Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.7.12
Machine configuration directory is '/home/user1/linuxcnc/configs/machin1'
Machine configuration file is 'machin1.ini'
INIFILE=/home/user1/linuxcnc/configs/machin1/machin1.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Found file(REL): ./machin1.hal
Found file(REL): ./custom.hal
Starting TASK program: milltask
Starting DISPLAY program: axis
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=7314
Killing task milltask, PID=7365
task: 75 cycles, min=0.000016, max=0.010858, avg=0.008105, 0 latency excursions (> 10x expected cycle time of 0.010000s)
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
X Error of failed request: BadRequest (invalid request code or no such operation)
Major opcode of failed request: 135 (GLX)
Minor opcode of failed request: 19 (X_GLXQueryServerString)
Serial number of failed request: 713
Current serial number in output stream: 713
7314
PID TTY STAT TIME COMMAND
7365
Stopping realtime threads
Unloading hal components
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Debian 4.6.3-14) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e4000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000007ff90000 (usable)
[ 0.000000] BIOS-e820: 000000007ff90000 - 000000007ff9e000 (ACPI data)
[ 0.000000] BIOS-e820: 000000007ff9e000 - 000000007ffe0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 000000007ffe0000 - 0000000080000000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb80000 - 0000000100000000 (reserved)
[ 0.000000] Notice: NX (Execute Disable) protection missing in CPU!
[ 0.000000] SMBIOS 2.4 present.
[ 0.000000] DMI: System manufacturer System Product Name/P5LD2-VM SE, BIOS 0701 06/01/2007
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x7ff90 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-DFFFF uncachable
[ 0.000000] E0000-EFFFF write-through
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask F80000000 write-back
[ 0.000000] 1 disabled
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] found SMP MP-table at [c00ff780] ff780
[ 0.000000] initial memory mapped : 0 - 01800000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0037400000 page 2M
[ 0.000000] 0037400000 - 00377fe000 page 4k
[ 0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[ 0.000000] RAMDISK: 36528000 - 3728c000
[ 0.000000] ACPI: RSDP 000fa5d0 00014 (v00 ACPIAM)
[ 0.000000] ACPI: RSDT 7ff90000 0003C (v01 NEC 06000701 MSFT 00000097)
[ 0.000000] ACPI: FACP 7ff90200 00081 (v01 A_M_I_ OEMFACP 06000701 MSFT 00000097)
[ 0.000000] ACPI: DSDT 7ff90590 04B7F (v01 A0607 A0607021 00000021 INTL 20060113)
[ 0.000000] ACPI: FACS 7ff9e000 00040
[ 0.000000] ACPI: SLIC 7ff90410 00176 (v01 NEC 06000701 MSFT 00000097)
[ 0.000000] ACPI: OEMB 7ff9e040 0006B (v01 A_M_I_ AMI_OEM 06000701 MSFT 00000097)
[ 0.000000] ACPI: HPET 7ff95110 00038 (v01 A_M_I_ OEMHPET 06000701 MSFT 00000097)
[ 0.000000] ACPI: MCFG 7ff95150 0003C (v01 A_M_I_ OEMMCFG 06000701 MSFT 00000097)
[ 0.000000] ACPI: ASF! 7ff9518c 00099 (v32 LEGEND I865PASF 00000001 INTL 20060113)
[ 0.000000] 1159MB HIGHMEM available.
[ 0.000000] 887MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 377fe000
[ 0.000000] low ram: 0 - 377fe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x000377fe
[ 0.000000] HighMem 0x000377fe -> 0x0007ff90
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] Early memory PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0007ff90
[ 0.000000] On node 0 totalpages: 524063
[ 0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f5528200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1744 pages used for memmap
[ 0.000000] Normal zone: 221486 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2320 pages used for memmap
[ 0.000000] HighMem zone: 294530 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: No APIC-table, disabling MPS
[ 0.000000] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Found and enabled local APIC!
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e4000
[ 0.000000] PM: Registered nosave memory: 00000000000e4000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at 80000000 (gap: 80000000:7fb80000)
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 17 pages/cpu @f77e0000 s48384 r0 d21248 u69632
[ 0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 519967
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=474e0187-5588-494e-8a03-f7e28e57d19d ro initrd=/install/gtk/initrd.gz lapic quiet rootdelay=5
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 4193280 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (000377fe:0007ff90)
[ 0.000000] Memory: 2055280k/2096704k available (3495k kernel code, 40972k reserved, 1237k data, 416k init, 1187400k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff17000 - 0xfffff000 ( 928 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xf7ffe000 - 0xff7fe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf77fe000 ( 887 MB)
[ 0.000000] .init : 0xc14a0000 - 0xc1508000 ( 416 kB)
[ 0.000000] .data : 0xc1369d4a - 0xc149f480 (1237 kB)
[ 0.000000] .text : 0xc1000000 - 0xc1369d4a (3495 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[ 0.000000] CPU 0 irqstacks, hard=f5006000 soft=f5008000
[ 0.000000] Interrupt pipeline (release #3)
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2127.796 MHz processor.
[ 0.004001] Calibrating delay loop (skipped), value calculated using timer frequency.. 4255.59 BogoMIPS (lpj=8511184)
[ 0.004007] pid_max: default: 32768 minimum: 301
[ 0.004051] Security Framework initialized
[ 0.004055] AppArmor: AppArmor disabled by boot time parameter
[ 0.004073] Mount-cache hash table entries: 512
[ 0.008081] Initializing cgroup subsys cpuacct
[ 0.008084] Initializing cgroup subsys memory
[ 0.008093] Initializing cgroup subsys devices
[ 0.008095] Initializing cgroup subsys freezer
[ 0.008097] Initializing cgroup subsys net_cls
[ 0.008100] Initializing cgroup subsys blkio
[ 0.008107] Initializing cgroup subsys perf_event
[ 0.008136] CPU: Physical Processor ID: 0
[ 0.008138] CPU: Processor Core ID: 0
[ 0.008140] mce: CPU supports 6 MCE banks
[ 0.008148] CPU0: Thermal monitoring enabled (TM2)
[ 0.008203] SMP alternatives: switching to UP code
[ 0.011606] Freeing SMP alternatives: 16k freed
[ 0.011611] ACPI: Core revision 20120320
[ 0.014764] ACPI: setting ELCR to 0200 (from 0c38)
[ 0.015018] weird, boot CPU (#0) not listed by the BIOS.
