Страница 1 из 1
Making helical gear with inkscape+ GRBL
СообщениеДобавлено: 27 мар 2019, 15:25
ARIS NOORSETYO
https://youtu.be/Zm8TsTcGKK0
Re: Making helical gear with inkscape+ GRBL
СообщениеДобавлено: 28 мар 2019, 13:36
daemon78
ARIS NOORSETYO писал(а):Making helical gear with inkscape
Wow looks great.
Why do you use GRBL?
Does it stable enough for you?
Do you use it with Arduino or STM32 hardware?
I am trying to move to Mach3 because of unstable behavior of the GRBL in some cases.
СообщениеДобавлено: 30 мар 2019, 08:34
ARIS NOORSETYO
I was studying CNC ... I knew CNC first using GRBl software and there were never any problems with GRBl ... maybe it should be paired with a rabbit mill source ... more stable
I use Arduino
