Достался мне ноут с лпт. поставил линукс ЦНЦ
При запуске ЕМС ругается, иногда так ругался и на обычном компе, но там помогала перезагрузка.
Вот лог ошибки
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/denis/linuxcnc/configs/XYZ_cnc'
Machine configuration file is 'XYZ_cnc.ini'
INIFILE=/home/denis/linuxcnc/configs/XYZ_cnc/XYZ_cnc.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Realtime system did not load
Shutting down and cleaning up LinuxCNC...
Killing task linuxcncsvr, PID=1843
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
1843
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
/usr/bin/linuxcnc: строка 428: 1880 Ошибка сегментирования $HALCMD stop
Unloading hal components
/usr/bin/linuxcnc: строка 428: 1881 Ошибка сегментирования $HALCMD unload all
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000001eff0000 (usable)
[ 0.000000] BIOS-e820: 000000001eff0000 - 000000001effffc0 (ACPI data)
[ 0.000000] BIOS-e820: 000000001effffc0 - 000000001f000000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000fff80000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] last_pfn = 0x1eff0 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-CBFFF write-protect
[ 0.000000] CC000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FF0000000 write-back
[ 0.000000] 1 base 010000000 mask FF8000000 write-back
[ 0.000000] 2 base 018000000 mask FFC000000 write-back
[ 0.000000] 3 base 01C000000 mask FFE000000 write-back
[ 0.000000] 4 base 01E000000 mask FFF000000 write-back
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009fc00 (usable)
[ 0.000000] modified: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 000000001eff0000 (usable)
[ 0.000000] modified: 000000001eff0000 - 000000001effffc0 (ACPI data)
[ 0.000000] modified: 000000001effffc0 - 000000001f000000 (ACPI NVS)
[ 0.000000] modified: 00000000fff80000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-000000001eff0000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 001ec00000 page 2M
[ 0.000000] 001ec00000 - 001eff0000 page 4k
[ 0.000000] kernel direct mapping tables up to 1eff0000 @ 7000-c000
[ 0.000000] RAMDISK: 167aa000 - 1743377c
[ 0.000000] ACPI: RSDP 000e5010 00014 (v00 OID_00)
[ 0.000000] ACPI: RSDT 1efffbc0 00030 (v01 INSYDE RSDT_000 00000001 _CSI 00010101)
[ 0.000000] ACPI: FACP 1efffac0 00074 (v01 INSYDE FACP_000 00000100 _CSI 00010101)
[ 0.000000] ACPI: DSDT 1effbac0 03FF5 (v01 FUJITS EF4 00000419 MSFT 0100000D)
[ 0.000000] ACPI: FACS 1effffc0 00040
[ 0.000000] ACPI: BOOT 1efffb50 00028 (v01 INSYDE SYS_BOOT 00000100 _CSI 00010101)
[ 0.000000] ACPI: DBGP 1efffb80 00034 (v01 INSYDE DBGP_000 00000100 _CSI 00010101)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 495MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 1eff0000
[ 0.000000] low ram: 0 - 1eff0000
[ 0.000000] node 0 low ram: 00000000 - 1eff0000
[ 0.000000] node 0 bootmap 00008000 - 0000be00
[ 0.000000] (9 early reservations) ==> bootmem [0000000000 - 001eff0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [00167aa000 - 001743377c] RAMDISK ==> [00167aa000 - 001743377c]
[ 0.000000] #5 [000009fc00 - 0000100000] BIOS reserved ==> [000009fc00 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b4161] BRK ==> [00008b1000 - 00008b4161]
[ 0.000000] #7 [0000007000 - 0000008000] PGTABLE ==> [0000007000 - 0000008000]
[ 0.000000] #8 [0000008000 - 000000c000] BOOTMAP ==> [0000008000 - 000000c000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x0001eff0
[ 0.000000] HighMem 0x0001eff0 -> 0x0001eff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0001eff0
[ 0.000000] On node 0 totalpages: 126859
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 960 pages used for memmap
[ 0.000000] Normal zone: 121904 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x1008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 1f000000 (gap: 1f000000:e0f80000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1400000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 125867
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=fa89abc1-5fa6-452b-9f63-5019587ba6d6 ro quiet splash
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 2539200 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 479368k/507840k available (4539k kernel code, 27704k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xdf7f0000 - 0xff7fe000 ( 512 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xdeff0000 ( 495 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=128, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 2492.047 MHz processor.
