GPU Caps Viewer v1.41.3.0 report
http://www.geeks3d.com
http://www.ozone3d.net/gpu_caps_viewer/
===================================[ System / CPU ]
- CPU Name: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
- CPU Core Speed: 2294 MHz
- CPU logical cores: 4
- Family: 6 - Model: 5 - Stepping: 1
- Physical Memory Size: 8192 MB
- Operating System: Windows 8.1 64-bit build 9600
- PhysX Version: drivers not installed
===================================[ Graphics Adapters / GPUs ]
- Current Display Mode: 1366x768 @ 60 Hz - 32 bpp
- Num GPUs: 2
- GPU 1
- Name: AMD Radeon R7 M265
- GPU codename:
- Device ID: 1002-6604
- Subdevice ID: 1025- 776
- Revision ID: 0
- Driver: Catalyst (13.201.0.0)
- Bus Id: 3
- BIOS version: 015.039.000.001/BR44788.001 (2013/09/05 23:21)
- Memory size: 2048MB
- Memory type: DDR3
- Memory bus width: 0-bit
- GPU clock: 300 MHz, memory: 300 MHz, VDDC: 0.800V
- GPU clock: 825 MHz, memory: 900 MHz, VDDC: 1.050V
- GPU 2
- Name: Intel(R) HD Graphics Family
- GPU codename: Haswell
- Device ID: 8086- A16
- Subdevice ID: 1025- 775
- Revision ID: 9
- Driver: 10.18.10.3355 (11-15-2013)
- Bus Id: -1
- Shader cores: 40
- Texture units: 1
- TDP: 84W
- BIOS version: Intel Video BIOS
- Memory size: 2112MB
- Memory type:
===================================[ OpenGL GPU Capabilities ]
- GL_VENDOR: Intel
- GL_RENDERER: Intel(R) HD Graphics 4400
- GL_VERSION: 4.2.0 - Build 10.18.10.3355
- GL_SHADING_LANGUAGE_VERSION: 4.20 - Build 10.18.10.3355
- ARB Texture Units: 8
- Vertex Shader Texture Units: 16
- Pixel Shader Texture Units: 16
- Geometry Shader Texture Units: 16
- Max Texture Size: 16384x16384
- Max Anisotropic Filtering Value: X16.0
- Max Point Sprite Size: 255.0
- Max Dynamic Lights: 8
- Max Viewport Size: 16384x16384
- Max Vertex Uniform Components: 4096
- Max Fragment Uniform Components: 4096
- Max Geometry Uniform Components: 4096
- Max Varying Float: 64
- Max Vertex Bindable Uniforms: 0
- Max Fragment Bindable Uniforms: 0
- Max Geometry Bindable Uniforms: 0
- Frame Buffer Objects (FBO) Support:[yes]
- Multiple Render Targets / Max draw buffers: 8
- Pixel Buffer Objects (PBO) Support:[yes]
- S3TC Texture Compression Support:[yes]
- ATI 3Dc Texture Compression Support:[no]
- Texture Rectangle Support:[yes]
- Floating Point Textures Support:[no]
- MSAA: 4X
- MSAA: 8X
- OpenGL Extensions: 182 extensions (GL=163 and WGL=19)
- GL_EXT_blend_minmax
- GL_EXT_blend_subtract
- GL_EXT_blend_color
- GL_EXT_abgr
- GL_EXT_texture3D
- GL_EXT_clip_volume_hint
- GL_EXT_compiled_vertex_array
- GL_SGIS_texture_edge_clamp
- GL_SGIS_generate_mipmap
- GL_EXT_draw_range_elements
- GL_SGIS_texture_lod
- GL_EXT_rescale_normal
- GL_EXT_packed_pixels
- GL_EXT_texture_edge_clamp
- GL_EXT_separate_specular_color
- GL_ARB_multitexture
- GL_ARB_map_buffer_alignment
- GL_ARB_conservative_depth
- GL_EXT_texture_env_combine
- GL_EXT_bgra
- GL_EXT_blend_func_separate
- GL_EXT_secondary_color
- GL_EXT_fog_coord
- GL_EXT_texture_env_add
- GL_ARB_texture_cube_map
- GL_ARB_transpose_matrix
- GL_ARB_internalformat_query
- GL_ARB_internalformat_query2
- GL_ARB_texture_env_add
- GL_IBM_texture_mirrored_repeat
- GL_EXT_multi_draw_arrays
- GL_SUN_multi_draw_arrays
- GL_NV_blend_square
- GL_ARB_texture_compression
- GL_3DFX_texture_compression_FXT1
- GL_EXT_texture_filter_anisotropic
- GL_ARB_texture_border_clamp
- GL_ARB_point_parameters
- GL_ARB_texture_env_combine
- GL_ARB_texture_env_dot3
- GL_ARB_texture_env_crossbar
- GL_EXT_texture_compression_s3tc
- GL_ARB_shadow
- GL_ARB_window_pos
- GL_EXT_shadow_funcs
- GL_EXT_stencil_wrap
- GL_ARB_vertex_program
