Страница 5 из 9
Re: Все-таки SCARA
Добавлено: 24 дек 2014, 18:20
РЕКЛАМА писал(а):Это тот что я мучааю.
Разница с дефолтным только в добавленных stepgen'ах.
РЕКЛАМА писал(а):Я не моу онять логику файла.
Считай это словесным описанием электрической схемы. :)
Посмотри мою тему про VisualHAL - там скриншоты могут помочь понять логику файла.
Re: Все-таки SCARA
Добавлено: 24 дек 2014, 18:36
РЕКЛАМА
я уже совсем запутался.
вот ини мой:
# EMC controller parameters for a simulated hexapod of the minitetra type.
# General note: Comments can either be preceded with a # or ; - either is
# acceptable, although # is in keeping with most linux config files.
# Settings with a + at the front of the comment are likely needed to get
# changed by the user.
# Settings with a - at the front are highly unneeded to be changed
# General section
# General section -------------------------------------------------------------
[EMC]
#- Version of this INI file
VERSION =               $Revision$
#+ Name of machine, for use with display, etc.
MACHINE =               LinuxCNC-HAL-SIM-SCARA
#+ Debug level, 0 means no messages. See src/emc/nml_int/emcglb.h for others
DEBUG = 0
# DEBUG =               0x00000007
#DEBUG =               0x7FFFFFFF
# Sections for display options
[DISPLAY]
#+ Name of display program, e.g., xemc
 DISPLAY =              axis
# DISPLAY =              usrmot
# DISPLAY =              mini
# DISPLAY = 		tkemc
#- Cycle time, in seconds, that display will sleep between polls
CYCLE_TIME =            0.200
#- Path to help file
HELP_FILE =             tklinucnc.txt
#- Initial display setting for position, RELATIVE or MACHINE
POSITION_OFFSET =       MACHINE
#- Initial display setting for position, COMMANDED or ACTUAL
POSITION_FEEDBACK =     ACTUAL
#+ Highest value that will be allowed for feed override, 1.0 = 100%
MAX_FEED_OVERRIDE =     2.0
#+ Prefix to be used
PROGRAM_PREFIX = /home/reklama/linuxcnc/nc_files
#- Introductory graphic
INTRO_TIME = 5
PYVCP = scara.xml
# Editor to be used with Axis
EDITOR = gedit
# Task controller section
[TASK]
# Name of task controller program, e.g., milltask
TASK =                  milltask
#- Cycle time, in seconds, that task controller will sleep between polls
CYCLE_TIME =            0.010
# Part program interpreter section
[RS274NGC]
#- File containing interpreter variables
PARAMETER_FILE =        scara.var
# Motion control section
[EMCMOT]
EMCMOT =              motmod
#- Timeout for comm to emcmot, in seconds
COMM_TIMEOUT =          1.0
#- Interval between tries to emcmot, in seconds
COMM_WAIT =             0.010
BASE_PERIOD =                100000
#- Servo task period, in nanoseconds
SERVO_PERIOD =               1000000
#- Trajectory Planner task period, in nanoseconds - will be rounded to an
#   integer multiple of SERVO_PERIOD
TRAJ_PERIOD =                10000000
# Hardware Abstraction Layer section
[HAL]