[ 0.015020] SMP motherboard not detected.
[ 0.015025] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.016000] SMP disabled
[ 0.016000] Performance Events: PEBS fmt0-, 4-deep LBR, Core2 events, Intel PMU driver.
[ 0.016000] PEBS disabled due to CPU errata.
[ 0.016000] ... version: 2
[ 0.016000] ... bit width: 40
[ 0.016000] ... generic registers: 2
[ 0.016000] ... value mask: 000000ffffffffff
[ 0.016000] ... max period: 000000007fffffff
[ 0.016000] ... fixed-purpose events: 3
[ 0.016000] ... event mask: 0000000700000003
[ 0.024030] NMI watchdog: enabled, takes one hw-pmu counter.
[ 0.024060] Brought up 1 CPUs
[ 0.024063] Total of 1 processors activated (4255.59 BogoMIPS).
[ 0.024191] devtmpfs: initialized
[ 0.024476] PM: Registering ACPI NVS region [mem 0x7ff9e000-0x7ffdffff] (270336 bytes)
[ 0.024594] dummy:
[ 0.024650] NET: Registered protocol family 16
[ 0.024809] ACPI: bus type pci registered
[ 0.024870] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.024873] PCI: Intel Corporation 945G/GZ/P/PL Express Memory Controller Hub with MMCONFIG support
[ 0.024878] PCI: not using MMCONFIG
[ 0.025235] PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=4
[ 0.025238] PCI: Using configuration type 1 for base access
[ 0.025921] bio: create slab <bio-0> at 0
[ 0.026007] ACPI: Added _OSI(Module Device)
[ 0.026010] ACPI: Added _OSI(Processor Device)
[ 0.026013] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.026016] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.027298] ACPI: EC: Look up EC in DSDT
[ 0.028987] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.032202] ACPI: Interpreter enabled
[ 0.032219] ACPI: (supports S0 S1 S4 S5)
[ 0.032248] ACPI: Using PIC for interrupt routing
[ 0.040657] ACPI: No dock devices found.
[ 0.040665] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.040737] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.040852] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.040855] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.040858] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.040862] pci_root PNP0A08:00: host bridge window [mem 0x80010000-0xffffffff] (ignored)
[ 0.040865] PCI: root bus 00: using default resources
[ 0.040902] PCI host bridge to bus 0000:00
[ 0.040906] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.040909] pci_bus 0000:00: root bus resource [mem 0x00000000-0xffffffff]
[ 0.040922] pci 0000:00:00.0: [8086:2770] type 00 class 0x060000
[ 0.040967] pci 0000:00:01.0: [8086:2771] type 01 class 0x060400
[ 0.041004] pci 0000:00:01.0: PME# supported from D0 D3hot D3cold
[ 0.041049] pci 0000:00:1c.0: [8086:27d0] type 01 class 0x060400
[ 0.041108] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.041131] pci 0000:00:1c.1: [8086:27d2] type 01 class 0x060400
[ 0.041189] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.041215] pci 0000:00:1d.0: [8086:27c8] type 00 class 0x0c0300
[ 0.041258] pci 0000:00:1d.0: reg 20: [io 0x8000-0x801f]
[ 0.041289] pci 0000:00:1d.1: [8086:27c9] type 00 class 0x0c0300
[ 0.041331] pci 0000:00:1d.1: reg 20: [io 0x8400-0x841f]
[ 0.041363] pci 0000:00:1d.2: [8086:27ca] type 00 class 0x0c0300
[ 0.041405] pci 0000:00:1d.2: reg 20: [io 0x8800-0x881f]
[ 0.041436] pci 0000:00:1d.3: [8086:27cb] type 00 class 0x0c0300
[ 0.041478] pci 0000:00:1d.3: reg 20: [io 0x9000-0x901f]
[ 0.041519] pci 0000:00:1d.7: [8086:27cc] type 00 class 0x0c0320
[ 0.041539] pci 0000:00:1d.7: reg 10: [mem 0xcfdffc00-0xcfdfffff]
[ 0.041612] pci 0000:00:1d.7: PME# supported from D0 D3hot D3cold
[ 0.041633] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[ 0.041693] pci 0000:00:1f.0: [8086:27b8] type 00 class 0x060100
[ 0.041780] pci 0000:00:1f.0: ICH7 LPC Generic IO decode 2 PIO at 0290 (mask 0007)
[ 0.041814] pci 0000:00:1f.1: [8086:27df] type 00 class 0x01018a
[ 0.041827] pci 0000:00:1f.1: reg 10: [io 0x0000-0x0007]
[ 0.041837] pci 0000:00:1f.1: reg 14: [io 0x0000-0x0003]
[ 0.041847] pci 0000:00:1f.1: reg 18: [io 0x0000-0x0007]
[ 0.041857] pci 0000:00:1f.1: reg 1c: [io 0x0000-0x0003]
[ 0.041867] pci 0000:00:1f.1: reg 20: [io 0xffa0-0xffaf]
[ 0.041903] pci 0000:00:1f.2: [8086:27c0] type 00 class 0x01018f
[ 0.041918] pci 0000:00:1f.2: reg 10: [io 0xa800-0xa807]
[ 0.041927] pci 0000:00:1f.2: reg 14: [io 0xa400-0xa403]
[ 0.041936] pci 0000:00:1f.2: reg 18: [io 0xa000-0xa007]
[ 0.041945] pci 0000:00:1f.2: reg 1c: [io 0x9800-0x9803]
[ 0.041954] pci 0000:00:1f.2: reg 20: [io 0x9400-0x940f]
[ 0.041984] pci 0000:00:1f.2: PME# supported from D3hot
[ 0.042000] pci 0000:00:1f.3: [8086:27da] type 00 class 0x0c0500
[ 0.042053] pci 0000:00:1f.3: reg 20: [io 0x0400-0x041f]
[ 0.042127] pci 0000:04:00.0: [1002:94c3] type 00 class 0x030000
[ 0.042142] pci 0000:04:00.0: reg 10: [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.042155] pci 0000:04:00.0: reg 18: [mem 0xcffe0000-0xcffeffff 64bit]
[ 0.042164] pci 0000:04:00.0: reg 20: [io 0xe000-0xe0ff]
[ 0.042179] pci 0000:04:00.0: reg 30: [mem 0xcffc0000-0xcffdffff pref]
