Страница 8 из 18
Re: 5i23+2x7i47+7i42TA
Добавлено: 22 июл 2015, 13:23
sysrover
Такс опять дебри опять бред.
Для начала у нас есть 2 степгена. Каждый настроен на свой мотор.
У нас есть пины шпинделя и вообще шпиндель в линуксцнц.
Вот код
# Step Gen signals/setup
setp hm2_5i23.0.stepgen.01.dirsetup [SPINDLE_9]DIRSETUP
setp hm2_5i23.0.stepgen.01.dirhold [SPINDLE_9]DIRHOLD
setp hm2_5i23.0.stepgen.01.steplen [SPINDLE_9]STEPLEN
setp hm2_5i23.0.stepgen.01.stepspace [SPINDLE_9]STEPSPACE
setp hm2_5i23.0.stepgen.01.position-scale [SPINDLE_9]STEP_SCALE
setp hm2_5i23.0.stepgen.01.step_type 0
setp hm2_5i23.0.stepgen.01.control-type 1
setp hm2_5i23.0.stepgen.01.maxaccel [SPINDLE_9]MAX_ACCELERATION
setp hm2_5i23.0.stepgen.01.maxvel [SPINDLE_9]MAX_VELOCITY
net machine-is-enabled => hm2_5i23.0.stepgen.01.enable
net spindle-vel-cmd-rps => hm2_5i23.0.stepgen.01.velocity-cmd
net spindle-vel-fb <= hm2_5i23.0.stepgen.01.velocity-fb
setp hm2_5i23.0.stepgen.00.dirsetup [SPINDLE_9]DIRSETUP
setp hm2_5i23.0.stepgen.00.dirhold [SPINDLE_9]DIRHOLD
setp hm2_5i23.0.stepgen.00.steplen [SPINDLE_9]STEPLEN
setp hm2_5i23.0.stepgen.00.stepspace [SPINDLE_9]STEPSPACE
setp hm2_5i23.0.stepgen.00.position-scale [SPINDLE_9]STEP_SCALE
setp hm2_5i23.0.stepgen.00.step_type 0
setp hm2_5i23.0.stepgen.00.control-type 1
setp hm2_5i23.0.stepgen.00.maxaccel [SPINDLE_9]MAX_ACCELERATION
setp hm2_5i23.0.stepgen.00.maxvel [SPINDLE_9]MAX_VELOCITY
# ---setup spindle control signals---
net spindle-vel-cmd-rps <= motion.spindle-speed-out-rps
net spindle-vel-cmd-rps-abs <= motion.spindle-speed-out-rps-abs
net spindle-vel-cmd <= motion.spindle-speed-out
net spindle-vel-cmd-rpm-abs <= motion.spindle-speed-out-abs
net spindle-on <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-brake <= motion.spindle-brake
net spindle-revs => motion.spindle-revs
net spindle-at-speed => motion.spindle-at-speed
net spindle-vel-fb => motion.spindle-speed-in
net spindle-index-enable <=> motion.spindle-index-enable
# ---Setup spindle at speed signals---
sets spindle-at-speed true
строки
подключают пинам сепгена 01 двигателя енейбл, скорость и фидбек(правда непонятно нафига)
Теперь нужно сделать возможность включать 1 степген 2 степген и оба вместе и того 3 положения.
Добавлено: 22 июл 2015, 13:28
sysrover писал(а):net spindle-vel-cmd-rps => hm2_5i23.0.stepgen.01.velocity-cmd
подключаем пин hm2_5i23.0.stepgen.01.velocity-cmd к сигналу spindle-vel-cmd-rps.
можешь посмотреть за одно, какие пины к нему еще подключены
.(сам сигнал ничего не делает и ничего не значит его можно назвать как угодно например s0001)
Комментируешь эту строчку (#).
встраиваем mux2
net spindle-vel-cmd-rps => mux2.0.in1
net spindle-vel-cmd-rps-mux <= mux2.0.out => hm2_5i23.0.stepgen.01.velocity-cmd
также надо еще этот mux "загрузить". посмотри по файлу hal, там нет больше никаких mux?
Добавлено: 22 июл 2015, 13:44
sysrover
Нет там муксов не подключено.
Добавлено: 22 июл 2015, 13:46
sysrover
ну судя по твоей строке мы сделали новый сигнал с приставкой мукс и подключили к его ауту степген а к ин прежний сигнал
Добавлено: 22 июл 2015, 14:06
sysrover писал(а):ну судя по твоей строке мы сделали новый сигнал с приставкой мукс и подключили к его ауту степген а к ин прежний сигнал
нет. Мы:
1. присоединили старый сигнал к mux2.0.in1
2. создали новый сигнал.
3. присоединили кнему mux2.0.out и hm2_5i23.0.stepgen.01.velocity-cmd
Вот по компонентам:
http://www.cnc-club.ru/wiki/index.php/% ... %D1%8B_hal
Тебе надо загрузить два mux2 и добавить их к servo-thread, т.е.
loadrt mux2 count=2
addf mux2.0 servo-thread
addf mux2.1 servo-thread
Добавлено: 22 июл 2015, 14:11
sysrover
такс понял мы подгрузили этот мукс
создали новый и завязали на него степген и старый сигнал.