# The run script first uses halcmd to execute any HALFILE
# files, and then to execute any individual HALCMD commands.
# list of hal config files to run through halcmd
# files are executed in the order in which they appear
HALFILE =                    scara_sim_4.hal
HALFILE =                    standard_pinout.hal
POSTGUI_HALFILE =            scara_postgui.hal
#- list of halcmd commands to execute
# commands are executed in the order in which they appear
#HALCMD =                    save neta
#load halui to enable
HALUI =                      halui
# Trajectory planner section
[TRAJ]
#+ machine specific settings
AXES =                  6
COORDINATES =           X Y Z C
HOME = 			0 0 0 0
LINEAR_UNITS =          mm
ANGULAR_UNITS =         degree
CYCLE_TIME =            0.010
DEFAULT_VELOCITY =      1.0
MAX_VELOCITY =          50.0
DEFAULT_ACCELERATION =  100.0
MAX_ACCELERATION =      200
# Axes sections
#+ First axis
[AXIS_0]
TYPE =                          ANGULAR
HOME =                          0.000
MAX_VELOCITY =                  300.0
MAX_ACCELERATION =              200.0
STEPGEN_MAXACCEL =              300
BACKLASH = 0.000
SCALE =                   4.4
INPUT_SCALE =                   4000
OUTPUT_SCALE =                  1.000
MIN_LIMIT =                     -200.0
MAX_LIMIT =                     200.0
FERROR =                       40.000
MIN_FERROR =                    5
HOME_OFFSET =                   0.0
HOME_SEARCH_VEL =               0.0
HOME_LATCH_VEL =                0.0
HOME_USE_INDEX =                NO
HOME_IGNORE_LIMITS =            NO
HOME_SEQUENCE =                 0
#+ Second axis
[AXIS_1]
TYPE =                          ANGULAR
HOME =                          0.000
BACKLASH = 0.000
SCALE =                   4.4
INPUT_SCALE =                   4000
MIN_LIMIT =                     -200.0
MAX_LIMIT =                     200.0
FERROR =                        40.000
MIN_FERROR =                    5
HOME_OFFSET =                   0.0
HOME_USE_INDEX =                NO
HOME_SEQUENCE =                 0
#+ Third axis
[AXIS_2]
TYPE =                          LINEAR
HOME =                         25.000
BACKLASH = 0.000
SCALE =                   800
INPUT_SCALE =                   4000
MIN_LIMIT =                     -200.0
MAX_LIMIT =                     300.0
FERROR =                        40.000
MIN_FERROR =                    5
HOME_OFFSET =                   25.0
HOME_USE_INDEX =                NO
HOME_SEQUENCE =                 0
#+ Fourth axis
[AXIS_5]
TYPE =                          ANGULAR
HOME =                          0.000
BACKLASH = 0.000
SCALE =                   4.4
INPUT_SCALE =                   4000
MIN_LIMIT =                     -360.0
MAX_LIMIT =                     360.0
FERROR =                       40.000
MIN_FERROR =                    5
HOME_OFFSET =                   0.0
HOME_USE_INDEX =                NO
HOME_SEQUENCE =                 0
# section for main IO controller parameters
[EMCIO]
#- Name of IO controller program, e.g., io
EMCIO = 	                io
#- cycle time, in seconds
CYCLE_TIME =                    0.100
#- tool table file
TOOL_TABLE =                    scara.tbl
Вот дефолтный:
# General section
[EMC]
DEBUG = 0
#DEBUG =               0x7FFFFFFF
[DISPLAY]
 DISPLAY =              axis
# DISPLAY =              usrmot
# DISPLAY =              mini
# DISPLAY = 		tkemc
CYCLE_TIME =            0.200
INTRO_TIME = 5
PYVCP = scara.xml
EDITOR = gedit
[TASK]
TASK =                  milltask
CYCLE_TIME =            0.010
[RS274NGC]
[EMCMOT]
EMCMOT =              motmod
COMM_TIMEOUT =          1.0
COMM_WAIT =             0.010
[HAL]
#HALCMD =                    save neta
HALUI =                      halui
[TRAJ]
AXES =                  6
HOME = 			0 0 0 0
LINEAR_UNITS =          1.0
ANGULAR_UNITS =         1.0
