Что ему надо от меня?
Сообщение Loituma » 29 апр 2013, 07:40
Станок начал выдавать вот такое:
Код: Выделить всёРазвернуть
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcnc
LINUXCNC_SCRIPT_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/linuxcnc
LINUXCNC_CONFIG_DIR=
LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
LINUXCNC_EMCSH=/usr/bin/wish8.5
LINUXCNC - 2.5.0
Machine configuration directory is '/home/stanley/linuxcnc/configs/steklo'
Machine configuration file is 'steklo.ini'
INIFILE=/home/stanley/linuxcnc/configs/steklo/steklo.ini
PARAMETER_FILE=linuxcnc.var
TASK=milltask
HALUI=halui
DISPLAY=axis
Starting LinuxCNC...
Starting LinuxCNC server program: linuxcncsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Starting LinuxCNC IO program: io
Starting HAL User Interface program: halui
Shutting down and cleaning up LinuxCNC...
Running HAL shutdown script
Killing task linuxcncsvr, PID=1695
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
Can not find -sec MOT -var MOT -num 1
Can not find -sec IO -var IO -num 1
Can not find -sec LINUXCNC -var NML_FILE -num 1
Can not find -sec EMC -var NML_FILE -num 1
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko': -1 Input/output error
steklo.hal:9: exit value: 1
steklo.hal:9: insmod failed, returned -1
See the output of 'dmesg' for more information.
1695
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
Unloading hal components
Kernel message information:
[  596.982839] I-pipe: Domain RTAI registered.
[  596.982846] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[  596.982848] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[  596.982881] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  596.982883] PIPELINE layers:
[  596.982886] fad2be20 9ac15d93 RTAI 200
[  596.982889] c085cb20 0 Linux 100
[  597.003741] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  597.003863] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[  597.003869] RTAI[sched]: hard timer type/freq = APIC/12499948(Hz); default timing: periodic; linear timed lists.
[  597.003873] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 2500356000 hz.
[  597.003876] RTAI[sched]: timer setup = 999 ns, resched latency = 2943 ns.
[  597.003949] RTAI[usi]: enabled.
[  597.042875] RTAI[math]: loaded.
[  597.117194] hm2: loading Mesa HostMot2 driver version 0.15
[  597.119884] hm2_pci: loading Mesa AnyIO HostMot2 driver version 0.7
[  597.119913] hm2_pci: discovered 5i20 at 0000:03:00.0
[  597.119958]  hm2_5i20.0: firmware: requesting hm2/5i20/SV12_2X7I48_72.BIT
[  597.122716] hm2_5i20.0: FPGA did not reset: /INIT = 1, DONE = 1
[  597.122724] hm2/hm2_5i20.0: failed to reset fpga, aborting hm2_register
[  597.122728] hm2_5i20.0: board fails HM2 registration
[  597.122741] hm2_pci: probe of 0000:03:00.0 failed with error -5
[  597.406489] hm2: unloading
[  597.442398] RTAI[math]: unloaded.
[  597.457264] SCHED releases registered named ALIEN RTGLBH
[  597.488307] RTAI[malloc]: unloaded.
[  597.588016] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  597.590484] I-pipe: Domain RTAI unregistered.
[  597.590523] RTAI[hal]: unmounted.[/spoiler]
Loituma
Медальки:
Re: Что ему надо от меня?
Сообщение PKM » 29 апр 2013, 08:16
Loituma писал(а):insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/linuxcnc/hm2_pci.ko': -1 Input/output error
Похоже, проблемы с загрузкой прошивки в 5i20. Для начала подергать, перепроверить.
PKM
Медальки:
Сообщение Nikomas » 22 май 2017, 21:37
Аналогичная шляпа. Установка по методичке на сайте. Система чистая Ubuntu 12.04. Вот что пишет:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.7.8
Machine configuration directory is '/home/cnc/linuxcnc/configs/sim.gmoccapy'
Machine configuration file is 'gmoccapy_4_axis.ini'
INIFILE=/home/cnc/linuxcnc/configs/sim.gmoccapy/gmoccapy_4_axis.ini
PARAMETER_FILE=sim.var
TASK=milltask
HALUI=halui
DISPLAY=gmoccapy
Found file(REL): ./core_sim4.hal
Found file(REL): ./spindle_sim.hal
Found file(lib): /usr/share/linuxcnc/hallib/simulated_home.hal
Starting TASK program: milltask
Starting DISPLAY program: gmoccapy
**** GMOCCAPY GETINIINFO ****
Preference file path: /home/cnc/linuxcnc/configs/sim.gmoccapy/gmoccapy_4_axis.pref
No option 'dro_size' in section: 'DEFAULT'
No option 'hide_axis_4' in section: 'DEFAULT'
No DEFAULT_SPINDLE_SPEED entry found in [DISPLAY] of INI file
No option 'spindle_start_rpm' in section: 'DEFAULT'
No option 'hide_turtle_jog_button' in section: 'DEFAULT'
No option 'turtle_jog_factor' in section: 'DEFAULT'
No option 'scale_max_vel' in section: 'DEFAULT'
No option 'scale_jog_vel' in section: 'DEFAULT'
No option 'scale_spindle_override' in section: 'DEFAULT'
No option 'scale_feed_override' in section: 'DEFAULT'
Killing task linuxcncsvr, PID=2951
Killing task milltask, PID=3028
task: 8961 cycles, min=0.000004, max=0.009147, avg=0.001098, 0 latency excursions (> 10x expected cycle time of 0.001000s)
/usr/bin/gmoccapy:237: GtkWarning: Invalid icon size 48
  self.widgets.window1.show()
Gen6+ requires Kernel 3.6 or later.
python: ../../../../src/mesa/main/context.c:1549: _mesa_make_current: Проверочное утверждение «newCtx->Version > 0» не выполнено.
/usr/bin/linuxcnc: строка 857:  3031 Аварийный останов         (подготовлен дамп ядра) $EMCDISPLAY -ini "$INIFILE" $EMCDISPLAYARGS $EXTRA_ARGS
2951
3028
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Linux version 3.4-9-rtai-686-pae (Debian 3.4.55-4linuxcnc) () (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #1 SMP PREEMPT Debian 3.4.55-4linuxcnc
[    0.000000] BIOS-provided physical RAM map:
[    0.000000]  BIOS-e820: 0000000000000000 - 000000000009ec00 (usable)
[    0.000000]  BIOS-e820: 000000000009ec00 - 00000000000a0000 (reserved)
[    0.000000]  BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[    0.000000]  BIOS-e820: 0000000000100000 - 0000000020000000 (usable)
[    0.000000]  BIOS-e820: 0000000020000000 - 0000000020200000 (reserved)
[    0.000000]  BIOS-e820: 0000000020200000 - 0000000040004000 (usable)
[    0.000000]  BIOS-e820: 0000000040004000 - 0000000040005000 (reserved)
[    0.000000]  BIOS-e820: 0000000040005000 - 00000000d987b000 (usable)
[    0.000000]  BIOS-e820: 00000000d987b000 - 00000000d9d27000 (reserved)
[    0.000000]  BIOS-e820: 00000000d9d27000 - 00000000d9d28000 (ACPI data)
[    0.000000]  BIOS-e820: 00000000d9d28000 - 00000000d9e4c000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000d9e4c000 - 00000000da605000 (reserved)
[    0.000000]  BIOS-e820: 00000000da605000 - 00000000da606000 (usable)
[    0.000000]  BIOS-e820: 00000000da606000 - 00000000da649000 (ACPI NVS)
[    0.000000]  BIOS-e820: 00000000da649000 - 00000000dadb1000 (usable)
[    0.000000]  BIOS-e820: 00000000dadb1000 - 00000000dafdd000 (reserved)
[    0.000000]  BIOS-e820: 00000000dafdd000 - 00000000db000000 (usable)
[    0.000000]  BIOS-e820: 00000000db800000 - 00000000dfa00000 (reserved)
[    0.000000]  BIOS-e820: 00000000f8000000 - 00000000fc000000 (reserved)
[    0.000000]  BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed00000 - 00000000fed04000 (reserved)
[    0.000000]  BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[    0.000000]  BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[    0.000000]  BIOS-e820: 00000000ff000000 - 0000000100000000 (reserved)
[    0.000000]  BIOS-e820: 0000000100000000 - 000000021e600000 (usable)
[    0.000000] Notice: NX (Execute Disable) protection cannot be enabled: non-PAE kernel!
