooth: RFCOMM socket layer initialized
[ 18.192978] Bluetooth: RFCOMM ver 1.11
[ 18.707991] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.707995] Bluetooth: BNEP filters: protocol multicast
[ 18.778753] lp0: using parport0 (interrupt-driven).
[ 18.824490] ppdev: user-space parallel port driver
[ 697.120019] usb 1-1: new high-speed USB device number 4 using ehci_hcd
[ 697.256884] usb 1-1: New USB device found, idVendor=0930, idProduct=6545
[ 697.256890] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 697.256894] usb 1-1: Product: DT 101 G2
[ 697.256897] usb 1-1: Manufacturer: Kingston
[ 697.256900] usb 1-1: SerialNumber: 0019E06B70F9ECC0F75C0035
[ 697.319948] Initializing USB Mass Storage driver...
[ 697.320275] scsi8 : usb-storage 1-1:1.0
[ 697.320403] usbcore: registered new interface driver usb-storage
[ 697.320406] USB Mass Storage support registered.
[ 698.402117] scsi 8:0:0:0: Direct-Access Kingston DT 101 G2 PMAP PQ: 0 ANSI: 4
[ 698.402986] sd 8:0:0:0: Attached scsi generic sg1 type 0
[ 699.726684] sd 8:0:0:0: [sdb] 15240576 512-byte logical blocks: (7.80 GB/7.26 GiB)
[ 699.727174] sd 8:0:0:0: [sdb] Write Protect is off
[ 699.727178] sd 8:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 699.727674] sd 8:0:0:0: [sdb] No Caching mode page present
[ 699.727678] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 699.731047] sd 8:0:0:0: [sdb] No Caching mode page present
[ 699.731052] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 699.751372] sdb: sdb1
[ 699.753680] sd 8:0:0:0: [sdb] No Caching mode page present
[ 699.753685] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[ 699.753689] sd 8:0:0:0: [sdb] Attached SCSI removable disk
[ 928.482948] FAT-fs (sdb1): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 990.807126] I-pipe: head domain RTAI registered.
[ 990.807133] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 990.807182] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 990.807186] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16624830, CLK_FREQ 1861829000, CPU_FREQ 1861829000
[ 990.807190] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 990.807194] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16624830, 16624830, 9797250
[ 990.850032] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 990.850073] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 990.850078] RTAI[sched]: hard timer type/freq = APIC/16624830(Hz); default timing: oneshot; linear timed lists.
[ 990.850083] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1861829000 hz.
[ 990.850086] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 990.871314] RTAI[math]: loaded.
[ 991.140628] to_pci: io_base: DFCFF000, mem_base: f812c000
[ 991.141118] to_pci: installed driver for 1 card(s)
[ 991.181005] config string '0x378 in'
[ 991.551360] to_pci: exit
[ 993.710439] RTAI[math]: unloaded.
[ 993.712653] SCHED releases registered named ALIEN PEDV$D
[ 993.718010] RTAI[malloc]: unloaded.
[ 993.816016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 993.818219] I-pipe: head domain RTAI unregistered.
[ 993.818292] RTAI[hal]: unmounted.
[ 1014.931527] I-pipe: head domain RTAI registered.
[ 1014.931535] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1014.931579] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1014.931584] SYSINFO: CPUs 2, LINUX APIC IRQ 2312, TIM_FREQ 16624830, CLK_FREQ 1861829000, CPU_FREQ 1861829000
[ 1014.931588] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1014.931592] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16624830, 16624830, 15418500
[ 1014.942276] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1014.942317] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1014.942323] RTAI[sched]: hard timer type/freq = APIC/16624830(Hz); default timing: oneshot; linear timed lists.
[ 1014.942328] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1861829000 hz.
[ 1014.942331] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1014.948889] RTAI[math]: loaded.
[ 1015.098294] to_pci: io_base: DFCFF000, mem_base: f812c000
[ 1015.098780] to_pci: installed driver for 1 card(s)
[ 1015.105574] config string '0x378 in'
[ 1018.792303] to_pci: exit
[ 1019.784330] [drm] nouveau 0000:02:00.0: PMFB0_SUBP0: 0x037f0040
[ 1019.784336] [drm] nouveau 0000:02:00.0: PMFB0_SUBP1: 0x037f0040
[ 1020.916100] RTAI[math]: unloaded.
[ 1020.918257] SCHED releases registered named ALIEN PEDV$D
[ 1020.928060] RTAI[malloc]: unloaded.
[ 1021.028022] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1021.030291] I-pipe: head domain RTAI unregistered.
[ 1021.030360] RTAI[hal]: unmounted.Привязка идёт так понимаю к тому номеру инструмента который уже установлен?verser писал(а):Будет работать. Руками выставлять offsets X,Y,(Z не надо, вместо него заполняется поле Block Height). Поле Probe Height, если установлен Tool setter, нормально отработает и с фрезой в шпинделе вместо пробника. Если и Tool setter отсутствует, тогда вроде как и смысла во всем этом нетelephant007 писал(а):а без пробника это будет работать? если нули детали врукопашную выставить после хомления?.
Я все ручками писал, сначала нашел одну ошибку, но ситуацию это не изменило.Ил76 писал(а):custom_postgui.hal:28: Pin 'auto_tool_measurement.toolchange-change' does not exist - У меня такое сообщение выдавало когда я простым копирование менял конфигурацию - две недели бился понять не мог и только после того когда я ручками прописал все изменения в ини нале и постгуи тогда только запустилось. видать какие- то проблемы с кодировкой.
