STEP2CNC - new LPT steerage program
Rakus
Сообщение Rakus »
Hi Everyone!
My name is Piotr Rakowski. I live in Poland/Warsaw. I'm owner and founder of LYNX company from Poland. We make CNC machines.
I have made cnc steerage program via LPT port, similar to Mach, but easy (not so complicated). The program called STEP2CNC. Latest version is 2.5.
Using this program you can run any CNC machine up to 4-axes, with full interpolation of all axes.
Recently I made russian version of the program, thanks to help of my collegue that been living in Russia for 20 years (now he lives in Poland).
So in my opinion the translation of the program is good enough. Could you please check the program and tell me if it's suitable for
your needs?
The interface looks like this:
step2cnc.jpg (12941 просмотр) <a class='original' href='./download/file.php?id=11226&sid=7beb5119c78a416be57eee52de3be641&mode=view' target=_blank>Загрузить оригинал (118.37 КБ)</a>
This is link to russian summary and program explanation: http://www.lynxsft.home.pl/ForumRUS/STEP2CNC_RUS.htm
Here you have link to the russian version: http://www.lynxsft.home.pl/programy/now ... NC_RUS.rar
Without registration (licence) it's limited to 500 lines of g-codes. Interface is based on russian Windows TTF font "Microsoft Sans Serif".
Regards, Rakus
Re: STEP2CNC - new LPT steerage program
Hi!
Interesting program! That bmp-tracing module for pcb engraving is very interesting! Can you show any results/screenshots/gcodes of it's work?
Russian is language is fine, I think I make more mistakes usually :freak:
Rakus
Сообщение Rakus »
Thanks for your interest.
The program is mailny made for routers and hot-wired cutters. PCB engraving is only one of the possibilities.
Of course I can make sample g-codes, but if you devote your time to check the program and it's possibilities - you can check better than me!
So, below are links to movies showing how machines goes on (are driven by) STEP2CNC:
Driving hot-wire cutting CNC plotter: https://www.youtube.com/watch?v=wg8c1LS7d_U
Relief 3D engraving (made from BMP file by BMP2CNC inner program module): https://www.youtube.com/watch?v=1bcVgaQ3fPs
4-axis driving of oscillating knife plotter: https://www.youtube.com/watch?v=df7J_XOJ3mQ
Program is simple, versatile and cheap. In fact has been developed for last 4 years, so I'ts well tried and tested for many users in Poland.
Now I would like to present it to Russian users.
Rakus
Сообщение Rakus »
Hi there! Is there someone, who tried the program?
Rakus
Сообщение Rakus »
Link to the program is above. Program is not free, but you can check it, for free. Demo mode allows all program capabilities. It's restricted to:
- max 500 g-code lines,
- limits max speed.
ALL OTHER OPTIONS ARE AVAILABLE.
Program is cheap - costs only $49
Вернуться в «English forum»