[    0.000000] SMBIOS 2.7 present.
[    0.000000] DMI: Gigabyte Technology Co., Ltd. To be filled by O.E.M./B75M-D3V, BIOS F9 08/23/2012
[    0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[    0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[    0.000000] last_pfn = 0xdb000 max_arch_pfn = 0x100000
[    0.000000] MTRR default type: uncachable
[    0.000000] MTRR fixed ranges enabled:
[    0.000000]   00000-9FFFF write-back
[    0.000000]   A0000-BFFFF uncachable
[    0.000000]   C0000-CFFFF write-protect
[    0.000000]   D0000-E7FFF uncachable
[    0.000000]   E8000-FFFFF write-protect
[    0.000000] MTRR variable ranges enabled:
[    0.000000]   0 base 000000000 mask E00000000 write-back
[    0.000000]   1 base 200000000 mask FE0000000 write-back
[    0.000000]   2 base 0E0000000 mask FE0000000 uncachable
[    0.000000]   3 base 0DC000000 mask FFC000000 uncachable
[    0.000000]   4 base 0DB800000 mask FFF800000 uncachable
[    0.000000]   5 base 21F000000 mask FFF000000 uncachable
[    0.000000]   6 base 21E800000 mask FFF800000 uncachable
[    0.000000]   7 base 21E600000 mask FFFE00000 uncachable
[    0.000000]   8 disabled
[    0.000000]   9 disabled
[    0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[    0.000000] e820 update range: 00000000db800000 - 0000000100000000 (usable) ==> (reserved)
[    0.000000] found SMP MP-table at [c00fd710] fd710
[    0.000000] initial memory mapped : 0 - 01800000
[    0.000000] Base memory trampoline at [c009a000] 9a000 size 16384
[    0.000000] init_memory_mapping: 0000000000000000-00000000377fe000
[    0.000000]  0000000000 - 0000400000 page 4k
[    0.000000]  0000400000 - 0037400000 page 2M
[    0.000000]  0037400000 - 00377fe000 page 4k
[    0.000000] kernel direct mapping tables up to 0x377fdfff @ [mem 0x017f8000-0x017fffff]
[    0.000000] RAMDISK: 363f0000 - 371f0000
[    0.000000] ACPI: RSDP 000f0490 00024 (v02 ALASKA)
[    0.000000] ACPI: XSDT d9e2e070 0005C (v01 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI: FACP d9e37638 000F4 (v04 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI: DSDT d9e2e160 094D8 (v02 ALASKA    A M I 00000012 INTL 20051117)
[    0.000000] ACPI: FACS d9e4af80 00040
[    0.000000] ACPI: APIC d9e37730 00072 (v03 ALASKA    A M I 01072009 AMI  00010013)
[    0.000000] ACPI: MCFG d9e377a8 0003C (v01                 01072009 MSFT 00000097)
[    0.000000] ACPI: HPET d9e377e8 00038 (v01 ALASKA    A M I 01072009 AMI. 00000005)
[    0.000000] ACPI: SSDT d9e37820 00495 (v01 IdeRef IdeTable 00001000 INTL 20091112)
[    0.000000] ACPI: SSDT d9e37cb8 009AA (v01  PmRef  Cpu0Ist 00003000 INTL 20051117)
[    0.000000] ACPI: SSDT d9e38668 00A92 (v01  PmRef    CpuPm 00003000 INTL 20051117)
[    0.000000] ACPI: Local APIC address 0xfee00000
[    0.000000] 2616MB HIGHMEM available.
[    0.000000] 887MB LOWMEM available.
[    0.000000]   mapped low ram: 0 - 377fe000
[    0.000000]   low ram: 0 - 377fe000
[    0.000000] Zone PFN ranges:
[    0.000000]   DMA      0x00000010 -> 0x00001000
[    0.000000]   Normal   0x00001000 -> 0x000377fe
[    0.000000]   HighMem  0x000377fe -> 0x000db000
[    0.000000] Movable zone start PFN for each node
[    0.000000] Early memory PFN ranges
[    0.000000]     0: 0x00000010 -> 0x0000009e
[    0.000000]     0: 0x00000100 -> 0x00020000
[    0.000000]     0: 0x00020200 -> 0x00040004
[    0.000000]     0: 0x00040005 -> 0x000d987b
[    0.000000]     0: 0x000da605 -> 0x000da606
[    0.000000]     0: 0x000da649 -> 0x000dadb1
[    0.000000]     0: 0x000dafdd -> 0x000db000
[    0.000000] On node 0 totalpages: 892308
[    0.000000] free_area_init_node: node 0, pgdat c1498a00, node_mem_map f4890200
[    0.000000]   DMA zone: 32 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 3950 pages, LIFO batch:0
[    0.000000]   Normal zone: 1744 pages used for memmap
[    0.000000]   Normal zone: 220974 pages, LIFO batch:31
[    0.000000]   HighMem zone: 5233 pages used for memmap
[    0.000000]   HighMem zone: 660375 pages, LIFO batch:31
[    0.000000] Using APIC driver default
[    0.000000] ACPI: PM-Timer IO Port: 0x408
[    0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x02] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x01] enabled)
[    0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x03] enabled)
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[    0.000000] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-23
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.000000] ACPI: IRQ0 used by override.
[    0.000000] ACPI: IRQ2 used by override.
[    0.000000] ACPI: IRQ9 used by override.
[    0.000000] Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[    0.000000] SMP: Allowing 4 CPUs, 0 hotplug CPUs
[    0.000000] nr_irqs_gsi: 40
[    0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000
[    0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[    0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e0000
[    0.000000] PM: Registered nosave memory: 00000000000e0000 - 0000000000100000
[    0.000000] PM: Registered nosave memory: 0000000020000000 - 0000000020200000
[    0.000000] Allocating PCI resources starting at dfa00000 (gap: dfa00000:18600000)
[    0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:4 nr_node_ids:1
[    0.000000] PERCPU: Embedded 17 pages/cpu @f77a7000 s48384 r0 d21248 u69632
[    0.000000] pcpu-alloc: s48384 r0 d21248 u69632 alloc=17*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 885299
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.4-9-rtai-686-pae root=UUID=e62b049a-ed21-4203-a544-e7dfcff35e64 ro quiet splash vt.handoff=7
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Initializing CPU#0
[    0.000000] xsave/xrstor: enabled xstate_bv 0x7, cntxt size 0x340
[    0.000000] allocated 7176064 bytes of page_cgroup
[    0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[    0.000000] Initializing HighMem for node 0 (000377fe:000db000)
[    0.000000] Memory: 3512844k/3588096k available (3496k kernel code, 56388k reserved, 1237k data, 416k init, 2662432k highmem)
[    0.000000] virtual kernel memory layout:
[    0.000000]     fixmap  : 0xfff17000 - 0xfffff000   ( 928 kB)
[    0.000000]     pkmap   : 0xff800000 - 0xffc00000   (4096 kB)
[    0.000000]     vmalloc : 0xf7ffe000 - 0xff7fe000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf77fe000   ( 887 MB)
[    0.000000]       .init : 0xc14a0000 - 0xc1508000   ( 416 kB)
[    0.000000]       .data : 0xc136a04a - 0xc149f480   (1237 kB)
[    0.000000]       .text : 0xc1000000 - 0xc136a04a   (3496 kB)
[    0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]    RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] NR_IRQS:2304 nr_irqs:712 16
[    0.000000] CPU 0 irqstacks, hard=f3c06000 soft=f3c08000
[    0.000000] Extended CMOS year: 2000
[    0.000000] Interrupt pipeline (release #3)
[    0.000000] Console: colour dummy device 80x25
[    0.000000] console [tty0] enabled
[    0.000000] hpet clockevent registered
[    0.000000] Fast TSC calibration using PIT
[    0.004000] Detected 3292.752 MHz processor.