[ 0.008009] Calibrating delay loop (skipped), value calculated using timer frequency.. 4984.09 BogoMIPS (lpj=9968188)
[ 0.008046] Security Framework initialized
[ 0.008085] AppArmor: AppArmor initialized
[ 0.008102] Mount-cache hash table entries: 512
[ 0.008339] Initializing cgroup subsys ns
[ 0.008350] Initializing cgroup subsys cpuacct
[ 0.008359] Initializing cgroup subsys memory
[ 0.008378] Initializing cgroup subsys devices
[ 0.008383] Initializing cgroup subsys freezer
[ 0.008387] Initializing cgroup subsys net_cls
[ 0.008428] CPU: Trace cache: 12K uops, L1 D cache: 8K
[ 0.008435] CPU: L2 cache: 256K
[ 0.008440] CPU: Hyper-Threading is disabled
[ 0.008447] mce: CPU supports 4 MCE banks
[ 0.008477] Performance Events: no PMU driver, software events only.
[ 0.008493] Checking 'hlt' instruction... OK.
[ 0.025367] SMP alternatives: switching to UP code
[ 0.039266] Freeing SMP alternatives: 31k freed
[ 0.039322] ACPI: Core revision 20090903
[ 0.049897] ACPI: setting ELCR to 0200 (from 0c00)
[ 0.052022] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.052039] ftrace: allocating 21003 entries in 42 pages
[ 0.067664] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.067672] weird, boot CPU (#0) not listed by the BIOS.
[ 0.067675] SMP motherboard not detected.
[ 0.067679] Local APIC not detected. Using dummy APIC emulation.
[ 0.067682] SMP disabled
[ 0.068093] Brought up 1 CPUs
[ 0.068101] Total of 1 processors activated (4984.09 BogoMIPS).
[ 0.068367] CPU0 attaching NULL sched-domain.
[ 0.068636] devtmpfs: initialized
[ 0.069213] regulator: core version 0.5
[ 0.069316] NET: Registered protocol family 16
[ 0.069528] EISA bus registered
[ 0.069549] ACPI: bus type pci registered
[ 0.069673] PCI: PCI BIOS revision 2.10 entry at 0xe8964, last bus=1
[ 0.069677] PCI: Using configuration type 1 for base access
[ 0.070990] bio: create slab <bio-0> at 0
[ 0.072035] ACPI: EC: Look up EC in DSDT
[ 0.084702] ACPI: Interpreter enabled
[ 0.084711] ACPI: (supports S0 S5)
[ 0.084731] ACPI: Using PIC for interrupt routing
[ 0.094533] ACPI: EC: GPE = 0x1, I/O: command/status = 0x66, data = 0x62
[ 0.096327] ACPI: ACPI Dock Station Driver: 1 docks/bays found
[ 0.096327] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.096388] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xa0000000-0xa3ffffff]
[ 0.096515] pci 0000:00:01.0: supports D1
[ 0.096568] pci 0000:00:0a.0: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.096593] pci 0000:00:0a.0: supports D1 D2
[ 0.096596] pci 0000:00:0a.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.096603] pci 0000:00:0a.0: PME# disabled
[ 0.096653] pci 0000:00:0a.1: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.096676] pci 0000:00:0a.1: supports D1 D2
[ 0.096680] pci 0000:00:0a.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.096685] pci 0000:00:0a.1: PME# disabled
[ 0.096736] pci 0000:00:0c.0: reg 10 32bit mmio: [0xf0000000-0xf00007ff]
[ 0.096746] pci 0000:00:0c.0: reg 14 32bit mmio: [0xf0004000-0xf0007fff]
[ 0.096795] pci 0000:00:0c.0: supports D1 D2
[ 0.096799] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot
[ 0.096804] pci 0000:00:0c.0: PME# disabled
[ 0.096844] pci 0000:00:0d.0: reg 10 io port: [0xe000-0xe0ff]
[ 0.096853] pci 0000:00:0d.0: reg 14 32bit mmio: [0xf0008000-0xf00080ff]
[ 0.096901] pci 0000:00:0d.0: supports D1 D2
[ 0.096904] pci 0000:00:0d.0: PME# supported from D1 D2 D3hot D3cold
[ 0.096910] pci 0000:00:0d.0: PME# disabled
