Страница 5 из 14
Re: LinuxCNC S-разгон и торможение
Добавлено: 15 май 2013, 17:33
Как-то странно у них получается
Jerk Equations
The jerk equations drive acceleration and deceleration planning. A good treatment can be found in Ed Red's course notes
http://www.et.byu.edu/~ered/ME537/Notes/Ch5.pdf
There are two core calculations that drive everything else. This pair of functions returns the fourth thing knowing the other three.
_mp_get_target_length() is a convenient expression for determining the optimal_length (L) of a line given the inital velocity (Vi), target velocity (Vt) and maximum jerk (Jm). The length (position) equation is derived from:
a) L = (Vt-Vi) * T - (Ar*T^2)/2 ... which becomes b) with substitutions for Ar and T
b) L = (Vt-Vi) * 2*sqrt((Vt-Vi)/Jm) - (2*sqrt((Vt-Vi)/Jm) * (Vt-Vi))/2
c) L = (Vt-Vi)^(3/2) / sqrt(Jm) ...is an alternate form of b) (see Wolfram Alpha)
d) L = abs(Vt-Vi) * sqrt(abs(Vt-Vi)/Jm) ... is a second alternate form. Note: Vt is not always > Vi due to rounding, tolerances, and other factors.
where Ar = (Jm*T)/4 Ar is ramp acceleration
where T = 2*sqrt((Vt-Vi)/Jm) T is time
where Jm (maximum jerk) is the cartesian sum of the jerks for each axis in the move. The values in the unit vector are used to scale the resultant jerk for the move.
assumes Vt, Vi and L are positive or zero
Дистанция зависит не только от текущей скорости и требуемой, но и от текущего ускорения.
Добавлено: 15 май 2013, 18:57
нам лижбы работало грамотно
Добавлено: 15 май 2013, 22:28
Starik
Nick писал(а):Дистанция зависит не только от текущей скорости и требуемой, но и от текущего ускорения.
Скорее всего ускорение должно быть равно нулю на концах.
Добавлено: 15 май 2013, 22:40
Дак они в формулах его вроде вообще не используют...
Добавлено: 15 май 2013, 23:14
Starik
Nick писал(а):a) L = (Vt-Vi) * T - (Ar*T^2)/2 ... which becomes b) with substitutions for Ar and T
Nick писал(а):where Ar = (Jm*T)/4 Ar is ramp acceleration
лишняя переменная...
Добавлено: 01 фев 2016, 20:12
Lexxa
Ник, как дела в этой области?
Добавлено: 02 фев 2016, 23:42
Lexxa
Nick, просто подумал, треугольные ускорения получаются при [EMCMOT]TRAJ_PERIOD = const.
т.е. внутри периода приращение скорости постоянно. Если, например, менять величину периода по какой-либо функции на этапах разгона и торможения, то получится, что приращение скорости в реальном времени будет меняться по этой функции.
Т.е. потребуется обойти только граничные условия.
Добавлено: 03 фев 2016, 09:48
Lexxa писал(а):т.е. внутри периода приращение скорости постоянно.
Так оно и так вроде постоянно? График скорости получается такой _/''''''''\_ , при этом ускорение такое '''------_ , а нам надо ускорение _/''''''''\_
А где про это почитать?
Добавлено: 04 фев 2016, 22:39
Lexxa
Нигде)
Я имел ввиду, что если на этапах разгона и торможения менять длину сервопериода,тодля внешних железках это будет равносильно изменению ускорения в момент ускорения оси.
Но начинается сложность с граничными условиями, когда a->0, т.е. t->бесконечности. Путь тупиковый.
Ник, почему нельзя ввести функцию для значения acc и не париться?
Ведь все вычисления мгновенные
Вот функция
trajInifile->Find(&axes, "AXES", "TRAJ");
в ней ищется значение MAX_ACCELERATION из INI файла:
trajInifile->Find(&acc, "MAX_ACCELERATION", "TRAJ");
Допустим надо разогнаться до скорости V со скорости Vo=0.