CYCLE_TIME =            0.010
MAX_VELOCITY =          600.0
# Axes sections
#+ First axis
[AXIS_0]
TYPE =                          ANGULAR
HOME =                          0.000
MAX_VELOCITY =                  30.0
BACKLASH =                      0.000
INPUT_SCALE =                   4000
MIN_LIMIT =                     -360.0
MAX_LIMIT =                     360.0
FERROR =                        2.000
MIN_FERROR =                    0.200
HOME_OFFSET =                   0.0
HOME_USE_INDEX =                NO
HOME_SEQUENCE =                 0
#+ Second axis
[AXIS_1]
TYPE =                          ANGULAR
HOME =                          0.000
MAX_VELOCITY =                  30.0
BACKLASH =                      0.000
INPUT_SCALE =                   4000
MIN_LIMIT =                     -360.0
MAX_LIMIT =                     360.0
FERROR =                        2.000
MIN_FERROR =                    0.200
HOME_OFFSET =                   0.0
HOME_USE_INDEX =                NO
HOME_SEQUENCE =                 0
#+ Third axis
[AXIS_2]
TYPE =                          LINEAR
HOME =                          25.000
MAX_VELOCITY =                  30.0
BACKLASH =                      0.000
INPUT_SCALE =                   4000
MIN_LIMIT =                     25.0
MAX_LIMIT =                     300.0
FERROR =                        2.000
MIN_FERROR =                    0.200
HOME_OFFSET =                   25.0
HOME_USE_INDEX =                NO
HOME_SEQUENCE =                 0
#+ Fourth axis
[AXIS_5]
TYPE =                          ANGULAR
HOME =                          0.000
MAX_VELOCITY =                  30.0
BACKLASH =                      0.000
INPUT_SCALE =                   4000
MIN_LIMIT =                     -180.0
MAX_LIMIT =                     180.0
FERROR =                        2.000
MIN_FERROR =                    0.200
HOME_OFFSET =                   0.0
HOME_USE_INDEX =                NO
HOME_SEQUENCE =                 0
[EMCIO]
EMCIO = 	                io
CYCLE_TIME =                    0.100
#- tool table file
Япробовал рисоваать все это. извел килограм макулатуры.
почему тогда дефолтный работает, а мой нет?
Я пробовал в дефолтный добавлять настройки для лпт. но не заработало. я что-то упускаю.
Re: Все-таки SCARA
Добавлено: 24 дек 2014, 19:37
РЕКЛАМА
Я тут вычитал что:
а системы на шаговых двигателях обычно имеют два таких файла, один задающий общую конфигурацию шаговых двигателей (core_stepper.hal) и один задающий вывод пинов для машины (xxx_pinout.hal).
У меня нет core_stepper.hal. или он вписан в основной?
Re: Все-таки SCARA
Добавлено: 24 дек 2014, 23:08
РЕКЛАМА
Признайтесь, вы специально не указали мне на ошибку в .хал чтоб я голову себе всю сломал и три ночи не спал? :bender:
Вроде заработало.
Но теперь ошибка вылезает когда "инструмент" не может "дотянуться" до координаты физически, т.е. не хватает длины сустава.
Понятно что есть софт лимиты, но они работают только в режиме сочленения. В режиме координат они почему-то превращаются в миллиметровые.
Т.е. лимит -180+180 град. превращается в -180+180 мм. а рука туда не дотягивается счас.
И с этой ошибки "не слезть" только перезагрузкой.
И еще может кто знает как поменять местами X и Y координаты в реале (и в визуализации) а то непривычно.
Re: Все-таки SCARA
Добавлено: 25 дек 2014, 11:31
solo
РЕКЛАМА писал(а):не указали мне на ошибку в .хал чтоб я голову себе всю сломал
так может поделишься , "замаскированной ошибкой " чтоб другим легче было.
Re: Все-таки SCARA
Добавлено: 25 дек 2014, 11:46
РЕКЛАМА
она не замаскированная. Она лежала на поверхности и смотрела на меня всё это время.
И выше еще пару строчек аксис 5 заменил на 3.
Если все доделаю выложу тут статейку по наладке Скары для чайников.
Еще вопросы:
как убрать кругляши индикаторов положения?
Как убрать отдельное окошко с симуляцией при запуске?
