Re: Как найти адресс LPT в Linux?
Добавлено: 31 янв 2014, 17:08
Вывод
lspci -v
lspci -v
cat /proc/ioports | grep parport
lspci -v
00:00.0 Host bridge: Intel Corporation 82865G/PE/P DRAM Controller/Host-Hub Interface (rev 02)
Subsystem: ASUSTeK Computer Inc. Device 80f2
Flags: bus master, fast devsel, latency 0
Memory at f8000000 (32-bit, prefetchable) [size=64M]
Capabilities: <access denied>
Kernel driver in use: agpgart-intel
Kernel modules: intel-agp
00:01.0 PCI bridge: Intel Corporation 82865G/PE/P PCI to AGP Controller (rev 02)
Flags: bus master, 66MHz, fast devsel, latency 64
Bus: primary=00, secondary=01, subordinate=01, sec-latency=64
Memory behind bridge: fc900000-fe9fffff
Prefetchable memory behind bridge: e7f00000-f7efffff
Kernel modules: shpchp
00:06.0 System peripheral: Intel Corporation 82865G/PE/P Processor to I/O Memory Interface (rev 02)
Flags: fast devsel
Memory at fecf0000 (32-bit, non-prefetchable) [size=4K]
00:1d.0 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #1 (rev 02)
Subsystem: ASUSTeK Computer Inc. Device 80a6
Flags: bus master, medium devsel, latency 0, IRQ 16
I/O ports at eec0 [size=32]
Kernel driver in use: uhci_hcd
00:1d.1 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #2 (rev 02)
Flags: bus master, medium devsel, latency 0, IRQ 19
I/O ports at ef00 [size=32]
00:1d.2 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #3 (rev 02)
Flags: bus master, medium devsel, latency 0, IRQ 18
I/O ports at ef20 [size=32]
00:1d.3 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB UHCI Controller #4 (rev 02)
I/O ports at ef40 [size=32]
00:1d.7 USB Controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) USB2 EHCI Controller (rev 02) (prog-if 20)
Flags: bus master, medium devsel, latency 0, IRQ 23
Memory at febffc00 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ehci_hcd
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev c2)
Bus: primary=00, secondary=02, subordinate=02, sec-latency=64
I/O behind bridge: 0000d000-0000dfff
Memory behind bridge: fea00000-feafffff
00:1f.0 ISA bridge: Intel Corporation 82801EB/ER (ICH5/ICH5R) LPC Interface Bridge (rev 02)
Kernel modules: iTCO_wdt, intel-rng
00:1f.1 IDE interface: Intel Corporation 82801EB/ER (ICH5/ICH5R) IDE Controller (rev 02) (prog-if 8a [Master SecP PriP])
I/O ports at 01f0 [size=8]
I/O ports at 03f4 [size=1]
I/O ports at 0170 [size=8]
I/O ports at 0374 [size=1]
I/O ports at fc00 [size=16]
Memory at 40000000 (32-bit, non-prefetchable) [size=1K]
Kernel driver in use: ata_piix
00:1f.3 SMBus: Intel Corporation 82801EB/ER (ICH5/ICH5R) SMBus Controller (rev 02)
Flags: medium devsel
I/O ports at 0400 [size=32]
Kernel modules: i2c-i801
00:1f.5 Multimedia audio controller: Intel Corporation 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller (rev 02)
Subsystem: ASUSTeK Computer Inc. Device 810d
Flags: bus master, medium devsel, latency 0, IRQ 17
I/O ports at e800 [size=256]
I/O ports at ee80 [size=64]
Memory at febff800 (32-bit, non-prefetchable) [size=512]
Memory at febff400 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: Intel ICH
Kernel modules: snd-intel8x0
01:00.0 VGA compatible controller: nVidia Corporation NV18 [GeForce4 MX 440 AGP 8x] (rev a2)
Flags: bus master, 66MHz, medium devsel, latency 248, IRQ 16
Memory at fd000000 (32-bit, non-prefetchable) [size=16M]
Memory at e8000000 (32-bit, prefetchable) [size=128M]
[virtual] Expansion ROM at fe9e0000 [disabled] [size=128K]
Kernel driver in use: nvidia
Kernel modules: nvidia-96, nvidia-173, nvidiafb, nouveau
02:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8139/8139C/8139C+ (rev 10)
Subsystem: ASUSTeK Computer Inc. Device 8026
Flags: bus master, medium devsel, latency 64, IRQ 22
I/O ports at d800 [size=256]
Memory at feaffc00 (32-bit, non-prefetchable) [size=256]
Kernel driver in use: 8139too
Kernel modules: 8139too, 8139cp
02:0a.0 Serial controller: Device 4348:5053 (rev 10) (prog-if 02)
Subsystem: Device 4348:5053
Flags: medium devsel, IRQ 22
I/O ports at dff0 [size=8]
I/O ports at dfe0 [size=8]
Kernel driver in use: serialКод: Выделить всё
Flags: fast devsel
0378-037a : parport0