[ 0.097063] pci 0000:00:11.1: reg 20 io port: [0x1100-0x110f]
[ 0.097155] pci 0000:00:11.2: reg 20 io port: [0x1200-0x121f]
[ 0.097244] pci 0000:00:11.3: reg 20 io port: [0x1300-0x131f]
[ 0.097336] pci 0000:00:11.4: reg 20 io port: [0x1700-0x171f]
[ 0.097410] pci 0000:00:11.5: reg 10 io port: [0xe100-0xe1ff]
[ 0.097501] pci 0000:00:11.6: reg 10 io port: [0xe200-0xe2ff]
[ 0.097626] pci 0000:01:00.0: reg 10 32bit mmio: [0xe0000000-0xe007ffff]
[ 0.097635] pci 0000:01:00.0: reg 14 32bit mmio pref: [0x90000000-0x97ffffff]
[ 0.097661] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x0c0000-0x0cffff]
[ 0.097685] pci 0000:01:00.0: supports D1 D2
[ 0.097734] pci 0000:00:01.0: bridge io port: [0xc000-0xdfff]
[ 0.097740] pci 0000:00:01.0: bridge 32bit mmio: [0xe0000000-0xefffffff]
[ 0.097746] pci 0000:00:01.0: bridge 32bit mmio pref: [0x90000000-0x9fffffff]
[ 0.097791] pci_bus 0000:00: on NUMA node 0
[ 0.097803] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.108468] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 7 9 14 15) *11
[ 0.108672] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 7 *9 14 15)
[ 0.108865] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 7 *10 14 15)
[ 0.109059] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 7 *10 14 15)
[ 0.109270] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.109276] vgaarb: loaded
[ 0.109493] SCSI subsystem initialized
[ 0.109650] libata version 3.00 loaded.
[ 0.109816] usbcore: registered new interface driver usbfs
[ 0.109838] usbcore: registered new interface driver hub
[ 0.109900] usbcore: registered new device driver usb
[ 0.110194] ACPI: WMI: Mapper loaded
[ 0.110199] PCI: Using ACPI for IRQ routing
[ 0.110435] NetLabel: Initializing
[ 0.110440] NetLabel: domain hash size = 128
[ 0.110442] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.110464] NetLabel: unlabeled traffic allowed by default
[ 0.110537] Switching to clocksource tsc
[ 0.112001] AppArmor: AppArmor Filesystem Enabled
[ 0.112001] pnp: PnP ACPI init
[ 0.112001] ACPI: bus type pnp registered
[ 0.114652] PCI: setting IRQ 13 as level-triggered
[ 0.118196] pnp: PnP ACPI: found 13 devices
[ 0.118202] ACPI: ACPI bus type pnp unregistered
[ 0.118210] PnPBIOS: Disabled by ACPI PNP
[ 0.118235] system 00:03: iomem range 0xfff80000-0xffffffff has been reserved
[ 0.118246] system 00:05: ioport range 0x330-0x331 has been reserved
[ 0.118251] system 00:05: ioport range 0x4d0-0x4d1 has been reserved
[ 0.118256] system 00:05: ioport range 0x1000-0x107f has been reserved
[ 0.118261] system 00:05: ioport range 0x1400-0x140f has been reserved
[ 0.118265] system 00:05: ioport range 0x600-0x60f has been reserved
[ 0.118270] system 00:05: iomem range 0xffc00000-0xfff7ffff has been reserved
[ 0.153091] pci 0000:01:00.0: BAR 6: no parent found for of device [0x0c0000-0x0cffff]
[ 0.153148] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.153154] pci 0000:00:01.0: IO window: 0xc000-0xdfff
[ 0.153161] pci 0000:00:01.0: MEM window: 0xe0000000-0xefffffff
[ 0.153167] pci 0000:00:01.0: PREFETCH window: 0x90000000-0x9fffffff
[ 0.153175] pci 0000:00:0a.0: CardBus bridge, secondary bus 0000:02
[ 0.153179] pci 0000:00:0a.0: IO window: 0x001800-0x0018ff
[ 0.153185] pci 0000:00:0a.0: IO window: 0x001c00-0x001cff
[ 0.153191] pci 0000:00:0a.0: PREFETCH window: 0x20000000-0x23ffffff
[ 0.153197] pci 0000:00:0a.0: MEM window: 0x24000000-0x27ffffff
[ 0.153203] pci 0000:00:0a.1: CardBus bridge, secondary bus 0000:06
