Inkscape CloseCurves extension English support forum
If you have any questions click here to register. You can choose English interface there.
This is an Inkscape extension that closes all open curves in the selection.
It may be useful when you want to use curves in other programs such OpenOffice. OpenOffice wont fill path if it isn't closed one. Also if you convert text to curve, you can see some trash in the outline because curves are not closed (see attached pictures).
Close curves inkscape extension (24410 просмотров) <a class='original' href='./download/file.php?id=95&sid=07dd9df67962892bf0ee6c29198140a4&mode=view' target=_blank>Загрузить оригинал (65.1 КБ)</a>
This extension works with paths. It modifies path's d parameter. It adds a 'z' just before each 'm' if it's not the first one in the line or there's already 'z' before it.
Instalation: Unpack files from attached archive to /usr/share/inkscape/extensions/. Extension appears at Extension->Modify path.
Any comments and contributions are welcome :)!
close_curves.inx
<?xml version="1.0" encoding="UTF-8"?>
<inkscape-extension xmlns="http://www.inkscape.org/namespace/inkscape/extension">
	<_name>Close curves</_name>
	<id>ru.cnc-club.filter.close_curves</id>
	<dependency type="executable" location="extensions">close_curves.py</dependency>
	<dependency type="executable" location="extensions">inkex.py</dependency>
	<param name="help" type="description">
		Select paths that you want to close, and press ok.
	</param>
	<effect needs-live-preview="false">
		 <effects-menu>
            <submenu _name="Modify Path"/>
        </effects-menu>
		<object-type>path</object-type>
	</effect>
	<script>
		<command reldir="extensions" interpreter="python">close_curves.py</command>
	</script>
</inkscape-extension>
close_curves.py
#!/usr/bin/env python
Copyright (C) 2009 Nick Drobchenko, nick@cnc-club.ru
based on gcode.py (C) 2007 hugomatic...
based on addnodes.py (C) 2005,2007 Aaron Spike, aaron@ekips.org
based on dots.py (C) 2005 Aaron Spike, aaron@ekips.org
This program is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
#	This extension close paths by adding 'z' before each 'm' if it is not
#	the first 'm' and it is not prepended by 'z' already.
import inkex, re, simplepath
class CloseCurves(inkex.Effect):
	def __init__(self):
		inkex.Effect.__init__(self)
	def effect(self):
		for id, node in self.selected.iteritems():
			if node.tag == inkex.addNS('path','svg'):
				d = node.get('d')
				d = simplepath.formatPath( simplepath.parsePath(d) )
				d = re.sub(r'(?i)(m[^mz]+)',r'\1 Z ',d)
				d = re.sub(r'(?i)\s*z\s*z\s*',r' Z ',d)
				node.set('d', d)
e = CloseCurves()
e.affect()
close_curves.tar.gz
(1.3 КБ) 4003 скачивания
alfcnc
Заслуга: Tester
Re: Inkscape CloseCurves extension English support forum
Сообщение alfcnc »
Thank's ! I'have try that's work great.
And it's very well when apply it before engraving or others gcode tools ! this resolve some errors in the generate path...
Have a nice day ! 8-)
Thanks :)! It was not to hard to write it :lol:.
DMexico
Сообщение DMexico »
Thanks, Nik! Useful extension!
Мнение автора может не совпадать с мнением редакции
Вернуться в «English forum»