[    0.000001] Calibrating delay loop (skipped), value calculated using timer frequency.. 6585.50 BogoMIPS (lpj=13171008)
[    0.000003] pid_max: default: 32768 minimum: 301
[    0.000027] Security Framework initialized
[    0.000031] AppArmor: AppArmor disabled by boot time parameter
[    0.000040] Mount-cache hash table entries: 512
[    0.000150] Initializing cgroup subsys cpuacct
[    0.000152] Initializing cgroup subsys memory
[    0.000156] Initializing cgroup subsys devices
[    0.000157] Initializing cgroup subsys freezer
[    0.000158] Initializing cgroup subsys net_cls
[    0.000159] Initializing cgroup subsys blkio
[    0.000163] Initializing cgroup subsys perf_event
[    0.000180] CPU: Physical Processor ID: 0
[    0.000181] CPU: Processor Core ID: 0
[    0.000184] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.000185] ENERGY_PERF_BIAS: View and update with x86_energy_perf_policy(8)
[    0.000187] mce: CPU supports 7 MCE banks
[    0.000195] CPU0: Thermal monitoring enabled (TM1)
[    0.000261] ACPI: Core revision 20120320
[    0.006748] Enabling APIC mode:  Flat.  Using 1 I/O APICs
[    0.007130] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.046689] CPU0: Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz stepping 09
[    0.152519] Performance Events: PEBS fmt1+, generic architected perfmon, Intel PMU driver.
[    0.152524] ... version:                3
[    0.152525] ... bit width:              48
[    0.152526] ... generic registers:      4
[    0.152527] ... value mask:             0000ffffffffffff
[    0.152528] ... max period:             000000007fffffff
[    0.152529] ... fixed-purpose events:   3
[    0.152531] ... event mask:             000000070000000f
[    0.164532] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.176459] CPU 1 irqstacks, hard=f3cf6000 soft=f3cf8000
[    0.176462] Booting Node   0, Processors  #1
[    0.186621] Initializing CPU#1
[    0.189567] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.196396] CPU 2 irqstacks, hard=f3d08000 soft=f3d0a000
[    0.196399]  #2
[    0.206566] Initializing CPU#2
[    0.209504] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.216332] CPU 3 irqstacks, hard=f3d1c000 soft=f3d1e000
[    0.216335]  #3 Ok.
[    0.226492] Initializing CPU#3
[    0.229438] NMI watchdog: enabled, takes one hw-pmu counter.
[    0.229461] Brought up 4 CPUs
[    0.229462] Total of 4 processors activated (26342.01 BogoMIPS).
[    0.231592] devtmpfs: initialized
[    0.231735] PM: Registering ACPI NVS region [mem 0xd9d28000-0xd9e4bfff] (1196032 bytes)
[    0.231758] PM: Registering ACPI NVS region [mem 0xda606000-0xda648fff] (274432 bytes)
[    0.231828] dummy:
[    0.231865] NET: Registered protocol family 16
[    0.231935] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.231937] ACPI: bus type pci registered
[    0.231970] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.231973] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.231974] PCI: Using MMCONFIG for extended config space
[    0.231975] PCI: Using configuration type 1 for base access
[    0.232376] bio: create slab <bio-0> at 0
[    0.232440] ACPI: Added _OSI(Module Device)
[    0.232442] ACPI: Added _OSI(Processor Device)
[    0.232444] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.232445] ACPI: Added _OSI(Processor Aggregator Device)
[    0.233928] ACPI: EC: Look up EC in DSDT
[    0.235708] ACPI: Executed 1 blocks of module-level executable AML code
[    0.238805] ACPI: SSDT d9ccf018 0083B (v01  PmRef  Cpu0Cst 00003001 INTL 20051117)
[    0.239195] ACPI: Dynamic OEM Table Load:
[    0.239197] ACPI: SSDT   (null) 0083B (v01  PmRef  Cpu0Cst 00003001 INTL 20051117)
[    0.239420] ACPI: SSDT d9cd0a98 00303 (v01  PmRef    ApIst 00003000 INTL 20051117)
[    0.239840] ACPI: Dynamic OEM Table Load:
[    0.239842] ACPI: SSDT   (null) 00303 (v01  PmRef    ApIst 00003000 INTL 20051117)
[    0.239932] ACPI: SSDT d9cced98 00119 (v01  PmRef    ApCst 00003000 INTL 20051117)
[    0.240315] ACPI: Dynamic OEM Table Load:
[    0.240317] ACPI: SSDT   (null) 00119 (v01  PmRef    ApCst 00003000 INTL 20051117)
[    0.240973] ACPI: Interpreter enabled
[    0.240984] ACPI: (supports S0 S3 S4 S5)
[    0.241002] ACPI: Using IOAPIC for interrupt routing
[    0.246423] ACPI: Power Resource [FN00] (off)
[    0.246483] ACPI: Power Resource [FN01] (off)
[    0.246541] ACPI: Power Resource [FN02] (off)
[    0.246600] ACPI: Power Resource [FN03] (off)
[    0.246657] ACPI: Power Resource [FN04] (off)
[    0.247049] ACPI: No dock devices found.
[    0.247054] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.247326] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-3e])
[    0.247706] pci_root PNP0A08:00: host bridge window [io  0x0000-0x0cf7]
[    0.247708] pci_root PNP0A08:00: host bridge window [io  0x0d00-0xffff]
[    0.247710] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[    0.247711] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000d3fff]
[    0.247713] pci_root PNP0A08:00: host bridge window [mem 0x000d4000-0x000d7fff]
[    0.247714] pci_root PNP0A08:00: host bridge window [mem 0x000d8000-0x000dbfff]
[    0.247716] pci_root PNP0A08:00: host bridge window [mem 0x000dc000-0x000dffff]
[    0.247717] pci_root PNP0A08:00: host bridge window [mem 0x000e0000-0x000e3fff]
[    0.247719] pci_root PNP0A08:00: host bridge window [mem 0x000e4000-0x000e7fff]
[    0.247720] pci_root PNP0A08:00: host bridge window [mem 0xdfa00000-0xfeafffff]
[    0.247740] PCI host bridge to bus 0000:00
[    0.247742] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7]
[    0.247744] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff]
[    0.247745] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff]
[    0.247747] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff]
[    0.247748] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff]
[    0.247750] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff]
[    0.247751] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff]
[    0.247753] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff]
[    0.247754] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff]
[    0.247756] pci_bus 0000:00: root bus resource [mem 0xdfa00000-0xfeafffff]
[    0.247763] pci 0000:00:00.0: [8086:0150] type 00 class 0x060000
[    0.247790] pci 0000:00:02.0: [8086:0152] type 00 class 0x030000
[    0.247800] pci 0000:00:02.0: reg 10: [mem 0xf7800000-0xf7bfffff 64bit]
[    0.247805] pci 0000:00:02.0: reg 18: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.247810] pci 0000:00:02.0: reg 20: [io  0xf000-0xf03f]
[    0.247852] pci 0000:00:14.0: [8086:1e31] type 00 class 0x0c0330
[    0.247872] pci 0000:00:14.0: reg 10: [mem 0xf7c00000-0xf7c0ffff 64bit]
[    0.247926] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.247946] pci 0000:00:16.0: [8086:1e3a] type 00 class 0x078000
[    0.247968] pci 0000:00:16.0: reg 10: [mem 0xf7c19000-0xf7c1900f 64bit]
[    0.248026] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[    0.248056] pci 0000:00:1a.0: [8086:1e2d] type 00 class 0x0c0320
[    0.248076] pci 0000:00:1a.0: reg 10: [mem 0xf7c17000-0xf7c173ff]
[    0.248144] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[    0.248167] pci 0000:00:1b.0: [8086:1e20] type 00 class 0x040300
[    0.248181] pci 0000:00:1b.0: reg 10: [mem 0xf7c10000-0xf7c13fff 64bit]
[    0.248235] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[    0.248256] pci 0000:00:1c.0: [8086:1e10] type 01 class 0x060400