[ 0.153206] pci 0000:00:0a.1: IO window: 0x002000-0x0020ff
[ 0.153212] pci 0000:00:0a.1: IO window: 0x002400-0x0024ff
[ 0.153218] pci 0000:00:0a.1: PREFETCH window: 0x28000000-0x2bffffff
[ 0.153224] pci 0000:00:0a.1: MEM window: 0x2c000000-0x2fffffff
[ 0.153247] pci 0000:00:01.0: setting latency timer to 64
[ 0.153640] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 9
[ 0.153646] PCI: setting IRQ 9 as level-triggered
[ 0.153653] pci 0000:00:0a.0: PCI INT A -> Link[LNKA] -> GSI 9 (level, low) -> IRQ 9
[ 0.153928] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 9
[ 0.153934] pci 0000:00:0a.1: PCI INT B -> Link[LNKB] -> GSI 9 (level, low) -> IRQ 9
[ 0.153946] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.153950] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.153954] pci_bus 0000:01: resource 0 io: [0xc000-0xdfff]
[ 0.153958] pci_bus 0000:01: resource 1 mem: [0xe0000000-0xefffffff]
[ 0.153961] pci_bus 0000:01: resource 2 pref mem [0x90000000-0x9fffffff]
[ 0.153966] pci_bus 0000:02: resource 0 io: [0x1800-0x18ff]
[ 0.153969] pci_bus 0000:02: resource 1 io: [0x1c00-0x1cff]
[ 0.153973] pci_bus 0000:02: resource 2 pref mem [0x20000000-0x23ffffff]
[ 0.153977] pci_bus 0000:02: resource 3 mem: [0x24000000-0x27ffffff]
[ 0.153980] pci_bus 0000:06: resource 0 io: [0x2000-0x20ff]
[ 0.153984] pci_bus 0000:06: resource 1 io: [0x2400-0x24ff]
[ 0.153988] pci_bus 0000:06: resource 2 pref mem [0x28000000-0x2bffffff]
[ 0.153991] pci_bus 0000:06: resource 3 mem: [0x2c000000-0x2fffffff]
[ 0.154052] NET: Registered protocol family 2
[ 0.154206] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.154623] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.154739] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.154875] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.154880] TCP reno registered
[ 0.155117] NET: Registered protocol family 1
[ 0.155158] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.155228] pci 0000:01:00.0: Boot video device
[ 0.155427] Simple Boot Flag at 0x37 set to 0x1
[ 0.155606] Scanning for low memory corruption every 60 seconds
[ 0.155790] audit: initializing netlink socket (disabled)
[ 0.155816] type=2000 audit(1393271390.153:1): initialized
[ 0.163560] Trying to unpack rootfs image as initramfs...
[ 0.173844] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.176017] VFS: Disk quotas dquot_6.5.2
[ 0.176159] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.181836] fuse init (API version 7.13)
[ 0.182093] msgmni has been set to 937
[ 0.182672] alg: No test for stdrng (krng)
[ 0.182839] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.182847] io scheduler noop registered
[ 0.182850] io scheduler anticipatory registered
[ 0.182853] io scheduler deadline registered
[ 0.182921] io scheduler cfq registered (default)
[ 0.183119] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.183161] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.183294] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.184841] ACPI: Lid Switch [LID]
[ 0.185004] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 0.185011] ACPI: Power Button [PWRF]
[ 0.187685] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.187824] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.187949] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a NS16550A
[ 0.188471] 00:0b: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.193850] isapnp: Scanning for PnP cards...
