Tangential knife lifts
Сообщение jamesd256 » 31 окт 2017, 01:59
Hello
So far I have had good success with the software, but I have one problem.
I need gcode with few arcs, because arduino / RAMPS doesn't handle arcs well. This I can do by setting the arc angle to a very high value.
I would like to have lifts between moves for the tangential knife, but so far can only make it lift every time via the parameters.
I would like to have it lift only when the angle is greater than a certain value, so that it does not lift between segments of a circle.
I am willing to make changes to the code if it's not supported. Any suggestions?
Thanks for the great software.
jamesd256
Настоящее имя: James Donnelly
Re: Tangential knife lifts
Сообщение jamesd256 » 31 окт 2017, 03:27
It looks clear that it's not supported from the code, but also clear it's easy to implement:
In gcodetools-dev.py [4625]:
Код: Выделить всёРазвернуть
      if tool['lift knife at corner']!=0. :
               g = "G00 Z%f  (Lift up)\n"%(depth+tool['lift knife at corner']) + "G00 "+ g + "G01 Z%f %s (Penetrate back)\n"%(depth,penetration_feed)
            else :
It seems like this is the place to check the angle before doing the lift. The angle is checked before against TURN_KNIFE_ANGLE_TOLERANCE on line 4621
jamesd256
Вернуться в English forum
Кто сейчас на конференции
Зарегистрированные пользователи: avld, Bing [Bot], Евжений, Georgij, Gestap, Google [Bot], mmv, Newengine, nizamus, odekolon, R6MF49T2, RNDL, ruh2100, savo, sima8520, svm, SVP, tokarka63, WoodLife, Yandex [bot], шпиндель
Reputation System ©'