[    0.248314] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.248339] pci 0000:00:1c.4: [8086:1e18] type 01 class 0x060400
[    0.248398] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.248426] pci 0000:00:1d.0: [8086:1e26] type 00 class 0x0c0320
[    0.248446] pci 0000:00:1d.0: reg 10: [mem 0xf7c16000-0xf7c163ff]
[    0.248514] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[    0.248532] pci 0000:00:1e.0: [8086:244e] type 01 class 0x060401
[    0.248583] pci 0000:00:1f.0: [8086:1e49] type 00 class 0x060100
[    0.248686] pci 0000:00:1f.2: [8086:1e00] type 00 class 0x01018f
[    0.248699] pci 0000:00:1f.2: reg 10: [io  0xf110-0xf117]
[    0.248706] pci 0000:00:1f.2: reg 14: [io  0xf100-0xf103]
[    0.248713] pci 0000:00:1f.2: reg 18: [io  0xf0f0-0xf0f7]
[    0.248720] pci 0000:00:1f.2: reg 1c: [io  0xf0e0-0xf0e3]
[    0.248727] pci 0000:00:1f.2: reg 20: [io  0xf0d0-0xf0df]
[    0.248734] pci 0000:00:1f.2: reg 24: [io  0xf0c0-0xf0cf]
[    0.248765] pci 0000:00:1f.3: [8086:1e22] type 00 class 0x0c0500
[    0.248779] pci 0000:00:1f.3: reg 10: [mem 0xf7c15000-0xf7c150ff 64bit]
[    0.248798] pci 0000:00:1f.3: reg 20: [io  0xf040-0xf05f]
[    0.248826] pci 0000:00:1f.5: [8086:1e08] type 00 class 0x010185
[    0.248839] pci 0000:00:1f.5: reg 10: [io  0xf0b0-0xf0b7]
[    0.248846] pci 0000:00:1f.5: reg 14: [io  0xf0a0-0xf0a3]
[    0.248853] pci 0000:00:1f.5: reg 18: [io  0xf090-0xf097]
[    0.248860] pci 0000:00:1f.5: reg 1c: [io  0xf080-0xf083]
[    0.248867] pci 0000:00:1f.5: reg 20: [io  0xf070-0xf07f]
[    0.248873] pci 0000:00:1f.5: reg 24: [io  0xf060-0xf06f]
[    0.248941] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[    0.249011] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[    0.249030] pci 0000:02:00.0: reg 10: [io  0xe000-0xe0ff]
[    0.249063] pci 0000:02:00.0: reg 18: [mem 0xf0004000-0xf0004fff 64bit pref]
[    0.249084] pci 0000:02:00.0: reg 20: [mem 0xf0000000-0xf0003fff 64bit pref]
[    0.249141] pci 0000:02:00.0: supports D1 D2
[    0.249143] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.256199] pci 0000:00:1c.4: PCI bridge to [bus 02-02]
[    0.256205] pci 0000:00:1c.4:   bridge window [io  0xe000-0xefff]
[    0.256215] pci 0000:00:1c.4:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.256295] pci 0000:00:1e.0: PCI bridge to [bus 03-03] (subtractive decode)
[    0.256303] pci 0000:00:1e.0:   bridge window [io  0x0000-0x0cf7] (subtractive decode)
[    0.256305] pci 0000:00:1e.0:   bridge window [io  0x0d00-0xffff] (subtractive decode)
[    0.256307] pci 0000:00:1e.0:   bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[    0.256308] pci 0000:00:1e.0:   bridge window [mem 0x000d0000-0x000d3fff] (subtractive decode)
[    0.256310] pci 0000:00:1e.0:   bridge window [mem 0x000d4000-0x000d7fff] (subtractive decode)
[    0.256312] pci 0000:00:1e.0:   bridge window [mem 0x000d8000-0x000dbfff] (subtractive decode)
[    0.256313] pci 0000:00:1e.0:   bridge window [mem 0x000dc000-0x000dffff] (subtractive decode)
[    0.256315] pci 0000:00:1e.0:   bridge window [mem 0x000e0000-0x000e3fff] (subtractive decode)
[    0.256316] pci 0000:00:1e.0:   bridge window [mem 0x000e4000-0x000e7fff] (subtractive decode)
[    0.256318] pci 0000:00:1e.0:   bridge window [mem 0xdfa00000-0xfeafffff] (subtractive decode)
[    0.256332] pci_bus 0000:00: on NUMA node 0
[    0.256334] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[    0.256514] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[    0.256557] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP01._PRT]
[    0.256597] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.RP05._PRT]
[    0.256724]  pci0000:00: Unable to request _OSC control (_OSC support mask: 0x0f)
[    0.260887] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.260927] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.260966] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.261003] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.261041] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.261079] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[    0.261117] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 *5 6 10 11 12 14 15)
[    0.261155] ACPI: PCI Interrupt Link [LNKH] (IRQs *3 4 5 6 10 11 12 14 15)
[    0.261205] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[    0.261210] vgaarb: loaded
[    0.261211] vgaarb: bridge control possible 0000:00:02.0
[    0.261226] PCI: Using ACPI for IRQ routing
[    0.262688] PCI: pci_cache_line_size set to 64 bytes
[    0.262732] reserve RAM buffer: 000000000009ec00 - 000000000009ffff
[    0.262734] reserve RAM buffer: 0000000040004000 - 0000000043ffffff
[    0.262735] reserve RAM buffer: 00000000d987b000 - 00000000dbffffff
[    0.262737] reserve RAM buffer: 00000000da606000 - 00000000dbffffff
[    0.262739] reserve RAM buffer: 00000000dadb1000 - 00000000dbffffff
[    0.262741] reserve RAM buffer: 00000000db000000 - 00000000dbffffff
[    0.262817] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.262823] hpet0: 8 comparators, 64-bit 14.318180 MHz counter
[    0.264831] Switching to clocksource hpet
[    0.264869] pnp: PnP ACPI init
[    0.264875] ACPI: bus type pnp registered
[    0.265084] pnp 00:00: [bus 00-3e]
[    0.265086] pnp 00:00: [io  0x0000-0x0cf7 window]
[    0.265088] pnp 00:00: [io  0x0cf8-0x0cff]
[    0.265089] pnp 00:00: [io  0x0d00-0xffff window]
[    0.265091] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[    0.265092] pnp 00:00: [mem 0x000c0000-0x000c3fff window]
[    0.265093] pnp 00:00: [mem 0x000c4000-0x000c7fff window]
[    0.265095] pnp 00:00: [mem 0x000c8000-0x000cbfff window]
[    0.265096] pnp 00:00: [mem 0x000cc000-0x000cffff window]
[    0.265098] pnp 00:00: [mem 0x000d0000-0x000d3fff window]
[    0.265099] pnp 00:00: [mem 0x000d4000-0x000d7fff window]
[    0.265100] pnp 00:00: [mem 0x000d8000-0x000dbfff window]
[    0.265102] pnp 00:00: [mem 0x000dc000-0x000dffff window]
[    0.265103] pnp 00:00: [mem 0x000e0000-0x000e3fff window]
[    0.265105] pnp 00:00: [mem 0x000e4000-0x000e7fff window]
[    0.265106] pnp 00:00: [mem 0x000e8000-0x000ebfff window]
[    0.265107] pnp 00:00: [mem 0x000ec000-0x000effff window]
[    0.265109] pnp 00:00: [mem 0x000f0000-0x000fffff window]
[    0.265110] pnp 00:00: [mem 0xdfa00000-0xfeafffff window]
[    0.265112] pnp 00:00: [mem 0x00010000-0x0001ffff window]
[    0.265147] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[    0.265164] pnp 00:01: [mem 0xfed40000-0xfed44fff]
[    0.265186] system 00:01: [mem 0xfed40000-0xfed44fff] has been reserved
[    0.265188] system 00:01: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.265195] pnp 00:02: [io  0x0000-0x001f]
[    0.265197] pnp 00:02: [io  0x0081-0x0091]
[    0.265198] pnp 00:02: [io  0x0093-0x009f]
[    0.265199] pnp 00:02: [io  0x00c0-0x00df]
[    0.265201] pnp 00:02: [dma 4]
[    0.265213] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[    0.265218] pnp 00:03: [mem 0xff000000-0xffffffff]
[    0.265231] pnp 00:03: Plug and Play ACPI device, IDs INT0800 (active)
[    0.265280] pnp 00:04: [mem 0xfed00000-0xfed003ff]
[    0.265294] pnp 00:04: Plug and Play ACPI device, IDs PNP0103 (active)
[    0.265304] pnp 00:05: [io  0x002e-0x002f]
[    0.265306] pnp 00:05: [io  0x004e-0x004f]
[    0.265308] pnp 00:05: [io  0x0061]
[    0.265309] pnp 00:05: [io  0x0063]
[    0.265311] pnp 00:05: [io  0x0065]
[    0.265313] pnp 00:05: [io  0x0067]
[    0.265315] pnp 00:05: [io  0x0070]
[    0.265316] pnp 00:05: [io  0x0080]
[    0.265318] pnp 00:05: [io  0x0092]
[    0.265319] pnp 00:05: [io  0x00b2-0x00b3]