Re: Все-таки SCARA
Добавлено: 25 дек 2014, 11:52
РЕКЛАМА писал(а):она не замаскированная. Она лежала на поверхности и смотрела на меня всё это время
рад - что у тебя заработало - знаю ,как это бывает приятно
особенно - если далось не сразу :)
но ошибка все таки не в этих строках...
net xflt axis.0.amp-fault-in
net yflt axis.1.amp-fault-in
net zflt axis.2.amp-fault-in
net aflt axis.5.amp-fault-in
loadusr -W scaragui
net j0 axis.0.joint-pos-fb scaragui.joint0
net j1 axis.1.joint-pos-fb scaragui.joint1
net j2 axis.2.joint-pos-fb scaragui.joint2
net j3 axis.5.joint-pos-fb scaragui.joint3
их можно попробовать убрать совсем - пропадет лишь трехмерная визуализация
хотя кто его знает - может из-за нее глючить али нет :thinking:
Re: Все-таки SCARA
Добавлено: 25 дек 2014, 12:38
РЕКЛАМА
nkp писал(а):но ошибка все таки не в этих строках...
И не в этих тоже?
# create HAL signals for position commands from motion module
net J0cmd <= axis.0.motor-pos-cmd => stepgen.0.position-cmd
net J1cmd <= axis.1.motor-pos-cmd => stepgen.1.position-cmd
net J2cmd <= axis.2.motor-pos-cmd => stepgen.2.position-cmd
net J3cmd <= axis.5.motor-pos-cmd => stepgen.3.position-cmd
# loop position commands back to motion module feedback
net J0fb => stepgen.0.position-fb => axis.0.motor-pos-fb
net J1fb => stepgen.1.position-fb => axis.1.motor-pos-fb
net J2fb => stepgen.2.position-fb => axis.2.motor-pos-fb
net J3fb => stepgen.3.position-fb => axis.5.motor-pos-fb
Но сразу после правки всё заработало..
nkp писал(а):их можно попробовать убрать совсем - пропадет лишь трехмерная визуализация
Та что стартует отдельным окошком? как сделать что-бы она не стартовала совсем?
Re: Все-таки SCARA
Добавлено: 25 дек 2014, 12:46
скорее всего вот это убрать:
loadusr -W scaragui
Re: Все-таки SCARA
Добавлено: 25 дек 2014, 12:49
Nick писал(а):скорее всего вот это убрать:loadusr -W scaragui
и пины его тоже убрать:
ну вобщем как выше и писал...
Re: Все-таки SCARA
Добавлено: 16 янв 2015, 10:55
windnord1
А как сделать чтобы все звенья крутились вокруг своей оси бесконечно?
Re: Все-таки SCARA
Добавлено: 16 янв 2015, 11:07
А в scara так можно вообще?
Или у тебя немного другая кинематика?
Re: Все-таки SCARA
Добавлено: 16 янв 2015, 11:11
Nick писал(а):А в scara так можно вообще?
можно
https://www.youtube.com/watch?v=L2fayyRO3wE
Re: Все-таки SCARA
Добавлено: 17 янв 2015, 05:30
windnord1
windnord1 писал(а):А как сделать чтобы все звенья крутились вокруг своей оси бесконечно?
нужно убрать
min limit и max limit
Re: Все-таки SCARA
Добавлено: 04 фев 2015, 15:54
windnord1
как scara сделать из сервоприводов в шаговый?
Re: Все-таки SCARA
Добавлено: 04 фев 2015, 16:47
В linuxcnc нет разницы...
Есть реальный станок?
Re: Все-таки SCARA
Добавлено: 06 фев 2015, 10:52
windnord1
есть шаговые двигатели и контроллеры
Re: Все-таки SCARA
Добавлено: 06 фев 2015, 10:53
windnord1
нужно написать HAL и INI файлы
Re: Все-таки SCARA
Добавлено: 06 фев 2015, 12:46
windnord1 писал(а):есть шаговые двигатели и контроллеры
собирай железо, и потихоньку будем делать hal и ini.
Для начала можешь сделать простую конфигурацию для трех осевого фрезера и просто покрутить движками, потом будем ее изменять.
Re: Все-таки SCARA
Добавлено: 06 фев 2015, 13:47
windnord1
собрал. сделал конфигурацию. покрутил движками. теперь надо изменить конфигурацию