[ 0.042200] pci 0000:04:00.0: supports D1 D2
[ 0.042221] pci 0000:04:00.1: [1002:aa10] type 00 class 0x040300
[ 0.042235] pci 0000:04:00.1: reg 10: [mem 0xcfffc000-0xcfffffff 64bit]
[ 0.042287] pci 0000:04:00.1: supports D1 D2
[ 0.048016] pci 0000:00:01.0: PCI bridge to [bus 04-04]
[ 0.048020] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.048024] pci 0000:00:01.0: bridge window [mem 0xcff00000-0xcfffffff]
[ 0.048029] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.048071] pci 0000:00:1c.0: PCI bridge to [bus 03-03]
[ 0.048076] pci 0000:00:1c.0: bridge window [io 0xd000-0xdfff]
[ 0.048153] pci 0000:02:00.0: [8086:109a] type 00 class 0x020000
[ 0.048177] pci 0000:02:00.0: reg 10: [mem 0xcfee0000-0xcfefffff]
[ 0.048211] pci 0000:02:00.0: reg 18: [io 0xc800-0xc81f]
[ 0.048326] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.048354] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.048369] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 0.048373] pci 0000:00:1c.1: bridge window [io 0xc000-0xcfff]
[ 0.048378] pci 0000:00:1c.1: bridge window [mem 0xcfe00000-0xcfefffff]
[ 0.048445] pci 0000:00:1e.0: PCI bridge to [bus 01-01] (subtractive decode)
[ 0.048450] pci 0000:00:1e.0: bridge window [io 0xb000-0xbfff]
[ 0.048458] pci 0000:00:1e.0: bridge window [io 0x0000-0xffff] (subtractive decode)
[ 0.048462] pci 0000:00:1e.0: bridge window [mem 0x00000000-0xffffffff] (subtractive decode)
[ 0.048480] pci_bus 0000:00: on NUMA node 0
[ 0.048484] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.048732] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.048800] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P3._PRT]
[ 0.048924] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P4._PRT]
[ 0.048992] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P5._PRT]
[ 0.049081] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0e)
[ 0.054118] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.054188] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.054255] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 *4 5 6 7 10 11 12 14 15)
[ 0.054322] ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 7 10 11 12 14 15)
[ 0.054390] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.054457] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.054525] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.054594] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
[ 0.054688] vgaarb: device added: PCI:0000:04:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.054693] vgaarb: loaded
[ 0.054695] vgaarb: bridge control possible 0000:04:00.0
[ 0.054728] PCI: Using ACPI for IRQ routing
[ 0.054731] PCI: pci_cache_line_size set to 64 bytes
[ 0.054796] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.054799] reserve RAM buffer: 000000007ff90000 - 000000007fffffff
[ 0.054952] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.054959] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.056017] Switching to clocksource hpet
[ 0.056065] pnp: PnP ACPI init
[ 0.056078] ACPI: bus type pnp registered
[ 0.056154] pnp 00:00: [bus 00-ff]
[ 0.056157] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.056160] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.056163] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.056166] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.056169] pnp 00:00: [mem 0x80010000-0xffffffff window]
[ 0.056212] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.056226] pnp 00:01: [mem 0xfed13000-0xfed19fff]
[ 0.056268] system 00:01: [mem 0xfed13000-0xfed19fff] has been reserved
[ 0.056272] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.056313] pnp 00:02: [dma 4]
[ 0.056316] pnp 00:02: [io 0x0000-0x000f]
[ 0.056318] pnp 00:02: [io 0x0081-0x0083]
[ 0.056321] pnp 00:02: [io 0x0087]
[ 0.056323] pnp 00:02: [io 0x0089-0x008b]
[ 0.056325] pnp 00:02: [io 0x008f]
[ 0.056328] pnp 00:02: [io 0x00c0-0x00df]
[ 0.056358] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.056374] pnp 00:03: [io 0x0070-0x0071]
[ 0.056377] pnp 00:03: [irq 8]
[ 0.056406] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.056419] pnp 00:04: [io 0x0061]
[ 0.056450] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.056463] pnp 00:05: [io 0x00f0-0x00ff]
[ 0.056466] pnp 00:05: [irq 13]
[ 0.056496] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.057238] pnp 00:06: [irq 7]
[ 0.057242] pnp 00:06: [dma 0 disabled]
[ 0.057245] pnp 00:06: [io 0x0378-0x037f]
[ 0.057445] pnp 00:06: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.057488] pnp 00:07: [io 0x0000-0xffffffff disabled]
[ 0.057492] pnp 00:07: [io 0x0000-0xffffffff disabled]
[ 0.057494] pnp 00:07: [io 0x0290-0x0297]
[ 0.057543] system 00:07: [io 0x0290-0x0297] has been reserved
[ 0.057547] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.057695] pnp 00:08: [io 0x0010-0x001f]
[ 0.057698] pnp 00:08: [io 0x0022-0x003f]
[ 0.057700] pnp 00:08: [io 0x0044-0x005f]
[ 0.057703] pnp 00:08: [io 0x0062-0x0063]
