Re: Настраиваем контроллер to_pci.
Добавлено: 25 июн 2017, 13:46
Ок! Два устройства , будут оба на одном пине сидеть ?
Статьи, обзоры, цены на станки и комплектующие.
https://cnc-club.ru/forum/
[code]loadrt trivkins
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
# My driver
loadrt to_pci
loadrt pid names=pid.x,pid.z,pid.y
loadrt oneshot count=1
loadrt or2 count=1
loadrt and2 count=2
loadrt timedelay count=2
loadrt not count=2
# THREADS
addf to_pci.1.update servo-thread
addf motion-command-handler servo-thread
addf motion-controller servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf oneshot.0 servo-thread
addf or2.0 servo-thread
addf and2.0 servo-thread
addf timedelay.0 servo-thread
addf not.0 servo-thread
addf timedelay.1 servo-thread
addf not.1 servo-thread
addf and2.1 servo-thread
# -------E-STOP--------
net estop-ext iocontrol.0.emc-enable-in <= iocontrol.0.user-enable-out
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# external output signals
net machine-is-enabled to_pci.1.pins.pin-00-out
# external input signals
# --- MAX-X ---
net max-x <= to_pci.1.pins.pin-00-in-n
# --- MIN-X ---
net min-x <= to_pci.1.pins.pin-01-in-n
# --- HOME-X ---
net home-x <= to_pci.1.pins.pin-02-in-n
# --- MAX-Y ---
net max-y <= to_pci.1.pins.pin-03-in-n
# --- MIN-Y ---
net min-y <= to_pci.1.pins.pin-04-in-n
# --- HOME-Y ---
net home-y <= to_pci.1.pins.pin-05-in-n
# --- MAX-Z ---
net max-z <= to_pci.1.pins.pin-06-in-n
# --- MIN-Z ---
net min-z <= to_pci.1.pins.pin-07-in-n
# --- HOME-Z ---
net home-z <= to_pci.1.pins.pin-08-in-n
# rail lube on/off #
# смазка при включении длительностью 10 секунд
setp oneshot.0.width 10
net machine-is-on oneshot.0.in
net delay oneshot.0.out => or2.0.in0
net timer-delay => or2.0.in1
net rail-lube => or2.0.out
net rail-lube => to_pci.1.pins.pin-01-out
# интервал смазки 600 секунд длительностью 10 секунд
setp timedelay.0.on-delay 600
setp timedelay.0.off-delay 10
net machine-is-on => and2.0.in0
net timer-in => and2.0.in1
net timer-in-1 => and2.0.out
net timer-in-1 => timedelay.0.in
net timer-delay => timedelay.0.out
net timer-delay => not.0.in
net timer-in <= not.0.out
#spinle lube on/off#
# интервал смазки 900 секунд длительностью 10 секунд
setp timedelay.1.on-delay 900
setp timedelay.1.off-delay 10
net spindle-on => and2.1.in0
net timer-in => and2.1.in1
net timer-in-2 => and2.1.out
net timer-in-2 => timedelay.1.in
net timer-delay.1 => timedelay.1.out
net timer-delay.1 => not.1.in
net timer-in.1 <= not.1.out
net spindle-lube => to_pci.1.pins.pin-02-out
# AXIS X
setp pid.x.Pgain [AXIS_0]P
setp pid.x.Igain [AXIS_0]I
setp pid.x.Dgain [AXIS_0]D
setp pid.x.bias [AXIS_0]BIAS
setp pid.x.FF0 [AXIS_0]FF0
setp pid.x.FF1 [AXIS_0]FF1
setp pid.x.FF2 [AXIS_0]FF2
setp pid.x.deadband [AXIS_0]DEADBAND
setp pid.x.maxoutput [AXIS_0]MAX_OUTPUT
net x-enable => pid.x.enable
net x-output => pid.x.output
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
# --------fb--------------
setp to_pci.1.feedback.enc_scale0 [AXIS_0]ENCODER_SCALE
net x-pos-fb <= to_pci.1.feedback.encoder0
net x-pos-fb => axis.0.motor-pos-fb
# ------PWM Generator signals/setup--------
net x-enable axis.0.amp-enable-out
net x-enable => to_pci.1.enable_drive