- GL_EXT_texture_rectangle
- GL_ARB_fragment_program
- GL_EXT_stencil_two_side
- GL_ATI_separate_stencil
- GL_ARB_vertex_buffer_object
- GL_EXT_texture_lod_bias
- GL_ARB_occlusion_query
- GL_ARB_fragment_shader
- GL_ARB_shader_objects
- GL_ARB_shading_language_100
- GL_ARB_texture_non_power_of_two
- GL_ARB_vertex_shader
- GL_NV_texgen_reflection
- GL_ARB_point_sprite
- GL_ARB_fragment_program_shadow
- GL_EXT_blend_equation_separate
- GL_ARB_depth_texture
- GL_ARB_texture_rectangle
- GL_ARB_draw_buffers
- GL_ARB_color_buffer_float
- GL_ARB_half_float_pixel
- GL_ARB_texture_float
- GL_ARB_pixel_buffer_object
- GL_EXT_framebuffer_object
- GL_ARB_draw_instanced
- GL_ARB_half_float_vertex
- GL_ARB_occlusion_query2
- GL_EXT_draw_buffers2
- GL_WIN_swap_hint
- GL_EXT_texture_sRGB
- GL_ARB_multisample
- GL_EXT_packed_float
- GL_EXT_texture_shared_exponent
- GL_ARB_texture_rg
- GL_ARB_texture_compression_rgtc
- GL_NV_conditional_render
- GL_ARB_texture_swizzle
- GL_EXT_texture_swizzle
- GL_ARB_texture_gather
- GL_ARB_sync
- GL_ARB_framebuffer_sRGB
- GL_EXT_packed_depth_stencil
- GL_ARB_depth_buffer_float
- GL_EXT_transform_feedback
- GL_ARB_transform_feedback2
- GL_ARB_draw_indirect
- GL_EXT_framebuffer_blit
- GL_EXT_framebuffer_multisample
- GL_ARB_framebuffer_object
- GL_EXT_texture_array
- GL_EXT_texture_integer
- GL_ARB_map_buffer_range
- GL_ARB_texture_buffer_range
- GL_EXT_texture_snorm
- GL_ARB_blend_func_extended
- GL_INTEL_performance_queries
- GL_ARB_copy_buffer
- GL_ARB_sampler_objects
- GL_NV_primitive_restart
- GL_ARB_seamless_cube_map
- GL_ARB_uniform_buffer_object
- GL_ARB_depth_clamp
- GL_ARB_vertex_array_bgra
- GL_ARB_shader_bit_encoding
- GL_ARB_draw_buffers_blend
- GL_ARB_geometry_shader4
- GL_EXT_geometry_shader4
- GL_ARB_texture_query_lod
- GL_ARB_explicit_attrib_location
- GL_ARB_draw_elements_base_vertex
- GL_ARB_instanced_arrays
- GL_ARB_base_instance
- GL_ARB_fragment_coord_conventions
- GL_EXT_gpu_program_parameters
- GL_ARB_texture_buffer_object_rgb32
- GL_ARB_compatibility
- GL_ARB_texture_rgb10_a2ui
- GL_ARB_texture_multisample
- GL_ARB_vertex_type_2_10_10_10_rev
- GL_ARB_timer_query
- GL_ARB_tessellation_shader
- GL_ARB_vertex_array_object
- GL_ARB_provoking_vertex
- GL_ARB_sample_shading
- GL_ARB_texture_cube_map_array
- GL_EXT_gpu_shader4
- GL_ARB_gpu_shader5
- GL_ARB_gpu_shader_fp64
- GL_INTEL_fragment_shader_ordering
- GL_ARB_shader_subroutine
- GL_ARB_transform_feedback3
- GL_ARB_get_program_binary
- GL_ARB_separate_shader_objects
- GL_ARB_shader_precision
- GL_ARB_vertex_attrib_64bit
- GL_ARB_viewport_array
- GL_ARB_transform_feedback_instanced
- GL_ARB_compressed_texture_pixel_storage
- GL_ARB_shader_atomic_counters
- GL_ARB_shading_language_packing
- GL_ARB_shader_image_load_store
- GL_ARB_shading_language_420pack
- GL_ARB_texture_storage
- GL_EXT_texture_storage
- GL_ARB_compute_shader
- GL_ARB_multi_draw_indirect
- GL_ARB_program_interface_query
- GL_ARB_shader_storage_buffer_object
- GL_ARB_debug_output
- GL_KHR_debug
- GL_ARB_arrays_of_arrays
- GL_INTEL_map_texture
- GL_ARB_texture_compression_bptc
- GL_ARB_ES2_compatibility
- GL_ARB_robustness
- GL_EXT_texture_sRGB_decode
- WGL_EXT_depth_float
- WGL_ARB_buffer_region
- WGL_ARB_extensions_string
- WGL_ARB_make_current_read
- WGL_ARB_pixel_format
- WGL_ARB_pbuffer
- WGL_EXT_extensions_string
- WGL_EXT_swap_control
- WGL_EXT_swap_control_tear
- WGL_ARB_multisample
- WGL_ARB_pixel_format_float
- WGL_ARB_framebuffer_sRGB
- WGL_ARB_create_context
- WGL_ARB_create_context_profile
- WGL_EXT_pixel_format_packed_float
- WGL_EXT_create_context_es_profile