четыре участка -
1 - скорость меняется не линейно время t1 на участке скорости _/
2 - скорость меняется линейно время t2 на участке скорости /
3 - скорость меняется нелинейно время t3 на участке скорости ""\
4 - скорость не меняется.
в INI файл добавляем три параметра T1, T2, T3 соответствующие участкам 1, 2, 3.
Математически описываем acc функцию, возвращающую acc на разных временных периодах - T1, T2 и T3.
Так не получится?
Ведь значение этого ускорения используется в TRAJECTORY PLANER?
Или если так сделать, то он не сможет корректно рассчитать путь оси до точки останова?
Добавлено: 05 фев 2016, 12:27
Impartial
Nick писал(а):А где про это почитать?
Чтобы все не читать стоит глянуть картинку на 20 странице. Будет понятно что откуда происходит.
Подобные характеристики скоростных траекторий важны в прямом приводе, допустим в позиционере камеры.
В станке, на мой взгляд, бесполезное увеличение сложности алгоритма планировщика.
Добавлено: 05 фев 2016, 16:41
Lexxa писал(а):Ник, почему нельзя ввести функцию для значения acc и не париться?
Потому, что ее должен знать планировщик. И исходя из нее рассчитывать траекторию. И еще по хорошему согласовывать траектории всех осей.
Планировщик считает дистанцию до остановки, чтобы понять когда надо начинать тормозить. При обычных условиях у нас есть скорость и ускорение v a. Дистанция до остановки S = v0*t + a*t^2/2. Время остановки t = v0/a.
К чему это приводит, когда просто добавляем jerk - максимальное изменение ускорения aka ускорение ускорения. То получаем дистанцию S = v0*t + a*t^2/2 + j*t^3/6, а время надо считать из уровнения v0 + a*t + j*t^2/2. Если подставить напрямую, то получается уравнение хрен знает какой степени. И приходится рассматривать 8 интервалов. В общем геморрой.
Добавлено: 28 мар 2019, 14:00
MGG
Господа, а у этой темы было какое то логическое продолжение?
Добавлено: 28 мар 2019, 15:25
Тут такое дело. Если нужно править планировщик, то и все stepgen'ы надо допиливать. Ибо скорость они меняют тоже линейно.
Добавлено: 28 мар 2019, 16:06
MGG
MX_Master писал(а):Тут такое дело. Если нужно править планировщик, то и все stepgen'ы надо допиливать. Ибо скорость они меняют тоже линейно.
Какие то наработки гуглятся, но вот пробовал ли кто что. Степгены пофиг, лично мне, аналог
Добавлено: 28 мар 2019, 17:56
Аналог пофиг, лично мне, EtherCAT (:
Добавлено: 28 мар 2019, 18:22
Lexxa
На мой взгляд ни степгены, ни пвмгены тут ни при чем. Расчет траетории должен быть на уровне планировщика. Как планировщик скажет так степген и поедет.
Добавлено: 29 мар 2019, 04:29
MX_Master писал(а):все stepgen'ы надо допиливать. Ибо скорость они меняют тоже линейно.
Генераторы держат ту частоту, которую прикажут (в меру своих способностей). А приказы поступают один раз за сервопериод. Скачок частоты за 1 мсек достаточно мал, чтобы механика что-то заметила.
Добавлено: 29 мар 2019, 08:35
Хорошо, уговорили. Осталось дело за малым, накатать другой планировщик
Добровольцы есть? -
Нет. Так и знал
Добавлено: 29 мар 2019, 08:50
S-кривые - не самоцель. Тут во взрослых системах эвон что бывает
Re: Обрабатывающий центр SV500 #569
Добавлено: 29 мар 2019, 09:16
Взрослые системы подразумевают взрослые деньги, потраченные на разработку и тесты с учётом взрослых задач. А просто так спрашивать по форумам запилил ли кто-то S-кривые в LinuxCNC - бессмысленно.