[ 0.200351] brd: module loaded
[ 0.201155] loop: module loaded
[ 0.201429] input: Macintosh mouse button emulation as /devices/virtual/input/input2
[ 0.201718] pata_acpi 0000:00:11.1: can't derive routing for PCI INT A
[ 0.201802] pata_acpi 0000:00:11.1: can't derive routing for PCI INT A
[ 0.202337] Fixed MDIO Bus: probed
[ 0.202403] PPP generic driver version 2.4.2
[ 0.202514] tun: Universal TUN/TAP device driver, 1.6
[ 0.202517] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 0.202689] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.202726] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.202746] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.203166] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 10
[ 0.203172] PCI: setting IRQ 10 as level-triggered
[ 0.203180] uhci_hcd 0000:00:11.2: PCI INT D -> Link[LNKD] -> GSI 10 (level, low) -> IRQ 10
[ 0.203197] uhci_hcd 0000:00:11.2: UHCI Host Controller
[ 0.203301] uhci_hcd 0000:00:11.2: new USB bus registered, assigned bus number 1
[ 0.203343] uhci_hcd 0000:00:11.2: irq 10, io base 0x00001200
[ 0.203545] usb usb1: configuration #1 chosen from 1 choice
[ 0.203593] hub 1-0:1.0: USB hub found
[ 0.203613] hub 1-0:1.0: 2 ports detected
[ 0.203700] uhci_hcd 0000:00:11.3: PCI INT D -> Link[LNKD] -> GSI 10 (level, low) -> IRQ 10
[ 0.203714] uhci_hcd 0000:00:11.3: UHCI Host Controller
[ 0.203813] uhci_hcd 0000:00:11.3: new USB bus registered, assigned bus number 2
[ 0.203847] uhci_hcd 0000:00:11.3: irq 10, io base 0x00001300
[ 0.204024] usb usb2: configuration #1 chosen from 1 choice
[ 0.204068] hub 2-0:1.0: USB hub found
[ 0.204088] hub 2-0:1.0: 2 ports detected
[ 0.204174] uhci_hcd 0000:00:11.4: PCI INT D -> Link[LNKD] -> GSI 10 (level, low) -> IRQ 10
[ 0.204188] uhci_hcd 0000:00:11.4: UHCI Host Controller
[ 0.204268] uhci_hcd 0000:00:11.4: new USB bus registered, assigned bus number 3
[ 0.204303] uhci_hcd 0000:00:11.4: irq 10, io base 0x00001700
[ 0.204473] usb usb3: configuration #1 chosen from 1 choice
[ 0.204518] hub 3-0:1.0: USB hub found
[ 0.204537] hub 3-0:1.0: 2 ports detected
[ 0.204703] PNP: PS/2 Controller [PNP0303:KBC,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.217810] i8042.c: Detected active multiplexing controller, rev 1.1.
[ 0.297740] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.297772] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 0.297873] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 0.297913] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 0.297952] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 0.298294] mice: PS/2 mouse device common for all mice
[ 0.298563] rtc_cmos 00:01: RTC can wake from S4
[ 0.298681] rtc_cmos 00:01: rtc core: registered rtc_cmos as rtc0
[ 0.298715] rtc0: alarms up to one year, 242 bytes nvram
[ 0.298943] device-mapper: uevent: version 1.0.3
[ 0.299267] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[ 0.301922] device-mapper: multipath: version 1.1.0 loaded
[ 0.301931] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.304097] EISA: Probing bus 0 at eisa.0
[ 0.304112] Cannot allocate resource for EISA slot 1
[ 0.304118] Cannot allocate resource for EISA slot 2
[ 0.304145] EISA: Detected 0 cards.