- WGL_EXT_create_context_es2_profile
- WGL_NV_DX_interop
- WGL_ARB_create_context_robustness
- OpenGL SPIR-V Extensions: 0
- OpenGL core capabilities: 177 caps listed
- GL_MAX_LIST_NESTING: 64
- GL_MAX_EVAL_ORDER: 32
- GL_MAX_LIGHTS: 8
- GL_MAX_CLIP_PLANES: 8
- GL_MAX_TEXTURE_SIZE: 16384
- GL_MAX_PIXEL_MAP_TABLE: 65536
- GL_MAX_ATTRIB_STACK_DEPTH: 16
- GL_MAX_MODELVIEW_STACK_DEPTH: 32
- GL_MAX_NAME_STACK_DEPTH: 128
- GL_MAX_PROJECTION_STACK_DEPTH: 4
- GL_MAX_TEXTURE_STACK_DEPTH: 10
- GL_MAX_VIEWPORT_DIMS: 16384
- GL_MAX_CLIENT_ATTRIB_STACK_DEPTH: 16
- GL_MAX_3D_TEXTURE_SIZE: 2048
- GL_MAX_ELEMENTS_VERTICES: 1048576
- GL_MAX_ELEMENTS_INDICES: 1048576
- GL_MAX_TEXTURE_UNITS: 8
- GL_MAX_CUBE_MAP_TEXTURE_SIZE: 16384
- GL_MAX_TEXTURE_LOD_BIAS: 15
- GL_MAX_DRAW_BUFFERS: 8
- GL_MAX_VERTEX_ATTRIBS: 16
- GL_MAX_TEXTURE_COORDS: 8
- GL_MAX_TEXTURE_IMAGE_UNITS: 16
- GL_MAX_FRAGMENT_UNIFORM_COMPONENTS: 4096
- GL_MAX_VERTEX_UNIFORM_COMPONENTS: 4096
- GL_MAX_VARYING_FLOATS: 64
- GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS: 16
- GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS: 96
- GL_MAX_CLIP_DISTANCES: 8
- GL_MAX_ARRAY_TEXTURE_LAYERS: 2048
- GL_MAX_VARYING_COMPONENTS: 64
- GL_MIN_PROGRAM_TEXEL_OFFSET: -8
- GL_MAX_PROGRAM_TEXEL_OFFSET: 7
- GL_MAX_TRANSFORM_FEEDBACK_SEPARATE_COMPONENTS: 4
- GL_MAX_TRANSFORM_FEEDBACK_INTERLEAVED_COMPONENTS: 128
- GL_MAX_TRANSFORM_FEEDBACK_SEPARATE_ATTRIBS: 4
- GL_MAX_RENDERBUFFER_SIZE: 16384
- GL_MAX_COLOR_ATTACHMENTS: 8
- GL_MAX_SAMPLES: 8
- GL_MIN_PROGRAM_TEXEL_OFFSET_EXT: -8
- GL_MAX_PROGRAM_TEXEL_OFFSET_EXT: 7
- GL_RGBA_FLOAT_MODE_ARB: 0
- GL_MAX_COLOR_ATTACHMENTS_EXT: 8
- GL_MAX_RENDERBUFFER_SIZE_EXT: 16384
- GL_MAX_SAMPLES_EXT: 8
- GL_RGBA_INTEGER_MODE_EXT: 0
- GL_MAX_ARRAY_TEXTURE_LAYERS_EXT: 2048
- GL_MAX_TRANSFORM_FEEDBACK_INTERLEAVED_COMPONENTS_EXT: 128
- GL_MAX_TRANSFORM_FEEDBACK_SEPARATE_ATTRIBS_EXT: 4
- GL_MAX_TRANSFORM_FEEDBACK_SEPARATE_COMPONENTS_EXT: 4
- GL_FRAMEBUFFER_SRGB_CAPABLE_EXT: 0
- GL_MAX_RECTANGLE_TEXTURE_SIZE: 16384
- GL_MAX_TEXTURE_BUFFER_SIZE: 4194304
- GL_MAX_TEXTURE_BUFFER_SIZE_ARB: 4194304
- GL_MAX_VERTEX_UNIFORM_BLOCKS: 14
- GL_MAX_GEOMETRY_UNIFORM_BLOCKS: 14
- GL_MAX_FRAGMENT_UNIFORM_BLOCKS: 14
- GL_MAX_COMBINED_UNIFORM_BLOCKS: 70
- GL_MAX_UNIFORM_BUFFER_BINDINGS: 70
- GL_MAX_UNIFORM_BLOCK_SIZE: 16384
- GL_MAX_COMBINED_VERTEX_UNIFORM_COMPONENTS: 61440
- GL_MAX_COMBINED_GEOMETRY_UNIFORM_COMPONENTS: 61440
- GL_MAX_COMBINED_FRAGMENT_UNIFORM_COMPONENTS: 61440
- GL_UNIFORM_BUFFER_OFFSET_ALIGNMENT: 16
- GL_MAX_GEOMETRY_TEXTURE_IMAGE_UNITS: 16
- GL_MAX_GEOMETRY_UNIFORM_COMPONENTS: 4096
- GL_MAX_GEOMETRY_OUTPUT_VERTICES: 256
- GL_MAX_GEOMETRY_TOTAL_OUTPUT_COMPONENTS: 1024
- GL_MAX_VERTEX_OUTPUT_COMPONENTS: 128
- GL_MAX_GEOMETRY_INPUT_COMPONENTS: 128
- GL_MAX_GEOMETRY_OUTPUT_COMPONENTS: 128
- GL_MAX_FRAGMENT_INPUT_COMPONENTS: 128
- GL_MAX_SERVER_WAIT_TIMEOUT: 0
- GL_MAX_SAMPLE_MASK_WORDS: 1
- GL_MAX_COLOR_TEXTURE_SAMPLES: 8
- GL_MAX_DEPTH_TEXTURE_SAMPLES: 8
- GL_MAX_INTEGER_SAMPLES: 8
- GL_PROVOKING_VERTEX: 36430
- GL_QUADS_FOLLOW_PROVOKING_VERTEX_CONVENTION: 0
- GL_MAX_GEOMETRY_TEXTURE_IMAGE_UNITS_ARB: 16
- GL_MAX_GEOMETRY_VARYING_COMPONENTS_ARB: 64
- GL_MAX_VERTEX_VARYING_COMPONENTS_ARB: 32
- GL_MAX_GEOMETRY_UNIFORM_COMPONENTS_ARB: 4096
- GL_MAX_GEOMETRY_OUTPUT_VERTICES_ARB: 256
- GL_MAX_GEOMETRY_TOTAL_OUTPUT_COMPONENTS_ARB: 1024
- GL_MAX_DUAL_SOURCE_DRAW_BUFFERS: 1
- GL_FRAGMENT_INTERPOLATION_OFFSET_BITS: 4
- GL_MIN_SAMPLE_SHADING_VALUE: 0
- GL_MAX_GEOMETRY_SHADER_INVOCATIONS: 32
- GL_MIN_FRAGMENT_INTERPOLATION_OFFSET: -1