[ 0.057705] pnp 00:08: [io 0x0065-0x006f]
[ 0.057708] pnp 00:08: [io 0x0072-0x007f]
[ 0.057710] pnp 00:08: [io 0x0080]
[ 0.057713] pnp 00:08: [io 0x0084-0x0086]
[ 0.057715] pnp 00:08: [io 0x0088]
[ 0.057718] pnp 00:08: [io 0x008c-0x008e]
[ 0.057720] pnp 00:08: [io 0x0090-0x009f]
[ 0.057723] pnp 00:08: [io 0x00a2-0x00bf]
[ 0.057725] pnp 00:08: [io 0x00e0-0x00ef]
[ 0.057727] pnp 00:08: [io 0x04d0-0x04d1]
[ 0.057732] pnp 00:08: [io 0x0800-0x087f]
[ 0.057734] pnp 00:08: [io 0x0400-0x041f]
[ 0.057737] pnp 00:08: [io 0x0480-0x04bf]
[ 0.057739] pnp 00:08: [mem 0xfed1c000-0xfed1ffff]
[ 0.057742] pnp 00:08: [mem 0xfed20000-0xfed8ffff]
[ 0.057745] pnp 00:08: [mem 0xffb00000-0xffbfffff]
[ 0.057747] pnp 00:08: [mem 0xfff00000-0xffffffff]
[ 0.057809] system 00:08: [io 0x04d0-0x04d1] has been reserved
[ 0.057813] system 00:08: [io 0x0800-0x087f] has been reserved
[ 0.057816] system 00:08: [io 0x0400-0x041f] has been reserved
[ 0.057820] system 00:08: [io 0x0480-0x04bf] has been reserved
[ 0.057823] system 00:08: [mem 0xfed1c000-0xfed1ffff] has been reserved
[ 0.057826] system 00:08: [mem 0xfed20000-0xfed8ffff] has been reserved
[ 0.057830] system 00:08: [mem 0xffb00000-0xffbfffff] could not be reserved
[ 0.057833] system 00:08: [mem 0xfff00000-0xffffffff] has been reserved
[ 0.057837] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.057930] pnp 00:09: [mem 0xfed00000-0xfed003ff]
[ 0.057964] pnp 00:09: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.058003] pnp 00:0a: [io 0x0060]
[ 0.058006] pnp 00:0a: [io 0x0064]
[ 0.058009] pnp 00:0a: [irq 1]
[ 0.058049] pnp 00:0a: Plug and Play ACPI device, IDs PNP0303 PNP030b (active)
[ 0.058111] pnp 00:0b: [irq 12]
[ 0.058150] pnp 00:0b: Plug and Play ACPI device, IDs PNP0f03 PNP0f13 (active)
[ 0.058220] pnp 00:0c: [mem 0xfec00000-0xfec00fff]
[ 0.058223] pnp 00:0c: [mem 0xfee00000-0xfee00fff]
[ 0.058273] system 00:0c: [mem 0xfec00000-0xfec00fff] has been reserved
[ 0.058276] system 00:0c: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.058280] system 00:0c: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.058529] pnp 00:0d: [mem 0xe0000000-0xefffffff]
[ 0.058578] system 00:0d: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.058582] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.058633] pnp 00:0e: [mem 0xe0000000-0xefffffff]
[ 0.058684] system 00:0e: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.058688] system 00:0e: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.058862] pnp 00:0f: [mem 0x00000000-0x0009ffff]
[ 0.058865] pnp 00:0f: [mem 0x000c0000-0x000dffff]
[ 0.058868] pnp 00:0f: [mem 0x000e0000-0x000fffff]
[ 0.058870] pnp 00:0f: [mem 0x00100000-0x7fffffff]
[ 0.058873] pnp 00:0f: [mem 0x00000000-0xffffffff disabled]
[ 0.058929] system 00:0f: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.058933] system 00:0f: [mem 0x000c0000-0x000dffff] could not be reserved
[ 0.058937] system 00:0f: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.058940] system 00:0f: [mem 0x00100000-0x7fffffff] could not be reserved
[ 0.058944] system 00:0f: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.059129] pnp: PnP ACPI: found 16 devices
[ 0.059132] ACPI: ACPI bus type pnp unregistered
[ 0.059135] PnPBIOS: Disabled by ACPI PNP
[ 0.095452] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 03-03] add_size 200000
[ 0.095457] pci 0000:00:1c.0: bridge window [mem 0x00100000-0x000fffff] to [bus 03-03] add_size 200000
[ 0.095476] pci 0000:00:1c.0: res[14]=[mem 0x00100000-0x000fffff] get_res_add_size add_size 200000
[ 0.095480] pci 0000:00:1c.0: res[15]=[mem 0x00100000-0x000fffff 64bit pref] get_res_add_size add_size 200000
[ 0.095485] pci 0000:00:1c.0: BAR 14: assigned [mem 0x80000000-0x801fffff]
[ 0.095488] pci 0000:00:1c.0: BAR 15: assigned [mem 0x80200000-0x803fffff 64bit pref]
[ 0.095492] pci 0000:00:01.0: PCI bridge to [bus 04-04]
[ 0.095496] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.095500] pci 0000:00:01.0: bridge window [mem 0xcff00000-0xcfffffff]
[ 0.095504] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.095510] pci 0000:00:1c.0: PCI bridge to [bus 03-03]
[ 0.095513] pci 0000:00:1c.0: bridge window [io 0xd000-0xdfff]
[ 0.095519] pci 0000:00:1c.0: bridge window [mem 0x80000000-0x801fffff]
[ 0.095523] pci 0000:00:1c.0: bridge window [mem 0x80200000-0x803fffff 64bit pref]
[ 0.095530] pci 0000:00:1c.1: PCI bridge to [bus 02-02]
[ 0.095533] pci 0000:00:1c.1: bridge window [io 0xc000-0xcfff]
[ 0.095539] pci 0000:00:1c.1: bridge window [mem 0xcfe00000-0xcfefffff]
[ 0.095547] pci 0000:00:1e.0: PCI bridge to [bus 01-01]
[ 0.095551] pci 0000:00:1e.0: bridge window [io 0xb000-0xbfff]
[ 0.095650] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
[ 0.095653] PCI: setting IRQ 11 as level-triggered
[ 0.095747] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 10
[ 0.095750] PCI: setting IRQ 10 as level-triggered
[ 0.095762] pci 0000:00:1e.0: setting latency timer to 64
[ 0.095767] pci_bus 0000:00: resource 4 [io 0x0000-0xffff]
