Страница 3 из 4
Gcode tools - lathe extension develop
Добавлено: 08 апр 2010, 09:25
Questions to discus
- Cutting tool parameters
- Additional lathe parameters
- Lathe's Gcode features
- Special places
Desired features list
- Special mode for 4axis mills
- Automatic flip along axis
Awaiting of realization
Done
- Path calculation
- Export path to gcode
- Defailt X and Z axis remap
Re: Gcode tools - lathe extension develop
Добавлено: 03 авг 2010, 23:25
alfcnc
First try in real use condition of lathe extension:
The machine configuration is a Mill with a little motor for rotary axis the long of the X axis.
Gcodetool extension lathe generate gcode in XY mode remap.
Making a wood ball...
On turning...
The result.... :
It have some little bug for finishing pass that doesn't subdivise the finishing width by the number of subdivision set...
It's not so easy to set the good direction for the path to tell gcodetools to go left to righ or righ to left... perhaps have you a trick... i make more try
and reports you another bugs...
The first try is nice for me ... good results to come.
Have a nice day
Добавлено: 04 авг 2010, 09:46
Hi! Nice job!
Thanks for the photos!
I've been doing some 3d modelin/drawing/rendering and photo of your wooden ball looks like a material test from the Vray
It's not a bug it's a feature
! The subdivision is not needed there. If you are cutting a ball you can cut it using only one gcode command G02 because ball' projection is a circle
Sure I have a trick
. It's in the FAQ... Oooppps I have forgot to publish it in English
. But thanks to Dormouse who have made this job. So see his FAQ
http://kalyaev.com/2010/20100408/inkscape-faq.html.
In a nutshell:
To check the direction of the path add middle or end markers that looks like an arrow pointing to the End. (Ctrl+Shift+F -> Stroke Style -> set stroke width more than '0', Middle markers Arrow2M
End.)
To change paths direction do the following Path->Reverse.
That's it. Easy, isn't it?
I have some advises:
- Remove that vertical line from the left. Material width should be defined in the lathe window.
- Add horizontal line at level 0 from the right. Doing this you avoid high depth step during the fine cut at the right.
- Define depth step at the tools parameters.
- Define material width at lathe's window.
- Some advises how to draw your scene:
- Draw a circle and a rectangle.
- Move circle until it's center not on the rectangle's edge. It will be easy if you turn on snapping and grab circle near the left or right points.
- Add them together (Ctrl+Shit+"+")
- Add rectangle at the left to hold your ball while it's being cut.
- Using knots editing tool (F2) remove unnecessary knots.
- Image that just showing that reverse works:
i make more try
Will be waiting for new results.
Добавлено: 04 авг 2010, 12:56
alfcnc
Hum I think you have don't understand me for this feature....
The feature i was thinking for this is that for have a good finishing surface at the end of cut require to cut very thin depht of material...
So when the tool arrive to finishing depth for example 1 mm and if have set 10 step the tool must cut all the shape Ten time with widht of 0,1mm
depht minus each pass... until arrive to the end of the last shape cuting.
Because if i cut in one time G02 the depht is too big and for example soft wood is tear... and to suppress this tearing effect of fiber
I must cut 3 or 5 pass with very thin depht befor arrive to final pass...
Or actualy if I set 1 mm fine cut width and cut count to 10 the gcode generate do 10 time the end shape.... and doesn't subdivide
the 1 mm depht to 10 depth cutting thin pass...
Excuse me if i have bad explain you this feature on the start of work...
So another solution is to do Twice the gcode generation ... One with roughing and another one just for finish... whith two sheet in inkscapte or two gcode file...but less beautifull and practical...
Добавлено: 04 авг 2010, 13:07
alfcnc
For the reverse funtion very Nice... It's so obvious that i don't understand why i haven't see it before...
Добавлено: 04 авг 2010, 13:08
Now I get it... Ok, I'll try to do it...
Добавлено: 04 авг 2010, 13:46
alfcnc
Just for illustrate and show you the errors... of no subdivide of end cutting depth and why i have a vertical line to the left of end of drawing...
because gcodetools go wrong in depht at the start or end of cutting depending the direction...
See on picture...and in gcode file were Y go to negative value....
The svg...
The ngc...
Добавлено: 04 авг 2010, 16:04
alfcnc писал(а):Just for illustrate and show you the errors... of no subdivide of end cutting depth and why i have a vertical line to the left of end of drawing...