[    0.265320] pnp 00:05: [io  0x0680-0x069f]
[    0.265321] pnp 00:05: [io  0x0200-0x020f]
[    0.265323] pnp 00:05: [io  0xffff]
[    0.265324] pnp 00:05: [io  0xffff]
[    0.265325] pnp 00:05: [io  0x0400-0x0453]
[    0.265326] pnp 00:05: [io  0x0458-0x047f]
[    0.265327] pnp 00:05: [io  0x0500-0x057f]
[    0.265352] system 00:05: [io  0x0680-0x069f] has been reserved
[    0.265354] system 00:05: [io  0x0200-0x020f] has been reserved
[    0.265356] system 00:05: [io  0xffff] has been reserved
[    0.265357] system 00:05: [io  0xffff] has been reserved
[    0.265359] system 00:05: [io  0x0400-0x0453] has been reserved
[    0.265361] system 00:05: [io  0x0458-0x047f] has been reserved
[    0.265362] system 00:05: [io  0x0500-0x057f] has been reserved
[    0.265364] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.265370] pnp 00:06: [io  0x0070-0x0077]
[    0.265375] pnp 00:06: [irq 8]
[    0.265389] pnp 00:06: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.265408] pnp 00:07: [io  0x0454-0x0457]
[    0.265429] system 00:07: [io  0x0454-0x0457] has been reserved
[    0.265431] system 00:07: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.265511] pnp 00:08: [io  0x0000-0xffffffff disabled]
[    0.265512] pnp 00:08: [io  0x0a00-0x0a0f]
[    0.265514] pnp 00:08: [io  0x0a30-0x0a3f]
[    0.265515] pnp 00:08: [io  0x0a20-0x0a2f]
[    0.265537] system 00:08: [io  0x0a00-0x0a0f] has been reserved
[    0.265539] system 00:08: [io  0x0a30-0x0a3f] has been reserved
[    0.265540] system 00:08: [io  0x0a20-0x0a2f] has been reserved
[    0.265542] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.265776] pnp 00:09: [io  0x03f8-0x03ff]
[    0.265780] pnp 00:09: [irq 4]
[    0.265781] pnp 00:09: [dma 0 disabled]
[    0.265817] pnp 00:09: Plug and Play ACPI device, IDs PNP0501 (active)
[    0.266102] pnp 00:0a: [io  0x0378-0x037f]
[    0.266106] pnp 00:0a: [irq 7]
[    0.266107] pnp 00:0a: [dma 0 disabled]
[    0.266214] pnp 00:0a: Plug and Play ACPI device, IDs PNP0400 (active)
[    0.266230] pnp 00:0b: [io  0x0010-0x001f]
[    0.266231] pnp 00:0b: [io  0x0022-0x003f]
[    0.266232] pnp 00:0b: [io  0x0044-0x005f]
[    0.266233] pnp 00:0b: [io  0x0062-0x0063]
[    0.266235] pnp 00:0b: [io  0x0065-0x006f]
[    0.266236] pnp 00:0b: [io  0x0072-0x007f]
[    0.266237] pnp 00:0b: [io  0x0080]
[    0.266238] pnp 00:0b: [io  0x0084-0x0086]
[    0.266239] pnp 00:0b: [io  0x0088]
[    0.266241] pnp 00:0b: [io  0x008c-0x008e]
[    0.266242] pnp 00:0b: [io  0x0090-0x009f]
[    0.266243] pnp 00:0b: [io  0x00a2-0x00bf]
[    0.266244] pnp 00:0b: [io  0x00e0-0x00ef]
[    0.266245] pnp 00:0b: [io  0x04d0-0x04d1]
[    0.266270] system 00:0b: [io  0x04d0-0x04d1] has been reserved
[    0.266272] system 00:0b: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.266278] pnp 00:0c: [io  0x00f0-0x00ff]
[    0.266282] pnp 00:0c: [irq 13]
[    0.266297] pnp 00:0c: Plug and Play ACPI device, IDs PNP0c04 (active)
[    0.266480] pnp 00:0d: [mem 0xfed1c000-0xfed1ffff]
[    0.266481] pnp 00:0d: [mem 0xfed10000-0xfed17fff]
[    0.266483] pnp 00:0d: [mem 0xfed18000-0xfed18fff]
[    0.266484] pnp 00:0d: [mem 0xfed19000-0xfed19fff]
[    0.266485] pnp 00:0d: [mem 0xf8000000-0xfbffffff]
[    0.266487] pnp 00:0d: [mem 0xfed20000-0xfed3ffff]
[    0.266488] pnp 00:0d: [mem 0xfed90000-0xfed93fff]
[    0.266489] pnp 00:0d: [mem 0xfed45000-0xfed8ffff]
[    0.266491] pnp 00:0d: [mem 0xff000000-0xffffffff]
[    0.266492] pnp 00:0d: [mem 0xfee00000-0xfeefffff]
[    0.266493] pnp 00:0d: [mem 0xdfa00000-0xdfa00fff]
[    0.266531] system 00:0d: [mem 0xfed1c000-0xfed1ffff] has been reserved
[    0.266533] system 00:0d: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.266535] system 00:0d: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.266536] system 00:0d: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.266538] system 00:0d: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.266540] system 00:0d: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.266542] system 00:0d: [mem 0xfed90000-0xfed93fff] has been reserved
[    0.266543] system 00:0d: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.266545] system 00:0d: [mem 0xff000000-0xffffffff] has been reserved
[    0.266547] system 00:0d: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.266549] system 00:0d: [mem 0xdfa00000-0xdfa00fff] has been reserved
[    0.266551] system 00:0d: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.266661] pnp 00:0e: [mem 0x20000000-0x201fffff]
[    0.266662] pnp 00:0e: [mem 0x40004000-0x40004fff]
[    0.266700] system 00:0e: [mem 0x20000000-0x201fffff] has been reserved
[    0.266702] system 00:0e: [mem 0x40004000-0x40004fff] has been reserved
[    0.266704] system 00:0e: Plug and Play ACPI device, IDs PNP0c01 (active)
[    0.266720] pnp: PnP ACPI: found 15 devices
[    0.266721] ACPI: ACPI bus type pnp unregistered
[    0.266723] PnPBIOS: Disabled by ACPI PNP
[    0.302444] pci 0000:00:1c.0: PCI bridge to [bus 01-01]
[    0.302455] pci 0000:00:1c.4: PCI bridge to [bus 02-02]
[    0.302458] pci 0000:00:1c.4:   bridge window [io  0xe000-0xefff]
[    0.302464] pci 0000:00:1c.4:   bridge window [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.302470] pci 0000:00:1e.0: PCI bridge to [bus 03-03]
[    0.302498] pci 0000:00:1e.0: setting latency timer to 64
[    0.302501] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7]
[    0.302502] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff]
[    0.302504] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[    0.302505] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff]
[    0.302507] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff]
[    0.302508] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff]
[    0.302510] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff]
[    0.302511] pci_bus 0000:00: resource 11 [mem 0x000e0000-0x000e3fff]
[    0.302513] pci_bus 0000:00: resource 12 [mem 0x000e4000-0x000e7fff]
[    0.302514] pci_bus 0000:00: resource 13 [mem 0xdfa00000-0xfeafffff]
[    0.302516] pci_bus 0000:02: resource 0 [io  0xe000-0xefff]
[    0.302517] pci_bus 0000:02: resource 2 [mem 0xf0000000-0xf00fffff 64bit pref]
[    0.302519] pci_bus 0000:03: resource 4 [io  0x0000-0x0cf7]
[    0.302520] pci_bus 0000:03: resource 5 [io  0x0d00-0xffff]
[    0.302522] pci_bus 0000:03: resource 6 [mem 0x000a0000-0x000bffff]
[    0.302523] pci_bus 0000:03: resource 7 [mem 0x000d0000-0x000d3fff]
[    0.302525] pci_bus 0000:03: resource 8 [mem 0x000d4000-0x000d7fff]
[    0.302526] pci_bus 0000:03: resource 9 [mem 0x000d8000-0x000dbfff]
[    0.302528] pci_bus 0000:03: resource 10 [mem 0x000dc000-0x000dffff]
[    0.302529] pci_bus 0000:03: resource 11 [mem 0x000e0000-0x000e3fff]
[    0.302531] pci_bus 0000:03: resource 12 [mem 0x000e4000-0x000e7fff]
[    0.302532] pci_bus 0000:03: resource 13 [mem 0xdfa00000-0xfeafffff]
[    0.302590] NET: Registered protocol family 2
[    0.302626] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.302732] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.302865] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[    0.302925] TCP: Hash tables configured (established 131072 bind 65536)
[    0.302927] TCP: reno registered
[    0.302929] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.302932] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.302987] NET: Registered protocol family 1
[    0.302994] pci 0000:00:02.0: Boot video device
[    0.340620] PCI: CLS 64 bytes, default 64
[    0.340680] Unpacking initramfs...