- GL_MAX_FRAGMENT_INTERPOLATION_OFFSET: 1
- GL_MIN_PROGRAM_TEXTURE_GATHER_OFFSET: -8
- GL_MAX_PROGRAM_TEXTURE_GATHER_OFFSET: 7
- GL_MAX_PROGRAM_TEXTURE_GATHER_COMPONENTS: 4
- GL_MAX_SUBROUTINES: 256
- GL_MAX_SUBROUTINE_UNIFORM_LOCATIONS: 1024
- GL_MAX_PATCH_VERTICES: 32
- GL_MAX_TESS_GEN_LEVEL: 64
- GL_MAX_TESS_CONTROL_UNIFORM_COMPONENTS: 4096
- GL_MAX_TESS_EVALUATION_UNIFORM_COMPONENTS: 4096
- GL_MAX_TESS_CONTROL_TEXTURE_IMAGE_UNITS: 16
- GL_MAX_TESS_EVALUATION_TEXTURE_IMAGE_UNITS: 16
- GL_MAX_TESS_CONTROL_OUTPUT_COMPONENTS: 128
- GL_MAX_TESS_PATCH_COMPONENTS: 120
- GL_MAX_TESS_CONTROL_TOTAL_OUTPUT_COMPONENTS: 4096
- GL_MAX_TESS_EVALUATION_OUTPUT_COMPONENTS: 128
- GL_MAX_TESS_CONTROL_UNIFORM_BLOCKS: 14
- GL_MAX_TESS_EVALUATION_UNIFORM_BLOCKS: 14
- GL_MAX_TESS_CONTROL_INPUT_COMPONENTS: 128
- GL_MAX_TESS_EVALUATION_INPUT_COMPONENTS: 128
- GL_MAX_COMBINED_TESS_CONTROL_UNIFORM_COMPONENTS: 61440
- GL_MAX_COMBINED_TESS_EVALUATION_UNIFORM_COMPONENTS: 61440
- GL_MAX_TRANSFORM_FEEDBACK_BUFFERS: 4
- GL_MAX_VERTEX_STREAMS: 4
- GL_NUM_PROGRAM_BINARY_FORMATS: 1
- GL_MAX_VERTEX_UNIFORM_VECTORS: 1024
- GL_MAX_VARYING_VECTORS: 16
- GL_MAX_FRAGMENT_UNIFORM_VECTORS: 1024
- GL_MAX_VIEWPORTS: 16
- GL_MAX_TESS_CONTROL_ATOMIC_COUNTER_BUFFERS: 8
- GL_MAX_TESS_EVALUATION_ATOMIC_COUNTER_BUFFERS: 8
- GL_MAX_VERTEX_ATOMIC_COUNTER_BUFFERS: 8
- GL_MAX_GEOMETRY_ATOMIC_COUNTER_BUFFERS: 8
- GL_MAX_FRAGMENT_ATOMIC_COUNTER_BUFFERS: 8
- GL_MAX_COMBINED_ATOMIC_COUNTER_BUFFERS: 40
- GL_MAX_VERTEX_ATOMIC_COUNTERS: 4096
- GL_MAX_TESS_CONTROL_ATOMIC_COUNTERS: 4096
- GL_MAX_TESS_EVALUATION_ATOMIC_COUNTERS: 4096
- GL_MAX_GEOMETRY_ATOMIC_COUNTERS: 4096
- GL_MAX_FRAGMENT_ATOMIC_COUNTERS: 4096
- GL_MAX_COMBINED_ATOMIC_COUNTERS: 4096
- GL_MAX_ATOMIC_COUNTER_BUFFER_SIZE: 16384
- GL_MAX_ATOMIC_COUNTER_BUFFER_BINDINGS: 8
- GL_MAX_IMAGE_UNITS: 8
- GL_MAX_COMBINED_IMAGE_UNITS_AND_FRAGMENT_OUTPUTS: 16
- GL_MAX_IMAGE_SAMPLES: 8
- GL_MAX_VERTEX_IMAGE_UNIFORMS: 8
- GL_MAX_TESS_CONTROL_IMAGE_UNIFORMS: 8
- GL_MAX_TESS_EVALUATION_IMAGE_UNIFORMS: 8
- GL_MAX_GEOMETRY_IMAGE_UNIFORMS: 8
- GL_MAX_FRAGMENT_IMAGE_UNIFORMS: 8
- GL_MAX_COMBINED_IMAGE_UNIFORMS: 40
- GL_MIN_MAP_BUFFER_ALIGNMENT: 64
- GL_UNPACK_COMPRESSED_BLOCK_WIDTH: 0
- GL_UNPACK_COMPRESSED_BLOCK_HEIGHT: 0
- GL_UNPACK_COMPRESSED_BLOCK_DEPTH: 0
- GL_UNPACK_COMPRESSED_BLOCK_SIZE: 0
- GL_PACK_COMPRESSED_BLOCK_WIDTH: 0
- GL_PACK_COMPRESSED_BLOCK_HEIGHT: 0
- GL_PACK_COMPRESSED_BLOCK_DEPTH: 0
- GL_PACK_COMPRESSED_BLOCK_SIZE: 0
- GL_MAX_COMPUTE_UNIFORM_BLOCKS: 14
- GL_MAX_COMPUTE_TEXTURE_IMAGE_UNITS: 16
- GL_MAX_COMPUTE_IMAGE_UNIFORMS: 8
- GL_MAX_COMPUTE_SHARED_MEMORY_SIZE: 32768
- GL_MAX_COMPUTE_UNIFORM_COMPONENTS: 4096
- GL_MAX_COMPUTE_ATOMIC_COUNTER_BUFFERS: 8
- GL_MAX_COMPUTE_ATOMIC_COUNTERS: 4096
- GL_MAX_COMBINED_COMPUTE_UNIFORM_COMPONENTS: 61440
- GL_MAX_COMPUTE_WORK_GROUP_INVOCATIONS: 1024
- GL_MAX_VERTEX_ATTRIB_RELATIVE_OFFSET: 0
- GL_MAX_VERTEX_ATTRIB_BINDINGS: 0
- GL_MAX_UNIFORM_LOCATIONS: 0
- GL_MAX_FRAMEBUFFER_WIDTH: 0
- GL_MAX_FRAMEBUFFER_HEIGHT: 0
- GL_MAX_FRAMEBUFFER_LAYERS: 0
- GL_MAX_FRAMEBUFFER_SAMPLES: 0
- GL_MAX_COMPUTE_VARIABLE_GROUP_INVOCATIONS_ARB: 0
- GL_MAX_COMPUTE_FIXED_GROUP_INVOCATIONS_ARB: 1024
- GL_MAX_COMPUTE_VARIABLE_GROUP_SIZE_ARB: 0
- GL_MAX_COMPUTE_FIXED_GROUP_SIZE_ARB: 0
- GL_MAX_SPARSE_TEXTURE_SIZE_ARB: 0
- GL_MAX_SPARSE_3D_TEXTURE_SIZE_ARB: 0
- GL_MAX_SPARSE_ARRAY_TEXTURE_LAYERS_ARB: 0
- GL_SPARSE_TEXTURE_FULL_ARRAY_CUBE_MIPMAPS_ARB: 0
- GL_MAX_CULL_DISTANCES: 0
- GL_MAX_COMBINED_CLIP_AND_CULL_DISTANCES: 0
- OpenGL extension capabilities: 143 caps listed
- GL_RGBA_FLOAT_MODE_ARB: 0 (GL_ARB_color_buffer_float)