The svg...
lathe_error_end_cutting.svg
The ngc...
lathe_error_end_cutting.ngc
There was a bug... while doing fine cutting penetration g00 was path.y - fine_cutting_width instead of path.y + fine_cutting_width.
I'll correct this in some minutes...
Добавлено: 04 авг 2010, 16:30
Revision 139
I've add a parameter "Create fine cut using" and two options:
"Move path" just moves original path up. And so creates a number of fine cuts. Gives worse results than offset but there should not be bugs.
"Offsets" offsets original path up. And so creates a number of fine cuts. Gives the best result but could be bugs due to offsets bugs. You can always try it first and in case of bugs try to add some knots to the path near the problem places or just use the first option.
I've changed the inx file so you'll have to run python create_inx.py before using separate lathe window.
Here's an illustration:
Добавлено: 04 авг 2010, 18:01
alfcnc
Ok ! I'll test...
Добавлено: 04 авг 2010, 18:06
Oppps wait a minet I've got to do the push....
Добавлено: 04 авг 2010, 18:11
Now you can try it... Revision 140.
Добавлено: 04 авг 2010, 19:41
alfcnc
Ok ! That's come great... but little error with offset...
The fine cuting path goes out on the left...
And on the right start at curious position for some of them....
svg file with trajectory and setting...
if setting 1mm fine cut and 5 count the right is good... but left alwas go out...
Hum Curious ! I see now with different setting all is ok... curious..perhaps this can help you to find
were is the bug..
Добавлено: 04 авг 2010, 21:49
Revision 142
I've found the bug. While calculating line and Bezier curve intersection we have to solve cubic equation and take only real roots that are 0<=root<=1. But due to calculation tolerances root becomes 1.000000001 which was ignored. Now we take roots that's abs(root.imag)<1e-7 = 0.0000001 and -0.0000000001<=root.real<=1.0000000001.
Thanks for the bug report
Добавлено: 05 авг 2010, 11:47
alfcnc
YES YES YES ....very very nice...
And I think that's correct some problem with Area....because I have some strange things look like this when working with little value...
Добавлено: 05 авг 2010, 12:39
alfcnc
Hi despit the debugging another bug arrive...
With some value gcodetools give a zero division error see on screen capture...
And with another value that's work but the before last fine cuting path is lost....
see another screen capture...
Добавлено: 05 авг 2010, 13:28
Revision 142
I think I've fixed first problem.
I've added tolerance=0.0000000001 into csp_split_by_two_points function.
The second problem caused by offset's clipping errors. I really do not know how to fix them right now. You can add some knots to path to do a "local" fix.
Добавлено: 06 авг 2010, 15:57
alfcnc
Hum rev 142 bug bug....
the fine cut count don't work any time if generate path cutting from left to right.... often division error with any settting and
when that work for example with 0.6 mm fine cut width and 3 fine cut count it have any fine cut generate...
And it's more more hard to find value that works with this direction... perhaps have you missing some subroutine for this direction...
Добавлено: 06 авг 2010, 16:00
alfcnc
alfcnc писал(а):Hum rev 142 bug bug....
Hum else if i add more and more knot... like you have tell me to do.
Добавлено: 06 авг 2010, 21:51
Could you post your svg and parameters please.
PS We have started to develop a Postprocessing feature. Which will enable axis flipping/remaping and other features...
Revision 145 includes beginning of Postprocessing class.
Postprocesing will look like a script with commands that are separated by semicolon.
command(parameters,..,parameter);command(parameters,..,parameter);command(parameters,..,parameter);command(parameters,..,parameter);
At the moment two one function is available: remap and remapi, they are the same but ramapi works case insensitive.
remap command has simple syntax:
remap("change from"->"change to",...,"change from"->"change to"). This function works almost the same as replace, the only difference that it do all replaces together not one after another.
I'll show the difference at the example:
lets take the code: "x 10 y 20"
remap("x"->"y","y"->"z") will give "y10 z20"
but if we'll do to consecutive replaces we'll have the following:
Original: "x 10 y 20"
after replace "x" to "y" : "y 10 y 20"
after replace "y" to "z" : "z 10 z 20"
See the difference?
Hmmmm... I thin we should start new thread to discuss postprocessing...
Добавлено: 06 авг 2010, 22:17
alfcnc
Ok ! process, processing...
The svg file is the same than post just previous this post... Boule1.svg...
were I have just change the direction of cutting path from "right to left" to
" left to right" with revert path... you'll have the bug with about all the value
you can set for fine cut.... very easy to reproduce...