[    0.531187] Freeing initrd memory: 14336k freed
[    0.532808] audit: initializing netlink socket (disabled)
[    0.532819] type=2000 audit(1495477038.428:1): initialized
[    0.541376] highmem bounce pool size: 64 pages
[    0.541379] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[    0.541535] VFS: Disk quotas dquot_6.5.2
[    0.541553] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.541599] msgmni has been set to 1688
[    0.541703] alg: No test for stdrng (krng)
[    0.541723] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.541726] io scheduler noop registered
[    0.541727] io scheduler deadline registered
[    0.541743] io scheduler cfq registered (default)
[    0.541868] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[    0.541879] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[    0.541880] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.542160] vesafb: mode is 1024x768x32, linelength=4096, pages=0
[    0.542162] vesafb: scrolling: redraw
[    0.542164] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    0.542420] vesafb: framebuffer at 0xe0000000, mapped to 0xf8080000, using 3072k, total 3072k
[    0.581441] Console: switching to colour frame buffer device 128x48
[    0.620385] fb0: VESA VGA frame buffer device
[    0.620423] GHES: HEST is not enabled!
[    0.620431] isapnp: Scanning for PnP cards...
[    0.929077] isapnp: No Plug & Play device found
[    0.929109] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    0.949424] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.969925] 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[    0.970094] Linux agpgart interface v0.103
[    0.970161] agpgart-intel 0000:00:00.0: Intel Ivybridge Chipset
[    0.970210] agpgart-intel 0000:00:00.0: detected gtt size: 2097152K total, 262144K mappable
[    0.970875] agpgart-intel 0000:00:00.0: detected 65536K stolen memory
[    0.970957] agpgart-intel 0000:00:00.0: AGP aperture is 256M @ 0xe0000000
[    0.971044] i8042: PNP: No PS/2 controller found. Probing ports directly.
[    0.971466] serio: i8042 KBD port at 0x60,0x64 irq 1
[    0.971475] serio: i8042 AUX port at 0x60,0x64 irq 12
[    0.971545] mousedev: PS/2 mouse device common for all mice
[    0.971589] rtc_cmos 00:06: RTC can wake from S4
[    0.971696] rtc_cmos 00:06: rtc core: registered rtc_cmos as rtc0
[    0.971720] rtc0: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    0.971803] TCP: cubic registered
[    0.971851] NET: Registered protocol family 10
[    0.971984] Mobile IPv6
[    0.971986] NET: Registered protocol family 17
[    0.971989] Registering the dns_resolver key type
[    0.972022] Using IPI No-Shortcut mode
[    0.972092] PM: Hibernation image not present or could not be loaded.
[    0.972100] registered taskstats version 1
[    0.972361] rtc_cmos 00:06: setting system clock to 2017-05-22 18:17:19 UTC (1495477039)
[    0.972435] Freeing unused kernel memory: 416k freed
[    0.972519] Write protecting the kernel text: 3500k
[    0.972534] Write protecting the kernel read-only data: 980k
[    0.982351] udevd[64]: starting version 175
[    0.994630] usbcore: registered new interface driver usbfs
[    0.994651] usbcore: registered new interface driver hub
[    0.996492] SCSI subsystem initialized
[    0.999134] usbcore: registered new device driver usb
[    0.999438] ACPI: Fan [FAN0] (off)
[    0.999482] ACPI: Fan [FAN1] (off)
[    0.999502] xhci_hcd 0000:00:14.0: setting latency timer to 64
[    0.999506] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.999516] ACPI: Fan [FAN2] (off)
[    0.999525] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    0.999546] ACPI: Fan [FAN3] (off)
[    0.999580] ACPI: Fan [FAN4] (off)
[    0.999610] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    0.999656] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    0.999658] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.999660] usb usb1: Product: xHCI Host Controller
[    0.999662] usb usb1: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[    0.999664] usb usb1: SerialNumber: 0000:00:14.0
[    0.999820] xHCI xhci_add_endpoint called for root hub
[    0.999822] xHCI xhci_check_bandwidth called for root hub
[    0.999850] hub 1-0:1.0: USB hub found
[    0.999857] hub 1-0:1.0: 4 ports detected
[    0.999921] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    0.999926] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    0.999944] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    0.999946] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    0.999948] usb usb2: Product: xHCI Host Controller
[    0.999950] usb usb2: Manufacturer: Linux 3.4-9-rtai-686-pae xhci_hcd
[    0.999952] usb usb2: SerialNumber: 0000:00:14.0
[    1.000251] xHCI xhci_add_endpoint called for root hub
[    1.000253] xHCI xhci_check_bandwidth called for root hub
[    1.000278] hub 2-0:1.0: USB hub found
[    1.000285] hub 2-0:1.0: 4 ports detected
[    1.003062] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.010190] r8169 Gigabit Ethernet driver 2.3LK-NAPI loaded
[    1.010449] r8169 0000:02:00.0: eth0: RTL8168evl/8111evl at 0xf8016000, 90:2b:34:d3:01:03, XID 0c900800 IRQ 16
[    1.010452] r8169 0000:02:00.0: eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    1.011310] libata version 3.00 loaded.