[ 0.304151] cpuidle: using governor ladder
[ 0.304154] cpuidle: using governor menu
[ 0.304776] TCP cubic registered
[ 0.304980] NET: Registered protocol family 10
[ 0.305702] lo: Disabled Privacy Extensions
[ 0.306145] NET: Registered protocol family 17
[ 0.306236] Using IPI No-Shortcut mode
[ 0.306521] registered taskstats version 1
[ 0.306915] rtc_cmos 00:01: setting system clock to 2014-02-24 19:49:51 UTC (1393271391)
[ 0.306921] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.306925] EDD information not available.
[ 0.324350] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input3
[ 0.893100] isapnp: No Plug & Play device found
[ 1.057402] Freeing initrd memory: 12837k freed
[ 1.086447] Freeing unused kernel memory: 620k freed
[ 1.087722] Write protecting the kernel text: 4540k
[ 1.087754] Write protecting the kernel read-only data: 1668k
[ 1.138117] udev: starting version 151
[ 1.509381] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A03:00/device:08/LNXVIDEO:00/input/input4
[ 1.509634] ACPI: Video Device [VGA0] (multi-head: yes rom: no post: no)
[ 1.551743] pata_via 0000:00:11.1: version 0.3.4
[ 1.551763] pata_via 0000:00:11.1: can't derive routing for PCI INT A
[ 1.552658] Floppy drive(s): fd0 is 1.44M
[ 1.555468] Linux agpgart interface v0.103
[ 1.555823] scsi0 : pata_via
[ 1.561266] scsi1 : pata_via
[ 1.562572] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1100 irq 14
[ 1.562579] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1108 irq 15
[ 1.571406] FDC 0 is a National Semiconductor PC87306
[ 1.626471] 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 1.626527] 8139cp 0000:00:0d.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
[ 1.627408] agpgart: Detected VIA P4M266x/P4N266 chipset
[ 1.663739] agpgart-via 0000:00:00.0: AGP aperture is 64M @ 0xa0000000
[ 1.724616] ata1.00: ATA-6: ST94019A, 3.05, max UDMA/100
[ 1.724623] ata1.00: 78140160 sectors, multi 16: LBA48
[ 1.740460] ata1.00: configured for UDMA/100
[ 1.740679] scsi 0:0:0:0: Direct-Access ATA ST94019A 3.05 PQ: 0 ANSI: 5
[ 1.740994] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.741740] sd 0:0:0:0: [sda] 78140160 512-byte logical blocks: (40.0 GB/37.2 GiB)
[ 1.741830] sd 0:0:0:0: [sda] Write Protect is off
[ 1.741835] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.741880] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.742210] sda: sda1 sda2 < sda5 sda6 sda7 >
[ 1.827072] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.896619] ata2.00: ATAPI: QSI DVD-ROM SDR-083, MJ03, max UDMA/33
[ 1.904452] ata2.00: configured for UDMA/33
[ 1.905206] scsi 1:0:0:0: CD-ROM QSI DVD-ROM SDR-083 MJ03 PQ: 0 ANSI: 5
[ 1.907394] sr0: scsi3-mmc drive: 24x/24x cd/rw xa/form2 cdda tray
[ 1.907403] Uniform CD-ROM driver Revision: 3.20
[ 1.907646] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 1.907807] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 1.918751] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 10
[ 1.918761] ohci1394 0000:00:0c.0: PCI INT A -> Link[LNKC] -> GSI 10 (level, low) -> IRQ 10
[ 1.929615] vga16fb: initializing
[ 1.929633] vga16fb: mapped to 0xc00a0000
[ 1.930007] fb0: VGA16 VGA frame buffer device
[ 1.930713] 8139too Fast Ethernet driver 0.9.28
[ 2.029869] ohci1394: fw-host0: OHCI-1394 1.1 (PCI): IRQ=[10] MMIO=[f0000000-f00007ff] Max Packet=[2048] IR/IT contexts=[4/8]
[ 2.032519] 8139too 0000:00:0d.0: PCI INT A -> Link[LNKD] -> GSI 10 (level, low) -> IRQ 10
[ 2.033835] eth0: RealTek RTL8139 at 0xe000, 00:0b:5d:39:6c:3f, IRQ 10
[ 2.092805] Console: switching to colour frame buffer device 80x30
[ 3.152206] xor: automatically using best checksumming function: pIII_sse
[ 3.172025] pIII_sse : 3258.000 MB/sec
[ 3.172029] xor: using function: pIII_sse (3258.000 MB/sec)
[ 3.204216] device-mapper: dm-raid45: initialized v0.2594b
[ 3.308279] ieee1394: Host added: ID:BUS[0-00:1023] GUID[00000e10000a53fc]
[ 3.473127] EXT4-fs (sda6): mounted filesystem with ordered data mode
[ 18.183455] Adding 376824k swap on /dev/sda7. Priority:-1 extents:1 across:376824k
[ 18.240605] udev: starting version 151
[ 18.354374] lp: driver loaded but no devices found
[ 18.824540] parport_pc 00:0a: reported by Plug and Play ACPI
[ 18.824620] parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
[ 18.917397] lp0: using parport0 (interrupt-driven).
