Mirroring to engrave both side of material
Re: Mirroring to engrave both side of material
Сообщение James628 » 31 янв 2013, 20:19
BINGO!
And big sorry !
I forgot to put the "gcodetools-dev.py" to the extension directory.
Thank you so much for your time and effort Nick!
I have to document the process of making a wooden toy. It's a great chance to do it with Gcodetools.
So I will show you this "manual" in Hungarian language.
Thanks again!
James628
Сообщение Nick » 01 фев 2013, 09:53
And what's about gcodetools-dev.py is it there too?
Aha! you've already found that :)
PS If you write a manual it will be great!
Notify me when it will be ready, I'll put a link to it in Gcodetools description page.
Медальки:
Сообщение James628 » 01 фев 2013, 13:38
Hi,
I think I found something not correctly working:
When "Parametrize Gcode" is selected as post-processor AND flip(x) as additional post-processor, then the produced Gcode is not correct.
You can test: draw few circles, make Gcode with no post-processor but use flip(x), and the very same but select "Parametrize Gcode" for postproc.
Take a look at the procduced Gcode: in parametrized flipped code, the G02/G03 and their I/J parameters are not set correctly to minus value.
I did not tried with other transformation or other axes, but the same issue is in stable and dev version.
Regards:
James
James628
Сообщение Nick » 01 фев 2013, 14:49
Parameterize is a quite specific funtion... In what order do you apply postprocessors? flip first, and parameterize after?
Медальки:
Сообщение James628 » 01 фев 2013, 15:19
Nick писал(а):Parameterize is a quite specific funtion... In what order do you apply postprocessors? flip first, and parameterize after?
I do it this way:
James628
Сообщение Nick » 04 фев 2013, 16:53
Hmmm... I do not remember how are they applied...
try using them both as additional post-processor:
flip(x); parameterize();
Медальки:
Сообщение James628 » 13 фев 2013, 20:20
Hi Nick,
When I use both of them as additional post-proc then it works. Thanks.
I sent you a PM. Would you have time to look at it?
Regards:
James
James628
Пред.
Вернуться в English forum
Кто сейчас на конференции
Зарегистрированные пользователи: aldemm, Alex777_72, atomichammer, Bing [Bot], CactusMan, Сергей Саныч, dirty1_1garry, Dmaster, evgenyjp, Gestap, Glite, Google [Bot], Izohron, Lafayette, MGG, nevkon, NikSR, Portos, Provodnik, Razzhivin Anton, Rom327, Smlua, steals_y2k, Taganrog, tooshka, vektor_z, Yandex [bot]
Reputation System ©'