- GL_MAX_COLOR_ATTACHMENTS_EXT: 8 (GL_EXT_framebuffer_object)
- GL_MAX_RENDERBUFFER_SIZE_EXT: 16384 (GL_EXT_framebuffer_object)
- GL_MAX_SAMPLES_EXT: 8 (GL_EXT_framebuffer_multisample)
- GL_RGBA_INTEGER_MODE_EXT: 0 (GL_EXT_texture_integer)
- GL_MAX_ARRAY_TEXTURE_LAYERS_EXT: 2048 (GL_EXT_texture_array)
- GL_MAX_TRANSFORM_FEEDBACK_INTERLEAVED_COMPONENTS_EXT: 128 (GL_EXT_transform_feedback)
- GL_MAX_TRANSFORM_FEEDBACK_SEPARATE_ATTRIBS_EXT: 4 (GL_EXT_transform_feedback)
- GL_MAX_TRANSFORM_FEEDBACK_SEPARATE_COMPONENTS_EXT: 4 (GL_EXT_transform_feedback)
- GL_MAX_VERTEX_UNIFORM_BLOCKS: 14 (GL_ARB_uniform_buffer_object)
- GL_MAX_GEOMETRY_UNIFORM_BLOCKS: 14 (GL_ARB_uniform_buffer_object)
- GL_MAX_FRAGMENT_UNIFORM_BLOCKS: 14 (GL_ARB_uniform_buffer_object)
- GL_MAX_COMBINED_UNIFORM_BLOCKS: 70 (GL_ARB_uniform_buffer_object)
- GL_MAX_UNIFORM_BUFFER_BINDINGS: 70 (GL_ARB_uniform_buffer_object)
- GL_MAX_UNIFORM_BLOCK_SIZE: 16384 (GL_ARB_uniform_buffer_object)
- GL_MAX_COMBINED_VERTEX_UNIFORM_COMPONENTS: 61440 (GL_ARB_uniform_buffer_object)
- GL_MAX_COMBINED_GEOMETRY_UNIFORM_COMPONENTS: 61440 (GL_ARB_uniform_buffer_object)
- GL_MAX_COMBINED_FRAGMENT_UNIFORM_COMPONENTS: 61440 (GL_ARB_uniform_buffer_object)
- GL_UNIFORM_BUFFER_OFFSET_ALIGNMENT: 16 (GL_ARB_uniform_buffer_object)
- GL_MAX_RECTANGLE_TEXTURE_SIZE: 16384 (GL_ARB_texture_rectangle)
- GL_PROVOKING_VERTEX: 36430 (GL_ARB_provoking_vertex)
- GL_QUADS_FOLLOW_PROVOKING_VERTEX_CONVENTION: 0 (GL_ARB_provoking_vertex)
- GL_MAX_SAMPLE_MASK_WORDS: 1 (GL_ARB_texture_multisample)
- GL_MAX_COLOR_TEXTURE_SAMPLES: 8 (GL_ARB_texture_multisample)
- GL_MAX_DEPTH_TEXTURE_SAMPLES: 8 (GL_ARB_texture_multisample)
- GL_MAX_INTEGER_SAMPLES: 8 (GL_ARB_texture_multisample)
- GL_MAX_GEOMETRY_TEXTURE_IMAGE_UNITS_ARB: 16 (GL_ARB_geometry_shader4)
- GL_MAX_GEOMETRY_VARYING_COMPONENTS_ARB: 64 (GL_ARB_geometry_shader4)
- GL_MAX_VERTEX_VARYING_COMPONENTS_ARB: 32 (GL_ARB_geometry_shader4)
- GL_MAX_GEOMETRY_UNIFORM_COMPONENTS_ARB: 4096 (GL_ARB_geometry_shader4)
- GL_MAX_GEOMETRY_OUTPUT_VERTICES_ARB: 256 (GL_ARB_geometry_shader4)
- GL_MAX_GEOMETRY_TOTAL_OUTPUT_COMPONENTS_ARB: 1024 (GL_ARB_geometry_shader4)
- GL_MAX_SERVER_WAIT_TIMEOUT: 0 (GL_ARB_sync)
- GL_MAX_DUAL_SOURCE_DRAW_BUFFERS: 1 (GL_ARB_blend_func_extended)
- GL_MAX_GEOMETRY_SHADER_INVOCATIONS: 32 (GL_ARB_gpu_shader5)
- GL_MIN_FRAGMENT_INTERPOLATION_OFFSET: -1 (GL_ARB_gpu_shader5)
- GL_MAX_FRAGMENT_INTERPOLATION_OFFSET: 1 (GL_ARB_gpu_shader5)
- GL_FRAGMENT_INTERPOLATION_OFFSET_BITS: 4 (GL_ARB_gpu_shader5)
- GL_MAX_VERTEX_STREAMS: 4 (GL_ARB_gpu_shader5)
- GL_MIN_SAMPLE_SHADING_VALUE: 0 (GL_ARB_sample_shading)
- GL_MAX_SUBROUTINES: 256 (GL_ARB_shader_subroutine)
- GL_MAX_SUBROUTINE_UNIFORM_LOCATIONS: 1024 (GL_ARB_shader_subroutine)
- GL_MAX_TESS_CONTROL_TEXTURE_IMAGE_UNITS: 16 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_EVALUATION_TEXTURE_IMAGE_UNITS: 16 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_GEN_LEVEL: 64 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_CONTROL_UNIFORM_COMPONENTS: 4096 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_EVALUATION_UNIFORM_COMPONENTS: 4096 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_CONTROL_INPUT_COMPONENTS: 128 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_EVALUATION_INPUT_COMPONENTS: 128 (GL_ARB_tessellation_shader)
- GL_MAX_COMBINED_TESS_CONTROL_UNIFORM_COMPONENTS: 61440 (GL_ARB_tessellation_shader)
- GL_MAX_COMBINED_TESS_EVALUATION_UNIFORM_COMPONENTS: 61440 (GL_ARB_tessellation_shader)