[ 0.095770] pci_bus 0000:00: resource 5 [mem 0x00000000-0xffffffff]
[ 0.095773] pci_bus 0000:04: resource 0 [io 0xe000-0xefff]
[ 0.095775] pci_bus 0000:04: resource 1 [mem 0xcff00000-0xcfffffff]
[ 0.095778] pci_bus 0000:04: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.095781] pci_bus 0000:03: resource 0 [io 0xd000-0xdfff]
[ 0.095784] pci_bus 0000:03: resource 1 [mem 0x80000000-0x801fffff]
[ 0.095787] pci_bus 0000:03: resource 2 [mem 0x80200000-0x803fffff 64bit pref]
[ 0.095790] pci_bus 0000:02: resource 0 [io 0xc000-0xcfff]
[ 0.095792] pci_bus 0000:02: resource 1 [mem 0xcfe00000-0xcfefffff]
[ 0.095795] pci_bus 0000:01: resource 0 [io 0xb000-0xbfff]
[ 0.095798] pci_bus 0000:01: resource 4 [io 0x0000-0xffff]
[ 0.095800] pci_bus 0000:01: resource 5 [mem 0x00000000-0xffffffff]
[ 0.095860] NET: Registered protocol family 2
[ 0.095921] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.096111] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.096532] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.096754] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.096757] TCP: reno registered
[ 0.096760] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.096770] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.096846] NET: Registered protocol family 1
[ 0.096983] ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 5
[ 0.096986] PCI: setting IRQ 5 as level-triggered
[ 0.097115] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 4
[ 0.097118] PCI: setting IRQ 4 as level-triggered
[ 0.097222] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 3
[ 0.097225] PCI: setting IRQ 3 as level-triggered
[ 0.097298] pci 0000:04:00.0: Boot video device
[ 0.097308] PCI: CLS 16 bytes, default 64
[ 0.097365] Unpacking initramfs...
[ 0.403787] Freeing initrd memory: 13712k freed
[ 0.409468] audit: initializing netlink socket (disabled)
[ 0.409486] type=2000 audit(1525653146.408:1): initialized
[ 0.422156] highmem bounce pool size: 64 pages
[ 0.422162] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.422293] VFS: Disk quotas dquot_6.5.2
[ 0.422317] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.422396] msgmni has been set to 1721
[ 0.422559] alg: No test for stdrng (krng)
[ 0.422583] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.422588] io scheduler noop registered
[ 0.422590] io scheduler deadline registered
[ 0.422603] io scheduler cfq registered (default)
[ 0.422789] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.422809] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.422812] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.423199] GHES: HEST is not enabled!
[ 0.423213] isapnp: Scanning for PnP cards...
[ 0.776278] isapnp: No Plug & Play device found
[ 0.776318] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.776837] Linux agpgart interface v0.103
[ 0.777097] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 0.779717] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.779750] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 0.779841] mousedev: PS/2 mouse device common for all mice
[ 0.779893] rtc_cmos 00:03: RTC can wake from S4
[ 0.780019] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 0.780040] rtc0: alarms up to one month, 114 bytes nvram, hpet irqs
[ 0.780178] TCP: cubic registered
[ 0.780217] NET: Registered protocol family 10
[ 0.780461] Mobile IPv6
[ 0.780464] NET: Registered protocol family 17
[ 0.780469] Registering the dns_resolver key type
[ 0.780533] Using IPI No-Shortcut mode
[ 0.780617] PM: Hibernation image not present or could not be loaded.
[ 0.780629] registered taskstats version 1
[ 0.780928] rtc_cmos 00:03: setting system clock to 2018-05-07 00:32:27 UTC (1525653147)
[ 0.781011] Freeing unused kernel memory: 416k freed
[ 0.781187] Write protecting the kernel text: 3496k
[ 0.781205] Write protecting the kernel read-only data: 984k
[ 0.797435] udevd[45]: starting version 175
[ 0.801534] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input0
[ 0.858888] usbcore: registered new interface driver usbfs
[ 0.858917] usbcore: registered new interface driver hub
[ 0.864947] SCSI subsystem initialized
[ 0.881400] usbcore: registered new device driver usb
[ 0.881917] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.881981] ehci_hcd 0000:00:1d.7: setting latency timer to 64
[ 0.881986] ehci_hcd 0000:00:1d.7: EHCI Host Controller
[ 0.882012] ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
[ 0.882031] ehci_hcd 0000:00:1d.7: using broken periodic workaround
[ 0.882041] ehci_hcd 0000:00:1d.7: debug port 1
[ 0.887708] e1000e: Intel(R) PRO/1000 Network Driver - 1.9.5-k
[ 0.887712] e1000e: Copyright(c) 1999 - 2012 Intel Corporation.
[ 0.887732] e1000e 0000:02:00.0: Disabling ASPM L0s L1
[ 0.887851] e1000e 0000:02:00.0: (unregistered net_device): Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[ 0.894411] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.902569] libata version 3.00 loaded.
