Друзья, не могу установить драйвера на тачскрин. (P.s. на Windows 10 всё отлично работает) Скачал все драйвера что можно, ноль реакции.
Драйвера брал отсюда
http://www.eeti.com.tw/drivers_Linux.html
Тач такой
https://item.taobao.com/item.htm?spm=a2 ... t=1#detail
Перехожу в терминале в папку с установочным файлом, пишу sh setup.sh
(*) Driver installer for touch controller
(*) Script Version = 1.04.6730
(I) Check user permission: root, you are the supervisor.
(I) Platform application binary interface = i686
(W) X server detected.
Declaration and Disclaimer
The programs, including but not limited to software and/or firmware (hereinafter referred to "Programs" or "PROGRAMS", are owned by eGalax_eMPIA Technology Inc. (hereinafter referred to EETI) and are compiled from EETI Source code. EETI hereby grants to licensee a personal, non-exclusive, non-transferable license to copy, use and create derivative works of Programs for the sole purpose in conjunction with an EETI Product, including but not limited to integrated circuit and/or controller. Any reproduction, copies, modification, translation, compilation, application, or representation of Programs except as specified above is prohibited without the express written permission by EETI.
Disclaimer: EETI MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH REGARD TO PROGRAMS, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE. EETI reserves the right to make changes without further notice to the Programs described herein. Licensee agrees that EETI does not assume any liability, damages or costs, including but not limited to attorney fees, arising out from Programs themselves or those arising out from the application or combination Programs into other products or circuit. The use or the inclusion of EETI's Programs implies that the Licensee assumes all risk of such use and in doing so indemnifies EETI against all charges, including but not limited to any claims to infringement of any third party's intellectual property right.
Do you agree with above patent declaration?
[Y] Yes, I agree. [N] No, I don't agree.
Y
(Q) Which interface controller do you use?
(I) [1] RS232 [2] USB [3] PS2 : 2
(I) Please confirm the touch controller is linked with your device. Press [Enter] key to continue..........
(I) Copying eGTouch.sh to /etc/rcS.d.
(I) /etc/rcS.d path found.
setup.sh: 235: [: Illegal number: 4-9-rtai-686-pae
(I) Found hidraw module enabled in system
(I) X.Org X server 1.12.4
(I) X version is 1.7.6 upwards
(I) Found uinput at path /dev/uinput
cp: не удалось выполнить stat для «eGTouch32/eGTouch32withX»: Нет такого файла или каталога
(I) Place eGTouch driver archive to /usr/local/eGTouch32withX.
cp: не удалось выполнить stat для «/usr/local/eGTouch32withX/eGTouchL.ini»: Нет такого файла или каталога
(I) Copy eGTouchL.ini to /etc failed.
root@GomelCNC:/media/usb1/Drivers/Touch#