- GL_MAX_PATCH_VERTICES: 32 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_CONTROL_OUTPUT_COMPONENTS: 128 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_PATCH_COMPONENTS: 120 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_CONTROL_TOTAL_OUTPUT_COMPONENTS: 4096 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_EVALUATION_OUTPUT_COMPONENTS: 128 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_CONTROL_UNIFORM_BLOCKS: 14 (GL_ARB_tessellation_shader)
- GL_MAX_TESS_EVALUATION_UNIFORM_BLOCKS: 14 (GL_ARB_tessellation_shader)
- GL_MIN_PROGRAM_TEXTURE_GATHER_OFFSET: -8 (GL_ARB_texture_gather)
- GL_MAX_PROGRAM_TEXTURE_GATHER_OFFSET: 7 (GL_ARB_texture_gather)
- GL_MAX_PROGRAM_TEXTURE_GATHER_COMPONENTS: 4 (GL_ARB_texture_gather)
- GL_MAX_TRANSFORM_FEEDBACK_BUFFERS: 4 (GL_ARB_transform_feedback3)
- GL_NUM_PROGRAM_BINARY_FORMATS: 1 (GL_ARB_get_program_binary)
- GL_MAX_VIEWPORTS: 16 (GL_ARB_viewport_array)
- GL_UNPACK_COMPRESSED_BLOCK_WIDTH: 0 (GL_ARB_compressed_texture_pixel_storage)
- GL_UNPACK_COMPRESSED_BLOCK_HEIGHT: 0 (GL_ARB_compressed_texture_pixel_storage)
- GL_UNPACK_COMPRESSED_BLOCK_DEPTH: 0 (GL_ARB_compressed_texture_pixel_storage)
- GL_UNPACK_COMPRESSED_BLOCK_SIZE: 0 (GL_ARB_compressed_texture_pixel_storage)
- GL_PACK_COMPRESSED_BLOCK_WIDTH: 0 (GL_ARB_compressed_texture_pixel_storage)
- GL_PACK_COMPRESSED_BLOCK_HEIGHT: 0 (GL_ARB_compressed_texture_pixel_storage)
- GL_PACK_COMPRESSED_BLOCK_DEPTH: 0 (GL_ARB_compressed_texture_pixel_storage)
- GL_PACK_COMPRESSED_BLOCK_SIZE: 0 (GL_ARB_compressed_texture_pixel_storage)
- GL_MAX_VERTEX_ATOMIC_COUNTER_BUFFERS: 8 (GL_ARB_shader_atomic_counters)
- GL_MAX_TESS_CONTROL_ATOMIC_COUNTER_BUFFERS: 8 (GL_ARB_shader_atomic_counters)
- GL_MAX_TESS_EVALUATION_ATOMIC_COUNTER_BUFFERS: 8 (GL_ARB_shader_atomic_counters)
- GL_MAX_GEOMETRY_ATOMIC_COUNTER_BUFFERS: 8 (GL_ARB_shader_atomic_counters)
- GL_MAX_FRAGMENT_ATOMIC_COUNTER_BUFFERS: 8 (GL_ARB_shader_atomic_counters)
- GL_MAX_COMBINED_ATOMIC_COUNTER_BUFFERS: 40 (GL_ARB_shader_atomic_counters)
- GL_MAX_VERTEX_ATOMIC_COUNTERS: 4096 (GL_ARB_shader_atomic_counters)
- GL_MAX_TESS_CONTROL_ATOMIC_COUNTERS: 4096 (GL_ARB_shader_atomic_counters)
- GL_MAX_TESS_EVALUATION_ATOMIC_COUNTERS: 4096 (GL_ARB_shader_atomic_counters)
- GL_MAX_GEOMETRY_ATOMIC_COUNTERS: 4096 (GL_ARB_shader_atomic_counters)
- GL_MAX_FRAGMENT_ATOMIC_COUNTERS: 4096 (GL_ARB_shader_atomic_counters)
- GL_MAX_COMBINED_ATOMIC_COUNTERS: 4096 (GL_ARB_shader_atomic_counters)
- GL_MAX_ATOMIC_COUNTER_BUFFER_SIZE: 16384 (GL_ARB_shader_atomic_counters)
- GL_MAX_ATOMIC_COUNTER_BUFFER_BINDINGS: 8 (GL_ARB_shader_atomic_counters)
- GL_MAX_IMAGE_UNITS: 8 (GL_ARB_shader_image_load_store)
- GL_MAX_COMBINED_IMAGE_UNITS_AND_FRAGMENT_OUTPUTS: 16 (GL_ARB_shader_image_load_store)
- GL_MAX_IMAGE_SAMPLES: 8 (GL_ARB_shader_image_load_store)
- GL_MAX_VERTEX_IMAGE_UNIFORMS: 8 (GL_ARB_shader_image_load_store)
- GL_MAX_TESS_CONTROL_IMAGE_UNIFORMS: 8 (GL_ARB_shader_image_load_store)
- GL_MAX_TESS_EVALUATION_IMAGE_UNIFORMS: 8 (GL_ARB_shader_image_load_store)
- GL_MAX_GEOMETRY_IMAGE_UNIFORMS: 8 (GL_ARB_shader_image_load_store)
- GL_MAX_FRAGMENT_IMAGE_UNIFORMS: 8 (GL_ARB_shader_image_load_store)
- GL_MAX_COMBINED_IMAGE_UNIFORMS: 40 (GL_ARB_shader_image_load_store)
- GL_MIN_MAP_BUFFER_ALIGNMENT: 64 (GL_ARB_map_buffer_alignment)
- GL_MAX_COMPUTE_UNIFORM_BLOCKS: 14 (GL_ARB_compute_shader)
- GL_MAX_COMPUTE_TEXTURE_IMAGE_UNITS: 16 (GL_ARB_compute_shader)
- GL_MAX_COMPUTE_IMAGE_UNIFORMS: 8 (GL_ARB_compute_shader)
- GL_MAX_COMPUTE_SHARED_MEMORY_SIZE: 32768 (GL_ARB_compute_shader)
- GL_MAX_COMPUTE_UNIFORM_COMPONENTS: 4096 (GL_ARB_compute_shader)
- GL_MAX_COMPUTE_ATOMIC_COUNTER_BUFFERS: 8 (GL_ARB_compute_shader)