[ 19.134570] irda_init()
[ 19.134599] NET: Registered protocol family 23
[ 19.137788] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 19.161942] yenta_cardbus 0000:00:0a.0: CardBus bridge found [10cf:10e7]
[ 19.161971] yenta_cardbus 0000:00:0a.0: O2: res at 0x94/0xD4: ea/00
[ 19.161975] yenta_cardbus 0000:00:0a.0: Yenta O2: old bridge, disabling read prefetch/write burst
[ 19.167803] nsc_ircc_pnp_probe() : From PnP, found firbase 0x2F8 ; irq 3 ; dma 1.
[ 19.167844] nsc-ircc, chip->init
[ 19.167855] nsc-ircc, Found chip at base=0x02e
[ 19.167881] nsc-ircc, driver loaded (Dag Brattli)
[ 19.167892] nsc_ircc_open(), can't get iobase of 0x2f8
[ 19.167924] nsc-ircc, Found chip at base=0x02e
[ 19.167950] nsc-ircc, driver loaded (Dag Brattli)
[ 19.167954] nsc_ircc_open(), can't get iobase of 0x2f8
[ 19.269671] nsc-ircc 00:0c: disabled
[ 19.288579] yenta_cardbus 0000:00:0a.0: ISA IRQ mask 0x0830, PCI irq 9
[ 19.288587] yenta_cardbus 0000:00:0a.0: Socket status: 30000006
[ 19.302490] yenta_cardbus 0000:00:0a.1: CardBus bridge found [10cf:10e7]
[ 19.393930] type=1505 audit(1393264210.585:2): operation="profile_load" pid=519 name="/sbin/dhclient3"
[ 19.394637] type=1505 audit(1393264210.585:3): operation="profile_load" pid=519 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 19.395045] type=1505 audit(1393264210.585:4): operation="profile_load" pid=519 name="/usr/lib/connman/scripts/dhclient-script"
[ 19.428749] yenta_cardbus 0000:00:0a.1: ISA IRQ mask 0x0838, PCI irq 9
[ 19.428757] yenta_cardbus 0000:00:0a.1: Socket status: 30000006
[ 19.441668] ppdev: user-space parallel port driver
[ 19.453686] ACPI: resource vt596_smbus [0x1400-0x1407] conflicts with ACPI region SM06 [0x1406-0x1406]
[ 19.453692] ACPI: If an ACPI driver is available for this device, you should use it instead of the native driver
[ 19.632616] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x100-0x3af: clean.
[ 19.634500] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x3e0-0x4ff: clean.
[ 19.635313] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x820-0x8ff: clean.
[ 19.636585] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xc00-0xcf7: clean.
[ 19.637562] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xa00-0xaff: clean.
[ 20.021819] VIA 82xx Modem 0000:00:11.6: PCI INT C -> Link[LNKC] -> GSI 10 (level, low) -> IRQ 10
[ 20.071771] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
[ 20.074410] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: clean.