[    1.018715] ehci_hcd 0000:00:1a.0: setting latency timer to 64
[    1.018719] ehci_hcd 0000:00:1a.0: EHCI Host Controller
[    1.018730] ehci_hcd 0000:00:1a.0: new USB bus registered, assigned bus number 3
[    1.018754] ehci_hcd 0000:00:1a.0: debug port 2
[    1.022615] ehci_hcd 0000:00:1a.0: cache line size of 64 is not supported
[    1.022625] ehci_hcd 0000:00:1a.0: irq 16, io mem 0xf7c17000
[    1.034353] ehci_hcd 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[    1.034392] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    1.034395] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.034397] usb usb3: Product: EHCI Host Controller
[    1.034399] usb usb3: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[    1.034400] usb usb3: SerialNumber: 0000:00:1a.0
[    1.034498] hub 3-0:1.0: USB hub found
[    1.034503] hub 3-0:1.0: 2 ports detected
[    1.034600] ehci_hcd 0000:00:1d.0: setting latency timer to 64
[    1.034604] ehci_hcd 0000:00:1d.0: EHCI Host Controller
[    1.034612] ehci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 4
[    1.034636] ehci_hcd 0000:00:1d.0: debug port 2
[    1.038522] ehci_hcd 0000:00:1d.0: cache line size of 64 is not supported
[    1.038539] ehci_hcd 0000:00:1d.0: irq 23, io mem 0xf7c16000
[    1.050292] ehci_hcd 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[    1.050319] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002
[    1.050323] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.050326] usb usb4: Product: EHCI Host Controller
[    1.050328] usb usb4: Manufacturer: Linux 3.4-9-rtai-686-pae ehci_hcd
[    1.050331] usb usb4: SerialNumber: 0000:00:1d.0
[    1.050438] hub 4-0:1.0: USB hub found
[    1.050442] hub 4-0:1.0: 2 ports detected
[    1.050508] ata_piix 0000:00:1f.2: version 2.13
[    1.050534] ata_piix 0000:00:1f.2: MAP [ P0 P2 P1 P3 ]
[    1.205793] ata_piix 0000:00:1f.2: SCR access via SIDPR is available but doesn't work
[    1.205811] ata_piix 0000:00:1f.2: setting latency timer to 64
[    1.206081] scsi0 : ata_piix
[    1.206167] scsi1 : ata_piix
[    1.206318] ata1: SATA max UDMA/133 cmd 0xf110 ctl 0xf100 bmdma 0xf0d0 irq 19
[    1.206320] ata2: SATA max UDMA/133 cmd 0xf0f0 ctl 0xf0e0 bmdma 0xf0d8 irq 19
[    1.206338] ata_piix 0000:00:1f.5: MAP [ P0 -- P1 -- ]
[    1.345335] usb 3-1: new high-speed USB device number 2 using ehci_hcd
[    1.361293] ata_piix 0000:00:1f.5: SCR access via SIDPR is available but doesn't work
[    1.361312] ata_piix 0000:00:1f.5: setting latency timer to 64
[    1.361535] scsi2 : ata_piix
[    1.361586] scsi3 : ata_piix
[    1.361688] ata3: SATA max UDMA/133 cmd 0xf0b0 ctl 0xf0a0 bmdma 0xf070 irq 19
[    1.361689] ata4: SATA max UDMA/133 cmd 0xf090 ctl 0xf080 bmdma 0xf078 irq 19
[    1.382929] ata1.01: ATA-8: Hitachi HDP725050GLA360, GM4OA52A, max UDMA/133
[    1.382934] ata1.01: 976773168 sectors, multi 16: LBA48 NCQ (depth 0/32)
[    1.397573] ata1.01: configured for UDMA/133
[    1.397686] scsi 0:0:1:0: Direct-Access     ATA      Hitachi HDP72505 GM4O PQ: 0 ANSI: 5
[    1.477320] usb 3-1: New USB device found, idVendor=8087, idProduct=0024
[    1.477325] usb 3-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.477587] hub 3-1:1.0: USB hub found
[    1.477688] hub 3-1:1.0: 6 ports detected
[    1.532719] Refined TSC clocksource calibration: 3292.519 MHz.
[    1.532723] Switching to clocksource tsc
[    1.540319] sd 0:0:1:0: [sda] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[    1.540380] sd 0:0:1:0: [sda] Write Protect is off
[    1.540383] sd 0:0:1:0: [sda] Mode Sense: 00 3a 00 00
[    1.540403] sd 0:0:1:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    1.580370]  sda: sda1 sda2 < sda5 >
[    1.580631] sd 0:0:1:0: [sda] Attached SCSI disk
[    1.592530] usb 4-1: new high-speed USB device number 2 using ehci_hcd
[    1.724514] usb 4-1: New USB device found, idVendor=8087, idProduct=0024
[    1.724519] usb 4-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    1.724783] hub 4-1:1.0: USB hub found
[    1.724881] hub 4-1:1.0: 6 ports detected
[    1.796031] usb 3-1.1: new low-speed USB device number 3 using ehci_hcd
[    1.891972] usb 3-1.1: New USB device found, idVendor=093a, idProduct=2510
[    1.891977] usb 3-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    1.891981] usb 3-1.1: Product: USB Optical Mouse
[    1.891983] usb 3-1.1: Manufacturer: PixArt
[    1.895586] input: PixArt USB Optical Mouse as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.1/3-1.1:1.0/input/input0
[    1.895666] generic-usb 0003:093A:2510.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:00:1a.0-1.1/input0
[    1.895683] usbcore: registered new interface driver usbhid
[    1.895685] usbhid: USB HID core driver
[    1.946286] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[    1.963497] usb 3-1.4: new high-speed USB device number 4 using ehci_hcd
[    2.055685] usb 3-1.4: New USB device found, idVendor=1a40, idProduct=0101
[    2.055690] usb 3-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.055694] usb 3-1.4: Product: USB 2.0 Hub
[    2.055966] hub 3-1.4:1.0: USB hub found
[    2.056056] hub 3-1.4:1.0: 4 ports detected
[    2.127085] usb 3-1.5: new low-speed USB device number 5 using ehci_hcd
[    2.224633] usb 3-1.5: New USB device found, idVendor=046d, idProduct=c312
[    2.224638] usb 3-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.224642] usb 3-1.5: Product: USB Multimedia Keyboard
[    2.224644] usb 3-1.5: Manufacturer: BTC
[    2.227637] input: BTC USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.5/3-1.5:1.0/input/input1
[    2.227673] generic-usb 0003:046D:C312.0002: input,hidraw1: USB HID v1.10 Keyboard [BTC USB Multimedia Keyboard] on usb-0000:00:1a.0-1.5/input0
[    2.234281] input: BTC USB Multimedia Keyboard as /devices/pci0000:00/0000:00:1a.0/usb3/3-1/3-1.5/3-1.5:1.1/input/input2
[    2.234356] generic-usb 0003:046D:C312.0003: input,hiddev0,hidraw2: USB HID v1.10 Device [BTC USB Multimedia Keyboard] on usb-0000:00:1a.0-1.5/input1
[    2.326306] usb 3-1.4.1: new full-speed USB device number 6 using ehci_hcd
[    2.419000] usb 3-1.4.1: New USB device found, idVendor=c1a5, idProduct=0501
[    2.419005] usb 3-1.4.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.419008] usb 3-1.4.1: Product: AvPass
[    2.419011] usb 3-1.4.1: Manufacturer: AVEST
[    2.419013] usb 3-1.4.1: SerialNumber: AVP3060099435
[    2.420581] generic-usb 0003:C1A5:0501.0004: hiddev0,hidraw3: USB HID v1.10 Device [AVEST AvPass] on usb-0000:00:1a.0-1.4.1/input0
[    2.489778] usb 3-1.4.3: new low-speed USB device number 7 using ehci_hcd
[    2.586086] usb 3-1.4.3: New USB device found, idVendor=04b9, idProduct=1000
[    2.586091] usb 3-1.4.3: New USB device strings: Mfr=2, Product=1, SerialNumber=0
[    2.586094] usb 3-1.4.3: Product: iKey 1000
[    2.586097] usb 3-1.4.3: Manufacturer: Rainbow Technologies
[    3.327129] init: ureadahead main process (290) terminated with status 5
[    4.174269] Adding 8259580k swap on /dev/sda5.  Priority:-1 extents:1 across:8259580k
[    5.067551] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[    6.122146] udevd[483]: starting version 175
[    8.805555] lp: driver loaded but no devices found
[    9.771895] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input3
[    9.771901] ACPI: Power Button [PWRB]
[    9.771946] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input4
[    9.771950] ACPI: Power Button [PWRF]
[    9.844836] parport_pc 00:0a: reported by Plug and Play ACPI
[    9.844886] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE]
[    9.852162] ppdev: user-space parallel port driver
[    9.868333] microcode: CPU0 sig=0x306a9, pf=0x2, revision=0x12
[    9.941501] lp0: using parport0 (interrupt-driven).
