Re: EMC2 и AlphaCAM
Добавлено: 01 ноя 2011, 15:10
Какой маркер? Давай скриншот
Статьи, обзоры, цены на станки и комплектующие.
https://cnc-club.ru/forum/
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/dron/emc2/configs/1'
Machine configuration file is '1.ini'
INIFILE=/home/dron/emc2/configs/1/1.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting EMC2 IO program: io
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=5033
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
HAL: ERROR: function 'mux4.0' not found
1.hal:81: addf failed
5033
PID TTY STAT TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[20754.466092] I-pipe: Domain RTAI registered.
[20754.466100] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[20754.466101] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[20754.466105] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[20754.466107] PIPELINE layers:
[20754.466109] f82bee20 9ac15d93 RTAI 200
[20754.466111] c085cb20 0 Linux 100
[20754.482627] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[20754.482709] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[20754.482712] RTAI[sched]: hard timer type/freq = APIC/12499748(Hz); default timing: periodic; linear timed lists.
[20754.482715] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2699840000 hz.
[20754.482717] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[20754.482781] RTAI[usi]: enabled.
[20754.547580] RTAI[math]: loaded.
[20754.624414] config string '0x378 out '
[20754.959660] RTAI[math]: unloaded.
[20755.008079] SCHED releases registered named ALIEN RTGLBH
[20755.024210] RTAI[malloc]: unloaded.
[20755.124011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[20755.132055] I-pipe: Domain RTAI unregistered.
[20755.132062] RTAI[hal]: unmounted.
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2 - 2.4.6
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Killing task emcsvr, PID=5446
Cleanup done
1.hal:88: Pin 'mux2.N.out' does not exist
5446
Unloading hal componentsКод: Выделить всё
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_SCRIPT_DIR=
EMC2_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
EMC2 - 2.4.6
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Killing task emcsvr, PID=5941
Cleanup done
1.hal:89: Pin 'halui.feed-override.value' does not exist
5941