setp to_pci.1.out_scale0 [AXIS_0]OUTPUT_SCALE
net x-output => to_pci.1.dcontrol0
net x-pos-cmd <= axis.0.motor-pos-cmd
# ---setup home / limit switch signals---
net home-x => axis.0.home-sw-in
net min-x => axis.0.neg-lim-sw-in
net max-x => axis.0.pos-lim-sw-in
# AXIS Y
setp pid.y.Pgain [AXIS_1]P
setp pid.y.Igain [AXIS_1]I
setp pid.y.Dgain [AXIS_1]D
setp pid.y.bias [AXIS_1]BIAS
setp pid.y.FF0 [AXIS_1]FF0
setp pid.y.FF1 [AXIS_1]FF1
setp pid.y.FF2 [AXIS_1]FF2
setp pid.y.deadband [AXIS_1]DEADBAND
setp pid.y.maxoutput [AXIS_1]MAX_OUTPUT
net y-enable => pid.y.enable
net y-output => pid.y.output
net y-pos-cmd => pid.y.command
net y-pos-fb => pid.y.feedback
setp to_pci.1.feedback.enc_scale1 [AXIS_1]ENCODER_SCALE
net y-pos-fb <= to_pci.1.feedback.encoder1
net y-pos-fb => axis.1.motor-pos-fb
net y-enable axis.1.amp-enable-out
setp to_pci.1.out_scale1 [AXIS_1]OUTPUT_SCALE
net y-output => to_pci.1.dcontrol1
net y-pos-cmd <= axis.1.motor-pos-cmd
net home-y => axis.1.home-sw-in
net min-y => axis.1.neg-lim-sw-in
net max-y => axis.1.pos-lim-sw-in
# AXIS Z
setp pid.z.Pgain [AXIS_2]P
setp pid.z.Igain [AXIS_2]I
setp pid.z.Dgain [AXIS_2]D
setp pid.z.bias [AXIS_2]BIAS
setp pid.z.FF0 [AXIS_2]FF0
setp pid.z.FF1 [AXIS_2]FF1
setp pid.z.FF2 [AXIS_2]FF2
setp pid.z.deadband [AXIS_2]DEADBAND
setp pid.z.maxoutput [AXIS_2]MAX_OUTPUT
net z-enable => pid.z.enable
net z-output => pid.z.output
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
setp to_pci.1.feedback.enc_scale2 [AXIS_2]ENCODER_SCALE
net z-pos-fb <= to_pci.1.feedback.encoder2
net z-pos-fb => axis.2.motor-pos-fb
net z-enable axis.2.amp-enable-out
setp to_pci.1.out_scale2 [AXIS_2]OUTPUT_SCALE
net z-output => to_pci.1.dcontrol2
net z-pos-cmd <= axis.2.motor-pos-cmd
net home-z => axis.2.home-sw-in
net min-z => axis.2.neg-lim-sw-in
net max-z => axis.2.pos-lim-sw-in
#_ _ _ SPINDLE _ _ _
net spindle-on <= motion.spindle-on
net spindle-cw <= motion.spindle-forward
net spindle-ccw <= motion.spindle-reverse
net spindle-enable => motion.spindle-at-speed
#============== PWM Generator command SPINDLE================
setp to_pci.1.out_scale3 [SPINDLE]OUTPUT_SCALE
net spindle-output to_pci.1.dcontrol3
net spindle-cw => to_pci.1.pins.pin-08-out
net spindle-ccw => to_pci.1.pins.pin-09-out
#----------- SIGNALS ---------------
#net buton_test => to_pci.1.feedback.index_en0
net buton_test => to_pci.1.pins.pin-10-outКод: Выделить всё
[code]# Generated by PNCconf at Sun May 22 23:57:42 2016
# Все изменения в этом файле будут перезаписаны
# overwritten when you run PNCconf again
[EMC]
MACHINE = mill
DEBUG = 0
[DISPLAY]
PYVCP = Panel.xml
DISPLAY = axis
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 1.2
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/q/Рабочий стол/Программы
INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm .005mm
DEFAULT_LINEAR_VELOCITY = 5.0000
MAX_LINEAR_VELOCITY = 80.000000
MIN_LINEAR_VELOCITY = 0.010000
DEFAULT_ANGULAR_VELOCITY = 0.250000
MAX_ANGULAR_VELOCITY = 1.000000
MIN_ANGULAR_VELOCITY = 0.010000
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
PROGRAM_EXTENSION = *,.png,.gif,.jpg Greyscale Depth Image
PROGRAM_EXTENSION = .py Python Script
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