3996
4049
Unloading hal componentsКод: Выделить всё
File "/usr/bin/gladevcp", line 40, in <module>
import gtk
File "/usr/lib/python2.7/dist-packages/gtk-2.0/gtk/__init__.py", line 30, in <module>
File "/usr/bin/gladevcp", line 39, in <module>
from optparse import Option, OptionParser
File "/usr/lib/python2.7/optparse.py", line 77, in <module>
import gobject as _gobject
File "/usr/lib/python2.7/dist-packages/gobject/__init__.py", line 26, in <module>
from glib import spawn_async, idle_add, timeout_add, timeout_add_seconds, \
File "/usr/lib/python2.7/dist-packages/glib/__init__.py", line 22, in <module>
from glib._glib import *
KeyboardInterrupt
import textwrap
File "/usr/lib/python2.7/textwrap.py", line 10, in <module>
import string, re
File "/usr/lib/python2.7/string.py", line 124, in <module>
class Template:
File "/usr/lib/python2.7/string.py", line 118, in __init__
'delim' : _re.escape(cls.delimiter),
File "/usr/lib/python2.7/re.py", line 206, in escape
s = list(pattern)
KeyboardInterrupt
3565
3615
Unloading hal componentsК сожалению не спасло ситуациюИл76 писал(а):Генадий, я сейчас проэксперементировал с постгуи.хал - уменя линуксснс не запускается если строчки написать как в описании установки. и выдает такие-же ошибки.
Если написать так-
# link to auto_tool_measurement toolchange, so you get the advantage of tool description on change dialog
net tool-change auto_tool_measurement.toolchange-change iocontrol.0.tool-change
net tool-changed auto_tool_measurement.toolchange-changed iocontrol.0.tool-changed
net tool-prep-number auto_tool_measurement.toolchange-number iocontrol.0.tool-prep-number
net tool-prep-loop iocontrol.0.tool-prepare iocontrol.0.tool-prepared
то программа запускается ( везде по одному пробелу) - не знаю может у Вас другая проблемма.
С Уважением, Илья.
Если имеем инструмент в оправках с заранее известными длинами, то для быстрой ручной смены можно воспользоваться штатными средствами linuxcnc, не прибегая к remap M6 и данному приложению (Auto Tool Measurement). Компонент, называемый hal_manualtoolchange, отобразит окно с сообщением о том, что ожидается смена инструмента, когда встретится команда M6. После нажатия кнопки OK выполнение программы продолжится.plotik писал(а):
ноль вверху вниз отрицательные числаMGG писал(а):Столкнулся с отсутствием отрицательных значений в изначальной версиинеужели у всех наверху 0 и вниз это положительное числа? Или верх это сразу большое положительное число, как ноль?
Вот и мне странно показалось, что очевидную вещь надо дописыватьplotik писал(а):ноль вверху вниз отрицательные числаMGG писал(а):Столкнулся с отсутствием отрицательных значений в изначальной версиинеужели у всех наверху 0 и вниз это положительное числа? Или верх это сразу большое положительное число, как ноль?
Есть любители ноль посерединеMGG писал(а): Вот и мне странно показалось, что очевидную вещь надо дописывать
alexx.bit писал(а):Добвил эти строки, теперь данные появляются в Tool setter Height и Block Height, но появлялась другая проблема. Теперь программа добавляет показания MIX_LIMIT к измеренному нулю.verser писал(а):Отрицательные тоже работают.
Например, я указываю MIN_LIMIT = -100.00 MAX_LIMIT = 0.00, нажимаю probe Tool Setter и -72,344 записывается в probe Tool Height, нажимаю probe Workpice (обмер там же), Block Height выдает -72,348. В координаторах такие данные: Z=103.995, G54 Z=-172.348
Тоже пробовал для MIN_LIMIT = -120.00, добавляет 120 к Z
Cross писал(а):Итак, вроде получилось, может кому пригодится. Кинетамитка моего станка следующая - по Z движется стол, в нижнем положении 0 ( максимальное удаление от шпинделя) в верхнем положении -255 ( шпиндель максимально близок к столу). В моем случае абсолютная координата по Z всегда отрицательная ( разумеется за исключением того случая когда она равна 0), а данная программа в поле TOOL SETTER HEIGHT не дает ввести отрицательное значение, поэтому это значение всегда выставлялось равным 0. Данную проблему решил следующим образом - в файле auto_tool_measurement.py в строке self.spbtn_probe_height.set_value( float(a[2]) ) внес следующие изменения self.spbtn_probe_height.set_value( float( 225.0 + a[2]) ), а для BLOCK HEIGHT в строке self.spbtn_block_height.set_value( float(a[2])) так же добавил 225 self.spbtn_block_height.set_value( 225.0 + float(a[2]) ). После этих не хитрых манипуляций все заработало и работает хорошо. Хочу выразить автору отдельную благодарность, за реализацию удобной ручной смены инструмента с автоизмерением длины.
Прописал эти 2 момента, пока только тестировал, но все показания адекватны.verser писал(а):Спасибо, Cross, за то, что поделились своими соображениями.
Так же предложу ещё один способ расширить диапазон ввода для probe_height и block_height.
Нужно добавить 2 строчки в файле auto_tool_measurement.glade
1. После строк 6-7 с содержимым
КОД: ВЫДЕЛИТЬ ВСЁ • РАЗВЕРНУТЬ
<object class="GtkAdjustment" id="adj_probe_height">
<property name="upper">1000</property>
вставить
<property name="lower">-1000</property>
2. После строк 13-14 с содержимым
<object class="GtkAdjustment" id="adj_block_height">
вставить