[ 20.075222] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 20.075916] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 20.080780] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 20.275280] Synaptics Touchpad, model: 1, fw: 5.9, id: 0x1b4cb1, caps: 0x88479b/0x0
[ 20.275294] serio: Synaptics pass-through port at isa0060/serio4/input0
[ 20.345626] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input5
[ 20.398507] type=1505 audit(1393264211.589:5): operation="profile_load" pid=681 name="/usr/share/gdm/guest-session/Xsession"
[ 20.437825] type=1505 audit(1393264211.629:6): operation="profile_replace" pid=688 name="/sbin/dhclient3"
[ 20.438561] type=1505 audit(1393264211.629:7): operation="profile_replace" pid=688 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 20.438967] type=1505 audit(1393264211.629:8): operation="profile_replace" pid=688 name="/usr/lib/connman/scripts/dhclient-script"
[ 20.523039] type=1505 audit(1393264211.713:9): operation="profile_load" pid=691 name="/usr/bin/evince"
[ 20.538173] eth0: link down
[ 20.538338] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 20.563699] type=1505 audit(1393264211.753:10): operation="profile_load" pid=691 name="/usr/bin/evince-previewer"
[ 20.606131] type=1505 audit(1393264211.797:11): operation="profile_load" pid=691 name="/usr/bin/evince-thumbnailer"
[ 20.772998] VIA 82xx Modem 0000:00:11.6: setting latency timer to 64
[ 21.380108] MC'97 0 converters and GPIO not ready (0x1)
[ 21.383656] VIA 82xx Audio 0000:00:11.5: power state changed by ACPI to D0
[ 21.383678] VIA 82xx Audio 0000:00:11.5: PCI INT C -> Link[LNKC] -> GSI 10 (level, low) -> IRQ 10
[ 21.383843] VIA 82xx Audio 0000:00:11.5: setting latency timer to 64
[ 23.646274] [drm] Initialized drm 1.1.0 20060810
[ 23.651532] pci 0000:01:00.0: PCI INT A -> Link[LNKA] -> GSI 9 (level, low) -> IRQ 9
[ 23.653584] [drm] Initialized savage 2.4.1 20050313 for 0000:01:00.0 on minor 0
[ 30.330259] ttyS1: LSR safety check engaged!
[ 68.429938] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
[ 68.975751] __ratelimit: 9 callbacks suppressed
[ 68.975760] halcmd[1880]: segfault at 8 ip 008666bc sp bfcc7700 error 6 in liblinuxcnchal.so.0[861000+8000]
[ 68.999398] halcmd[1881]: segfault at 8 ip 0016b6bc sp bf989750 error 6 in liblinuxcnchal.so.0[166000+8000]
[ 69.015295] halcmd[1884]: segfault at 8 ip 0087b6bc sp bf833830 error 6 in liblinuxcnchal.so.0[876000+8000]
[ 69.259679] halcmd[1888]: segfault at 8 ip 0055c6bc sp bfd5b9a0 error 6 in liblinuxcnchal.so.0[557000+8000]
[ 69.475426] halcmd[1892]: segfault at 8 ip 00d756bc sp bfc42e90 error 6 in liblinuxcnchal.so.0[d70000+8000]
[ 69.691231] halcmd[1896]: segfault at 8 ip 00e4a6bc sp bfb01c60 error 6 in liblinuxcnchal.so.0[e45000+8000]
[ 69.906981] halcmd[1900]: segfault at 8 ip 009876bc sp bfcd5780 error 6 in liblinuxcnchal.so.0[982000+8000]
[ 70.122862] halcmd[1904]: segfault at 8 ip 005196bc sp bfaa4b50 error 6 in liblinuxcnchal.so.0[514000+8000]
[ 70.338782] halcmd[1908]: segfault at 8 ip 00ddb6bc sp bfe34910 error 6 in liblinuxcnchal.so.0[dd6000+8000]
[ 70.554991] halcmd[1912]: segfault at 8 ip 008e46bc sp bfd5b1c0 error 6 in liblinuxcnchal.so.0[8df000+8000]