COMM_WAIT = 0.010
SERVO_PERIOD = 1000000
[HOSTMOT2]
# **** This is for info only ****
# DRIVER0=hm2_pci
# BOARD0=5i20
[HAL]
HALUI = halui
HALFILE = stanok.hal
POSTGUI_HALFILE = custom_postgui.hal
[HALUI]
[TRAJ]
AXES = 3
COORDINATES = X Y Z
MAX_ANGULAR_VELOCITY = 360.00
DEFAULT_ANGULAR_VELOCITY = 36.00
LINEAR_UNITS = mm
ANGULAR_UNITS = degree
CYCLE_TIME = 0.010
DEFAULT_VELOCITY = 8
MAX_LINEAR_VELOCITY = 60.00
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
# Axis X
[AXIS_0]
TYPE = LINEAR
HOME = 0.0
FERROR = 40
MIN_FERROR = 1
MAX_VELOCITY = 50.0
MAX_ACCELERATION = 200.0
P = 4.0
I = 0.0
D = 0.02
FF0 = 0.0
FF1 = 0.065
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 10
ENCODER_SCALE = 1000
OUTPUT_SCALE = 1.0
MIN_LIMIT = 0.0
MAX_LIMIT = 400.0
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = -15
HOME_LATCH_VEL = -5
HOME_FINAL_VEL = 5
HOME_USE_INDEX = no
HOME_SEQUENCE = 1
HOME_IGNORE_LIMITS = no
# Axis Y
[AXIS_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 40
MIN_FERROR = 1
MAX_VELOCITY = 50.0
P = 4.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 0.03
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 10
OUTPUT_SCALE = -1.0
MIN_LIMIT = 0
MAX_LIMIT = 300.0
HOME_OFFSET = 0.0
HOME_SEARCH_VEL = 15
HOME_LATCH_VEL = 0.1
HOME_FINAL_VEL = 5
HOME_USE_INDEX = yes
HOME_SEQUENCE = 1
# Axis Z
[AXIS_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 40
MIN_FERROR = 0.1
MAX_VELOCITY = 50
P = 4.0
I = 0.0
D = 0.02
FF0 = 0.0
FF1 = 0.065
FF2 = 0.0
BIAS = 0
DEADBAND = 0.0
MAX_OUTPUT = 10
OUTPUT_SCALE = 1.0
MIN_LIMIT = -400
MAX_LIMIT = 0
HOME_OFFSET = 0.0
HOME_LATCH_VEL = 5
HOME_FINAL_VEL = 5
HOME_USE_INDEX = no
HOME_SEQUENCE = 1
# Spindle
[SPINDLE]
P = 1
I = 0
D = 0
FF0 = 0
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 10
OUTPUT_SCALE = 1.0Решили проблему?MGG писал(а):Ну все равно не работает )
нет, не видит. буду пробовать через лптT00T писал(а):ешили проблему?
Ошибаетесь. Однажды подвесил LinuxCNC. После этого вывел все управление в отдельную плату с реле. При любой ошибке (наезд на лимит, авария с любого усилка) релюхой рвутся сигналы ServoON и EMG всех усилков, и замыкается пин EMG для LinuxCNC.MGG писал(а):Правда я как-то ненагуглил, чтобы линуха висла на ходу
LinuxCNC может повиснуть как и любая другая прикладная программа, для этого достаточно просто внутри её начать выполнять бесконечный цикл или ещё какую фигню.Nikomas писал(а):Однажды подвесил LinuxCNC
2ГБ точно есть, возможно и больше. У меня еще есть вопросы к материнке, есть подозрения что подглючивает. Этот способ у меня стабильно вешает, больше проблем не было.UAVpilot писал(а):Попробовал несколько раз - без проблем.
Может у тебя памяти мало и свопа нет?..
1. Вы сначала скажите к какой голове и для какого станка, если 16А20 - то в конфиге для токарника именно она.maratNC писал(а):А теперь вопросы:
1. Алгоритм работы револьверной работы есть у кого нибудь? T00T, в Вашей конфигурации код какой то есть управления головой, она проверялась ? или требуется доработка? Насколько понял логика реализована на Ladder.
2. Как посмотреть Ladder Вашей логики управления?
3. T00T, на плате ввода вывода есть дополнительные выходы, их напрямую к обмоткам реле подключать можно?