- GL_MAX_COMPUTE_ATOMIC_COUNTERS: 4096 (GL_ARB_compute_shader)
- GL_MAX_COMBINED_COMPUTE_UNIFORM_COMPONENTS: 61440 (GL_ARB_compute_shader)
- GL_MAX_COMPUTE_WORK_GROUP_INVOCATIONS: 1024 (GL_ARB_compute_shader)
- GL_MAX_COMPUTE_WORK_GROUP_COUNT: 65535/65535/65535 (GL_ARB_compute_shader)
- GL_MAX_COMPUTE_WORK_GROUP_SIZE: 1024/1024/64 (GL_ARB_compute_shader)
- GL_MIN_PROGRAM_TEXEL_OFFSET_EXT: -8 (GL_EXT_gpu_shader4)
- GL_MAX_PROGRAM_TEXEL_OFFSET_EXT: 7 (GL_EXT_gpu_shader4)
- GL_MAX_TEXTURE_UNITS_ARB: 8 (GL_ARB_multitexture)
- GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS_ARB: 16 (GL_ARB_multitexture)
- GL_MAX_TEXTURE_IMAGE_UNITS_ARB: 16 (GL_ARB_multitexture)
- GL_MAX_CUBE_MAP_TEXTURE_SIZE_ARB: 16384 (GL_ARB_texture_cube_map)
- GL_NUM_COMPRESSED_TEXTURE_FORMATS: 10 (GL_ARB_texture_compression)
- GL_MAX_TEXTURE_MAX_ANISOTROPY_EXT: 16.000000 (GL_EXT_texture_filter_anisotropic)
- GL_MAX_VERTEX_UNIFORM_COMPONENTS: 4096 (GL_ARB_vertex_shader)
- GL_MAX_VARYING_FLOATS: 64 (GL_ARB_vertex_shader)
- GL_MAX_VERTEX_ATTRIBS: 16 (GL_ARB_vertex_shader)
- GL_MAX_TEXTURE_IMAGE_UNITS: 16 (GL_ARB_vertex_shader)
- GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS: 16 (GL_ARB_vertex_shader)
- GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS: 96 (GL_ARB_vertex_shader)
- GL_MAX_TEXTURE_COORDS: 8 (GL_ARB_vertex_shader)
- GL_MAX_FRAGMENT_UNIFORM_COMPONENTS_ARB: 4096 (GL_ARB_fragment_shader)
- GL_MAX_VERTEX_ATTRIBS_ARB: 16 (GL_ARB_vertex_program)
- GL_MAX_PROGRAM_MATRICES_ARB: 8 (GL_ARB_vertex_program)
- GL_MAX_PROGRAM_MATRIX_STACK_DEPTH_ARB: 2 (GL_ARB_vertex_program)
- GL_MAX_TEXTURE_COORDS_ARB: 8 (GL_ARB_fragment_program)
- GL_MAX_FRAGMENT_UNIFORM_COMPONENTS: 4096 (GL_ARB_shading_language_100)
- GL_MAX_GEOMETRY_UNIFORM_COMPONENTS_EXT: 4096 (GL_ARB_shading_language_100)
- GL_MAX_DRAW_BUFFERS_ARB: 8 (GL_ARB_draw_buffers)
- GL_MAX_COLOR_ATTACHMENTS: 8 (GL_ARB_framebuffer_object)
- GL_MAX_RENDERBUFFER_SIZE: 16384 (GL_ARB_framebuffer_object)
- GL_MAX_SAMPLES: 8 (GL_ARB_framebuffer_object)
- GL_POINT_SIZE_MIN_ARB: 0.000000 (GL_ARB_point_parameters)
- GL_POINT_SIZE_MAX_ARB: 255.000000 (GL_ARB_point_parameters)
- GL_MAX_VERTEX_UNIFORM_VECTORS: 1024 (GL_ARB_ES2_compatibility)
- GL_MAX_VARYING_VECTORS: 16 (GL_ARB_ES2_compatibility)
- GL_MAX_FRAGMENT_UNIFORM_VECTORS: 1024 (GL_ARB_ES2_compatibility)
- GL_MAX_DEBUG_MESSAGE_LENGTH: 1024 (GL_ARB_debug_output)
- GL_MAX_DEBUG_LOGGED_MESSAGES_ARB: 128 (GL_ARB_debug_output)
- GL_MAX_GEOMETRY_TEXTURE_IMAGE_UNITS_EXT: 16 (GL_EXT_geometry_shader4)
- GL_MAX_GEOMETRY_OUTPUT_VERTICES_EXT: 256 (GL_EXT_geometry_shader4)
===================================[ OpenCL Capabilities ]
- Num OpenCL platforms: 2
- CL_PLATFORM_NAME: Intel(R) OpenCL
- CL_PLATFORM_VENDOR: Intel(R) Corporation
- CL_PLATFORM_VERSION: OpenCL 1.2
- CL_PLATFORM_PROFILE: FULL_PROFILE
- Num devices: 1
- CL_DEVICE_NAME: Intel(R) Core(TM) i5-4200U CPU @ 1.60GHz
- CL_DEVICE_VENDOR: Intel(R) Corporation
- CL_DRIVER_VERSION: 3.0.1.10878
- CL_DEVICE_PROFILE: FULL_PROFILE
- CL_DEVICE_VERSION: OpenCL 1.2 (Build 76413)
- CL_DEVICE_TYPE: CPU
- CL_DEVICE_VENDOR_ID: 0x8086
- CL_DEVICE_MAX_COMPUTE_UNITS: 4
- CL_DEVICE_MAX_CLOCK_FREQUENCY: 1600MHz
- CL_DEVICE_ADDRESS_BITS: 32
- CL_DEVICE_MAX_MEM_ALLOC_SIZE: 524256KB
- CL_DEVICE_GLOBAL_MEM_SIZE: 2047MB
- CL_DEVICE_MAX_PARAMETER_SIZE: 3840
- CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE: 64 Bytes
- CL_DEVICE_GLOBAL_MEM_CACHE_SIZE: 256KB
- CL_DEVICE_ERROR_CORRECTION_SUPPORT: NO
- CL_DEVICE_LOCAL_MEM_TYPE: Global
- CL_DEVICE_LOCAL_MEM_SIZE: 32KB
- CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE: 128KB
- CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS: 3
- CL_DEVICE_MAX_WORK_ITEM_SIZES: [1024 ; 1024 ; 1024]
- CL_DEVICE_MAX_WORK_GROUP_SIZE: 1024
- CL_EXEC_NATIVE_KERNEL: 12435280
- CL_DEVICE_IMAGE_SUPPORT: YES
- CL_DEVICE_MAX_READ_IMAGE_ARGS: 480
- CL_DEVICE_MAX_WRITE_IMAGE_ARGS: 480
- CL_DEVICE_IMAGE2D_MAX_WIDTH: 16384
- CL_DEVICE_IMAGE2D_MAX_HEIGHT: 16384
- CL_DEVICE_IMAGE3D_MAX_WIDTH: 2048
- CL_DEVICE_IMAGE3D_MAX_HEIGHT: 2048
- CL_DEVICE_IMAGE3D_MAX_DEPTH: 2048
- CL_DEVICE_MAX_SAMPLERS: 480
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR: 1
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT: 1
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT: 1
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG: 1
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT: 1
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE: 1
- CL_DEVICE_EXTENSIONS: 14
- Extensions:
- cl_khr_fp64
- cl_khr_icd
- cl_khr_global_int32_base_atomics
- cl_khr_global_int32_extended_atomics
- cl_khr_local_int32_base_atomics
- cl_khr_local_int32_extended_atomics
- cl_khr_byte_addressable_store
- cl_intel_printf
- cl_ext_device_fission
- cl_intel_exec_by_local_thread
- cl_khr_gl_sharing
- cl_intel_dx9_media_sharing
- cl_khr_dx9_media_sharing
- cl_khr_d3d11_sharing
- CL_PLATFORM_NAME: AMD Accelerated Parallel Processing
- CL_PLATFORM_VENDOR: Advanced Micro Devices, Inc.
- CL_PLATFORM_VERSION: OpenCL 1.2 AMD-APP (1311.2)
- Num devices: 2
- CL_DEVICE_NAME: Oland
- CL_DEVICE_VENDOR: Advanced Micro Devices, Inc.
- CL_DRIVER_VERSION: 1311.2 (VM)
- CL_DEVICE_VERSION: OpenCL 1.2 AMD-APP (1311.2)
- CL_DEVICE_TYPE: GPU
- CL_DEVICE_VENDOR_ID: 0x1002
- CL_DEVICE_MAX_COMPUTE_UNITS: 6
- CL_DEVICE_MAX_CLOCK_FREQUENCY: 825MHz
- CL_DEVICE_MAX_MEM_ALLOC_SIZE: 524288KB
- CL_DEVICE_GLOBAL_MEM_SIZE: 2048MB
- CL_DEVICE_MAX_PARAMETER_SIZE: 1024
- CL_DEVICE_GLOBAL_MEM_CACHE_SIZE: 16KB
- CL_DEVICE_LOCAL_MEM_TYPE: Local (scratchpad)
- CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE: 64KB
- CL_DEVICE_MAX_WORK_ITEM_SIZES: [256 ; 256 ; 256]
- CL_DEVICE_MAX_WORK_GROUP_SIZE: 256
- CL_EXEC_NATIVE_KERNEL: 12435284
- CL_DEVICE_MAX_READ_IMAGE_ARGS: 128
- CL_DEVICE_MAX_WRITE_IMAGE_ARGS: 8
- CL_DEVICE_MAX_SAMPLERS: 16
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR: 4
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT: 2
- CL_DEVICE_EXTENSIONS: 21
- Extensions:
- cl_khr_fp64
- cl_amd_fp64
- cl_khr_int64_base_atomics
- cl_khr_int64_extended_atomics
- cl_khr_3d_image_writes
- cl_khr_gl_sharing
- cl_ext_atomic_counters_32
- cl_amd_device_attribute_query
- cl_amd_vec3
- cl_amd_printf
- cl_amd_media_ops
- cl_amd_media_ops2
- cl_amd_popcnt
- cl_khr_d3d10_sharing
- cl_khr_image2d_from_buffer
- CL_DEVICE_VENDOR: GenuineIntel
- CL_DRIVER_VERSION: 1311.2 (sse2,avx)
- CL_DEVICE_MAX_CLOCK_FREQUENCY: 2295MHz
- CL_DEVICE_MAX_MEM_ALLOC_SIZE: 1048576KB
- CL_DEVICE_MAX_PARAMETER_SIZE: 4096
- CL_DEVICE_GLOBAL_MEM_CACHE_SIZE: 32KB
- CL_DEVICE_IMAGE2D_MAX_WIDTH: 8192
- CL_DEVICE_IMAGE2D_MAX_HEIGHT: 8192
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR: 16
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT: 8
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT: 4
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG: 2
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT: 8
- CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE: 4
- CL_DEVICE_EXTENSIONS: 17
- Extensions:
- cl_khr_fp64
- cl_amd_fp64
- cl_khr_gl_sharing
- cl_amd_vec3
- cl_amd_printf
- cl_amd_media_ops
- cl_amd_media_ops2
- cl_amd_popcnt