теперь нам нада сделать такойже для второго степгена ?
Добавлено: 22 июл 2015, 14:16
Да.
Добавлено: 22 июл 2015, 14:27
sysrover
окей
так ?
net spindle-vel-cmd-rps => mux2.1.in1
net spindle-vel-cmd-rps-mux <= mux2.1.out => hm2_5i23.0.stepgen.00.velocity-cmd
или так
net spindle-vel-cmd-rps-mux1 <= mux2.1.out => hm2_5i23.0.stepgen.00.velocity-cmd
Добавлено: 22 июл 2015, 15:11
Больше похож второй вариант
mux1 это правильно - значение другое = сигнал другой <= mux2.1.out => hm2_5i23.0.stepgen.
00 .velocity-cmd
Добавлено: 22 июл 2015, 15:17
sysrover
Отично теперь как этим управлять и куда пихать файлы M101 M102 M103 и что в них писать.
Добавлено: 22 июл 2015, 15:22
нужно подключить пин mux2.1.sel к motion.digital-out-00 почитай в описаниик G62.
Добавлено: 22 июл 2015, 15:38
sysrover
не нахожу описания команды g62
Добавлено: 22 июл 2015, 16:03
Пардонте, М62
Добавлено: 22 июл 2015, 16:29
sysrover
loadrt mux2 count=2
#net spindle-vel-cmd-rps => hm2_5i23.0.stepgen.01.velocity-cmd
mux2.0.out <= motion.digital-out-00
mux2.1.out <= motion.digital-out-01
так ?
и что дальше ?
Добавлено: 22 июл 2015, 16:30
sysrover
самое интересное что я нихрена не понимаю что я делаю и как работает этот М62 и как работает этот мукс и куда что оно по результату даст.
Добавлено: 23 июл 2015, 09:12
sysrover писал(а):mux2.0.out <= motion.digital-out-00
Так, только где вот это:
net название_сигнала пин [пин [пин] [...]]]
И пин не mux2.0.out, а sel!
sysrover писал(а):самое интересное что я нихрена не понимаю что я делаю и как работает этот М62 и как работает этот мукс и куда что оно по результату даст.
М64 P0 включает motion.digital-out-00 => он включает mux2.0.sel => от этого mux2 передает свой второй пин на свой выход => включает шпиндель
М65 P0 выключает motion.digital-out-00 => он ...
M64 P- - turn on digital output immediately. The P- word specifies the digital output number.
M65 P- - turn off digital output immediately. The P- word specifies the digital output number.
Вот что делает mux2:
http://linuxcnc.org/docs/html/man/man9/mux2.9.html#NAME
Добавлено: 23 июл 2015, 13:44
sysrover
net spindle1-on motion.digital-out-00 => mux2.0.sel
net spindle2-on motion.digital-out-01 => mux2.1.sel
Так ?
Добавлено: 23 июл 2015, 13:52
sysrover
РАБОТАЕТ итить.
Как сделать обратный сигнал для второго шпинделя ?
Добавлено: 23 июл 2015, 14:09
sysrover
теперь понял что такое мукс и как он работает
для чайника переключатель между двумя положениями.
loadrt mux2 count=2
net machine-is-enabled => hm2_5i23.0.stepgen.00.enable
Добавлено: 23 июл 2015, 14:26
sysrover
В общем разобрался спасибо Ник
Управление шпинделями и скоростью как обычно m3 m4 m5 S
А через M64 включаем выключаем тот или иной шпиндель
M64 P0 включает 1 шпиндель
M65 P0 выключает 1 шпиндель
M64 P1 включает второй
вот кусок хала и кусок ини
loadrt mux2 count=2
setp hm2_5i23.0.stepgen.00.dirsetup [SPINDLE_8]DIRSETUP
setp hm2_5i23.0.stepgen.00.dirhold [SPINDLE_8]DIRHOLD
setp hm2_5i23.0.stepgen.00.steplen [SPINDLE_8]STEPLEN
setp hm2_5i23.0.stepgen.00.stepspace [SPINDLE_8]STEPSPACE
setp hm2_5i23.0.stepgen.00.position-scale [SPINDLE_8]STEP_SCALE
setp hm2_5i23.0.stepgen.00.maxaccel [SPINDLE_8]MAX_ACCELERATION
setp hm2_5i23.0.stepgen.00.maxvel [SPINDLE_8]MAX_VELOCITY
# Spindle
[SPINDLE_9]
MAX_VELOCITY = 33.3333333333
MAX_ACCELERATION = 40.0
# The values below should be 25% larger than MAX_VELOCITY and MAX_ACCELERATION
# If using BACKLASH compensation STEPGEN_MAXACCEL should be 100% larger.
STEPGEN_MAXVEL = 41.7
STEPGEN_MAXACCEL = 50.0
# these are in nanoseconds
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = 10000.0
[SPINDLE_8]
DIRSETUP = 1000
DIRHOLD = 1000
STEPLEN = 1000
STEPSPACE = 1000
STEP_SCALE = -10000.0