[ 0.915973] ehci_hcd 0000:00:1d.7: cache line size of 16 is not supported
[ 0.915988] ehci_hcd 0000:00:1d.7: irq 5, io mem 0xcfdffc00
[ 0.924083] ehci_hcd 0000:00:1d.7: USB 2.0 started, EHCI 1.00
[ 0.924116] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.924120] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.924122] usb usb1: Product: EHCI Host Controller
[ 0.924125] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[ 0.924128] usb usb1: SerialNumber: 0000:00:1d.7
[ 0.924251] hub 1-0:1.0: USB hub found
[ 0.924257] hub 1-0:1.0: 8 ports detected
[ 0.924798] uhci_hcd 0000:00:1d.0: setting latency timer to 64
[ 0.924803] uhci_hcd 0000:00:1d.0: UHCI Host Controller
[ 0.924813] uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
[ 0.924841] uhci_hcd 0000:00:1d.0: irq 5, io base 0x00008000
[ 0.924879] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.924882] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.924885] usb usb2: Product: UHCI Host Controller
[ 0.924887] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 0.924890] usb usb2: SerialNumber: 0000:00:1d.0
[ 0.925099] hub 2-0:1.0: USB hub found
[ 0.925105] hub 2-0:1.0: 2 ports detected
[ 0.925195] uhci_hcd 0000:00:1d.1: setting latency timer to 64
[ 0.925199] uhci_hcd 0000:00:1d.1: UHCI Host Controller
[ 0.925207] uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
[ 0.925232] uhci_hcd 0000:00:1d.1: irq 10, io base 0x00008400
[ 0.925268] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.925271] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.925274] usb usb3: Product: UHCI Host Controller
[ 0.925276] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 0.925279] usb usb3: SerialNumber: 0000:00:1d.1
[ 0.925387] hub 3-0:1.0: USB hub found
[ 0.925392] hub 3-0:1.0: 2 ports detected
[ 0.925478] uhci_hcd 0000:00:1d.2: setting latency timer to 64
[ 0.925482] uhci_hcd 0000:00:1d.2: UHCI Host Controller
[ 0.925490] uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
[ 0.925517] uhci_hcd 0000:00:1d.2: irq 4, io base 0x00008800
[ 0.925553] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.925556] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.925559] usb usb4: Product: UHCI Host Controller
[ 0.925562] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 0.925564] usb usb4: SerialNumber: 0000:00:1d.2
[ 0.925671] hub 4-0:1.0: USB hub found
[ 0.925677] hub 4-0:1.0: 2 ports detected
[ 0.925763] uhci_hcd 0000:00:1d.3: setting latency timer to 64
[ 0.925767] uhci_hcd 0000:00:1d.3: UHCI Host Controller
[ 0.925775] uhci_hcd 0000:00:1d.3: new USB bus registered, assigned bus number 5
[ 0.925800] uhci_hcd 0000:00:1d.3: irq 3, io base 0x00009000
[ 0.925835] usb usb5: New USB device found, idVendor=1d6b, idProduct=0001
[ 0.925838] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.925841] usb usb5: Product: UHCI Host Controller
[ 0.925843] usb usb5: Manufacturer: Linux 3.4-9-rtai-686-pae uhci_hcd
[ 0.925846] usb usb5: SerialNumber: 0000:00:1d.3
[ 0.925957] hub 5-0:1.0: USB hub found
[ 0.925962] hub 5-0:1.0: 2 ports detected
[ 0.926041] ata_piix 0000:00:1f.1: version 2.13
[ 0.926086] ata_piix 0000:00:1f.1: setting latency timer to 64
[ 0.929543] scsi0 : ata_piix
[ 0.930968] microcode: CPU0 sig=0x6f2, pf=0x1, revision=0x56
[ 0.932247] scsi1 : ata_piix
[ 0.934951] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0xffa0 irq 14
[ 0.934955] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0xffa8 irq 15
[ 0.935148] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[ 0.935189] ata_piix 0000:00:1f.2: setting latency timer to 64
[ 0.938188] scsi2 : ata_piix
[ 0.939864] scsi3 : ata_piix
[ 0.939920] ata3: SATA max UDMA/133 cmd 0xa800 ctl 0xa400 bmdma 0x9400 irq 10
[ 0.939924] ata4: SATA max UDMA/133 cmd 0xa000 ctl 0x9800 bmdma 0x9408 irq 10
[ 0.970108] microcode: CPU0 updated to revision 0x5d, date = 2010-10-02
[ 0.970367] microcode: Microcode Update Driver: v2.00 <
tigran@aivazian.fsnet.co.uk>, Peter Oruba
[ 1.023106] e1000e 0000:02:00.0: eth0: (PCI Express:2.5GT/s:Width x1) 00:17:31:58:65:58
[ 1.023110] e1000e 0000:02:00.0: eth0: Intel(R) PRO/1000 Network Connection
[ 1.023195] e1000e 0000:02:00.0: eth0: MAC: 2, PHY: 2, PBA No: FFFFFF-0FF
[ 1.159285] ata3.00: ATA-7: ST3160811AS, 3.AAE, max UDMA/133
[ 1.159289] ata3.00: 312581808 sectors, multi 16: LBA48 NCQ (depth 0/32)
[ 1.225904] ata3.00: configured for UDMA/133
[ 1.226016] scsi 2:0:0:0: Direct-Access ATA ST3160811AS 3.AA PQ: 0 ANSI: 5
[ 1.233803] sd 2:0:0:0: [sda] 312581808 512-byte logical blocks: (160 GB/149 GiB)
[ 1.233867] sd 2:0:0:0: [sda] Write Protect is off
[ 1.233870] sd 2:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.233897] sd 2:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.297433] sda: sda1 sda2 < sda5 >
[ 1.297743] sd 2:0:0:0: [sda] Attached SCSI disk
[ 1.299862] sd 2:0:0:0: Attached scsi generic sg0 type 0
[ 1.420015] Refined TSC clocksource calibration: 2127.951 MHz.
