Re: Настраиваем контроллер to_pci.
Добавлено: 21 июн 2021, 18:47
Я чего то не понимаю, причем тут конфиг pwm, ссылка дана была на конфиг степ/Дир. Dcontrol 0 есть в степ/Дир - один аналоговый канал для шпинделя.
Статьи, обзоры, цены на станки и комплектующие.
https://cnc-club.ru/forum/
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/lib/linuxcnc/modules
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/lib/tcltk/linuxcnc/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.6
LINUXCNC - 2.8.2
Machine configuration directory is '/home/dron/linuxcnc/configs/ETHcombP'
Machine configuration file is 'TA.ini'
INIFILE=/home/dron/linuxcnc/configs/ETHcombP/TA.ini
VERSION=1.1
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
COORDINATES=XZ
KINEMATICS=trivkins coordinates=XZ
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Found file(REL): ./TA.hal
Shutting down and cleaning up LinuxCNC...
Running HAL shutdown script
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Debug file information:
inifile: warning: File contains DOS-style line endings.
Note: Using POSIX realtime
./TA.hal:3: File contains embedded carriage returns.
2730
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
http://pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Ср сен 1 22:56:34 +07 2021
UTC Date: Ср сен 1 15:56:34 UTC 2021
this program: /usr/bin/linuxcnc_info
uptime: 22:56:34 up 33 min, 1 user, load average: 0,39, 0,58, 0,70
lsb_release -sa: Debian Debian GNU/Linux 10 (buster) 10 buster
which linuxcnc: /usr/bin/linuxcnc
pwd: /home/dron/linuxcnc/configs/ETHcombP
USER: dron
LOGNAME: dron
HOME: /home/dron
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1280x800 pixels (338x211 millimeters)
PATH: /usr/bin:/home/dron/linuxcnc/configs/ETHcombP/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: debian-dron
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT RT Debian 4.19.194-2 (2021-06-21)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-4.19.0-17-rt-amd64 root=UUID=3a2cc925-3515-4a2c-b50e-6f31d492b6a8 ro initrd=/install/initrd.gz quiet
model name: Intel(R) Core(TM)2 Duo CPU T8100 @ 2.10GHz
cores: 2
cpu MHz: 1595.866
parport: 0000-0000 : parport0 0000-0000 : parport0
serial:
Versions:
gcc: gcc (Debian 8.3.0-6) 8.3.0
python: Python 2.7.16
git: not_in_PATH
git commit: NA
tcl: 8.6
tk: 8.6
glade: not_in_PATH
glade-gtk2: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.8.2
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /etc/init.d/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
dpkg -l '*linuxcnc*':
Желаемый=неизвестно[u]/установить[i]/удалить[r]/вычистить[p]/зафиксировать[h]
| Состояние=не[n]/установлен[i]/настроен[c]/распакован[U]/частично настроен[F]/
частично установлен[H]/trig-aWait/Trig-pend
|/ Ошибка?=(нет)/требуется переустановка[R] (верхний регистр
в полях состояния и ошибки указывает на ненормальную ситуацию)
||/ Имя Версия Архитектура Описание
un linuxcnc <нет> <нет> (описание недоступно)
un linuxcnc-dev <нет> <нет> (описание недоступно)
un linuxcnc-doc <нет> <нет> (описание недоступно)
ii linuxcnc-doc-cn 1:2.8.2 all motion controller for CNC machines and robots (Chinese
ii linuxcnc-doc-en 1:2.8.2 all motion controller for CNC machines and robots (English documentation)
ii linuxcnc-doc-es 1:2.8.2 all controlador de movimiento para máquinas CNC y robots (Español).
ii linuxcnc-doc-fr 1:2.8.2 all motion controller for CNC machines and robots (French documentation)
un linuxcnc-sim <нет> <нет> (описание недоступно)
un linuxcnc-sim-dev <нет> <нет> (описание недоступно)
ii linuxcnc-uspace 1:2.8.2 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.8.2 amd64 PC based motion controller for real-time Linuxничего не понятно. запусти linuxcnc из консоли, и укажи путь к своему INI файлу. Так увидишь ошибки, а не кучу лишнего мусора.
А вообще возможно надо файл сконвертировать в unix-like стиль (окончание строк)../TA.hal:3: File contains embedded carriage returns.
здесь я не совсем понял что нужно сделать ../TA.hal:3: File contains embedded carriage returns.
В системе должен быть установлен текстовый редактор geany, там поидеи можно это сделать через менюшки мышкой.
В каком файле менять? в HAL ?