[   10.137738] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[   11.060923] microcode: CPU1 sig=0x306a9, pf=0x2, revision=0x12
[   11.062047] microcode: CPU2 sig=0x306a9, pf=0x2, revision=0x12
[   11.062993] microcode: CPU3 sig=0x306a9, pf=0x2, revision=0x12
[   11.064158] microcode: Microcode Update Driver: v2.00 <tigran@aivazian.fsnet.co.uk>, Peter Oruba
[   13.158221] [drm] Initialized drm 1.1.0 20060810
[   13.536524] Bluetooth: Core ver 2.16
[   13.536541] NET: Registered protocol family 31
[   13.536543] Bluetooth: HCI device and connection manager initialized
[   13.536546] Bluetooth: HCI socket layer initialized
[   13.536548] Bluetooth: L2CAP socket layer initialized
[   13.536554] Bluetooth: SCO socket layer initialized
[   13.543992] i915 0000:00:02.0: setting latency timer to 64
[   13.555072] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[   13.555074] [drm] MTRR allocation failed.  Graphics performance may suffer.
[   13.555232] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[   13.555235] [drm] Driver supports precise vblank timestamp query.
[   13.555762] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[   13.590193] Bluetooth: RFCOMM TTY layer initialized
[   13.590198] Bluetooth: RFCOMM socket layer initialized
[   13.590200] Bluetooth: RFCOMM ver 1.11
[   13.718944] [drm] Enabling RC6 states: RC6 on, RC6p on, RC6pp off
[   13.765447] NET: Registered protocol family 4
[   13.841839] NET: Registered protocol family 5
[   14.016740] checking generic (e0000000 300000) vs hw (e0000000 10000000)
[   14.016743] fb: conflicting fb hw usage inteldrmfb vs VESA VGA - removing generic driver
[   14.016763] Console: switching to colour dummy device 80x25
[   14.016888] fbcon: inteldrmfb (fb0) is primary device
[   14.354205] Console: switching to colour frame buffer device 128x48
[   14.393290] fb0: inteldrmfb frame buffer device
[   14.393292] drm: registered panic notifier
[   14.399224] acpi device:4d: registered as cooling_device5
[   14.399427] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[   14.399464] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[   14.399482] [drm] Initialized i915 1.6.0 20080730 for 0000:00:02.0 on minor 0
[   14.435894] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   14.435897] Bluetooth: BNEP filters: protocol multicast
[   14.575741] input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input6
[   14.581102] input: HDA Intel PCH Line as /devices/pci0000:00/0000:00:1b.0/sound/card0/input7
[   14.581155] input: HDA Intel PCH Front Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input8
[   14.581204] input: HDA Intel PCH Rear Mic as /devices/pci0000:00/0000:00:1b.0/sound/card0/input9
[   14.581246] input: HDA Intel PCH Front Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input10
[   14.581291] input: HDA Intel PCH Line Out as /devices/pci0000:00/0000:00:1b.0/sound/card0/input11
[   16.642292] init: failsafe main process (848) killed by TERM signal
[   24.538865] r8169 0000:02:00.0: eth0: link down
[   24.538911] r8169 0000:02:00.0: eth0: link down
[   24.538949] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   26.072947] init: plymouth-stop pre-start process (1309) terminated with status 1
[   26.100399] r8169 0000:02:00.0: eth0: link up
[   26.100451] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   32.611451] fuse init (API version 7.18)
[   36.590711] eth0: no IPv6 routers present
[  766.617469] I-pipe: head domain RTAI registered.
[  766.617474] RTAI[hal]: compiled with gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) .
[  766.617516] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[  766.617518] SYSINFO: CPUs 4, LINUX APIC IRQ 2312, TIM_FREQ 6235350, CLK_FREQ 3292752000, CPU_FREQ 3292752000
[  766.617520] RTAI_APIC_TIMER_IPI: RTAI DEFINED 2314, VECTOR 2314; LINUX_APIC_TIMER_IPI: RTAI DEFINED 2312, VECTOR 2312
[  766.617522] TIMER NAME: lapic; VARIOUSLY FOUND APIC FREQs: 6235350, 6235350, 3319250
[  766.648809] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[  766.648833] , <uses LINUX SYSCALLs>, kstacks pool size = 524288 bytes.
[  766.648837] RTAI[sched]: hard timer type/freq = APIC/6235350(Hz); default timing: oneshot; linear timed lists.
[  766.648840] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 3292752000 hz.
[  766.648842] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[  766.662646] RTAI[math]: loaded.
[  779.329308] RTAI[math]: unloaded.
[  779.330484] SCHED releases registered named ALIEN PEDV$D
[  779.339478] RTAI[malloc]: unloaded.
[  779.437276] RTAI[sched]: unloaded (forced hard/soft/hard transitions: traps 0, syscalls 0).
[  779.438814] I-pipe: head domain RTAI unregistered.
[  779.438865] RTAI[hal]: unmounted.
Более того, после установки так и не нашел установленные wizard'ы...
Nikomas
Сообщение nkp » 22 май 2017, 21:45
а если не gmoccapy запускать,а что нибудь "попроще" ?
например - linuxcnc/configs/sim/axis/axis_mm.ini
Медальки:
Сообщение merkwurdigliebe » 22 май 2017, 23:06
это не gmoccapy, это OpenGL не работает
ругается mesa (которая http://www.mesa3d.org), хочет ядро 3.6 или новее для поддежки вашей интеловской встроенной графики. попробуйте запустить какую-нить OpenGL программку (glxgears, glxinfo и т.п.) - скажет то же самое. как лечить - не знаю...
merkwurdigliebe
Сообщение Nikomas » 23 май 2017, 08:01
merkwurdigliebe писал(а):как лечить - не знаю...
Ставить Debian. Там все работало. Но нет звука со встроенной карты.
Nikomas
Сообщение nkp » 23 май 2017, 08:42
Nikomas писал(а):Ставить Debian. Там все работало.
Debian хороший вариант,потому что "из коробки")
но у меня все работает и под 12.04
(и не только у меня)
не зря же инструкция есть
Медальки:
Сообщение MIX » 23 май 2017, 13:43
а может подойти к вопросу последовательно и решить "хотелки" GMOCCAPY?
Она же пишет, что ей не хватает данныы переменных в файле "gmoccapy_4_axis.pref" и файле INI.
Nikomas писал(а):**** GMOCCAPY GETINIINFO ****
Создайте переменные
dro_size и hide_axis_4 в секции 'DEFAULT' файла gmoccapy_4_axis.pref и присвойте им значение.
А также переменные
DEFAULT_SPINDLE_SPEED в секции DISPLAY
spindle_start_rpm, hide_turtle_jog_button, turtle_jog_factor, scale_max_vel, scale_max_vel, scale_jog_vel, scale_spindle_override, scale_feed_override в секции 'DEFAULT' файла INI.
Именно после того, как система не находит эти переменные (а может файлы?) система пишет "Shutting down and cleaning up LinuxCNC..."
Последующая ругань может быть следствием аварийного завершения LINUXCNC. И выгрузки соответствующих модулей. В том числе OPENGL и MESA
MIX
Сообщение MIX » 23 май 2017, 13:52
В сообщении Loituma немного другая ситуация.
Не определены какие то параметры для месы. Если правильно понимаю - секции в конфигах. Подробнее надо смотреть в справке.
Loituma писал(а):Can not find -sec MOT -var MOT -num 1
MIX
Вернуться в LinuxCNC
Кто сейчас на конференции
Зарегистрированные пользователи: Adskiydart, aftaev, Alex lamaka, Bender, Bing [Bot], enderukov, Evgen91, Google [Bot], guges, Kiriller, Lafayette, NikolayUa24, niksooon, NKS, Nonstopich, not4u, odekolon, Remton, shalek, sima8520, STNRO, suleyman, UAVpilot, vit_rus, vugar27, Yandex [bot], Zur
Поделиться
Reputation System ©'