[ 1.420022] Switching to clocksource tsc
[ 6.661955] PM: Starting manual resume from disk
[ 6.661960] PM: Hibernation image partition 8:5 present
[ 6.661962] PM: Looking for hibernation image.
[ 6.662141] PM: Image not found (code -22)
[ 6.662143] PM: Hibernation image not present or could not be loaded.
[ 6.711580] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 9.204966] udevd[320]: starting version 175
[ 9.606796] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 9.606803] ACPI: Power Button [PWRB]
[ 9.606996] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 9.607000] ACPI: Power Button [PWRF]
[ 9.918782] parport_pc 00:06: reported by Plug and Play ACPI
[ 9.918828] parport0: PC-style at 0x378, irq 7 [PCSPP]
[ 10.026451] coretemp coretemp.0: Using relative temperature scale!
[ 10.053904] intel_rng: FWH not detected
[ 10.069135] iTCO_vendor_support: vendor-support=0
[ 10.071389] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.07
[ 10.071463] iTCO_wdt: Found a ICH7 or ICH7R TCO device (Version=2, TCOBASE=0x0860)
[ 10.072199] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[ 10.270941] input: GenPS/2 Genius Mouse as /devices/platform/i8042/serio1/input/input3
[ 10.362109] leds_ss4200: no LED devices found
[ 10.492552] input: HDA ATI HDMI HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:01.0/0000:04:00.1/sound/card0/input4
[ 12.530677] Adding 4190204k swap on /dev/sda5. Priority:-1 extents:1 across:4190204k
[ 12.544701] EXT4-fs (sda1): re-mounted. Opts: (null)
[ 12.826165] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 12.944539] loop: module loaded
[ 14.406731] RPC: Registered named UNIX socket transport module.
[ 14.406735] RPC: Registered udp transport module.
[ 14.406737] RPC: Registered tcp transport module.
[ 14.406739] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 14.513710] FS-Cache: Loaded
[ 14.560516] NFS: Registering the id_resolver key type
[ 14.560537] FS-Cache: Netfs 'nfs' registered for caching
[ 14.566565] Installing knfsd (copyright (C) 1996
okir@monad.swb.de).
[ 18.736275] input: ACPI Virtual Keyboard Device as /devices/virtual/input/input5
[ 20.895577] Bluetooth: Core ver 2.16
[ 20.895769] NET: Registered protocol family 31
[ 20.895772] Bluetooth: HCI device and connection manager initialized
[ 20.895775] Bluetooth: HCI socket layer initialized
[ 20.895777] Bluetooth: L2CAP socket layer initialized
[ 20.895782] Bluetooth: SCO socket layer initialized
[ 20.913607] Bluetooth: RFCOMM TTY layer initialized
[ 20.913613] Bluetooth: RFCOMM socket layer initialized
[ 20.913615] Bluetooth: RFCOMM ver 1.11
[ 20.967027] lp0: using parport0 (interrupt-driven).
[ 21.090330] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.090334] Bluetooth: BNEP filters: protocol multicast
[ 21.125528] ppdev: user-space parallel port driver
[ 24.414360] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 27.496136] e1000e 0000:02:00.0: Disabling ASPM L0s L1
[ 27.498394] e1000e 0000:02:00.0: eth0: MAC Wakeup cause - Link Status Change
[ 29.936954] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx
[ 29.937148] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 40.656016] eth0: no IPv6 routers present
[ 89.352896] I-pipe: head domain RTAI registered.
[ 89.352901] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 89.352908] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 89.352912] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 89.352915] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 89.352918] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16595000
[ 89.397101] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 89.397125] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 89.397129] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 89.397133] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 89.397136] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 89.416991] RTAI[math]: loaded.
[ 94.152079] RTAI[math]: unloaded.
[ 94.156981] SCHED releases registered named ALIEN PEDV$D
[ 94.164200] RTAI[malloc]: unloaded.
[ 94.264013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 94.265785] I-pipe: head domain RTAI unregistered.
[ 94.265795] RTAI[hal]: unmounted.
[ 180.963165] I-pipe: head domain RTAI registered.
[ 180.963172] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 180.963178] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 180.963182] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 180.963185] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 180.963189] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16587750
[ 180.973224] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 180.973248] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 180.973253] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 180.973256] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 180.973259] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 180.983263] RTAI[math]: loaded.
[ 184.120096] RTAI[math]: unloaded.
[ 184.124125] SCHED releases registered named ALIEN PEDV$D
[ 184.130838] RTAI[malloc]: unloaded.
[ 184.228013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 184.229806] I-pipe: head domain RTAI unregistered.
[ 184.229816] RTAI[hal]: unmounted.
[ 228.103359] I-pipe: head domain RTAI registered.
[ 228.103365] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 228.103372] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 228.103376] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 228.103379] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 228.103382] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16584750
[ 228.113425] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 228.113451] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 228.113456] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 228.113460] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 228.113462] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 228.123656] RTAI[math]: loaded.
[ 231.268097] RTAI[math]: unloaded.
[ 231.270811] SCHED releases registered named ALIEN PEDV$D
[ 231.278012] RTAI[malloc]: unloaded.
[ 231.376011] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 231.377781] I-pipe: head domain RTAI unregistered.
[ 231.377791] RTAI[hal]: unmounted.
[ 268.190729] I-pipe: head domain RTAI registered.
[ 268.190735] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 268.190742] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 268.190746] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 268.190749] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 268.190752] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16584250
[ 268.200933] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 268.200957] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 268.200962] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 268.200966] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 268.200968] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 268.210714] RTAI[math]: loaded.
[ 268.351406] config string '0 out'
[ 270.404083] RTAI[math]: unloaded.
[ 270.407330] SCHED releases registered named ALIEN PEDV$D
[ 270.414236] RTAI[malloc]: unloaded.
[ 270.512012] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 270.513818] I-pipe: head domain RTAI unregistered.
[ 270.513827] RTAI[hal]: unmounted.
[ 278.918754] I-pipe: head domain RTAI registered.
[ 278.918761] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 278.918768] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 278.918772] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 278.918775] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 278.918778] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16587750
[ 278.927270] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 278.927294] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 278.927299] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 278.927303] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 278.927305] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 278.937665] RTAI[math]: loaded.
[ 279.061086] config string '0 out'
[ 280.176052] RTAI[math]: unloaded.
[ 280.180405] SCHED releases registered named ALIEN PEDV$D
[ 280.189139] RTAI[malloc]: unloaded.
[ 280.288014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 280.289845] I-pipe: head domain RTAI unregistered.
[ 280.289854] RTAI[hal]: unmounted.
[ 286.032502] I-pipe: head domain RTAI registered.
[ 286.032508] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 286.032514] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 286.032518] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 286.032521] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 286.032525] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16553250
[ 286.040949] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 286.040974] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 286.040979] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 286.040983] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 286.040985] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 286.051628] RTAI[math]: loaded.
[ 289.192090] RTAI[math]: unloaded.
[ 289.196971] SCHED releases registered named ALIEN PEDV$D
[ 289.204022] RTAI[malloc]: unloaded.
[ 289.304013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 289.305808] I-pipe: head domain RTAI unregistered.
[ 289.305817] RTAI[hal]: unmounted.
[ 443.206816] I-pipe: head domain RTAI registered.
[ 443.206823] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 443.206829] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 443.206833] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 443.206836] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 443.206840] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16586500
[ 443.216941] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 443.216967] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 443.216972] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 443.216975] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 443.216978] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 443.227142] RTAI[math]: loaded.
[ 446.364065] RTAI[math]: unloaded.
[ 446.367946] SCHED releases registered named ALIEN PEDV$D
[ 446.375169] RTAI[malloc]: unloaded.
[ 446.472014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 446.473840] I-pipe: head domain RTAI unregistered.
[ 446.473850] RTAI[hal]: unmounted.
[ 475.154753] I-pipe: head domain RTAI registered.
[ 475.154760] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 475.154767] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 475.154771] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 475.154774] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 475.154777] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16586000
[ 475.165032] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 475.165060] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 475.165065] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 475.165068] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 475.165071] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 475.175821] RTAI[math]: loaded.
[ 480.204021] RTAI[math]: unloaded.
[ 480.207495] SCHED releases registered named ALIEN PEDV$D
[ 480.214279] RTAI[malloc]: unloaded.
[ 480.312013] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 480.313845] I-pipe: head domain RTAI unregistered.
[ 480.313854] RTAI[hal]: unmounted.
[ 492.097252] I-pipe: head domain RTAI registered.
[ 492.097258] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 492.097265] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 492.097269] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 492.097272] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 492.097275] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16563500
[ 492.105749] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 492.105774] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 492.105779] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 492.105783] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 492.105785] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 492.115800] RTAI[math]: loaded.
[ 495.268025] RTAI[math]: unloaded.
[ 495.271945] SCHED releases registered named ALIEN PEDV$D
[ 495.278693] RTAI[malloc]: unloaded.
[ 495.376012] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 495.377773] I-pipe: head domain RTAI unregistered.
[ 495.377782] RTAI[hal]: unmounted.
[ 586.842671] I-pipe: head domain RTAI registered.
[ 586.842678] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 586.842684] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 586.842688] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 586.842691] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 586.842695] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16593750
[ 586.851165] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 586.851190] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 586.851194] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 586.851198] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 586.851201] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 586.861941] RTAI[math]: loaded.
[ 590.028068] RTAI[math]: unloaded.
[ 590.032478] SCHED releases registered named ALIEN PEDV$D
[ 590.039345] RTAI[malloc]: unloaded.
[ 590.136014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 590.137782] I-pipe: head domain RTAI unregistered.
[ 590.137791] RTAI[hal]: unmounted.
[ 727.921873] I-pipe: head domain RTAI registered.
[ 727.921880] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 727.921886] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 727.921890] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 727.921893] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 727.921897] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16588250
[ 727.930371] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 727.930395] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 727.930400] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 727.930404] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 727.930406] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 727.940751] RTAI[math]: loaded.
[ 731.080053] RTAI[math]: unloaded.
[ 731.083934] SCHED releases registered named ALIEN PEDV$D
[ 731.090678] RTAI[malloc]: unloaded.
[ 731.188014] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 731.189801] I-pipe: head domain RTAI unregistered.
[ 731.189811] RTAI[hal]: unmounted.
[ 1127.483097] I-pipe: head domain RTAI registered.
[ 1127.483104] RTAI[hal]: compiled with gcc version 4.7.2 (Debian 4.7.2-5) .
[ 1127.483110] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[ 1127.483114] SYSINFO: CPUs 1, LINUX APIC IRQ 2312, TIM_FREQ 16623370, CLK_FREQ 2127796000, CPU_FREQ 2127796000
[ 1127.483117] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[ 1127.483121] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 16623370, 16623370, 16584000
[ 1127.491803] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[ 1127.491829] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[ 1127.491834] RTAI[sched]: hard timer type/freq = APIC/16623370(Hz); default timing: oneshot; linear timed lists.
[ 1127.491837] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2127796000 hz.
[ 1127.491840] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[ 1127.502314] RTAI[math]: loaded.
[ 1130.664065] RTAI[math]: unloaded.
[ 1130.667804] SCHED releases registered named ALIEN PEDV$D
[ 1130.674209] RTAI[malloc]: unloaded.
[ 1130.772012] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[ 1130.773797] I-pipe: head domain RTAI unregistered.
[ 1130.773806] RTAI[hal]: unmounted.
